17 - instruments
Steph
Angers, France
C?ID=437794
On my Golf IV, I'm trying to change the fuel consumption reading in VCDS section 17 - Instruments.
Unfortunately, channel 03, which should allow this adjustment, is not editable.
Do you have a solution?
Thank you.
Steph
Angers, France
C?ID=437794
Here is my VCDS scan :
          76
VIN: WVWZZZ1JZ3W580464   Mileage: 259170km-161040miles
Address 01: Engine        Labels: 036-906-034-AZD.clb
   Part No: 036 906 034 DR
   Component:  MARELLI 4MV G      5957
   Coding: 00031
   VCID: 6597BB049C7D03925C5-4B5C
   WVWZZZ1JZ3W580464     VWZ7Z0C7467297
17812 - EGR System
            P1404 - 35-00 - Basic Setting not Performed
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0020098
   Shop #: WSC 01266 785 00200
   VCID: 343116406227AA1A1BB-5184
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 01271
   VCID: 211FEF14C8D52FB2E0D-51A8
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0008
   Coding: 12855
   Shop #: WSC 01266
   VCID: 221DE018CDD334AAF97-5160
   Part No: 1J5 920 826 A
   Component: KOMBI+WEGFAHRSP VDO V20
   Coding: 05113
   Shop #: WSC 00046
   VCID: 2C010E20BF17F2DA43B-5160
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00046
   VCID: 70B9DA5053BFD63A3F3-5160
   Part No: 1C0 959 799 B
   Component: 1C Komfortger t HLO 0003
   Coding: 00259
   Shop #: WSC 01266
   VCID: 36352C48715BB80A25F-4B3C
   Component: 1C T rsteuer.FS KLO 0009
   Component: 1C T rsteuer.BF KLO 0009
   Component: 1C T rsteuer.HL KLO 0009
   Component: 1C T rsteuer.HR KLO 0009
End----(Elapsed Time: 04:54, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
-------------------------------1 Fault Found-------------------------------
Ignore the engine fault; this results from the physical removal of the EGR valve. I don't have a warning light on the dashboard, but this fault still appears during scans.
Regarding access to the adaptation of channel 03 in block 17 Instruments, activating code 13861 does not allow me to make the modification!
Thnak you.
Nope. Since you've already a Login with 13861, it appears that your cluster has that channel locked.
FWIW, we've seen some clusters of that vintage in which that channel doesn't exist at all.
Steph
Angers, France
C?ID=437794
Thank you for your reply. Is it impossible to unblock this channel using some kind of "sophisticated manipulation"?
You mean via some kind of back-door approach? Maybe, but I'm not sure, because we don't get involved in such things.
Steph
Angers, France
C?ID=437794
I understand, thank you for your help.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
It's rare that these channels aren't available but as Uwe already wrote, it's not unheard of. There are different instrument cluster firmware versions and configurations out there and channels can be enabled/disabled in the actual firmware. If that is the case (as it seems here), there is no way to enable them after the fact.
Long story short, you need to live with the situation as it is.
Steph
Angers, France
C?ID=437794
Ok, thank you.
