Resolved 2014 Touareg EPB error after changing rotors, pads and wear sensor
Resolved
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
After installing front and rear rotors, front and rear pads and new brake pad wear sensors.
Dash warning is saying check brake pads, as well as park brake error. It beeps and does not stop.
I did adjust the park brake gaps and it would not calibrate.
As I found suggested here, I did the grind in as done in the video.
Then I was able to do the calibration, but the errors and beeping are still there.
I am going to look at a couple of things while I wait for a response here. (wiring damage during repairs? pull off rotors to check park brake "parts" for any signs of bad things)
Scan before doing repairs. and Scan after replacing the brakes
Saturday,18,April,2026,14:27:10:63819
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
VIN: WVGDP9BP6ED006814   License Plate: JG165B
Mileage: 167911km-104335mi   Repair Order: apr18 pre rear brake repairs
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 65 69 6C 6D 72
VIN: WVGDP9BP6ED006814   Mileage: 167911km-104335miles
36-Seat Mem. Drvr -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    X21 0011
   Revision: 56X21---    CVN: 490DA9B538D3FF8238D3FF820E1FC39E
   Coding: 292A4012233600050000
   Shop #: WSC 23116 035 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
   ROD: EV_ECM30TDI0117P0907401K.rod
   VCID: 372B2F124FC210023E9-8062
   VINID: 9E65D48094A0195500006201106E644EF3
Readiness: 0 0 0 1 X
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 CF    HW: 0C8 927 750 CF
   Component: AL1000 AISIN  002 3376
   Serial number:                CVN: C24DF369
   Coding: 00B168
   Shop #: WSC 99999 999 83333
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 72BDDE066420B52AC97-8026
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 424930010EC010 Dataset Number: 7P0012v____ 0001
   Coding: 5B7613C349242559DAFCC89492D6A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD66E62C309DEA517-801E
   Part No SW: 4H0 907 064 DK    HW: 4H0 907 064 DK
   Component: BCM2 2.0      H35 0510
   Coding: 0D860016000000000000
   VCID: 75B7E51A15CEA212EC5-8020
   Subsystem 1 - Part No SW: 7P6 959 754 AR    HW: 7P6 959 754 AR
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 0813000122602012
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0213000331264008
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B686000A80
   VCID: 055795DA45AEB292FC5-8050
0278 - Coolant Shut-Off Valve
          B10C8 13 [00001001] - Open Circuit
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:52
0320 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:52
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001653195
   Coding: 26001012D73C5D010020180780005D0C431C660882010261800000020000
   VCID: 6C81C07E468463DA03B-8038
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    131029  033 0021
   Serial number: 90243400131030190322
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20211093
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000811130103
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R6Y9N02
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106971000004943053
   Coding: 010300
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28231330803885
   Coding: 318501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43D34BC20B1A4CA2921-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag02B H06 0026
   Revision: --------    Serial number: 003L5003BHJ- Dataset Number: 7P6003v____ 1073
   Coding: 000000000000000000000000000000003242
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 42DD4EC6140045AA997-8016
   Seat occupant detection:
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R136250EHU9
   Serial number: 3575LRB405923HNE91HB
   Serial number: 3585LRB405723HNEA0A3
   Serial number: 3515RRB401C50OC8H9VU
   Serial number: 3525RRB401C50OC84H61
   Serial number: 3555NRB400E50OV0AHU%
   Serial number: 3565NRB400E50OV0AHJW
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 99999MK8000SP
   Coding: 000C35
   VCID: 38292C2E425C1F7A373-806C
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0019637 TRW 20131023
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658081113592065
   Coding: 0B3733012B000008020004
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 47CB5FD23F2260824E9-8012
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001156659 Dataset Number: 7P6067v____ 0032
   Coding: 000103AD00
   GVL: FB4F40455D7F000000
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3FDB473267F22842F69-806A
   Control module for battery monitoring:
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 30306K25525701340828
5274 - Seat/Mirror Postion Control Module - Driver
          U0208 00 [00001001] - No Communications
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:51
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.7 V
                    Control Module temperature: 28 °C
                    System status: Terminal 15 on
                    Engine is running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 36: Seat Mem. Drvr
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000081968617
   Coding: 011D17205E00453005080000
   VCID: 7AADF6263CD0CD6A817-802E
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:50
   Revision: 00002001    Serial number: 0317209739
   Coding: 01861E3A68B9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 297136517
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO25136393
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO2522590%
   Coding: 191100
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811002736707
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000081731168
   VCID: 48C95CEE32BC6FFA473-801C
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:50
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C13B0801320    Dataset Number:             A001
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 3635221648C8E90A25F-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0009
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA1F03E3664F35A93B-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Revision: AB001007    Serial number: 156KA0D7932389
   Coding: 020007010000000001
   VCID: 2411E85EEED46B9A8BB-8070
   Part No SW: 7P6 035 664 E    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0783
   Revision: --------    Serial number: 273K90D7506985
   Coding: 020200050040E1EF41022B0E00000003F00001030000000000
   VCID: 3A2D36267C500D6AC17-806E
   Subsystem 1 - Part No: 7P6 060 884 F
   Component: NAR 2016/2017  1402
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9NA30029N
   Subsystem 3 - Part No: 8R0 060 961 F
   Component: CD-Database  5571
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:54
                    Text: DUA001,Front,M,0,0,6
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:54
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:55
                    Voltage: 11.50 V
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000081405898
   Coding: 011817200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000116581 Dataset Number: 7P6096v____ 0019
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revision: 5A001001    Serial number: 00000194715399
   Coding: 020D000000000000
   VCID: 3B233322736A3462DA1-806E
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8J3X1247
   Coding: 0130001
   VCID: 372B2F12434210023E9-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 293300169 Dataset Number: 7P6959107C  D045
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000081404610
End----(Elapsed Time: 02:10, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
------------------------------9 Faults Found-------------------------------
Scan after installing front and rear rotors, front and rear pads and new brake pad wear sensors.
Sunday,19,April,2026,21:05:08:63819
Mileage: 167911km-104335mi   Repair Order: full scan after successful park brake calibration
          62 65 69 6C 6D 72
   Coding: 00B168
72972 - Front Right Wheel Speed Sensor
          C101B 01 [00001000] - Electrical Failure
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 12:29:51
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 00 00 30
72460 - Front Left Wheel Speed Sensor
          C101A 01 [00001000] - Electrical Failure
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 12:29:51
                    Standard Freeze  Frame Dynamic: 00 3B 00 00 00 00 00 07 00 00 00 00 20
                    Fault Status: 00101101
                    Reset counter: 55
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 10:58:46
   Coding: B686000A80
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:52
0325 - Control Module for Auxiliary Heater
          B10C0 16 [00001000] - Voltage Too Low
                    Reset counter: 55
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 19:14:45
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:52
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
                    Fault Frequency: 8
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 19:14:46
0386 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
                    Reset counter: 55
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 18:55:16
   Coding: 004DBD
   Coding: 025223
   Coding: 010300
01853 - Heated Seat; Left Front (Z45)
                    Fault Status: 01101100
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 19:14:00
                    Reset counter: 55
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 10:58:00
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:00
   Coding: 318501
   Coding: 000C35
   Coding: 000103AD00
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:51
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [00001000] - -
          [Powermanagement active]
                    Fault Frequency: 8
                    Reset counter: 55
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 18:55:17
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 11.3 V
                    IN ZAS_Te_X: On
                    Datenfeld: 1
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:50
   Coding: 191100
   Coding: 191100
                    Reset counter: 55
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 10:58:46
                    Fault Status: 00101011
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 10:53:56
                    Voltage: 11.90 V
                    Temperature: 10.0°C
                    Temperature: 12.0°C
                    Bin. Bits: 00000100
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:50
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 1:
   Slave 3:
0040 - Motor for Electronic Parking Brake
          C10E3 29 [00001000] - Signal Implausible
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 20:53:31
                    Voltage: 13.8 V
0025 - No Calibration
          B2010 F0 [00001000] - Deviation from Expected Range
          [Steuergerät EPB - Kalibrierung fehlgeschlagen]
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 20:55:08
                    Voltage: 14.0 V
0024 - No Basic Setting
          B2010 00 [00001001] - -
          [Steuergerät EPB - System nicht kalibriert]
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 20:54:24
                    Voltage: 14.0 V
   Coding: 130000
   Coding: 130000
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:54
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.19
                    Time: 20:32:25
                    Reset counter: 15
                    Mileage: 167911 km
                    Date: 2026.04.18
                    Time: 14:15:55
                    Voltage: 11.50 V
   Coding: 0130001
   Coding: 0533314003
End----------(Elapsed Time: 02:20, VBatt start/end: 12.5V/12.4V)-----------
------------------------------23 Faults Found------------------------------
What are the air gap values?
Jef
HQ
OK, what you are running into is "normal". The EPB system is more sensitive than a rich kid who went full emo.
When you try the EPB Basic Settings "IDE04509 Air gap calibration", do the hear the parking brakes operate? If so, hopefully it will update what the data for the actual airgap. If no, you may need to tweak the EPB coding, see this post and then see if your airgap data updates.
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
Sunday,19,April,2026,20:50:50:63819
Mileage: 167911 Repair Order: after successful calibration
Address 53: Parking Brake (7P0 907 801 F)
20:49:55
IDE04435-MAS01849 Air gap-Left 2.094 mm
IDE04435-MAS01850 Air gap-Right 1.948 mm
IDE05272-MAS01849 Air gap before calibration-Left 2.094 mm
IDE05272-MAS01850 Air gap before calibration-Right 1.948 mm
Ziddywerks
Northern NJ USA
C?ID=208579
This is normal if you have the sensors disconnected and turn ignition on. Test drive the vehicle for more than 7 miles. Warning will go away.
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
I decided to try this as I needed to bed in the pads to the new rotors anyway.Unfortunately this didn’t work.
On to the next idea
Jef
HQ
At face value, those are good. If you adjust the right side 1 click towards the front of the vehicle, that put the right side at 2.098 and that change should show up after doing the Basic Setting IDE04509 Air gap calibration.
In the scan you submitted, no DTCs in 03 or 53. By chance, what data do you see in 09-08-028?
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
to add to my original post.
Air gap values still within spec
Jef, I can hear the parking brake operate. Although with further investigation and listening, I heard a clanking noise. I have identified it coming from the left (driver) when engaging the caliper using VCDS “open caliper” and “close caliper” functions.
Now the air gap calibration is only reading “Not Running” when I try to calibrate it.
Monday,20,April,2026,14:28:07:63819
VCDS Version: Release 26.3.0 (x64) Running on Windows 10 x64
Address 53: Parking Brake Labels: 7P0-907-801.CLB
Control Module Part Number: 7P0 907 801 F HW: 7P0 907 801 F
Component and/or Version: EPB H51 1201
Software Coding: 01040200
Work Shop Code: WSC 31414 790 00001
ASAM Dataset: EV_ParkbA7 000006 (VW52)
ROD: EV_ParkbA7.rod
Reset counter: 16
Mileage: 167926 km
Date: 2026.04.20
Time: 11:49:59
Voltage: 14.0 V
Reset counter: 15
Mileage: 167911 km
Date: 2026.04.20
Time: 11:23:17
Voltage: 14.0 V
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
Monday,20,April,2026,14:35:03:63819
Mileage: 167926km Repair Order: 09-08-028 data
Address 09: Cent. Elect. (4H0 907 063 CD)
14:34:07 Group 028: Sensor inputs
Full Coolant Level (G32) sensor
Not Oper. Oil pressure switch
Active Brake pad wear detection
Inactive Brake fluid level (F34)
the vehicle is on one jack stand at the moment as i was adjusting the right air gap.
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
and the air gaps went wack again. I readjusted but cannot calibrate. Car not running (12.2V)
15:18:38
IDE05272-MAS01849 Air gap before calibration-Left 2.130 mm
IDE05272-MAS01850 Air gap before calibration-Right 2.159 mm
MAS01634 Supply voltage 12.2 V
and with the vehicle running and I cycled the parking brake a few times, now the gaps are the same
15:31:26
IDE05272-MAS01849 Air gap before calibration-Left 2.127 mm
IDE05272-MAS01850 Air gap before calibration-Right 2.127 mm
MAS00711 kilometer reading 167926 km
MAS01634 Supply voltage 13.8 V
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
How do I get "Security Access" for doing the ceramic coding?
I have had this system make me reach for the proverbial gallon of petrol and match, I do them with ODIS now. One of the problem I face is finding somewhere to do the grind (the local dogging spots are always too busy), so we use the local park and ride later in the day when it gets less busy.
I'm not clear on where the OP is at, or what the current issues are.
Am I the only one missing this clarity? :confused:
I will have clarity by approx 6:45pm
Absolutely... :thumbs: but actually American, distilled in Kentucky.
Jef
HQ
When you go into Security Access, there will be a pop up window that gives you the number to enable coding... 21673.
That kind of implies to me that it thinks the brake pads are worn. The brake pad sensors are just a loop of wire.
J519 T32c/9 >> left front >> right front >> right rear >> left rear >> ground
Each "sensor" has a 2 pin connector, /1 goes back to J519 and /2 goes to ground. Does the J519 T32c/9 have a good solid path to ground or do you need to double check your connections?
silverbulletwagon
Surrey, BC, Canada
C?ID=419231
I was able to get the air gaps sorted, I just cannot get the calibration to work. I will do the grind in again (after I go do some errands in my sons car) and report back.
The parking brake warning and beeping is still happening as of posting this at 10:31am PST
Jef
HQ
In your first Auto-Scan, there are no DTCs in ABS or EPB. Are there fault codes in them now?
When you say "I just cannot get the calibration to work.", please provide more context there... what issue are you trying to fix and how are you going about doing it?
What kind of error messages are you getting?
