2018 Audi Q5 2.0TDI EGT sensor......Or is it...?!
NotBigPharma
Midlands, UK
C?ID=438020
Hi all.
2018 Audi Q5 2.0 TDI came to me with MIL illuminated. Initially interrogated with generic scan tool to reveal P0242A and P0242b.
EGT sensor bank 1, sensor 3.
Sensor identified by unplugging to confirm and replaced with genuine. Codes cleared and all appeared well.
Seemingly from a cold start the issue has recurred.
Interrogated using VCDS as below. Any suggestions welcome!
Thanks.
Sunday,19,April,2026,18:09:54:31041
VCDS Version: http://26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 026 CE    HW: 04L 907 309 L
  Component and/or Version: R4 2.0l TDI   H35 6648
           Software Coding: 2A654032252605083408
            Work Shop Code: WSC 64862 004 1048576
              ASAM Dataset: EV_ECM20TDI01104L906026CE 005007 (AU49)
                       ROD: EV_ECM20TDI01104L906026CE_005.rod
                      VCID: 6FBBD928471A9862269-803A
8189 - Exhaust Gas Temperature Sensor; B1 S3
          P242B 00 [01100000] - Range/Performance
9829 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [00100000] - Malfunction
                    Mileage: 119038 km
                    Date: 2026.04.12
                    Time: 10:40:03
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 61 °C
                    Voltage terminal 30: 12.540 V
                    Unlearning counter according OBD: 35
                    Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value: 201.8 °C
                    Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 205.4 °C
                    Particulate filter input: temp. sensor 1: bank 1: raw value: 1000.0 °C
                    Particulate filter output: temp. sensor 1: bank 1: raw value: 215.7 °C
                    EGR temp. sensor 2: B1: raw value: 2222.0 °C
                    Shut-off timer: last engine shut-off time: 44 s
5257 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [10101100] - Malfunction
                    Mileage: 118944 km
                    Date: 2026.04.11
                    Time: 13:01:42
                    Engine speed: 2496.00 /min
                    Normed load value: 37.3 %
                    Vehicle speed: 86 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 123 °C
                    Voltage terminal 30: 12.880 V
                    Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value: 634.9 °C
                    Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 452.0 °C
                    Particulate filter output: temp. sensor 1: bank 1: raw value: 261.8 °C
                    Shut-off timer: last engine shut-off time: 502 s
Readiness: 1 1 0 0 0
Sunday,19,April,2026,18:15:43:31041
VIN: WAUZZZFY8J2163660   License Plate: JP55GUY
Mileage: 119604km-74318mi   Repair Order:
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 22 29 2B 39 42 44 46 52 5F 6D 81
          A5 AC BB BC D6 D7
VIN: WAUZZZFY8J2163660   Mileage: 119604km-74318miles
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 CE    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H35 6648
   Revision: B1H35---    CVN: FACB31A8D33A0CA3B866C2AD
   Shop #: WSC 64862 004 1048576
   VINID: 9D196AAAA5A921A08118318600DFFDA82A
                    Mileage: 119038 km
                    Date: 2026.04.12
                    Time: 10:40:03
                    Mileage: 118944 km
                    Date: 2026.04.11
                    Time: 13:01:42
   Part No SW: 80A 927 155 BA    HW: 0CJ 927 156
   Component: 0CJ 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000001001 CVN: BF920B2E
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 698FB73079FE765278D-803C
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180030000319
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 80A 907 379 B    HW: 80A 907 379
   Component: ESP9 Plus     H11 0766
   Dataset Number: 80B909504S  0002 CVN: C2A13B20
   Coding: 48AA48BE28A80A9991A45897207D5292E4A5D212121450891A044A4927A54B
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 2E05042C8090D16A6DF-807A
   Part No SW: 80A 820 043 K    HW: 80A 820 043 K
   Component: Klima Zone 3  H60 0262
   Coding: 641800295544440D02000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2517FB00D56692329C5-8070
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002219385
   Humidity sensor: exterior:
   Serial number: D452501900PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 80B909517F  0029
   Coding: 07501143E11800CD054587149FAE80F9110B3108000000000000000020001A810A450122025601
   VCID: 025D809C6488850AD97-8056
   Subsystem 1 - Part No SW: 80C 955 119     HW: 80C 955 119
   Component: 426 RL 180212  040 0570
   Serial number: 00000001802112102395
   Coding: 5FC7F7
   Serial number: 21121624X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 29 03 2018  80880072
   Serial number: GX1CE117021823810261
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 G    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00033071
   Coding: 0D0104
   Subsystem 6 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000042747003
Address 15: Airbags (J234)       Labels:| 80A-959-655-V1.clb
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM045BMO Dataset Number: 80A909602G  0014
   Coding: AACCF0C00C800000585400FFF08C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   VCID: 3E25346C50F021EAFDF-806A
   Subsystem 1 - Part No SW: -----------    HW: 480 001 201 18
   Serial number: 35700000000EA1250B2H
   Subsystem 2 - Part No SW: -----------    HW: 480 001 201 18
   Serial number: 35800000000B2B50AA2O
   Subsystem 3 - Part No SW: -----------    HW: 480 031 401 18
   Serial number: 351001C082AD9D9009FO
   Subsystem 4 - Part No SW: -----------    HW: 480 031 401 18
   Serial number: 352001C08F2409903EAB
   Subsystem 5 - Part No SW: -----------    HW: 480 030 402 18
   Serial number: 355001C08C126241197-
   Subsystem 6 - Part No SW: -----------    HW: 480 030 402 18
   Serial number: 356001C08C12AD712BDL
   Subsystem 7 - Part No SW: -----------    HW: 480 031 102 18
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C08C4C35707F27
   Subsystem 8 - Part No SW: -----------    HW: 480 003 101 18
   Serial number: I0M000000000BC9069AB
   Subsystem 9 - Part No SW: -----------    HW: 480 003 101 18
   Serial number: I0N00000000DBC9069AP
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 401 18
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C7288861325CV
   Part No SW: 80A 907 129 BE    HW: 80A 907 129 BE
   Component: Lenks.Modul   H02 0003
   VCID: 6C81CE24760C637A03B-8038
   Part No SW: 80A 920 971 A    HW: 80A 920 971 A
   Component: MMQ5T18DIEUK  H04 0518
   Revision: 0518v2.0    Serial number: 0E2391055F3U
   Coding: 25A48ED4A88006000123E9601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 2615FC0CA860992A95F-8072
   Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
   Component: Gateway       H43 0123
   Revision: 7A000002    Serial number: 0287A852618220 Dataset Number: 80B909515F  0045
   Coding: 03010001000086404107000000590032483A0007100000000175078E10000000
   GVL: 01D03C0008040200408C08000000C80000080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   VCID: 4CC16EA4164C837A63B-8018
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0004
   Serial number: 20180314145635 00758
   Serial number: 7499035700
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 80A 927 755     HW: 0CJ 927 749 A
   Component: Q5_DL3_N_SD2H01 0012
   Serial number: 18016B0837
   Coding: 01070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 B    HW: 80A 907 397 B
   Component: LCM_MLBevo    H06 0017
   Dataset Number: 80B909519C  0009
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000022240005
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 323D105C94A8F58A097-8066
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 80B909520C  0009
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1RCO00H9E Dataset Number: 80B909872C  0027
   Coding: 001F8A014001040000001002
   ROD: EV_DCU2DriveSideMAXHKLO_AU49.rod
   VCID: 084992B442B4AF5A873-805C
Address 44: Steering Assist (J500)       Labels:* 4N0-909-144-V1.clb
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000470847 Dataset Number: 80B909852K  0001
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 343116446EBCFBBA1BB-8060
   Part No SW: 4N0 907 064 AM    HW: 4N0 907 064 M
   Component: BCM2 MLBevo H14 0128
   Dataset Number: 80B909501G  0032
   Coding: 013500002FB100406301A0000400980233020010804306502F00000000040030001F0001000000
   ASAM Dataset: EV_BCM2CONTIAU651 007005
   ROD: EV_BCM2CONTIAU651_007_AU49.rod
   VCID: 7AADF87C0C58CDCA817-802E
   ID - sensor:
   Serial number: 000000000ZY173332Z9P
   Serial number: 00000000000000141327
   Rear spoiler control module:
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1RB4006AX Dataset Number: 80B909873C  0032
   Coding: 001F8A014001040000001000
   ROD: EV_DCU2PasseSideMAXHKLO_AU49.rod
   VCID: 074B91884FAAA0228E9-8052
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 K    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  050 0235
   Serial number:                Dataset Number: 80B909545P  0023
   Coding: 01240601FF0A000053111101000A00102F0019E601F00100CE
   ROD: EV_MUHigScl6C3DELP.rod
   Subsystem 1 - Part No SW: 8W0 919 866 AB    HW: -----------
   Component: ECE 2018  --- 0032
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 80A 919 604     HW: 80A 919 604
   Component: AU426_DU_STD  H42 0008
   Serial number: AUZ8Z9JBM01MVP
   Subsystem 3 - Part No SW: 80A 919 614 A    HW: 80A 919 614 A
   Component: ControlUnit_B  H20 0200
   Serial number: AMXAM130011800010179
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: A2-C748-5750-5 Dataset Number: 80B909541C  0009
   Coding: 0710
   VCID: 48C952B402346F5A473-801C
   Part No SW: 80C 713 041 S    HW: 80C 713 041 S
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20180319003024
   ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H16 0050
   Dataset Number: 80B909466D  0023
   Coding: 0404020600000401024023A0A50000FE00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 2411E604DE5C6B3A8BB-8070
Address AC: Reductant Control (J880)       Labels: 80A-907-355.clb
   Part No SW: 80A 907 355 F    HW: 80A 907 355 D
   Component: SCR-Stg-G4H07 0004
   Dataset Number: 80B909571J  0001
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   VCID: 2C010E24B68CA37A43B-8078
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1RCD00NKJ Dataset Number: 80B909897C  0027
   Coding: 000F88000001040000001000
   ROD: EV_DCU2RearDriveMAXHKLO_VW41.rod
   VCID: 0A4DA8BC5CB8DD4A917-805E
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS001 0737
   Serial number: CLSM1RCD00NIH Dataset Number: 80B909896C  0027
   ROD: EV_DCU2RearPasseMAXHKLO_VW41.rod
   Dataset Number: 80B909471B  0004
   VCID: 176BC1C81F0A30A21E9-8042
   Dataset Number: 80B909472B  0004
End----(Elapsed Time: 02:02, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------3 Faults Found-------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
You clearly have 3 DTC's for EGT B1 S3
Then there are some wonky temp readings in the Freeze Frame data.
Locate the EGT's and unplug one at a time to identify them accurately. Once S3 is identified you can move forwards.
NotBigPharma
Midlands, UK
C?ID=438020
Thanks for the reply. That’s the current frustration. B1S3 was identified by unplugging and watching the value flick to 1000C open circuit. There look to be wonky numbers for B1S1 too in the freeze frame but no DTC.
