2020 A4 B9.5 MMI NOT LOGGING AS REGISTERED USER
drmonks1159
C?ID=641168
SOOOO IVE LEARNED A LOT ABOUT THE FUNDIMENTALS OF PLAYING WITH VCDS BY MESSING UP BEFORE HAVING THE ADAPTION LOGS..... I WAS TRING TO ENABLE SOME FEATURES AND NOW I CANT LOG IN AS KEY USER. EVERY NOW IN THEN IT WILL LOG IN TO IT AUTOMATICALLY BUT NEVER ON START UP. I HAD PLAYED WITH THE 5GHTZ WIFI AND STUFF LIKE THAT..... IF ANYONE IS WILLING TO SHARE SOME KNOWLAGE AND OR LOOK AT MY LOGS TO TELL ME WHERE I WENT WRONG I WILL NOT BE OFFENDED AND WILL BE EXTREAMLY APPRECITIATVE. BELOW ARE SOME OF MY LOGS AND I CAN ADD MORE IF NEED
Saturday,18,April,2026,17:56:32:01662
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: WAUENAF49LN004351   License Plate:
Chassis Type: F4-AU49 (8W0)
Scan: 01 02 03 08 09 15 16 17 19 36 3C 42 44 46 52 5F 6C 75 81 A5
          BB BC CA CF D6 D7 DE
VIN: WAUENAF49LN004351   Mileage: 83831km-52090miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels: Redir Fail!
   Part No SW: 8W0 906 259 AC    HW: 06L 907 425 C
   Component: R4 2.0l TFSI  H15 0002
   Revision: --H15---    CVN: 723D6D8C
   Coding: 0A2500322326010E34200000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0208W0906259AC 001002
   ROD: EV_ECM20TFS0208W0906259AC.rod
   VCID: 025A696A648F76FAD97-8056
   VINID: 9D195579158425C7800040C504709F52D0
Readiness: 1110 0101
   Part No SW: 8W2 927 155 FP    HW: 0HK 927 156 B
   Component: 0CL 20TFSINAR H01 0001
   Revision: --H01---    Serial number: 0000002413 CVN: 4828F348
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 14765F320EFBE84A7BB-8040
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190256002582
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 8W0 907 379 AB    HW: 8W0 907 379 J
   Component: ESP9 Plus     H16 0836
   Dataset Number: 8W0909504S  0008 CVN: 2E81EC87
   Coding: 18AA409928A20A9A11A14896007E5292E5359A180214508812004A49A7AC59
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 0550727675A141C2FC5-8050
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0251
   Coding: 140805095544000D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D6AF723E1BB8CAABB-8010
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000004229706
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H04 0010
   Serial number: 0710191599PAG0MUFU04
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W1 907 063 G    HW: 8W1 907 063 G
   Component: BCM1 MLBevo   H10 0690
   Dataset Number: 8W1909514A  0011
   Coding: 07000363E0691CCD0515870918AC98AB110B35080000009401000A0020001A01086901320257050000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 40DEA3622A03A4EA8F3-8014
   Subsystem 1 - Part No SW: 8W1 955 119 A    HW: 566 955 119
   Component: J400FRWISCH  051 0822
   Serial number: 887353F0401925304308
   Coding: 7DC727
   Serial number: 23673256X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AK    HW: 4M0 941 531 AK
   Component: E1 - LDS  H06 0008
   Serial number: 04 06 2019  02012257
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z004V02
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE103061924210424
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AH    HW: 4K0 947 135 AH
   Component: Dachmodul  H42 0415
   Serial number: C00372122
   Coding: 0D0104
Address 15: Airbags (J234)       Labels:| 8W0-959-655-V1.clb
   Part No SW: 8W0 959 655 M    HW: 8W0 959 655 M
   Component: Airbag10.44   H05 0109
   Serial number: 0030C001PTE+ Dataset Number: 8W0909602BA 0012
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 53F49C2ECB752F72221-8006
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 8W0857705M0277T00684
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 8W0857706P0277T00982
   Coding: 80000D
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000C6N7M0A
   Subsystem 4 - Part No SW: -----------    HW: 442 060 110 19
   Serial number: 3577Y009B3215A71509X
   Subsystem 5 - Part No SW: -----------    HW: 442 060 110 19
   Serial number: 3587Y009B3215A71139X
   Subsystem 6 - Part No SW: -----------    HW: 442 0B1 309 19
   Serial number: 3517700A533B2861C2AA
   Subsystem 7 - Part No SW: -----------    HW: 442 0B1 309 19
   Serial number: 3527700B733A356281B8
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 609 19
   Serial number: 3557500BD33D513232FD
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 701 20
   Serial number: 3567500B53507724D456
   Part No SW: 4N0 907 129     HW: 4N0 907 129
   VCID: 6E822DDA4017629A2DF-803A
Address 17: Instruments ()       Labels:* None-SRI2
   Part No SW: 8W5 920 790 J    HW: 8W5 920 790 J
   Component: FBenRDW------ H08 0063
   Coding: 83CF29C12A88D7050200E3601800080008000800
   Shop #: WSC 31117 006 104857
   ASAM Dataset: EV_DashBoardAU65X 002018
   ROD: EV_DashBoardAU65X_002_AU49.rod
   VCID: 49C8BE46193965A258D-801C
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 8W0 907 468 F    HW: 8W0 907 468
   Component: Gateway       H04 0613
   Serial number: 11F05089257901 Dataset Number: 8W0909515VM 0003
   Coding: 030100010000064029070000005900124C180007100000000100008E00000000
   GVL: 01513C000000000040DC08008002C800100C0000000000000000000000006500
   ASAM Dataset: EV_Gatew31xAU65x 003250
   ROD: EV_Gatew31xAU65x_AU49.rod
   VCID: 47CCB87E0F2D93D24E9-8012
   Subsystem 1 - Part No SW: 82A 951 523 F    HW: 82A 951 523 F
   Component: E221__MFL  H02 0003
   Serial number: 02S02000373090319281
   Serial number: 6417042505
   Part No SW: 4M6 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0060
   Serial number: 00000393506383 Dataset Number: 8W0909856D  0011
   Coding: 015C1A000000B0010003010101010000000000000000000000000000004000
   VCID: 7BA4148E036507329A1-802E
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 F    HW: 4M0 907 566
   Component: MRR1Rear      H22 0440
   Revision: --------    Dataset Number: 8W0909535D  0002
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 382ECB8272D3EC2A373-806C
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        010 0384
   Serial number: 0000392129418  Dataset Number: 8W0909872H  0034
   Coding: 005F8B205200108000010032
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 48CEBB4202339CAA473-801C
Address 44: Steering Assist (J500)       Labels:| 8W0-909-144-V1.clb
   Part No SW: 8W0 909 144 J    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0411
   Dataset Number: 8W0909852R  0043
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   Part No SW: 8W1 907 064 AC    HW: 8W1 907 064 C
   Component: BCM2 MLBevo   044 0530
   Dataset Number: 8W0909501M  0009
   Coding: 013421004FB00080650FA0002C01000203024000810026502F0400000B04803F001E0681001F11
   Shop #: WSC 32985 006 104857
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 7EA21D9A1077121ABDF-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY19270436X
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047555604
   Left taillight 1:
   Subsystem 3 - Part No SW: 8W5 945 423 A    HW: 8W5 945 423 A
   Component: T1 LH SAE  H09 0510
   Serial number: H9X00006GN8V000020BC
   Power rear lid opening control module:
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14077936
   Left taillight 2:
   Subsystem 5 - Part No SW: 8W5 945 429 A    HW: 8W5 945 429 A
   Component: T2 LH SAE  H09 0510
   Serial number: H9X00001GM8V000020BJ
   Right taillight 1:
   Subsystem 6 - Part No SW: 8W5 945 424 A    HW: 8W5 945 424 A
   Component: T1 RH SAE  H09 0510
   Serial number: H9X0000717AV000020BB
   Right taillight 2:
   Subsystem 7 - Part No SW: 8W5 945 430 A    HW: 8W5 945 430 A
   Component: T2 RH SAE  H09 0510
   Serial number: H9X00002Y28V000020BH
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       010 0384
   Serial number: 0000392075787  Dataset Number: 8W0909873H  0034
   Coding: 005F8B205E00108000010030
   ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
   Part No SW: 8W2 035 050 K    HW: 8W2 035 050
   Component: MU-TH-NS-US   041 3696
   Serial number: GRO-63309.10.19 Dataset Number: 8W1909545VJ 0003
   Coding: 14910010804020000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: 3928CE8649D9F522C8D-806C
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 8W2 919 620     HW: 8W2 919 620
   Component: DU Top AU49x   H41 0070
   Serial number: TPO00118091910110169
   Subsystem 2 - Part No: V03 959 807 AS
   Component: MIB3_NA_Q418   0266
   Compact disc data bank:
   Component: Gracenote2     3003
   Volume Control 1:
   Subsystem 4 - Part No SW: 8W1 919 616 D    HW: 8W1 919 616 D
   Component: LSR-B9PA       H20 0103
   Serial number: ALJAL208071900030167
   Media socket:
   Subsystem 5 - Part No: 8W0 035 708 A
009 0007
   Digital Sound System Control Module 2:
   Subsystem 6 - Part No SW: 8Y0 035 465     HW: 8Y0 035 465
   Component: B_A_3_P_0_AU   H10 0140
   Serial number: JTH-07620.09.1932170
   Component: RVC Compact   H18 0250
   Dataset Number: 8W0909460D  0012
   Coding: 0294010102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 3334FCAE6BB50F72021-8066
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4KE 035 283 F    HW: 4KE 035 283 B
   Component: CB_H_NAR      042 0372
   Serial number: A971E0P3030294 Dataset Number: 8W0909612VD 0004
   Coding: 01E0E0F8C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_AU49.rod
   VCID: 3FDCA09E57FDDB12F69-806A
   Part No SW: 8W1 713 041 N    HW: 8W1 713 041 K
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19092555438363
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 3E22DD9A50F7D21AFDF-806A
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 F    HW: 8W0 907 217 F
   Component: BVS           H21 0062
   Dataset Number: 8W0909466G  0046
   Coding: 0404090100000203022000A2A50000FC00F0C0200020
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       010 0384
   Serial number: 0000391383159  Dataset Number: 8W0909897H  0034
   Coding: 000F8B200000108040000020
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   VCID: 4ACA814A1C3F6EBA517-801E
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS      010 0384
   Serial number: 0000391383239  Dataset Number: 8W0909896H  0034
   ROD: EV_DCU2RearPasseMAXHCONT_VW41.rod
   Part No SW: 4K0 907 594 AB    HW: 4K0 907 594
   Dataset Number: 8W0909469E  0014
   Coding: 228000049100
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 74B63FB22E3B484ADBB-8020
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 F    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 3530C2B665C111422C5-8060
   Part No SW: 4K0 941 572 DD    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H06 0040
   Dataset Number: 8W0909471F  0012
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 73B43CAE2B354F72C21-8026
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   VCID: 201E03E2CA4384EAEF3-8074
End----------(Elapsed Time: 10:52, VBatt start/end: 12.7V/12.8V)-----------
---------------------------No fault code found.----------------------------
[/CODE 5F]
;SW:8W2-035-050-K   HW:8W2-035-050 ---  5F: Information Electr.
;Component:MU-TH-NS-US   041 3696, Coding:14910010804020000000000000000000000000000000000000
;EV_MUTI,001010,EV_MUTI_AU27.rod
;Saturday,18,April,2026,17:53:16:01662
;VCDS Version: 26.3.0.0 (x64)  Data version: 20260320 DS375.1
;VCID: 3928CE8649D9F522C8D-806C
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,automatic ,1
IDE00768-Country identification: country of sale,US ,2
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT00078-Installation list: specified installations-Display/operating unit rear right,No ,3
IDE01996-SFT00094-Installation list: specified installations-Display/operating unit rear left,No ,3
IDE01996-SFT00200-Installation list: specified installations-Auxiliary display/control head 2,No ,3
IDE01996-SFT00222-Installation list: specified installations-charging device 1 for mobile end device,Yes ,3
IDE01996-SFT00223-Installation list: specified installations-charging device 2 for mobile end device,No ,3
IDE01996-SFT00224-Installation list: specified installations-Auxiliary display/control head 1,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head,No ,3
IDE01996-ENG262683-Installation list: specified installations-Reserved_Bit_0,No ,3
IDE01996-ENG171864-Installation list: specified installations-reserved_Bit_1,No ,3
IDE01996-ENG262679-Installation list: specified installations-reserved_Bit_2,No ,3
IDE01996-ENG262684-Installation list: specified installations-Reserved_Bit_3,No ,3
IDE01996-ENG262685-Installation list: specified installations-Reserved_Bit_4,No ,3
IDE01996-ENG262686-Installation list: specified installations-Reserved_Bit_5,No ,3
IDE01996-ENG262687-Installation list: specified installations-Reserved_Bit_6,No ,3
IDE01996-ENG262688-Installation list: specified installations-Reserved_Bit_7,No ,3
IDE02125-MAS08233-Voice operation for telephone-other,not installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,126
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,18 ,126
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,22 ,126
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,0 ,126
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,22 ,126
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,0 ,126
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,22 ,126
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,0 ,126
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,22 ,126
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,0 ,126
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,100 ,126
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,0 ,126
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,100 ,126
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,0 ,126
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,22 ,126
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,0 ,126
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,22 ,126
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,0 ,126
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,22 ,126
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,0 ,126
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,22 ,126
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,0 ,126
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,22 ,126
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,1 ,126
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,9 ,126
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,0 ,126
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,22 ,126
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,0 ,126
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,22 ,126
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,0 ,126
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,22 ,126
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,0 ,126
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,22 ,126
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,0 ,126
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,22 ,126
IDE02476-ENG260193-Electrical test of speakers-channel_25_lower_threshold,0 ,126
IDE02476-ENG259500-Electrical test of speakers-channel_25_upper_threshold,22 ,126
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,1 ,126
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,9 ,126
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,18 ,126
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,22 ,126
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,18 ,126
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,22 ,126
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,18 ,126
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,22 ,126
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,18 ,126
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,22 ,126
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,18 ,126
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,22 ,126
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,0 ,126
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,22 ,126
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,126
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,126
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,126
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,126
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,126
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,126
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,126
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,126
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,126
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,126
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,126
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,126
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,126
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,126
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,126
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,126
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,126
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,27 ,126
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,126
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,27 ,126
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,126
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,27 ,126
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,126
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,126
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,126
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,27 ,126
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,126
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,27 ,126
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,126
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,27 ,126
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,126
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,27 ,126
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,126
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,10 ,126
IDE02476-ENG260707-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_25_Test_Frequency,19000 Hz,126
IDE02476-ENG259929-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_25_Test_Volume,10 ,126
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,126
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,126
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,126
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,126
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,126
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,126
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,126
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,126
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,126
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,126
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,126
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,126
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,126
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,126
IDE02502-Confirmation of installation change,2D DE ,2
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,not activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,not activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,not activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,not activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,not activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,not activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,not activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,not activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,not activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,not activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,not activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,not activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,not activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,not activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,not activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,not activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,not activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,not activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,not activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,not activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,not activated ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,not activated ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,not activated ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,not activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,not activated ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,CAB_2 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Terminal 15 ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,not activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,not activated ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Terminal 15 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,not activated ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Infotainment data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,not activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,Infotainment data bus ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,CAB_4 ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Infotainment data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,Infotainment data bus ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Infotainment data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Terminal 15 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,not activated ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Infotainment data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Terminal 15 ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,not activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,not activated ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Terminal 15 ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,Infotainment data bus ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,not activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,not activated ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,not activated ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Terminal 15 ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Terminal 15 ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,Infotainment data bus ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Terminal 15 ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Terminal 15 ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,not activated ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,Terminal 15 ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Terminal 15 ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Terminal 15 ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,not activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,not activated ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Terminal 15 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE04521-Sporadic ring break detection,none ,1
IDE04522-Awakening ability on optical databus,OFF ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,-128 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,not activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-Gnss update rate,0 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10082-MAS09814-Telephone functions configuration-Call Center Function,OFF ,1
IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,Available ,1
IDE10082-ENG278502-Telephone functions configuration-Icon_for_data_connection,Show ,1
IDE10494-ENG128241-Active noise reduction: configuration-ANC_EOL_level,3 ,31
IDE10494-ENG128062-Active noise reduction: configuration-mask_level_result_FL_FL_1,NO_Mask ,31
IDE10494-ENG128064-Active noise reduction: configuration-mask_level_result_FL_FL_2,NO_Mask ,31
IDE10494-ENG128066-Active noise reduction: configuration-mask_level_result_FL_FL_3,NO_Mask ,31
IDE10494-ENG128068-Active noise reduction: configuration-mask_level_result_FL_FR_1,NO_Mask ,31
IDE10494-ENG128070-Active noise reduction: configuration-mask_level_result_FL_FR_2,NO_Mask ,31
IDE10494-ENG128072-Active noise reduction: configuration-mask_level_result_FL_FR_3,NO_Mask ,31
IDE10494-ENG128086-Active noise reduction: configuration-mask_level_result_FL_Mic5_1,NO_Mask ,31
IDE10494-ENG128088-Active noise reduction: configuration-mask_level_result_FL_Mic5_2,NO_Mask ,31
IDE10494-ENG128090-Active noise reduction: configuration-mask_level_result_FL_Mic5_3,NO_Mask ,31
IDE10494-ENG128092-Active noise reduction: configuration-mask_level_result_FL_Mic6_1,NO_Mask ,31
IDE10494-ENG128094-Active noise reduction: configuration-mask_level_result_FL_Mic6_2,NO_Mask ,31
IDE10494-ENG128096-Active noise reduction: configuration-mask_level_result_FL_Mic6_3,NO_Mask ,31
IDE10494-ENG128074-Active noise reduction: configuration-mask_level_result_FL_RL_1,NO_Mask ,31
IDE10494-ENG128076-Active noise reduction: configuration-mask_level_result_FL_RL_2,NO_Mask ,31
IDE10494-ENG128078-Active noise reduction: configuration-mask_level_result_FL_RL_3,NO_Mask ,31
IDE10494-ENG128080-Active noise reduction: configuration-mask_level_result_FL_RR_1,NO_Mask ,31
IDE10494-ENG128082-Active noise reduction: configuration-mask_level_result_FL_RR_2,NO_Mask ,31
IDE10494-ENG128084-Active noise reduction: configuration-mask_level_result_FL_RR_3,NO_Mask ,31
IDE10494-ENG128098-Active noise reduction: configuration-mask_level_result_FR_FL_1,NO_Mask ,31
IDE10494-ENG128100-Active noise reduction: configuration-mask_level_result_FR_FL_2,NO_Mask ,31
IDE10494-ENG128102-Active noise reduction: configuration-mask_level_result_FR_FL_3,NO_Mask ,31
IDE10494-ENG128104-Active noise reduction: configuration-mask_level_result_FR_FR_1,NO_Mask ,31
IDE10494-ENG128106-Active noise reduction: configuration-mask_level_result_FR_FR_2,NO_Mask ,31
IDE10494-ENG128108-Active noise reduction: configuration-mask_level_result_FR_FR_3,NO_Mask ,31
IDE10494-ENG128122-Active noise reduction: configuration-mask_level_result_FR_Mic5_1,NO_Mask ,31
IDE10494-ENG128124-Active noise reduction: configuration-mask_level_result_FR_Mic5_2,NO_Mask ,31
IDE10494-ENG128126-Active noise reduction: configuration-mask_level_result_FR_Mic5_3,NO_Mask ,31
IDE10494-ENG128128-Active noise reduction: configuration-mask_level_result_FR_Mic6_1,NO_Mask ,31
IDE10494-ENG128130-Active noise reduction: configuration-mask_level_result_FR_Mic6_2,NO_Mask ,31
IDE10494-ENG128132-Active noise reduction: configuration-mask_level_result_FR_Mic6_3,NO_Mask ,31
IDE10494-ENG128110-Active noise reduction: configuration-mask_level_result_FR_RL_1,NO_Mask ,31
IDE10494-ENG128112-Active noise reduction: configuration-mask_level_result_FR_RL_2,NO_Mask ,31
IDE10494-ENG128114-Active noise reduction: configuration-mask_level_result_FR_RL_3,NO_Mask ,31
IDE10494-ENG128116-Active noise reduction: configuration-mask_level_result_FR_RR_1,NO_Mask ,31
IDE10494-ENG128118-Active noise reduction: configuration-mask_level_result_FR_RR_2,NO_Mask ,31
IDE10494-ENG128120-Active noise reduction: configuration-mask_level_result_FR_RR_3,NO_Mask ,31
IDE10494-ENG128134-Active noise reduction: configuration-mask_level_result_RL_FL_1,NO_Mask ,31
IDE10494-ENG128136-Active noise reduction: configuration-mask_level_result_RL_FL_2,NO_Mask ,31
IDE10494-ENG128138-Active noise reduction: configuration-mask_level_result_RL_FL_3,NO_Mask ,31
IDE10494-ENG128140-Active noise reduction: configuration-mask_level_result_RL_FR_1,NO_Mask ,31
IDE10494-ENG128142-Active noise reduction: configuration-mask_level_result_RL_FR_2,NO_Mask ,31
IDE10494-ENG128144-Active noise reduction: configuration-mask_level_result_RL_FR_3,NO_Mask ,31
IDE10494-ENG128158-Active noise reduction: configuration-mask_level_result_RL_Mic5_1,NO_Mask ,31
IDE10494-ENG128160-Active noise reduction: configuration-mask_level_result_RL_Mic5_2,NO_Mask ,31
IDE10494-ENG128162-Active noise reduction: configuration-mask_level_result_RL_Mic5_3,NO_Mask ,31
IDE10494-ENG128164-Active noise reduction: configuration-mask_level_result_RL_Mic6_1,NO_Mask ,31
IDE10494-ENG128166-Active noise reduction: configuration-mask_level_result_RL_Mic6_2,NO_Mask ,31
IDE10494-ENG128168-Active noise reduction: configuration-mask_level_result_RL_Mic6_3,NO_Mask ,31
IDE10494-ENG128146-Active noise reduction: configuration-mask_level_result_RL_RL_1,NO_Mask ,31
IDE10494-ENG128148-Active noise reduction: configuration-mask_level_result_RL_RL_2,NO_Mask ,31
IDE10494-ENG128150-Active noise reduction: configuration-mask_level_result_RL_RL_3,NO_Mask ,31
IDE10494-ENG128152-Active noise reduction: configuration-mask_level_result_RL_RR_1,NO_Mask ,31
IDE10494-ENG128154-Active noise reduction: configuration-mask_level_result_RL_RR_2,NO_Mask ,31
IDE10494-ENG128156-Active noise reduction: configuration-mask_level_result_RL_RR_3,NO_Mask ,31
IDE10494-ENG128170-Active noise reduction: configuration-mask_level_result_RR_FL_1,NO_Mask ,31
IDE10494-ENG128172-Active noise reduction: configuration-mask_level_result_RR_FL_2,NO_Mask ,31
IDE10494-ENG128174-Active noise reduction: configuration-mask_level_result_RR_FL_3,NO_Mask ,31
IDE10494-ENG128176-Active noise reduction: configuration-mask_level_result_RR_FR_1,NO_Mask ,31
IDE10494-ENG128178-Active noise reduction: configuration-mask_level_result_RR_FR_2,NO_Mask ,31
IDE10494-ENG128180-Active noise reduction: configuration-mask_level_result_RR_FR_3,NO_Mask ,31
IDE10494-ENG128194-Active noise reduction: configuration-mask_level_result_RR_Mic5_1,NO_Mask ,31
IDE10494-ENG128196-Active noise reduction: configuration-mask_level_result_RR_Mic5_2,NO_Mask ,31
IDE10494-ENG128198-Active noise reduction: configuration-mask_level_result_RR_Mic5_3,NO_Mask ,31
IDE10494-ENG128200-Active noise reduction: configuration-mask_level_result_RR_Mic6_1,NO_Mask ,31
IDE10494-ENG128202-Active noise reduction: configuration-mask_level_result_RR_Mic6_2,NO_Mask ,31
IDE10494-ENG128204-Active noise reduction: configuration-mask_level_result_RR_Mic6_3,NO_Mask ,31
IDE10494-ENG128182-Active noise reduction: configuration-mask_level_result_RR_RL_1,NO_Mask ,31
IDE10494-ENG128184-Active noise reduction: configuration-mask_level_result_RR_RL_2,NO_Mask ,31
IDE10494-ENG128186-Active noise reduction: configuration-mask_level_result_RR_RL_3,NO_Mask ,31
IDE10494-ENG128188-Active noise reduction: configuration-mask_level_result_RR_RR_1,NO_Mask ,31
IDE10494-ENG128190-Active noise reduction: configuration-mask_level_result_RR_RR_2,NO_Mask ,31
IDE10494-ENG128192-Active noise reduction: configuration-mask_level_result_RR_RR_3,NO_Mask ,31
IDE10494-ENG128206-Active noise reduction: configuration-mask_level_result_Subw_FL_1,NO_Mask ,31
IDE10494-ENG128208-Active noise reduction: configuration-mask_level_result_Subw_FL_2,NO_Mask ,31
IDE10494-ENG128210-Active noise reduction: configuration-mask_level_result_Subw_FL_3,NO_Mask ,31
IDE10494-ENG128212-Active noise reduction: configuration-mask_level_result_Subw_FR_1,NO_Mask ,31
IDE10494-ENG128214-Active noise reduction: configuration-mask_level_result_Subw_FR_2,NO_Mask ,31
IDE10494-ENG128216-Active noise reduction: configuration-mask_level_result_Subw_FR_3,NO_Mask ,31
IDE10494-ENG128230-Active noise reduction: configuration-mask_level_result_Subw_Mic5_1,NO_Mask ,31
IDE10494-ENG128232-Active noise reduction: configuration-mask_level_result_Subw_Mic5_2,NO_Mask ,31
IDE10494-ENG128234-Active noise reduction: configuration-mask_level_result_Subw_Mic5_3,NO_Mask ,31
IDE10494-ENG128236-Active noise reduction: configuration-mask_level_result_Subw_Mic6_1,NO_Mask ,31
IDE10494-ENG128238-Active noise reduction: configuration-mask_level_result_Subw_Mic6_2,NO_Mask ,31
IDE10494-ENG128240-Active noise reduction: configuration-mask_level_result_Subw_Mic6_3,NO_Mask ,31
IDE10494-ENG128218-Active noise reduction: configuration-mask_level_result_Subw_RL_1,NO_Mask ,31
IDE10494-ENG128220-Active noise reduction: configuration-mask_level_result_Subw_RL_2,NO_Mask ,31
IDE10494-ENG128222-Active noise reduction: configuration-mask_level_result_Subw_RL_3,NO_Mask ,31
IDE10494-ENG128224-Active noise reduction: configuration-mask_level_result_Subw_RR_1,NO_Mask ,31
IDE10494-ENG128226-Active noise reduction: configuration-mask_level_result_Subw_RR_2,NO_Mask ,31
IDE10494-ENG128228-Active noise reduction: configuration-mask_level_result_Subw_RR_3,NO_Mask ,31
IDE10494-ENG128061-Active noise reduction: configuration-mask_phase_result_FL_FL_1,NO_Mask ,31
IDE10494-ENG128063-Active noise reduction: configuration-mask_phase_result_FL_FL_2,NO_Mask ,31
IDE10494-ENG128065-Active noise reduction: configuration-mask_phase_result_FL_FL_3,NO_Mask ,31
IDE10494-ENG128067-Active noise reduction: configuration-mask_phase_result_FL_FR_1,NO_Mask ,31
IDE10494-ENG128069-Active noise reduction: configuration-mask_phase_result_FL_FR_2,NO_Mask ,31
IDE10494-ENG128071-Active noise reduction: configuration-mask_phase_result_FL_FR_3,NO_Mask ,31
IDE10494-ENG128085-Active noise reduction: configuration-mask_phase_result_FL_Mic5_1,NO_Mask ,31
IDE10494-ENG128087-Active noise reduction: configuration-mask_phase_result_FL_Mic5_2,NO_Mask ,31
IDE10494-ENG128089-Active noise reduction: configuration-mask_phase_result_FL_Mic5_3,NO_Mask ,31
IDE10494-ENG128091-Active noise reduction: configuration-mask_phase_result_FL_Mic6_1,NO_Mask ,31
IDE10494-ENG128093-Active noise reduction: configuration-mask_phase_result_FL_Mic6_2,NO_Mask ,31
IDE10494-ENG128095-Active noise reduction: configuration-mask_phase_result_FL_Mic6_3,NO_Mask ,31
IDE10494-ENG128073-Active noise reduction: configuration-mask_phase_result_FL_RL_1,NO_Mask ,31
IDE10494-ENG128075-Active noise reduction: configuration-mask_phase_result_FL_RL_2,NO_Mask ,31
IDE10494-ENG128077-Active noise reduction: configuration-mask_phase_result_FL_RL_3,NO_Mask ,31
IDE10494-ENG128079-Active noise reduction: configuration-mask_phase_result_FL_RR_1,NO_Mask ,31
IDE10494-ENG128081-Active noise reduction: configuration-mask_phase_result_FL_RR_2,NO_Mask ,31
IDE10494-ENG128083-Active noise reduction: configuration-mask_phase_result_FL_RR_3,NO_Mask ,31
IDE10494-ENG128097-Active noise reduction: configuration-mask_phase_result_FR_FL_1,NO_Mask ,31
IDE10494-ENG128099-Active noise reduction: configuration-mask_phase_result_FR_FL_2,NO_Mask ,31
IDE10494-ENG128101-Active noise reduction: configuration-mask_phase_result_FR_FL_3,NO_Mask ,31
IDE10494-ENG128103-Active noise reduction: configuration-mask_phase_result_FR_FR_1,NO_Mask ,31
IDE10494-ENG128105-Active noise reduction: configuration-mask_phase_result_FR_FR_2,NO_Mask ,31
IDE10494-ENG128107-Active noise reduction: configuration-mask_phase_result_FR_FR_3,NO_Mask ,31
IDE10494-ENG128121-Active noise reduction: configuration-mask_phase_result_FR_Mic5_1,NO_Mask ,31
IDE10494-ENG128123-Active noise reduction: configuration-mask_phase_result_FR_Mic5_2,NO_Mask ,31
IDE10494-ENG128125-Active noise reduction: configuration-mask_phase_result_FR_Mic5_3,NO_Mask ,31
IDE10494-ENG128127-Active noise reduction: configuration-mask_phase_result_FR_Mic6_1,NO_Mask ,31
IDE10494-ENG128129-Active noise reduction: configuration-mask_phase_result_FR_Mic6_2,NO_Mask ,31
IDE10494-ENG128131-Active noise reduction: configuration-mask_phase_result_FR_Mic6_3,NO_Mask ,31
IDE10494-ENG128109-Active noise reduction: configuration-mask_phase_result_FR_RL_1,NO_Mask ,31
IDE10494-ENG128111-Active noise reduction: configuration-mask_phase_result_FR_RL_2,NO_Mask ,31
IDE10494-ENG128113-Active noise reduction: configuration-mask_phase_result_FR_RL_3,NO_Mask ,31
IDE10494-ENG128115-Active noise reduction: configuration-mask_phase_result_FR_RR_1,NO_Mask ,31
IDE10494-ENG128117-Active noise reduction: configuration-mask_phase_result_FR_RR_2,NO_Mask ,31
IDE10494-ENG128119-Active noise reduction: configuration-mask_phase_result_FR_RR_3,NO_Mask ,31
IDE10494-ENG128133-Active noise reduction: configuration-mask_phase_result_RL_FL_1,NO_Mask ,31
IDE10494-ENG128135-Active noise reduction: configuration-mask_phase_result_RL_FL_2,NO_Mask ,31
IDE10494-ENG128137-Active noise reduction: configuration-mask_phase_result_RL_FL_3,NO_Mask ,31
IDE10494-ENG128139-Active noise reduction: configuration-mask_phase_result_RL_FR_1,NO_Mask ,31
IDE10494-ENG128141-Active noise reduction: configuration-mask_phase_result_RL_FR_2,NO_Mask ,31
IDE10494-ENG128143-Active noise reduction: configuration-mask_phase_result_RL_FR_3,NO_Mask ,31
IDE10494-ENG128157-Active noise reduction: configuration-mask_phase_result_RL_Mic5_1,NO_Mask ,31
IDE10494-ENG128159-Active noise reduction: configuration-mask_phase_result_RL_Mic5_2,NO_Mask ,31
IDE10494-ENG128161-Active noise reduction: configuration-mask_phase_result_RL_Mic5_3,NO_Mask ,31
IDE10494-ENG128163-Active noise reduction: configuration-mask_phase_result_RL_Mic6_1,NO_Mask ,31
IDE10494-ENG128165-Active noise reduction: configuration-mask_phase_result_RL_Mic6_2,NO_Mask ,31
IDE10494-ENG128167-Active noise reduction: configuration-mask_phase_result_RL_Mic6_3,NO_Mask ,31
IDE10494-ENG128145-Active noise reduction: configuration-mask_phase_result_RL_RL_1,NO_Mask ,31
IDE10494-ENG128147-Active noise reduction: configuration-mask_phase_result_RL_RL_2,NO_Mask ,31
IDE10494-ENG128149-Active noise reduction: configuration-mask_phase_result_RL_RL_3,NO_Mask ,31
IDE10494-ENG128151-Active noise reduction: configuration-mask_phase_result_RL_RR_1,NO_Mask ,31
IDE10494-ENG128153-Active noise reduction: configuration-mask_phase_result_RL_RR_2,NO_Mask ,31
IDE10494-ENG128155-Active noise reduction: configuration-mask_phase_result_RL_RR_3,NO_Mask ,31
IDE10494-ENG128169-Active noise reduction: configuration-mask_phase_result_RR_FL_1,NO_Mask ,31
IDE10494-ENG128171-Active noise reduction: configuration-mask_phase_result_RR_FL_2,NO_Mask ,31
IDE10494-ENG128173-Active noise reduction: configuration-mask_phase_result_RR_FL_3,NO_Mask ,31
IDE10494-ENG128175-Active noise reduction: configuration-mask_phase_result_RR_FR_1,NO_Mask ,31
IDE10494-ENG128177-Active noise reduction: configuration-mask_phase_result_RR_FR_2,NO_Mask ,31
IDE10494-ENG128179-Active noise reduction: configuration-mask_phase_result_RR_FR_3,NO_Mask ,31
IDE10494-ENG128193-Active noise reduction: configuration-mask_phase_result_RR_Mic5_1,NO_Mask ,31
IDE10494-ENG128195-Active noise reduction: configuration-mask_phase_result_RR_Mic5_2,NO_Mask ,31
IDE10494-ENG128197-Active noise reduction: configuration-mask_phase_result_RR_Mic5_3,NO_Mask ,31
IDE10494-ENG128199-Active noise reduction: configuration-mask_phase_result_RR_Mic6_1,NO_Mask ,31
IDE10494-ENG128201-Active noise reduction: configuration-mask_phase_result_RR_Mic6_2,NO_Mask ,31
IDE10494-ENG128203-Active noise reduction: configuration-mask_phase_result_RR_Mic6_3,NO_Mask ,31
IDE10494-ENG128181-Active noise reduction: configuration-mask_phase_result_RR_RL_1,NO_Mask ,31
IDE10494-ENG128183-Active noise reduction: configuration-mask_phase_result_RR_RL_2,NO_Mask ,31
IDE10494-ENG128185-Active noise reduction: configuration-mask_phase_result_RR_RL_3,NO_Mask ,31
IDE10494-ENG128187-Active noise reduction: configuration-mask_phase_result_RR_RR_1,NO_Mask ,31
IDE10494-ENG128189-Active noise reduction: configuration-mask_phase_result_RR_RR_2,NO_Mask ,31
IDE10494-ENG128191-Active noise reduction: configuration-mask_phase_result_RR_RR_3,NO_Mask ,31
IDE10494-ENG128205-Active noise reduction: configuration-mask_phase_result_Subw_FL_1,NO_Mask ,31
IDE10494-ENG128207-Active noise reduction: configuration-mask_phase_result_Subw_FL_2,NO_Mask ,31
IDE10494-ENG128209-Active noise reduction: configuration-mask_phase_result_Subw_FL_3,NO_Mask ,31
IDE10494-ENG128211-Active noise reduction: configuration-mask_phase_result_Subw_FR_1,NO_Mask ,31
IDE10494-ENG128213-Active noise reduction: configuration-mask_phase_result_Subw_FR_2,NO_Mask ,31
IDE10494-ENG128215-Active noise reduction: configuration-mask_phase_result_Subw_FR_3,NO_Mask ,31
IDE10494-ENG128229-Active noise reduction: configuration-mask_phase_result_Subw_Mic5_1,NO_Mask ,31
IDE10494-ENG128231-Active noise reduction: configuration-mask_phase_result_Subw_Mic5_2,NO_Mask ,31
IDE10494-ENG128233-Active noise reduction: configuration-mask_phase_result_Subw_Mic5_3,NO_Mask ,31
IDE10494-ENG128235-Active noise reduction: configuration-mask_phase_result_Subw_Mic6_1,NO_Mask ,31
IDE10494-ENG128237-Active noise reduction: configuration-mask_phase_result_Subw_Mic6_2,NO_Mask ,31
IDE10494-ENG128239-Active noise reduction: configuration-mask_phase_result_Subw_Mic6_3,NO_Mask ,31
IDE10494-ENG128217-Active noise reduction: configuration-mask_phase_result_Subw_RL_1,NO_Mask ,31
IDE10494-ENG128219-Active noise reduction: configuration-mask_phase_result_Subw_RL_2,NO_Mask ,31
IDE10494-ENG128221-Active noise reduction: configuration-mask_phase_result_Subw_RL_3,NO_Mask ,31
IDE10494-ENG128223-Active noise reduction: configuration-mask_phase_result_Subw_RR_1,NO_Mask ,31
IDE10494-ENG128225-Active noise reduction: configuration-mask_phase_result_Subw_RR_2,NO_Mask ,31
IDE10494-ENG128227-Active noise reduction: configuration-mask_phase_result_Subw_RR_3,NO_Mask ,31
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dB V,34 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,50 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11105-Brand-specific display of connect application,de.audi.myaudimobileassistant ,64
IDE11122-Country identification: country of sale HMI,US ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
IDE11638-Bluetooth Audio Codec,FF ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,slave ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Deactivated ,2
IDE14729-ENG258620-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_bus_number,0 ,22
IDE14729-ENG260754-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_channel_uplink_high,0 ,22
IDE14729-ENG258987-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_channel_uplink_low,0 ,22
IDE14729-ENG259482-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_downlink_availability,OFF ,22
IDE14729-ENG260069-Automotive audio bus (A2B): function configuration-ANC_microphone_FL_uplink_availability,OFF ,22
IDE14729-ENG259265-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_bus_number,0 ,22
IDE14729-ENG260504-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_channel_uplink_high,0 ,22
IDE14729-ENG260890-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_channel_uplink_low,0 ,22
IDE14729-ENG258681-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_downlink_availability,OFF ,22
IDE14729-ENG258531-Automotive audio bus (A2B): function configuration-ANC_microphone_FR_uplink_availability,OFF ,22
IDE14729-ENG259867-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_bus_number,0 ,22
IDE14729-ENG259148-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_channel_uplink_high,0 ,22
IDE14729-ENG258419-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_channel_uplink_low,0 ,22
IDE14729-ENG259263-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_downlink_availability,OFF ,22
IDE14729-ENG260988-Automotive audio bus (A2B): function configuration-ANC_microphone_RL_uplink_availability,OFF ,22
IDE14729-ENG259725-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_bus_number,0 ,22
IDE14729-ENG260426-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_channel_uplink_high,0 ,22
IDE14729-ENG260243-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_channel_uplink_low,0 ,22
IDE14729-ENG260582-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_downlink_availability,OFF ,22
IDE14729-ENG260045-Automotive audio bus (A2B): function configuration-ANC_microphone_RR_uplink_availability,OFF ,22
IDE14729-ENG258744-Automotive audio bus (A2B): function configuration-Booster_bus_number,1 ,22
IDE14729-ENG261041-Automotive audio bus (A2B): function configuration-Booster_channel_uplink_high,14 ,22
IDE14729-ENG259938-Automotive audio bus (A2B): function configuration-Booster_channel_uplink_low,6 ,22
IDE14729-ENG258241-Automotive audio bus (A2B): function configuration-Booster_downlink_availability,On ,22
IDE14729-ENG260543-Automotive audio bus (A2B): function configuration-Booster_uplink_availability,On ,22
IDE14729-ENG258951-Automotive audio bus (A2B): function configuration-Con_Box_bus_number,1 ,22
IDE14729-ENG261246-Automotive audio bus (A2B): function configuration-Con_Box_channel_uplink_high,5 ,22
IDE14729-ENG259052-Automotive audio bus (A2B): function configuration-Con_Box_channel_uplink_low,0 ,22
IDE14729-ENG260513-Automotive audio bus (A2B): function configuration-Con_Box_downlink_availability,On ,22
IDE14729-ENG260873-Automotive audio bus (A2B): function configuration-Con_Box_uplink_availability,On ,22
IDE14729-ENG376570-Automotive audio bus (A2B): function configuration-DDM3i1_bus_number,0 ,22
IDE14729-ENG376571-Automotive audio bus (A2B): function configuration-DDM3i1_channel_uplink_high,0 ,22
IDE14729-ENG376572-Automotive audio bus (A2B): function configuration-DDM3i1_channel_uplink_low,0 ,22
IDE14729-ENG376573-Automotive audio bus (A2B): function configuration-DDM3i1_downlink_availability,OFF ,22
IDE14729-ENG376574-Automotive audio bus (A2B): function configuration-DDM3i1_uplink_availability,OFF ,22
IDE14729-ENG376804-Automotive audio bus (A2B): function configuration-OCU3_UNECE_bus_number,0 ,22
IDE14729-ENG376805-Automotive audio bus (A2B): function configuration-OCU3_UNECE_channel_uplink_high,0 ,22
IDE14729-ENG376806-Automotive audio bus (A2B): function configuration-OCU3_UNECE_channel_uplink_low,0 ,22
IDE14729-ENG376807-Automotive audio bus (A2B): function configuration-OCU3_UNECE_downlink_availability,OFF ,22
IDE14729-ENG376808-Automotive audio bus (A2B): function configuration-OCU3_UNECE_uplink_availability,OFF ,22
IDE14729-ENG281991-Automotive audio bus (A2B): function configuration-OCU4_bus_number,0 ,22
IDE14729-ENG282001-Automotive audio bus (A2B): function configuration-OCU4_channel_uplink_high,0 ,22
IDE14729-ENG281909-Automotive audio bus (A2B): function configuration-OCU4_channel_uplink_low,0 ,22
IDE14729-ENG282039-Automotive audio bus (A2B): function configuration-OCU4_downlink_availability,OFF ,22
IDE14729-ENG281931-Automotive audio bus (A2B): function configuration-OCU4_uplink_availability,OFF ,22
IDE14729-ENG260986-Automotive audio bus (A2B): function configuration-PASD_bus_number,0 ,22
IDE14729-ENG258579-Automotive audio bus (A2B): function configuration-PASD_channel_uplink_high,0 ,22
IDE14729-ENG261104-Automotive audio bus (A2B): function configuration-PASD_channel_uplink_low,0 ,22
IDE14729-ENG259739-Automotive audio bus (A2B): function configuration-PASD_downlink_availability,OFF ,22
IDE14729-ENG261262-Automotive audio bus (A2B): function configuration-PASD_uplink_availability,OFF ,22
IDE14729-ENG398439-Automotive audio bus (A2B): function configuration-RearMic_bus_number,0 ,22
IDE14729-ENG398440-Automotive audio bus (A2B): function configuration-RearMic_channel_uplink_high,0 ,22
IDE14729-ENG398441-Automotive audio bus (A2B): function configuration-RearMic_channel_uplink_low,0 ,22
IDE14729-ENG398442-Automotive audio bus (A2B): function configuration-RearMic_downlink_availability,OFF ,22
IDE14729-ENG398443-Automotive audio bus (A2B): function configuration-RearMic_uplink_availability,OFF ,22
IDE14730-ENG258862-Automotive audio bus (A2B): diagnostic configuration bus 1-discovery_type,optimized ,10
IDE14730-ENG185820-Automotive audio bus (A2B): diagnostic configuration bus 1-Master,activated ,10
IDE14730-ENG261149-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _1,External sound amplifier ,10
IDE14730-ENG260380-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _2,Emergency call module and communication unit ,10
IDE14730-ENG260854-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _3,Deactivated ,10
IDE14730-ENG259870-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _4,Deactivated ,10
IDE14730-ENG260765-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _5,Deactivated ,10
IDE14730-ENG258502-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _6,Deactivated ,10
IDE14730-ENG261272-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _7,Deactivated ,10
IDE14730-ENG261221-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _8,Deactivated ,10
IDE14730-ENG259340-Automotive audio bus (A2B): diagnostic configuration bus 1-Slave _9,Deactivated ,10
IDE15222-ENG259093-Configuration of DK1 components-capacitive_volume_knob,not activated ,3
IDE15222-ENG398379-Configuration of DK1 components-Disable_Haptic_Feedback_Initially,OFF ,3
IDE15222-ENG260047-Configuration of DK1 components-display_audio_feedback,MU_speaker ,3
IDE15222-ENG260185-Configuration of DK1 components-shutter_foil,not activated ,3
IDE15335-ENG253480-Vehicle name information electronics-default_value_prefix_MMI_name,Audi_MMI_ ,42
IDE15335-ENG253482-Vehicle name information electronics-Postfix_2.4_GHz_SSID, ,42
IDE15335-ENG253481-Vehicle name information electronics-Postfix_5_GHz_SSID,_5GHz ,42
IDE15361-ENG259850-Wi-Fi settings-2.4_GHz_max_channel_bandwidth,20_MHz ,7
IDE15361-ENG260321-Wi-Fi settings-2.4_GHz_visibility,activated ,7
IDE15361-ENG258978-Wi-Fi settings-5_GHz_max_channel_bandwidth,80_MHz ,7
IDE15361-ENG258896-Wi-Fi settings-5_ghz_visibility,activated ,7
IDE15361-ENG248412-Wi-Fi settings-5_ghz_wlan,On ,7
IDE15361-ENG248626-Wi-Fi settings-channel_number_for_2_4GHz,6 ,7
IDE15361-ENG248627-Wi-Fi settings-channel_number_for_5GHz,0 ,7
IDE15361-ENG253479-Wi-Fi settings-DHCP_lease_time,72 H,7
IDE15361-ENG261211-Wi-Fi settings-internet_over_WLAN_default_setting,activated ,7
IDE15361-ENG260341-Wi-Fi settings-location_of_BT_WLAN_chip,active ,7
IDE15361-ENG259649-Wi-Fi settings-WLAN_password_sync,Synchronized ,7
IDE15362-ENG253478-Smartphone configuration-Apple_car_play_wireless,On ,3
IDE15362-ENG398367-Smartphone configuration-AppleMapsEvRouting,OFF ,3
IDE15362-ENG185765-Smartphone configuration-Baidu_Car_Life_ios_Wireless,OFF ,3
IDE15362-ENG185766-Smartphone configuration-Baidu_Car_Life_Wireless,OFF ,3
IDE15362-ENG253483-Smartphone configuration-Google_android_auto_wireless,On ,3
IDE15387-ENG259927-Settings for navigation with e-vehicles-Built_In_Booster,0 kW,10
IDE15387-ENG259118-Settings for navigation with e-vehicles-Charging_Time_Factor,0 ,10
IDE15387-ENG258929-Settings for navigation with e-vehicles-Charging_Time_Offset,0 min,10
IDE15387-ENG259085-Settings for navigation with e-vehicles-Max_Battery_Ampere,0 A,10
IDE15387-ENG259058-Settings for navigation with e-vehicles-Max_Battery_Voltage,0 V,10
IDE15387-ENG261213-Settings for navigation with e-vehicles-Range_Assurance_Level_1_NumChargers,0 ,10
IDE15387-ENG259231-Settings for navigation with e-vehicles-Range_Assurance_Level_1_SOC,0 %,10
IDE15387-ENG258257-Settings for navigation with e-vehicles-Range_Assurance_Level_2_NumChargers,0 ,10
IDE15387-ENG259808-Settings for navigation with e-vehicles-Range_Assurance_Level_2_SOC,0 %,10
IDE15947-Back end configuration,24 ,1
ENG117918-ENG117811-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_On_Off,On ,12
ENG117918-ENG117813-Audio_Management_Audio_Delay_Lines-Amplifier_Delay_Time,0 ms,12
ENG117918-ENG126188-Audio_Management_Audio_Delay_Lines-Headphone_Delay_On_Off,OFF ,12
ENG117918-ENG126189-Audio_Management_Audio_Delay_Lines-Headphone_Delay_Time,0 ms,12
ENG117918-ENG126190-Audio_Management_Audio_Delay_Lines-Headphone_wireless_Delay_On_Off,OFF ,12
ENG117918-ENG126191-Audio_Management_Audio_Delay_Lines-Headphone_wireless_Delay_Time,0 ms,12
ENG117918-ENG117810-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_On_Off,On ,12
ENG117918-ENG117812-Audio_Management_Audio_Delay_Lines-Main_Unit_Delay_Time,0 ms,12
ENG264032-ENG264184-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264185-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264186-Automotive_audio_bus_configuration_EMC_bus-Master_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264187-Automotive_audio_bus_configuration_EMC_bus-Master_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264188-Automotive_audio_bus_configuration_EMC_bus-Master_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264208-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264209-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264210-Automotive_audio_bus_configuration_EMC_bus-Slave_1_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264211-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264212-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264213-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264214-Automotive_audio_bus_configuration_EMC_bus-Slave_1_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264215-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264216-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264217-Automotive_audio_bus_configuration_EMC_bus-Slave_2_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264218-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264219-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264220-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264221-Automotive_audio_bus_configuration_EMC_bus-Slave_2_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264222-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264223-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264224-Automotive_audio_bus_configuration_EMC_bus-Slave_3_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264225-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264226-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264227-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264228-Automotive_audio_bus_configuration_EMC_bus-Slave_3_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264229-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264230-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264231-Automotive_audio_bus_configuration_EMC_bus-Slave_4_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264232-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264233-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264234-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264235-Automotive_audio_bus_configuration_EMC_bus-Slave_4_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264236-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264237-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264238-Automotive_audio_bus_configuration_EMC_bus-Slave_5_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264239-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264240-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264241-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264242-Automotive_audio_bus_configuration_EMC_bus-Slave_5_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264243-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264244-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264245-Automotive_audio_bus_configuration_EMC_bus-Slave_6_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264246-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264247-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264248-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264249-Automotive_audio_bus_configuration_EMC_bus-Slave_6_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264250-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264251-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264252-Automotive_audio_bus_configuration_EMC_bus-Slave_7_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264253-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264254-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264255-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264256-Automotive_audio_bus_configuration_EMC_bus-Slave_7_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264257-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264258-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264259-Automotive_audio_bus_configuration_EMC_bus-Slave_8_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264260-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264261-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264262-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264263-Automotive_audio_bus_configuration_EMC_bus-Slave_8_TXBCTL_TXBOVREN,Disable ,29
ENG264032-ENG264264-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSDEPTH,low ,29
ENG264032-ENG264265-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSFREQ,4_times ,29
ENG264032-ENG264266-Automotive_audio_bus_configuration_EMC_bus-Slave_9_PLLCTL_SSMODE,no_spread ,29
ENG264032-ENG264267-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXACTL_TXALEVEL,high ,29
ENG264032-ENG264268-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXACTL_TXAOVREN,Disable ,29
ENG264032-ENG264269-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXBCTL_TXBLEVEL,high ,29
ENG264032-ENG264270-Automotive_audio_bus_configuration_EMC_bus-Slave_9_TXBCTL_TXBOVREN,Disable ,29
ENG277053-ENG273739-battery_charging_curve-Charging_power_01,0 ,30
ENG277053-ENG273716-battery_charging_curve-Charging_power_02,0 ,30
ENG277053-ENG273749-battery_charging_curve-Charging_power_03,0 ,30
ENG277053-ENG273698-battery_charging_curve-Charging_power_04,0 ,30
ENG277053-ENG273834-battery_charging_curve-Charging_power_05,0 ,30
ENG277053-ENG273839-battery_charging_curve-Charging_power_06,0 ,30
ENG277053-ENG273868-battery_charging_curve-Charging_power_07,0 ,30
ENG277053-ENG273719-battery_charging_curve-Charging_power_08,0 ,30
ENG277053-ENG273828-battery_charging_curve-Charging_power_09,0 ,30
ENG277053-ENG273624-battery_charging_curve-Charging_power_10,0 ,30
ENG277053-ENG273852-battery_charging_curve-Soc_01,0 ,30
ENG277053-ENG273701-battery_charging_curve-Soc_02,0 ,30
ENG277053-ENG273861-battery_charging_curve-Soc_03,0 ,30
ENG277053-ENG273825-battery_charging_curve-Soc_04,0 ,30
ENG277053-ENG273654-battery_charging_curve-Soc_05,0 ,30
ENG277053-ENG273816-battery_charging_curve-Soc_06,0 ,30
ENG277053-ENG273836-battery_charging_curve-Soc_07,0 ,30
ENG277053-ENG273870-battery_charging_curve-Soc_08,0 ,30
ENG277053-ENG273677-battery_charging_curve-Soc_09,0 ,30
ENG277053-ENG273801-battery_charging_curve-Soc_10,0 ,30
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,Yes ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,MOST_streaming ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,MOST ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,1 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,LVDS_map_FPK ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,8
ENG152376-ENG101574-Dimming_ambient_illumination_for_volume_control-X1,Conditions not correct or request sequence error,8
ENG152376-ENG99557-Dimming_ambient_illumination_for_volume_control-X2,Conditions not correct or request sequence error,8
ENG152376-ENG102140-Dimming_ambient_illumination_for_volume_control-X3,Conditions not correct or request sequence error,8
ENG152376-ENG99777-Dimming_ambient_illumination_for_volume_control-Y1,Conditions not correct or request sequence error,8
ENG152376-ENG100480-Dimming_ambient_illumination_for_volume_control-Y2,Conditions not correct or request sequence error,8
ENG152376-ENG100773-Dimming_ambient_illumination_for_volume_control-Y3,Conditions not correct or request sequence error,8
ENG152377-ENG101574-Dimming_illumination_for_display_unit_1_for_multimedia_system-X1,0 ,18
ENG152377-ENG99557-Dimming_illumination_for_display_unit_1_for_multimedia_system-X2,40 ,18
ENG152377-ENG102140-Dimming_illumination_for_display_unit_1_for_multimedia_system-X3,70 ,18
ENG152377-ENG102936-Dimming_illumination_for_display_unit_1_for_multimedia_system-X4,100 ,18
ENG152377-ENG103548-Dimming_illumination_for_display_unit_1_for_multimedia_system-X5,150 ,18
ENG152377-ENG113992-Dimming_illumination_for_display_unit_1_for_multimedia_system-X6,253 ,18
ENG152377-ENG99777-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y1,1.0 %,18
ENG152377-ENG100480-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y2,2.0 %,18
ENG152377-ENG100773-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y3,6.0 %,18
ENG152377-ENG100631-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y4,13.0 %,18
ENG152377-ENG102174-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y5,36.0 %,18
ENG152377-ENG113993-Dimming_illumination_for_display_unit_1_for_multimedia_system-Y6,100.0 %,18
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,not activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,0 ms,2
ENG262676-ENG331832-function_configuration_AED-AED_Version,1 ,18
ENG262676-ENG262680-function_configuration_AED-debbug_trace_profile,0 ,18
ENG262676-ENG262691-function_configuration_AED-shutdown_timer,0 ,18
ENG262676-ENG262692-function_configuration_AED-suspend_2_RAM_timer,0 ,18
ENG262676-ENG262693-function_configuration_AED-temperature_profile,0 ,18
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,not installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,0A ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,On ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_with_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,On ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,On ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,OFF ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,OFF ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,OFF ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,OFF ,6
ENG253093-ENG152554-function_configuration_connectivity_extended-Phone_HMI_Privacy,0 ,5
ENG253093-ENG152555-function_configuration_connectivity_extended-Privacy_WithPINRequest,0 ,5
ENG253093-ENG152556-function_configuration_connectivity_extended-scon_telephony,On ,5
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,On ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,0 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,On ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,On ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,On ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,On ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,On ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,On ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,NAR ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,On ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG273674-function_configuration_navigation-max_AC_Charging_Power,0 kW,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,OFF ,4
ENG248433-ENG248828-function_configuration_navigation-vza,not activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG253085-ENG376580-function_configuration_online-Devmode,Deactivated ,1
ENG253085-ENG258874-function_configuration_online-hmi_sdk,OFF ,1
ENG253085-ENG376833-function_configuration_online-PSO_data_export,activated ,1
ENG253085-ENG138663-function_configuration_online-Smartphone_interface_for_rhmi,activated ,1
ENG253085-ENG376900-function_configuration_online-SPIN_timer,Deactivated ,1
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,On ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,Deactivated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG331901-function_configuration_phone-Kopplebox_Fast_Charger,Deactivated ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,activated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,OFF ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,two ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,installed ,3
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,Deactivated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,NAR ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,OFF ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,NAR ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,not activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,not activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,MRC ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,activated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,automatic_with_time_scaling ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,OFF ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,On ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,activated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,0 ,8
ENG248438-ENG248523-function_configuration_sound-brand_sound,Default ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,NAR ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,REGION_NAR ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,On ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,On ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG244879-ENG297725-function_configuration_sw_update-UOTA_T_Box,Not available ,1
ENG248440-function_configuration_swap_fod,swap_not_active_fod_slave_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,Full_System ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,FBAS ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,activated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248442-geocoordinate_create,create ,1
ENG248443-geocoordinate_show,Show ,1
ENG281875-ENG282037-LHI_LHW_common_settings-Abnormal_vehicle_blocking_time,0 ,25
ENG281875-ENG282061-LHI_LHW_common_settings-Accident_vehicle_blocking_time,0 ,25
ENG281875-ENG282000-LHI_LHW_common_settings-Display_signal_output_time,0 ,25
ENG281875-ENG281949-LHI_LHW_common_settings-Maximum_distance_speed_high,0 ,25
ENG281875-ENG281907-LHI_LHW_common_settings-Maximum_distance_speed_low,0 ,25
ENG281875-ENG281956-LHI_LHW_common_settings-Maximum_distance_speed_med,0 ,25
ENG281875-ENG282053-LHI_LHW_common_settings-Minimum_distance_speed_high,0 ,25
ENG281875-ENG281973-LHI_LHW_common_settings-Minimum_distance_speed_low,0 ,25
ENG281875-ENG282014-LHI_LHW_common_settings-Minimum_distance_speed_med,0 ,25
ENG281875-ENG282028-LHI_LHW_common_settings-Popup_blocking_time,0 ,25
ENG281875-ENG282003-LHI_LHW_common_settings-speed_high,0 ,25
ENG281875-ENG281915-LHI_LHW_common_settings-speed_low,0 ,25
ENG281875-ENG282024-LHI_LHW_common_settings-speed_med,0 ,25
ENG281875-ENG281918-LHI_LHW_common_settings-Traction_loss_vehicle_blocking_time,0 ,25
ENG281879-ENG282016-LHI_settings-category_min_non_urban,0 ,5
ENG281879-ENG282055-LHI_settings-category_min_urban,0 ,5
ENG281879-ENG282027-LHI_settings-LHI_accident,OFF ,5
ENG281879-ENG282026-LHI_settings-LHI_breakdown,OFF ,5
ENG281879-ENG282045-LHI_settings-LHI_reduced_visibility,OFF ,5
ENG281879-ENG281906-LHI_settings-LHI_traction_loss,OFF ,5
ENG281879-ENG281944-LHI_settings-Reduced_visibility_blocking_time,0 ,5
ENG281880-ENG281962-LHW_event_settings-Accelaration_Threshold_Accident,0.00 m/s ,50
ENG281880-ENG281911-LHW_event_settings-Ahead_Angle_Tolerancy_Dyn_EV,0  ,50
ENG281880-ENG281926-LHW_event_settings-Angle_Relevancy_Check_EEBL,0  ,50
ENG281880-ENG281938-LHW_event_settings-Driveaway_Acceleration_ASR_Traction_Loss,0.00 m/s ,50
ENG281880-ENG282029-LHW_event_settings-Ego_Base_Speeds_EEBL_0,0.00 ms,50
ENG281880-ENG282062-LHW_event_settings-Ego_Base_Speeds_EEBL_1,0.00 ms,50
ENG281880-ENG282020-LHW_event_settings-Ego_Base_Speeds_EEBL_2,0.00 ms,50
ENG281880-ENG282010-LHW_event_settings-Ego_Base_Speeds_EEBL_3,0.00 ms,50
ENG281880-ENG281977-LHW_event_settings-Ego_Base_Speeds_EEBL_4,0.00 ms,50
ENG281880-ENG281955-LHW_event_settings-Ego_Speed_Threshold_EEBL,0 km/h,50
ENG281880-ENG281922-LHW_event_settings-Front_Half_Tube_Width_Dyn_EV,0 m,50
ENG281880-ENG281924-LHW_event_settings-High_Acceleration_ABS_Traction_Loss,0.00 m/s ,50
ENG281880-ENG282032-LHW_event_settings-High_Acceleration_ESC_Traction_Loss,0.00 m/s ,50
ENG281880-ENG282035-LHW_event_settings-int_Dyn_EV_distance_intersection_point,0 m,50
ENG281880-ENG281998-LHW_event_settings-int_Dyn_EV_safety_area_longitudinal,0 m,50
ENG281880-ENG281958-LHW_event_settings-int_Dyn_EV_safety_area_transverse,0 m,50
ENG281880-ENG281904-LHW_event_settings-int_Dyn_EV_safety_time,0 s,50
ENG281880-ENG282036-LHW_event_settings-Number_Events_ABS_Traction_Loss,0 ,50
ENG281880-ENG282059-LHW_event_settings-Number_Events_ASR_Traction_Loss,0 ,50
ENG281880-ENG281988-LHW_event_settings-Number_Events_Disabled_Vehicle_Threshold_Breakdown,0 ,50
ENG281880-ENG282052-LHW_event_settings-Number_Events_ESC_Traction_Loss,0 ,50
ENG281880-ENG282030-LHW_event_settings-Number_Events_Flat_Tire_Threshold_Breakdown,0 ,50
ENG281880-ENG281954-LHW_event_settings-Number_Events_Hazard_Lights_Threshold_Breakdown,0 ,50
ENG281880-ENG281936-LHW_event_settings-Number_Events_Safeguarding_EV,0 ,50
ENG281880-ENG281990-LHW_event_settings-Paramterer_1_Dyn_EV,0 ,50
ENG281880-ENG282006-LHW_event_settings-Paramterer_2_Dyn_EV,0 ,50
ENG281880-ENG281972-LHW_event_settings-Paramterer_3_Dyn_EV,0 ,50
ENG281880-ENG282019-LHW_event_settings-Radius_Ahead_Dyn_EV,0 m,50
ENG281880-ENG282040-LHW_event_settings-Radius_Behind_Dyn_EV,0 m,50
ENG281880-ENG282033-LHW_event_settings-Radius_Side_Dyn_EV,0 m,50
ENG281880-ENG281992-LHW_event_settings-RV_Long_Acceleration_Threshold_EEBL,0.00 m/s ,50
ENG281880-ENG282009-LHW_event_settings-RV_Speed_Threshold_EEBL,0 km/h,50
ENG281880-ENG281981-LHW_event_settings-Stationary_Threshold,0 km/h,50
ENG281880-ENG281976-LHW_event_settings-Time_Period_ABS_Traction_Loss,0.00 s,50
ENG281880-ENG281917-LHW_event_settings-Time_Period_ASR_Traction_Loss,0.00 s,50
ENG281880-ENG281948-LHW_event_settings-Time_Period_ESC_Traction_Loss,0.00 s,50
ENG281880-ENG282057-LHW_event_settings-Time_Period_Safeguarding_EV,0.00 s,50
ENG281880-ENG281999-LHW_event_settings-TTC_Delta_EEBL,0.00 s,50
ENG281880-ENG281961-LHW_event_settings-TTC_Relevancy_Check_EEBL_0,0.00 s,50
ENG281880-ENG281987-LHW_event_settings-TTC_Relevancy_Check_EEBL_1,0.00 s,50
ENG281880-ENG281978-LHW_event_settings-TTC_Relevancy_Check_EEBL_2,0.00 s,50
ENG281880-ENG281908-LHW_event_settings-TTC_Relevancy_Check_EEBL_3,0.00 s,50
ENG281880-ENG282022-LHW_event_settings-TTC_Relevancy_Check_EEBL_4,0.00 s,50
ENG281873-LHW_extended_settings,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,50
ENG281874-ENG281934-LHW_settings-Delete_Not_Updated_Event_Accident,0 s,48
ENG281874-ENG281939-LHW_settings-Delete_Not_Updated_Event_Breakdown,0 s,48
ENG281874-ENG282023-LHW_settings-Delete_Not_Updated_Event_Dynamic_EV,0 s,48
ENG281874-ENG282054-LHW_settings-Delete_Not_Updated_Event_Safeguarding_EV,0 s,48
ENG281874-ENG282060-LHW_settings-Delete_Not_Updated_Event_Traction_Loss,0 s,48
ENG281874-ENG282038-LHW_settings-Dynamic_EV_Blocking_Time,0 s,48
ENG281874-ENG281984-LHW_settings-EEBL_Blocking_Time,0 s,48
ENG281874-ENG281957-LHW_settings-Ego_Speed_Threshold_Accident,0 km/h,48
ENG281874-ENG281935-LHW_settings-Ego_Speed_Threshold_Breakdown,0 km/h,48
ENG281874-ENG282041-LHW_settings-Ego_Speed_Threshold_Dynamic_EV,0 km/h,48
ENG281874-ENG281945-LHW_settings-Ego_Speed_Threshold_Safeguarding_EV,0 km/h,48
ENG281874-ENG282050-LHW_settings-Ego_Speed_Threshold_Traction_Loss,0 km/h,48
ENG281874-ENG282012-LHW_settings-LHW_accident,OFF ,48
ENG281874-ENG281989-LHW_settings-LHW_breakdown,OFF ,48
ENG281874-ENG282013-LHW_settings-LHW_dyn_EV,OFF ,48
ENG281874-ENG281923-LHW_settings-LHW_EEBL,OFF ,48
ENG281874-ENG281964-LHW_settings-LHW_safeguarding_EV,OFF ,48
ENG281874-ENG282049-LHW_settings-LHW_traction_loss,OFF ,48
ENG281874-ENG281921-LHW_settings-Max_Number_Icons_On_Map,0 ,48
ENG281874-ENG282004-LHW_settings-Safeguarding_EV_Blocking_Time,0 s,48
ENG281874-ENG281979-LHW_settings-TTC_Threshold_Accident,0 s,48
ENG281874-ENG282015-LHW_settings-TTC_Threshold_Breakdown,0 s,48
ENG281874-ENG282018-LHW_settings-TTC_Threshold_Dynamic_EV,0 s,48
ENG281874-ENG281983-LHW_settings-TTC_Threshold_Safeguarding_EV,0 s,48
ENG281874-ENG281966-LHW_settings-TTC_Threshold_Traction_Loss,0 s,48
ENG277065-ENG273775-navigation_settings_e_vehicles_extended-base_load,0 W,15
ENG277065-ENG273758-navigation_settings_e_vehicles_extended-Charging_station_preference,0 min,15
ENG277065-ENG106054-navigation_settings_e_vehicles_extended-Efficiency,0 %,15
ENG277065-ENG273815-navigation_settings_e_vehicles_extended-first_arrival_soc_factor,0 %,15
ENG277065-ENG273776-navigation_settings_e_vehicles_extended-max_arrival_soc,0 %,15
ENG277065-ENG273653-navigation_settings_e_vehicles_extended-max_target_soc,0 %,15
ENG277065-ENG273844-navigation_settings_e_vehicles_extended-min_arrival_soc,0 %,15
ENG277065-ENG273690-navigation_settings_e_vehicles_extended-multistop_routing,OFF ,15
ENG277065-ENG398429-navigation_settings_e_vehicles_extended-plugType,GB/T2015 ,15
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG248467-number_to_name_matching_algorithm,compare_last_digits ,1
ENG262674-region_coding_truffles,EU ,1
ENG167432-MAS19716-RSE_function_configuration-Services,Tracking Data group selected ,10
ENG167432-MAS19722-RSE_function_configuration-Data collector,activated ,10
ENG167432-MAS19797-RSE_function_configuration-Basic settings not detected guest: services,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19798-RSE_function_configuration-Basic settings not detected guest: campaigns with balancing of interests,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19799-RSE_function_configuration-Basic settings not detected guest: campaigns with consent,Settings from the previous drive cycle are adopted ,10
ENG167432-MAS19887-RSE_function_configuration-Display info window for current privacy settings,Display ,10
ENG167432-MAS19892-RSE_function_configuration-Display selection for recurring dialog display,Display ,10
ENG167432-MAS19893-RSE_function_configuration-Selection for recurring dialog display availability,for personalized users ,10
ENG167432-ENG398388-RSE_function_configuration-IAA_online_offline_screen_control,Enable_Online_and_Offline_User_Login ,10
ENG167432-ENG167528-RSE_function_configuration-RSE_navigation_coding,activated ,10
ENG167432-ENG138661-RSE_function_configuration-RSE_software_component,not activated ,10
ENG167432-ENG398364-RSE_function_configuration-TTDSG_consent_screen,No_Display ,10
ENG248469-same_ssid_for_2_4_and_5_ghz,No ,1
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,1
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,1
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,1
ENG248470-sortorder,sortorder_4 ,1
ENG253041-ENG260670-speechinput_properties_for_activation-use_microphone_1_for_speech_input,Yes ,1
ENG253041-ENG260799-speechinput_properties_for_activation-use_microphone_2_for_speech_input,Yes ,1
ENG253041-ENG261039-speechinput_properties_for_activation-use_microphone_3_for_speech_input,No ,1
ENG253041-ENG259276-speechinput_properties_for_activation-use_microphone_4_for_speech_input,No ,1
ENG253041-ENG260534-speechinput_properties_for_activation-Voice_barge_in,On ,1
ENG253041-ENG258983-speechinput_properties_for_activation-Wake_up_phrase,On ,1
ENG253124-ENG261068-subsystem_identifier_version_implementation-abt_1,slave_component_lists ,2
ENG253124-ENG259782-subsystem_identifier_version_implementation-abt_2,slave_component_lists ,2
ENG253124-ENG253445-subsystem_identifier_version_implementation-actuator,slave_component_lists ,2
ENG253124-ENG260508-subsystem_identifier_version_implementation-display_1,individual_identifier_for_each_slave ,2
ENG253124-ENG260946-subsystem_identifier_version_implementation-display_2,slave_component_lists ,2
ENG253124-ENG260037-subsystem_identifier_version_implementation-display_3,slave_component_lists ,2
ENG253124-ENG286255-subsystem_identifier_version_implementation-display_4,slave_component_lists ,2
ENG253124-ENG258562-subsystem_identifier_version_implementation-display_5,slave_component_lists ,2
ENG253124-ENG99668-subsystem_identifier_version_implementation-Reserved_3,slave_component_lists ,2
ENG253124-ENG154261-subsystem_identifier_version_implementation-Reserved_4,slave_component_lists ,2
ENG253124-ENG154330-subsystem_identifier_version_implementation-Reserved_5,slave_component_lists ,2
ENG253124-ENG154188-subsystem_identifier_version_implementation-Reserved_6,slave_component_lists ,2
ENG253124-ENG154256-subsystem_identifier_version_implementation-Reserved_7,slave_component_lists ,2
ENG253124-ENG154341-subsystem_identifier_version_implementation-Reserved_8,slave_component_lists ,2
ENG253124-ENG154185-subsystem_identifier_version_implementation-Reserved_9,slave_component_lists ,2
ENG253124-ENG259851-subsystem_identifier_version_implementation-volume_controler_mmi,individual_identifier_for_each_slave ,2
Elapsed Time: 01:10
;SW:8W1-907-063-G   HW:8W1-907-063-G ---  09: Cent. Elect.
;Component:BCM1 MLBevo   H10 0690, Coding:07000363E0691CCD0515870918AC98AB110B35080000009401000A0020001A01086901320257050000000000000000000000000000000000000000000000000000
;EV_BCM1BOSCHAU651,016011,EV_BCM1BOSCHAU651_016.rod
;Saturday,18,April,2026,17:48:23:01662
;VCDS Version: 26.3.0.0 (x64)  Data version: 20260320 DS375.1
;VCID: 40DEA3622A03A4EA8F3-8014
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE00001-MAS15400-Production mode-Continuation of basic settings without tester,not active ,3
IDE00001-MAS15622-Production mode-Cleaning of rearview camera: changed actuation time,not active ,3
IDE00001-MAS16746-Production mode-Deactivate air recirculation door,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,Security access required,3
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,Security access required,3
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,Security access required,3
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,Security access required,3
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,Security access required,3
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,Security access required,3
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,Security access required,3
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,Security access required,3
IDE00845-Wheel circumference,Conditions not correct or request sequence error,3
IDE01169-Audio lowering request,On ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,According to country version ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01485-Shut-off temperature for solar sunroof,-35  C,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01500-Reduction of window condensation with high humidity,Matching coding ,1
IDE01501-Air leak to footwell,automatic ,1
IDE01503-Running time of basic setting for compressor break-in,120 s,1
IDE01506-Tolerance range for flap end stops,0 ,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE01550-Service position,138.70 ,2
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,not installed ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,not installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,installed ,1
IDE01996-SFT00216-Installation list: specified installations-Projection module in left matrix headlamp,not installed ,1
IDE01996-SFT00217-Installation list: specified installations-Projection module in right matrix headlamp,not installed ,1
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,not installed ,1
IDE02328-Distance to curb,Conditions not correct or request sequence error,1
IDE02329-Allowance for vehicle fittings (width),Conditions not correct or request sequence error,1
IDE02333-Allowance for vehicle fittings (length),Conditions not correct or request sequence error,3
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03782-Switch-off speed for parking assist,10 ,1
IDE03783-Switch-on speed for parallel parking assist,Conditions not correct or request sequence error,1
IDE04034-Compass: magnetic field zone,Security access required,1
IDE04845-Deactivation of stop prevention by parking aid,Security access required,1
IDE04846-Deactivation of stop prevention by parallel parking assistance,Security access required,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE05318-Retrofitted components installed,Default ,1
IDE05569-Compressor control in efficiency mode,Eco mode ,1
IDE05743-Reverse gear recognition debounce time,Security access required,1
IDE06546-Interior specified temperature for production routines,22  C,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE06769-Blower regulator for production routines,7 ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,Security access required,1
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,Security access required,1
IDE07356-Position during interval mode,12.51 ,2
IDE08209-Speed of motors,Default ,1
IDE08373-Offset of fresh air blower speed,Default ,1
IDE08577-Garage door opener: use of GPS data,Security access required,1
IDE08578-Garage door opener: bi-directional communic.,Security access required,1
IDE08579-Garage door opener: drift adapt.,Security access required,1
IDE08580-Garage door opener: increasing transm. power,Security access required,1
IDE08583-Garage door opener: no. of channels,Security access required,1
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,Security access required,1
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,Security access required,1
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,Security access required,1
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,Security access required,1
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,Security access required,1
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,Security access required,1
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,Security access required,1
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,Security access required,1
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,Security access required,1
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,Security access required,1
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,Security access required,1
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,Security access required,1
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,Security access required,1
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,Security access required,1
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,Security access required,1
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,Security access required,1
IDE08585-Garage door opener: activation via remote key,Security access required,1
IDE08778-Garage door opener: surround. target area,Security access required,1
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,1
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,1
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,1
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,1
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,1
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,1
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,1
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,1
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,1
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,1
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,1
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,1
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,1
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,1
IDE10118-Fan speed reduction for telephony,Not available ,1
IDE10119-Blower reduction during voice control,Not available ,1
IDE10296-upper turn position,154.80 ,2
IDE10297-lower turn position,16.01 ,2
IDE10298-Alternating park position 1,7.31 ,2
IDE10299-Alternating park position 2,10.60 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10308-Garage door opener: support door name,Security access required,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0  C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0  C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0  C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10331-MAS02201-Roof electronics control module: temperature-related dim.-Temperature,65  C,2
IDE10331-MAS10404-Roof electronics control module: temperature-related dim.-max. brightness,10 %,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,not active ,1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,not active ,1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,not active ,1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,not active ,1
IDE10350-Garage door opener: programming antenna,Security access required,1
IDE10362-MAS10458-Electrically adjustable steering column: adjustment speed-axial,No Response From Subnet Component,1
IDE10362-MAS10462-Electrically adjustable steering column: adjustment speed-vertical,No Response From Subnet Component,1
IDE10363-Electrically adjust. steering column: entry assist.,No Response From Subnet Component,1
IDE10364-Electrically adjust. steering column: soft stop,No Response From Subnet Component,1
IDE10661-Deactivation of start-stop function (climate control),not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE10914-Seat occupancy-depending A/C,Matching coding ,1
IDE11217-Show parking space,not activated ,1
IDE11549-Automatic query of the identification data on LIN-Bus,activated: no backup ,1
IDE11613-MAS01364-Rear seat ventilation: micro adjustment-Stage 1,0 %,3
IDE11613-MAS01365-Rear seat ventilation: micro adjustment-Stage 2,0 %,3
IDE11613-MAS01366-Rear seat ventilation: micro adjustment-Stage 3,0 %,3
IDE11794-MAS13241-Fragrance diffuser system control module-Aroma 1,0 ,2
IDE11794-MAS13242-Fragrance diffuser system control module-Aroma 2,0 ,2
IDE11954-Automatic activation of parking distance control,not active ,1
IDE12119-Garage door opener: frequency range of bi-directional communication,Security access required,1
IDE12120-Garage door opener: piloted parking,Security access required,1
IDE12121-Garage door opener: vehicle variant,Security access required,1
IDE12122-Garage door opener: continuous transmission mode for level measurement,Security access required,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12291-A/C control and display heads: dimming,Dimming: no dimming when approaching ,1
IDE12359-Roof electronics control module 2: delay time: change of dimming value,No Response From Subnet Component,1
IDE12360-MAS02201-Roof electronics control module 2: temperature-related dim.-Temperature,No Response From Subnet Component,1
IDE12360-MAS10404-Roof electronics control module 2: temperature-related dim.-max. brightness,No Response From Subnet Component,1
IDE12361-Roof electronics control module 2: child-safety dependent,No Response From Subnet Component,1
IDE13059-Cleaning of rearview camera: actuation time in production mode,10000 ms,2
IDE13064-Wiper motor control module: dataset,00 00 06 0C 00 A0 00 7D 00 49 00 6A 05 6B 00 00 00 AA 04 06 02 C0 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 0E 14 19 00 00 00 00 0C 00 00 FC FD 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B7 ED 41 5A ,90
IDE13354-Wiper motor control module: dataset 2,No Response From Subnet Component,90
IDE13355-Wiper motor control module: dataset 3,00 00 0F 00 6E 19 00 00 0A 04 64 96 C8 FA 6E 73 78 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 FF 6B E1 ,50
IDE13356-Wiper motor control module: dataset 4,00 00 38 57 31 39 35 35 31 31 39 41 20 35 36 36 39 35 35 31 31 39 20 20 30 35 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 07 9F B8 ,70
IDE13962-Upper soft distance,No Response From Subnet Component,70
IDE13963-Lower soft distance,No Response From Subnet Component,70
IDE13964-Soft distance retracted,No Response From Subnet Component,70
IDE13965-Soft distance extended,No Response From Subnet Component,70
IDE80001-Analysis 1,Security access required,70
IDE80002-Analysis 2,Security access required,70
IDE80003-Analysis 3,Security access required,70
IDE80251-MAS09644-Neck heating-Vent temperature,Security access required,70
IDE80251-MAS10293-Neck heating-Fan speed,Security access required,70
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 6 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 4 ,1
MAS12843-Maneuvering brake function,activated ,1
MAS15621-Restart information,activated ,1
ENG153768-AAU_CL_Adresse,Security access required,1
ENG133846-ENG98987-amature_ conditioning-Time,Security access required,1
ENG133846-ENG99033-amature_ conditioning-Voltage,Security access required,1
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,Security access required,1
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,Security access required,1
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,Security access required,1
ENG153775-ENG125698-Blower_1_Backrest_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153775-ENG125700-Blower_1_Backrest_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153775-ENG125697-Blower_1_Backrest_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153775-ENG125699-Blower_1_Backrest_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153775-ENG125701-Blower_1_Backrest_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153775-ENG134731-Blower_1_Backrest_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153775-ENG125695-Blower_1_Backrest_Left_fond-Overvoltage_treshold,Security access required,1
ENG153775-ENG125696-Blower_1_Backrest_Left_fond-Undervoltage_treshold,Security access required,1
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,Security access required,1
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,Security access required,1
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,Security access required,1
ENG153776-ENG125698-Blower_1_Backrest_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153776-ENG125700-Blower_1_Backrest_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153776-ENG125697-Blower_1_Backrest_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153776-ENG125699-Blower_1_Backrest_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153776-ENG125701-Blower_1_Backrest_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153776-ENG134731-Blower_1_Backrest_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153776-ENG125695-Blower_1_Backrest_Right_fond-Overvoltage_treshold,Security access required,1
ENG153776-ENG125696-Blower_1_Backrest_Right_fond-Undervoltage_treshold,Security access required,1
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,Security access required,1
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,Security access required,1
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,Security access required,1
ENG153777-ENG125698-Blower_1_Cushion_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153777-ENG125700-Blower_1_Cushion_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153777-ENG125697-Blower_1_Cushion_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153777-ENG125699-Blower_1_Cushion_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153777-ENG125701-Blower_1_Cushion_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153777-ENG134731-Blower_1_Cushion_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153777-ENG125695-Blower_1_Cushion_Left_fond-Overvoltage_treshold,Security access required,1
ENG153777-ENG125696-Blower_1_Cushion_Left_fond-Undervoltage_treshold,Security access required,1
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,Security access required,1
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,Security access required,1
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,Security access required,1
ENG153778-ENG125698-Blower_1_Cushion_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153778-ENG125700-Blower_1_Cushion_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153778-ENG125697-Blower_1_Cushion_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153778-ENG125699-Blower_1_Cushion_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153778-ENG125701-Blower_1_Cushion_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153778-ENG134731-Blower_1_Cushion_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153778-ENG125695-Blower_1_Cushion_Right_fond-Overvoltage_treshold,Security access required,1
ENG153778-ENG125696-Blower_1_Cushion_Right_fond-Undervoltage_treshold,Security access required,1
ENG125620-ENG125698-Blower_2_Backrest_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125620-ENG125700-Blower_2_Backrest_Left-Critical_Temperature_Treshold,Security access required,1
ENG125620-ENG125697-Blower_2_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125620-ENG125699-Blower_2_Backrest_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125620-ENG125701-Blower_2_Backrest_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125620-ENG134731-Blower_2_Backrest_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125620-ENG125695-Blower_2_Backrest_Left-Overvoltage_treshold,Security access required,1
ENG125620-ENG125696-Blower_2_Backrest_Left-Undervoltage_treshold,Security access required,1
ENG153779-ENG125698-Blower_2_Backrest_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153779-ENG125700-Blower_2_Backrest_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153779-ENG125697-Blower_2_Backrest_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153779-ENG125699-Blower_2_Backrest_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153779-ENG125701-Blower_2_Backrest_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153779-ENG134731-Blower_2_Backrest_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153779-ENG125695-Blower_2_Backrest_Left_fond-Overvoltage_treshold,Security access required,1
ENG153779-ENG125696-Blower_2_Backrest_Left_fond-Undervoltage_treshold,Security access required,1
ENG125619-ENG125698-Blower_2_Backrest_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125619-ENG125700-Blower_2_Backrest_Right-Critical_Temperature_Treshold,Security access required,1
ENG125619-ENG125697-Blower_2_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125619-ENG125699-Blower_2_Backrest_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125619-ENG125701-Blower_2_Backrest_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125619-ENG134731-Blower_2_Backrest_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125619-ENG125695-Blower_2_Backrest_Right-Overvoltage_treshold,Security access required,1
ENG125619-ENG125696-Blower_2_Backrest_Right-Undervoltage_treshold,Security access required,1
ENG153780-ENG125698-Blower_2_Backrest_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153780-ENG125700-Blower_2_Backrest_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153780-ENG125697-Blower_2_Backrest_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153780-ENG125699-Blower_2_Backrest_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153780-ENG125701-Blower_2_Backrest_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153780-ENG134731-Blower_2_Backrest_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153780-ENG125695-Blower_2_Backrest_Right_fond-Overvoltage_treshold,Security access required,1
ENG153780-ENG125696-Blower_2_Backrest_Right_fond-Undervoltage_treshold,Security access required,1
ENG125617-ENG125698-Blower_2_Cushion_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125617-ENG125700-Blower_2_Cushion_Left-Critical_Temperature_Treshold,Security access required,1
ENG125617-ENG125697-Blower_2_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125617-ENG125699-Blower_2_Cushion_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125617-ENG125701-Blower_2_Cushion_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125617-ENG134731-Blower_2_Cushion_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125617-ENG125695-Blower_2_Cushion_Left-Overvoltage_treshold,Security access required,1
ENG125617-ENG125696-Blower_2_Cushion_Left-Undervoltage_treshold,Security access required,1
ENG153781-ENG125698-Blower_2_Cushion_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153781-ENG125700-Blower_2_Cushion_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153781-ENG125697-Blower_2_Cushion_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153781-ENG125699-Blower_2_Cushion_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153781-ENG125701-Blower_2_Cushion_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153781-ENG134731-Blower_2_Cushion_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153781-ENG125695-Blower_2_Cushion_Left_fond-Overvoltage_treshold,Security access required,1
ENG153781-ENG125696-Blower_2_Cushion_Left_fond-Undervoltage_treshold,Security access required,1
ENG125618-ENG125698-Blower_2_Cushion_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125618-ENG125700-Blower_2_Cushion_Right-Critical_Temperature_Treshold,Security access required,1
ENG125618-ENG125697-Blower_2_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125618-ENG125699-Blower_2_Cushion_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125618-ENG125701-Blower_2_Cushion_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125618-ENG134731-Blower_2_Cushion_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125618-ENG125695-Blower_2_Cushion_Right-Overvoltage_treshold,Security access required,1
ENG125618-ENG125696-Blower_2_Cushion_Right-Undervoltage_treshold,Security access required,1
ENG153782-ENG125698-Blower_2_Cushion_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153782-ENG125700-Blower_2_Cushion_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153782-ENG125697-Blower_2_Cushion_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153782-ENG125699-Blower_2_Cushion_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153782-ENG125701-Blower_2_Cushion_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153782-ENG134731-Blower_2_Cushion_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153782-ENG125695-Blower_2_Cushion_Right_fond-Overvoltage_treshold,Security access required,1
ENG153782-ENG125696-Blower_2_Cushion_Right_fond-Undervoltage_treshold,Security access required,1
ENG128948-ENG128957-Compass_display_dimming_curve_manipulation-Point_0_Bus_Value,Security access required,1
ENG128948-ENG128958-Compass_display_dimming_curve_manipulation-Point_0_PWM_Value,Security access required,1
ENG128948-ENG128959-Compass_display_dimming_curve_manipulation-Point_1_Bus_Value,Security access required,1
ENG128948-ENG128960-Compass_display_dimming_curve_manipulation-Point_1_PWM_Value,Security access required,1
ENG128948-ENG128961-Compass_display_dimming_curve_manipulation-Point_2_Bus_Value,Security access required,1
ENG128948-ENG128962-Compass_display_dimming_curve_manipulation-Point_2_PWM_Value,Security access required,1
ENG128948-ENG128963-Compass_display_dimming_curve_manipulation-Point_3_Bus_Value,Security access required,1
ENG128948-ENG128964-Compass_display_dimming_curve_manipulation-Point_3_PWM_Value,Security access required,1
ENG128948-ENG128965-Compass_display_dimming_curve_manipulation-Point_4_Bus_Value,Security access required,1
ENG128948-ENG128966-Compass_display_dimming_curve_manipulation-Point_4_PWM_Value,Security access required,1
ENG128948-ENG128967-Compass_display_dimming_curve_manipulation-Point_5_Bus_Value,Security access required,1
ENG128948-ENG128968-Compass_display_dimming_curve_manipulation-Point_5_PWM_Value,Security access required,1
ENG128949-Compass_display_memory,Security access required,1
ENG133837-ENG134737-dim_ramp-dim_ambiente,Security access required,1
ENG133837-ENG134735-dim_ramp-dim_cockpit,Security access required,1
ENG133837-ENG134738-dim_ramp-dim_contact_switch,Security access required,1
ENG133837-ENG134736-dim_ramp-dim_fond,Security access required,1
ENG133837-ENG134741-dim_ramp-dim_in_light_0,Security access required,1
ENG133837-ENG134742-dim_ramp-dim_in_light_1,Security access required,1
ENG133837-ENG134739-dim_ramp-dim_read_light_0,Security access required,1
ENG133837-ENG134740-dim_ramp-dim_read_light_1,Security access required,1
ENG133837-ENG142175-dim_ramp-dim_touch_actuation,Security access required,1
ENG153807-ENG155029-dim_ramp_light_module_2-dim_contact_switch_light_module_2,Security access required,1
ENG153807-ENG155030-dim_ramp_light_module_2-dim_in_light_0_light_module_2,Security access required,1
ENG153807-ENG155031-dim_ramp_light_module_2-dim_in_light_1_light_module_2,Security access required,1
ENG153807-ENG155033-dim_ramp_light_module_2-dim_read_light_0_light_module_2,Security access required,1
ENG153807-ENG155034-dim_ramp_light_module_2-dim_read_light_1_light_module_2,Security access required,1
ENG153807-ENG155035-dim_ramp_light_module_2-dim_touch_activation_light_module_2,Security access required,1
ENG133840-ENG134747-dim_read_light-dim_read_light_back,Security access required,1
ENG133840-ENG134746-dim_read_light-dim_read_light_front,Security access required,1
ENG133841-ENG134749-dim_read_light_ring-dim_light_ring_back,Security access required,1
ENG133841-ENG134748-dim_read_light_ring-dim_light_ring_front,Security access required,1
ENG153808-dim_rear_button,Security access required,1
ENG133839-ENG134745-dim_value_in_light-dim_in_light_back,Security access required,1
ENG133839-ENG134744-dim_value_in_light-dim_in_light_front,Security access required,1
ENG153809-dim_value_light_module_2,Security access required,1
ENG133847-ENG134768-displacement_compensation-evls_defect,Security access required,1
ENG133847-ENG134761-displacement_compensation-evls_fault,Security access required,1
ENG133847-ENG134762-displacement_compensation-hall_axial_fault,Security access required,1
ENG133847-ENG134763-displacement_compensation-hall_vertical_fault,Security access required,1
ENG133847-ENG134764-displacement_compensation-motor_axial_fault,Security access required,1
ENG133847-ENG134765-displacement_compensation-motor_vertical_fault,Security access required,1
ENG133847-ENG134769-displacement_compensation-number_halls,Security access required,1
ENG133847-ENG134767-displacement_compensation-scaling_status_fault,Security access required,1
ENG133847-ENG134766-displacement_compensation-switch_fault,Security access required,1
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,Security access required,1
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,Security access required,1
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,Security access required,1
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,Security access required,1
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,Security access required,1
ENG125594-ENG125682-Driver_failure_detection_multi-contour_seat-s_GrobleckerkennungDauer,Security access required,1
ENG125594-ENG125680-Driver_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,Security access required,1
ENG125594-ENG125681-Driver_failure_detection_multi-contour_seat-s_Leckageerkennung,Security access required,1
ENG125594-ENG125678-Driver_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,Security access required,1
ENG125594-ENG125679-Driver_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,Security access required,1
ENG125588-ENG125667-Driver_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125666-Driver_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125668-Driver_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125673-Driver_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125672-Driver_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125674-Driver_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125670-Driver_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125669-Driver_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125671-Driver_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125676-Driver_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125675-Driver_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125677-Driver_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125664-Driver_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125663-Driver_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125665-Driver_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125667-Driver_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125666-Driver_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125668-Driver_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125673-Driver_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125672-Driver_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125674-Driver_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125670-Driver_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125669-Driver_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125671-Driver_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125676-Driver_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125675-Driver_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125677-Driver_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125664-Driver_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125663-Driver_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125665-Driver_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125667-Driver_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125666-Driver_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125668-Driver_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125673-Driver_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125672-Driver_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125674-Driver_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125670-Driver_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125669-Driver_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125671-Driver_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125676-Driver_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125675-Driver_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125677-Driver_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125664-Driver_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125663-Driver_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125665-Driver_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125667-Driver_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125666-Driver_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125668-Driver_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125673-Driver_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125672-Driver_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125674-Driver_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125670-Driver_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125669-Driver_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125671-Driver_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125676-Driver_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125675-Driver_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125677-Driver_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125664-Driver_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125663-Driver_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125665-Driver_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125667-Driver_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125666-Driver_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125668-Driver_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125673-Driver_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125672-Driver_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125674-Driver_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125670-Driver_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125669-Driver_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125671-Driver_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125676-Driver_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125675-Driver_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125677-Driver_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125664-Driver_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125663-Driver_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125665-Driver_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125667-Driver_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125666-Driver_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125668-Driver_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125673-Driver_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125672-Driver_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125674-Driver_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125670-Driver_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125669-Driver_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125671-Driver_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125676-Driver_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125675-Driver_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125677-Driver_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125664-Driver_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125663-Driver_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125665-Driver_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125667-Driver_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125666-Driver_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125668-Driver_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125673-Driver_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125672-Driver_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125674-Driver_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125670-Driver_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125669-Driver_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125671-Driver_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125676-Driver_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125675-Driver_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125677-Driver_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125664-Driver_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125663-Driver_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125665-Driver_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125667-Driver_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125666-Driver_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125668-Driver_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125673-Driver_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125672-Driver_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125674-Driver_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125670-Driver_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125669-Driver_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125671-Driver_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125676-Driver_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125675-Driver_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125677-Driver_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125664-Driver_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125663-Driver_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125665-Driver_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125667-Driver_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125666-Driver_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125668-Driver_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125673-Driver_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125672-Driver_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125674-Driver_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125670-Driver_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125669-Driver_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125671-Driver_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125676-Driver_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125675-Driver_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125677-Driver_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125664-Driver_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125663-Driver_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125665-Driver_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG133363-ENG133471-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_LM,Security access required,1
ENG133363-ENG133470-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_LO,Security access required,1
ENG133363-ENG133472-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_LU,Security access required,1
ENG133363-ENG133473-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_SH,Security access required,1
ENG133363-ENG133475-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_LM,Security access required,1
ENG133363-ENG133474-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_LO,Security access required,1
ENG133363-ENG133476-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_LU,Security access required,1
ENG133363-ENG133477-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_SH,Security access required,1
ENG133363-ENG133483-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_LM,Security access required,1
ENG133363-ENG133482-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_LO,Security access required,1
ENG133363-ENG133484-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_LU,Security access required,1
ENG133363-ENG133485-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_SH,Security access required,1
ENG133363-ENG133486-Driver_multi-contour_seat_Alfmeier_1-Offset_PV2_LO,Security access required,1
ENG133363-ENG133488-Driver_multi-contour_seat_Alfmeier_1-Offset_PV2_LU,Security access required,1
ENG133363-ENG133489-Driver_multi-contour_seat_Alfmeier_1-Offset_PV2_SH,Security access required,1
ENG133363-ENG134733-Driver_multi-contour_seat_Alfmeier_1-OffsetPP1 3,Security access required,1
ENG133363-ENG134734-Driver_multi-contour_seat_Alfmeier_1-OffsetPP2 4,Security access required,1
ENG133363-ENG133487-Driver_multi-contour_seat_Alfmeier_1-OffsetPV2_LMy,Security access required,1
ENG133363-ENG133478-Driver_multi-contour_seat_Alfmeier_1-OffsetT1,Security access required,1
ENG133363-ENG134732-Driver_multi-contour_seat_Alfmeier_1-OffsetT2 2,Security access required,1
ENG133363-ENG133490-Driver_multi-contour_seat_Alfmeier_1-p_function_feedback_timeout,Security access required,1
ENG133363-ENG133491-Driver_multi-contour_seat_Alfmeier_1-p_longpush_time,Security access required,1
ENG133363-ENG133497-Driver_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_eins,Security access required,1
ENG133363-ENG133498-Driver_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_zwei,Security access required,1
ENG133363-ENG133494-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_drei,Security access required,1
ENG133363-ENG133492-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_eins,Security access required,1
ENG133363-ENG133496-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_fuenf,Security access required,1
ENG133363-ENG133495-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_vier,Security access required,1
ENG133363-ENG133493-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_zwei,Security access required,1
ENG133363-ENG133458-Driver_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Befuellen,Security access required,1
ENG133363-ENG133460-Driver_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Druckmessung,Security access required,1
ENG133363-ENG133459-Driver_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Entlueften,Security access required,1
ENG133363-ENG133469-Driver_multi-contour_seat_Alfmeier_1-s_Faktor_Druck_Entlueftung_Seitenhalt,Security access required,1
ENG133363-ENG133464-Driver_multi-contour_seat_Alfmeier_1-s_IntervallUmgebungsbedingungen,Security access required,1
ENG133363-ENG133465-Driver_multi-contour_seat_Alfmeier_1-s_MaxIntervall,Security access required,1
ENG133363-ENG133461-Driver_multi-contour_seat_Alfmeier_1-s_Messdauer_Initialisierung,Security access required,1
ENG133363-ENG133462-Driver_multi-contour_seat_Alfmeier_1-s_Messdauer_Kurzzeitmessung,Security access required,1
ENG133363-ENG133463-Driver_multi-contour_seat_Alfmeier_1-s_Messdauer_Langzeitmessung,Security access required,1
ENG133363-ENG133468-Driver_multi-contour_seat_Alfmeier_1-s_Sitzvariante,Security access required,1
ENG133363-ENG133467-Driver_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Linearbereich,Security access required,1
ENG133363-ENG133466-Driver_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Startbereich,Security access required,1
ENG133363-ENG133457-Driver_multi-contour_seat_Alfmeier_1-s_Uebernahmedruck_P_u,Security access required,1
ENG133363-ENG133456-Driver_multi-contour_seat_Alfmeier_1-s_Uebernahmedruck_PUe_o,Security access required,1
ENG125596-ENG125687-Driver_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,Security access required,1
ENG125596-ENG125689-Driver_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,Security access required,1
ENG125596-ENG125685-Driver_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,Security access required,1
ENG125596-ENG125688-Driver_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,Security access required,1
ENG125596-ENG125686-Driver_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,Security access required,1
ENG125595-ENG125684-Driver_pressure_values_multi-contour_seat_driver-s_DruckschwelleNachlauf,Security access required,1
ENG125595-ENG126855-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_m,Security access required,1
ENG125595-ENG126854-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_o,Security access required,1
ENG125595-ENG126856-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_u,Security access required,1
ENG125595-ENG126857-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Sitzlehnenwangen,Security access required,1
ENG125595-ENG126863-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Ueberlastschutz,Security access required,1
ENG125595-ENG126862-Driver_pressure_values_multi-contour_seat_driver-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,Security access required,1
ENG125595-ENG126859-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_m,Security access required,1
ENG125595-ENG126858-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_o,Security access required,1
ENG125595-ENG126860-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_u,Security access required,1
ENG125595-ENG126864-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_Massage,Security access required,1
ENG125595-ENG126861-Driver_pressure_values_multi-contour_seat_driver-s_MinimaldruckSitzlehnenwangen,Security access required,1
ENG125595-ENG125683-Driver_pressure_values_multi-contour_seat_driver-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,Security access required,1
ENG252014-ENG252049-Driver_seat_perso_1-Hoehe_Lordose_Perso,Security access required,1
ENG252014-ENG252081-Driver_seat_perso_1-Perso_Lehnenwangen,Security access required,1
ENG252014-ENG252087-Driver_seat_perso_1-Perso_letztes_Massageprogramm,Security access required,1
ENG252014-ENG252064-Driver_seat_perso_1-Perso_Massageintensitaet,Security access required,1
ENG252014-ENG252088-Driver_seat_perso_1-Weite_Lordose_Perso,Security access required,1
ENG252015-ENG252049-Driver_seat_perso_2-Hoehe_Lordose_Perso,Security access required,1
ENG252015-ENG252081-Driver_seat_perso_2-Perso_Lehnenwangen,Security access required,1
ENG252015-ENG252087-Driver_seat_perso_2-Perso_letztes_Massageprogramm,Security access required,1
ENG252015-ENG252064-Driver_seat_perso_2-Perso_Massageintensitaet,Security access required,1
ENG252015-ENG252088-Driver_seat_perso_2-Weite_Lordose_Perso,Security access required,1
ENG252016-ENG252049-Driver_seat_perso_3-Hoehe_Lordose_Perso,Security access required,1
ENG252016-ENG252081-Driver_seat_perso_3-Perso_Lehnenwangen,Security access required,1
ENG252016-ENG252087-Driver_seat_perso_3-Perso_letztes_Massageprogramm,Security access required,1
ENG252016-ENG252064-Driver_seat_perso_3-Perso_Massageintensitaet,Security access required,1
ENG252016-ENG252088-Driver_seat_perso_3-Weite_Lordose_Perso,Security access required,1
ENG252017-ENG252049-Driver_seat_perso_4-Hoehe_Lordose_Perso,Security access required,1
ENG252017-ENG252081-Driver_seat_perso_4-Perso_Lehnenwangen,Security access required,1
ENG252017-ENG252087-Driver_seat_perso_4-Perso_letztes_Massageprogramm,Security access required,1
ENG252017-ENG252064-Driver_seat_perso_4-Perso_Massageintensitaet,Security access required,1
ENG252017-ENG252088-Driver_seat_perso_4-Weite_Lordose_Perso,Security access required,1
ENG252018-ENG252049-Driver_seat_perso_5-Hoehe_Lordose_Perso,Security access required,1
ENG252018-ENG252081-Driver_seat_perso_5-Perso_Lehnenwangen,Security access required,1
ENG252018-ENG252087-Driver_seat_perso_5-Perso_letztes_Massageprogramm,Security access required,1
ENG252018-ENG252064-Driver_seat_perso_5-Perso_Massageintensitaet,Security access required,1
ENG252018-ENG252088-Driver_seat_perso_5-Weite_Lordose_Perso,Security access required,1
ENG252019-ENG252049-Driver_seat_perso_6-Hoehe_Lordose_Perso,Security access required,1
ENG252019-ENG252081-Driver_seat_perso_6-Perso_Lehnenwangen,Security access required,1
ENG252019-ENG252087-Driver_seat_perso_6-Perso_letztes_Massageprogramm,Security access required,1
ENG252019-ENG252064-Driver_seat_perso_6-Perso_Massageintensitaet,Security access required,1
ENG252019-ENG252088-Driver_seat_perso_6-Weite_Lordose_Perso,Security access required,1
ENG252020-ENG252049-Driver_seat_perso_7-Hoehe_Lordose_Perso,Security access required,1
ENG252020-ENG252081-Driver_seat_perso_7-Perso_Lehnenwangen,Security access required,1
ENG252020-ENG252087-Driver_seat_perso_7-Perso_letztes_Massageprogramm,Security access required,1
ENG252020-ENG252064-Driver_seat_perso_7-Perso_Massageintensitaet,Security access required,1
ENG252020-ENG252088-Driver_seat_perso_7-Weite_Lordose_Perso,Security access required,1
ENG128947-ENG128957-EC_indicator_dimming_curve_manipulation-Point_0_Bus_Value,Security access required,1
ENG128947-ENG128958-EC_indicator_dimming_curve_manipulation-Point_0_PWM_Value,Security access required,1
ENG128947-ENG128959-EC_indicator_dimming_curve_manipulation-Point_1_Bus_Value,Security access required,1
ENG128947-ENG128960-EC_indicator_dimming_curve_manipulation-Point_1_PWM_Value,Security access required,1
ENG128947-ENG128961-EC_indicator_dimming_curve_manipulation-Point_2_Bus_Value,Security access required,1
ENG128947-ENG128962-EC_indicator_dimming_curve_manipulation-Point_2_PWM_Value,Security access required,1
ENG128947-ENG128963-EC_indicator_dimming_curve_manipulation-Point_3_Bus_Value,Security access required,1
ENG128947-ENG128964-EC_indicator_dimming_curve_manipulation-Point_3_PWM_Value,Security access required,1
ENG128947-ENG128965-EC_indicator_dimming_curve_manipulation-Point_4_Bus_Value,Security access required,1
ENG128947-ENG128966-EC_indicator_dimming_curve_manipulation-Point_4_PWM_Value,Security access required,1
ENG128947-ENG128967-EC_indicator_dimming_curve_manipulation-Point_5_Bus_Value,Security access required,1
ENG128947-ENG128968-EC_indicator_dimming_curve_manipulation-Point_5_PWM_Value,Security access required,1
ENG133843-EC_interior_mirror_turn_down,Security access required,1
ENG131964-ENG133589-EntwID_activation-CapSense,Security access required,1
ENG131964-ENG133591-EntwID_activation-Clima-OBD,Security access required,1
ENG131964-ENG133588-EntwID_activation-Climate,Security access required,1
ENG131964-ENG98556-EntwID_activation-Display,Security access required,1
ENG131964-ENG133587-EntwID_activation-Flaps,Security access required,1
ENG131964-ENG133590-EntwID_activation-Massflow,Security access required,1
ENG131964-ENG116788-EntwID_activation-Potentiometer,Security access required,1
ENG131964-ENG98962-EntwID_activation-system,Security access required,1
ENG116833-Error Message,00 00 ,2
ENG133844-ENG134755-evls_ramp-break_ramp_axial,Security access required,2
ENG133844-ENG134756-evls_ramp-break_ramp_vertical,Security access required,2
ENG133844-ENG134753-evls_ramp-start_up_ramp_axail,Security access required,2
ENG133844-ENG134754-evls_ramp-start_up_ramp_vertical,Security access required,2
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,10 ,2
ENG153887-ENG154466-LIN_CAN_mirrow-LIN_1,Security access required,2
ENG153887-ENG155269-LIN_CAN_mirrow-LIN_10,Security access required,2
ENG153887-ENG155270-LIN_CAN_mirrow-LIN_11,Security access required,2
ENG153887-ENG155271-LIN_CAN_mirrow-LIN_12,Security access required,2
ENG153887-ENG154480-LIN_CAN_mirrow-LIN_2,Security access required,2
ENG153887-ENG154481-LIN_CAN_mirrow-LIN_3,Security access required,2
ENG153887-ENG154482-LIN_CAN_mirrow-LIN_4,Security access required,2
ENG153887-ENG154483-LIN_CAN_mirrow-LIN_5,Security access required,2
ENG153887-ENG154484-LIN_CAN_mirrow-LIN_6,Security access required,2
ENG153887-ENG155272-LIN_CAN_mirrow-LIN_7,Security access required,2
ENG153887-ENG155273-LIN_CAN_mirrow-LIN_8,Security access required,2
ENG153887-ENG155274-LIN_CAN_mirrow-LIN_9,Security access required,2
ENG115646-Loeschen Fehlerspeicher,Security access required,2
ENG153894-Matrix_read_light,Security access required,2
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,2
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,2
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,2
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,2
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,2
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,2
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,2
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,2
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,2
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,2
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,2
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,2
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,2
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,2
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,2
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,2
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,2
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,2
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,2
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,2
ENG133838-off_timer_inside_light,Security access required,2
ENG153906-off_timer_inside_light_light_module_2,Security access required,2
ENG153907-ENG155443-p_Allgemeine_Parameter-p_Fkt_Motorstart_enable,Security access required,2
ENG153907-ENG155514-p_Allgemeine_Parameter-p_t_Motorstart_reenable,Security access required,2
ENG153907-ENG155533-p_Allgemeine_Parameter-p_v_hood,Security access required,2
ENG153908-ENG155420-p_Bereich-p_DWP_v_Bereich_1,Security access required,2
ENG153908-ENG155421-p_Bereich-p_DWP_v_Bereich_2,Security access required,2
ENG153908-ENG155422-p_Bereich-p_DWP_v_Bereich_3,Security access required,2
ENG153908-ENG155538-p_Bereich-p_vfzg_Hysterese,Security access required,2
ENG153909-ENG155408-p_FKT_DWP-p_DWP_Fkt_Boost,Security access required,2
ENG153909-ENG155409-p_FKT_DWP-p_DWP_Fkt_EM,Security access required,2
ENG153909-ENG155410-p_FKT_DWP-p_DWP_Fkt_first_Cycle,Security access required,2
ENG153909-ENG155411-p_FKT_DWP-p_DWP_Fkt_LHZ_AUS,Security access required,2
ENG153909-ENG155412-p_FKT_DWP-p_DWP_Fkt_U_Komp,Security access required,2
ENG153909-ENG155442-p_FKT_DWP-p_Fkt_Door_open_active,Security access required,2
ENG153909-ENG155444-p_FKT_DWP-p_Fkt_SAD_open_active,Security access required,2
ENG153909-ENG155445-p_FKT_DWP-p_Fkt_Water_Warning_active,Security access required,2
ENG153910-ENG155447-p_Fkt_HZG-p_HZG_Fkt_EM,Security access required,2
ENG153910-ENG155448-p_Fkt_HZG-p_HZG_Fkt_GefTemp,Security access required,2
ENG153911-ENG155397-p_FSP_Mask-p_010616_U11FD00,Security access required,2
ENG153911-ENG155398-p_FSP_Mask-p_010620_B1921F1,Security access required,2
ENG153911-ENG155399-p_FSP_Mask-p_010623_U11FC00,Security access required,2
ENG153911-ENG155400-p_FSP_Mask-p_010624_B192004,Security access required,2
ENG153911-ENG155401-p_FSP_Mask-p_1_010617_B192111,Security access required,2
ENG153911-ENG155402-p_FSP_Mask-p_1_010621_B192211,Security access required,2
ENG153911-ENG155403-p_FSP_Mask-p_10619_B1921F0,Security access required,2
ENG153911-ENG155404-p_FSP_Mask-p_2_010618_B192115,Security access required,2
ENG153911-ENG155405-p_FSP_Mask-p_2_010622_B192215,Security access required,2
ENG153912-ENG155497-p_HZG_Ansteuerung-p_PWM_Derating_Nachlauf_HZG_Off,Security access required,2
ENG153912-ENG155499-p_HZG_Ansteuerung-p_PWM_MAX_HZG,Security access required,2
ENG153912-ENG155502-p_HZG_Ansteuerung-p_PWM_MIN_HZG,Security access required,2
ENG153912-ENG155515-p_HZG_Ansteuerung-p_t_Nachlauf_HZG_Off,Security access required,2
ENG153912-ENG155519-p_HZG_Ansteuerung-p_T_WTC_PWM_0_HZG,Security access required,2
ENG153912-ENG155520-p_HZG_Ansteuerung-p_T_WTC_PWM_100_HZG,Security access required,2
ENG153913-ENG155512-p_Modus_DWP-p_T_Modus_DWP,Security access required,2
ENG153913-ENG155513-p_Modus_DWP-p_T_Modus_Hysterese_DWP,Security access required,2
ENG153914-ENG155407-p_Parameter_1-p_delta_Pos_Boost,Security access required,2
ENG153914-ENG155454-p_Parameter_1-p_LIN_Variant_ID,Security access required,2
ENG153914-ENG155462-p_Parameter_1-p_pos_DWP_Ansteuerung_disable_LHZ,Security access required,2
ENG153914-ENG155507-p_Parameter_1-p_t_Boost,Security access required,2
ENG153914-ENG155528-p_Parameter_1-p_v_crank,Security access required,2
ENG153914-ENG155532-p_Parameter_1-p_v_Faktor_Boost,Security access required,2
ENG153914-ENG155534-p_Parameter_1-p_v_klemme_15_AUS,Security access required,2
ENG153914-ENG155535-p_Parameter_1-p_v_klemme_X_AUS,Security access required,2
ENG153914-ENG155536-p_Parameter_1-p_v_WWS_timeout,Security access required,2
ENG153914-ENG155537-p_Parameter_1-p_Version_Parameter,Security access required,2
ENG153915-ENG155413-p_Parameter_2-p_DWP_Hood_enable,Security access required,2
ENG153915-ENG155416-p_Parameter_2-p_DWP_ReversierSperrzeit,Security access required,2
ENG153915-ENG155417-p_Parameter_2-p_DWP_Stop_Delay,Security access required,2
ENG153915-ENG155418-p_Parameter_2-p_DWP_Stop_Position,Security access required,2
ENG153915-ENG155419-p_Parameter_2-p_DWP_U_Komp_UBatRef,Security access required,2
ENG153915-ENG155440-p_Parameter_2-p_Faktor_EM_DWP,Security access required,2
ENG153915-ENG155441-p_Parameter_2-p_Faktor_EM_Hzg,Security access required,2
ENG153915-ENG155446-p_Parameter_2-p_HeizungPwmFrequenz,Security access required,2
ENG153915-ENG155449-p_Parameter_2-p_Hzg_GefTemp_Par_ske,Security access required,2
ENG153915-ENG155450-p_Parameter_2-p_Hzg_GefTemp_Par_u,Security access required,2
ENG153915-ENG155451-p_Parameter_2-p_Hzg_GefTemp_Par_v,Security access required,2
ENG153915-ENG155452-p_Parameter_2-p_Hzg_GefTemp_Par_w,Security access required,2
ENG153915-ENG155453-p_Parameter_2-p_LDF_MLB_active,Security access required,2
ENG153915-ENG155496-p_Parameter_2-p_PumpePwmFrequenz,Security access required,2
ENG153915-ENG155511-p_Parameter_2-p_t_min_Aussetzzeit_DWP,Security access required,2
ENG153916-ENG155406-p_Parameter_Diag_1-p_Debug_Mux_Control,Security access required,2
ENG153916-ENG155423-p_Parameter_Diag_1-p_DWP_WWS_Timeout,Security access required,2
ENG153916-ENG155505-p_Parameter_Diag_1-p_Reset_nach_Parametrierung,Security access required,2
ENG153916-ENG155506-p_Parameter_Diag_1-p_SG_BusKnockout_Tmr,Security access required,2
ENG153916-ENG155517-p_Parameter_Diag_1-p_t_STGL_DWP_aktiv,Security access required,2
ENG153916-ENG155518-p_Parameter_Diag_1-p_t_UKlemme30_Entprellung,Security access required,2
ENG153916-ENG155523-p_Parameter_Diag_1-p_u_DWP_Ueberspannung_Off,Security access required,2
ENG153916-ENG155524-p_Parameter_Diag_1-p_u_DWP_Ueberspannung_On,Security access required,2
ENG153916-ENG155525-p_Parameter_Diag_1-p_u_DWP_Unterspannung_Off,Security access required,2
ENG153916-ENG155526-p_Parameter_Diag_1-p_u_DWP_Unterspannung_On,Security access required,2
ENG153916-ENG155530-p_Parameter_Diag_1-p_v_DWP_Ueberspannung,Security access required,2
ENG153916-ENG155531-p_Parameter_Diag_1-p_v_DWP_Unterspannung,Security access required,2
ENG153917-ENG155425-p_Parameter_Diag_2-p_ED_Hzg_KS_n_max,Security access required,2
ENG153917-ENG155426-p_Parameter_Diag_2-p_ED_HZG_KS_Ubat_Offline,Security access required,2
ENG153917-ENG155427-p_Parameter_Diag_2-p_ED_HZG_OpenLoad_Offline,Security access required,2
ENG153917-ENG155428-p_Parameter_Diag_2-p_ED_HZG_R_Einzeldraht_Abriss,Security access required,2
ENG153917-ENG155429-p_Parameter_Diag_2-p_ED_Imax_HighSide_Hzg,Security access required,2
ENG153917-ENG155430-p_Parameter_Diag_2-p_ED_Imax_HighSide_WP,Security access required,2
ENG153917-ENG155431-p_Parameter_Diag_2-p_ED_Imax_HighSide_WP_u_Hzg,Security access required,2
ENG153917-ENG155432-p_Parameter_Diag_2-p_ED_WP_KS_GND_Offline,Security access required,2
ENG153917-ENG155433-p_Parameter_Diag_2-p_ED_WP_KS_n_max,Security access required,2
ENG153917-ENG155434-p_Parameter_Diag_2-p_ED_WP_KS_Ubat_Offline,Security access required,2
ENG153917-ENG155435-p_Parameter_Diag_2-p_ED_WP_LS_Block,Security access required,2
ENG153917-ENG155436-p_Parameter_Diag_2-p_ED_WP_LS_Kurzschluss,Security access required,2
ENG153917-ENG155437-p_Parameter_Diag_2-p_ED_WP_LS_Ueberlast,Security access required,2
ENG153917-ENG155438-p_Parameter_Diag_2-p_ED_WP_OpenLoad_Offline,Security access required,2
ENG153917-ENG155439-p_Parameter_Diag_2-p_EigenDiag_Aktiv,Security access required,2
ENG153917-ENG155503-p_Parameter_Diag_2-p_Reserve_1,Security access required,2
ENG153917-ENG155504-p_Parameter_Diag_2-p_Reserve_2,Security access required,2
ENG153917-ENG155508-p_Parameter_Diag_2-p_T_Derating,Security access required,2
ENG153917-ENG155516-p_Parameter_Diag_2-p_t_Quali_Tiefspannung,Security access required,2
ENG153917-ENG155521-p_Parameter_Diag_2-p_TreiberUebertemperatur_Freigabe,Security access required,2
ENG153917-ENG155522-p_Parameter_Diag_2-p_TreiberUebertemperatur_Sperre,Security access required,2
ENG153917-ENG155527-p_Parameter_Diag_2-p_u_Tiefspannung,Security access required,2
ENG153918-ENG155424-p_Parameter_MWP-p_dyn_waschen_aktiv,Security access required,2
ENG153918-ENG155455-p_Parameter_MWP-p_MWP_v_Bereich_1,Security access required,2
ENG153918-ENG155456-p_Parameter_MWP-p_MWP_v_Bereich_2,Security access required,2
ENG153918-ENG155457-p_Parameter_MWP-p_MWP_v_Bereich_3,Security access required,2
ENG153918-ENG155458-p_Parameter_MWP-p_MWP_v_Bereich_4,Security access required,2
ENG153918-ENG155459-p_Parameter_MWP-p_MWP_v_Bereich_5,Security access required,2
ENG153918-ENG155539-p_Parameter_MWP-p_waschen_Dach_PWM_1,Security access required,2
ENG153918-ENG155540-p_Parameter_MWP-p_waschen_Dach_PWM_2,Security access required,2
ENG153918-ENG155541-p_Parameter_MWP-p_waschen_Dach_PWM_3,Security access required,2
ENG153918-ENG155542-p_Parameter_MWP-p_waschen_Dach_PWM_4,Security access required,2
ENG153918-ENG155543-p_Parameter_MWP-p_waschen_Dach_PWM_5,Security access required,2
ENG153918-ENG155544-p_Parameter_MWP-p_waschen_Dach_PWM_6,Security access required,2
ENG153918-ENG155545-p_Parameter_MWP-p_waschen_Offset_Temp,Security access required,2
ENG153918-ENG155546-p_Parameter_MWP-p_waschen_PWM_V_1,Security access required,2
ENG153918-ENG155547-p_Parameter_MWP-p_waschen_PWM_V_2,Security access required,2
ENG153918-ENG155548-p_Parameter_MWP-p_waschen_PWM_V_3,Security access required,2
ENG153918-ENG155549-p_Parameter_MWP-p_waschen_PWM_V_4,Security access required,2
ENG153918-ENG155550-p_Parameter_MWP-p_waschen_PWM_V_5,Security access required,2
ENG153918-ENG155551-p_Parameter_MWP-p_waschen_PWM_V_6,Security access required,2
ENG153918-ENG155552-p_Parameter_MWP-p_waschen_rampenzeit,Security access required,2
ENG153918-ENG155553-p_Parameter_MWP-p_waschen_Temp_PWM_1,Security access required,2
ENG153918-ENG155554-p_Parameter_MWP-p_waschen_Temp_PWM_2,Security access required,2
ENG153918-ENG155555-p_Parameter_MWP-p_waschen_Temp_PWM_3,Security access required,2
ENG153918-ENG155556-p_Parameter_MWP-p_waschen_Temp_PWM_4,Security access required,2
ENG153918-ENG155557-p_Parameter_MWP-p_waschen_Temp_PWM_5,Security access required,2
ENG153918-ENG155558-p_Parameter_MWP-p_waschen_Temp_PWM_6,Security access required,2
ENG153918-ENG155559-p_Parameter_MWP-p_waschen_zeit_rampestart,Security access required,2
ENG153919-ENG155463-p_Profile_Curve-p_Profile_Angel_pos_1,Security access required,2
ENG153919-ENG155464-p_Profile_Curve-p_Profile_Angel_pos_10,Security access required,2
ENG153919-ENG155465-p_Profile_Curve-p_Profile_Angel_pos_11,Security access required,2
ENG153919-ENG155466-p_Profile_Curve-p_Profile_Angel_pos_12,Security access required,2
ENG153919-ENG155467-p_Profile_Curve-p_Profile_Angel_pos_13,Security access required,2
ENG153919-ENG155468-p_Profile_Curve-p_Profile_Angel_pos_14,Security access required,2
ENG153919-ENG155469-p_Profile_Curve-p_Profile_Angel_pos_15,Security access required,2
ENG153919-ENG155470-p_Profile_Curve-p_Profile_Angel_pos_16,Security access required,2
ENG153919-ENG155471-p_Profile_Curve-p_Profile_Angel_pos_2,Security access required,2
ENG153919-ENG155472-p_Profile_Curve-p_Profile_Angel_pos_3,Security access required,2
ENG153919-ENG155473-p_Profile_Curve-p_Profile_Angel_pos_4,Security access required,2
ENG153919-ENG155474-p_Profile_Curve-p_Profile_Angel_pos_5,Security access required,2
ENG153919-ENG155475-p_Profile_Curve-p_Profile_Angel_pos_6,Security access required,2
ENG153919-ENG155476-p_Profile_Curve-p_Profile_Angel_pos_7,Security access required,2
ENG153919-ENG155477-p_Profile_Curve-p_Profile_Angel_pos_8,Security access required,2
ENG153919-ENG155478-p_Profile_Curve-p_Profile_Angel_pos_9,Security access required,2
ENG153919-ENG155479-p_Profile_Curve-p_Profile_Curve_Index,Security access required,2
ENG153919-ENG155480-p_Profile_Curve-p_Profile_PWM_pos_1,Security access required,2
ENG153919-ENG155481-p_Profile_Curve-p_Profile_PWM_pos_10,Security access required,2
ENG153919-ENG155482-p_Profile_Curve-p_Profile_PWM_pos_11,Security access required,2
ENG153919-ENG155483-p_Profile_Curve-p_Profile_PWM_pos_12,Security access required,2
ENG153919-ENG155484-p_Profile_Curve-p_Profile_PWM_pos_13,Security access required,2
ENG153919-ENG155485-p_Profile_Curve-p_Profile_PWM_pos_14,Security access required,2
ENG153919-ENG155486-p_Profile_Curve-p_Profile_PWM_pos_15,Security access required,2
ENG153919-ENG155487-p_Profile_Curve-p_Profile_PWM_pos_16,Security access required,2
ENG153919-ENG155488-p_Profile_Curve-p_Profile_PWM_pos_2,Security access required,2
ENG153919-ENG155489-p_Profile_Curve-p_Profile_PWM_pos_3,Security access required,2
ENG153919-ENG155490-p_Profile_Curve-p_Profile_PWM_pos_4,Security access required,2
ENG153919-ENG155491-p_Profile_Curve-p_Profile_PWM_pos_5,Security access required,2
ENG153919-ENG155492-p_Profile_Curve-p_Profile_PWM_pos_6,Security access required,2
ENG153919-ENG155493-p_Profile_Curve-p_Profile_PWM_pos_7,Security access required,2
ENG153919-ENG155494-p_Profile_Curve-p_Profile_PWM_pos_8,Security access required,2
ENG153919-ENG155495-p_Profile_Curve-p_Profile_PWM_pos_9,Security access required,2
ENG153920-ENG155414-p_Pumpenansteuerung-p_DWP_PWM_Vorlauf_Sommer,Security access required,2
ENG153920-ENG155415-p_Pumpenansteuerung-p_DWP_PWM_Vorlauf_Winter,Security access required,2
ENG153920-ENG155460-p_Pumpenansteuerung-p_n_max_Waschzyklen,Security access required,2
ENG153920-ENG155461-p_Pumpenansteuerung-p_n_min_Waschzyklen,Security access required,2
ENG153920-ENG155498-p_Pumpenansteuerung-p_PWM_MAX_DWP,Security access required,2
ENG153920-ENG155501-p_Pumpenansteuerung-p_PWM_MIN_DWP,Security access required,2
ENG153920-ENG155509-p_Pumpenansteuerung-p_t_DWP_delay,Security access required,2
ENG153920-ENG155510-p_Pumpenansteuerung-p_t_max_Vorlauf,Security access required,2
ENG153920-ENG155529-p_Pumpenansteuerung-p_v_DWP_delay,Security access required,2
ENG153921-p_WaschWarnung,Security access required,2
ENG133842-ENG134750-pao_chamber-pao_chamber_1,Security access required,2
ENG133842-ENG134751-pao_chamber-pao_chamber_2,Security access required,2
ENG133842-ENG134752-pao_chamber-pao_chamber_3,Security access required,2
ENG125607-ENG126865-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,Security access required,2
ENG125607-ENG126867-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,Security access required,2
ENG125607-ENG126866-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,Security access required,2
ENG125607-ENG126868-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,Security access required,2
ENG125607-ENG125690-Passenger_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,Security access required,2
ENG125608-Passenger_detection_multi-contour_seat,Security access required,2
ENG125604-ENG125693-Passenger_failure_detection_multi-contour_seat-s_DauerFuerGrobleckerkennung,Security access required,2
ENG125604-ENG125680-Passenger_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,Security access required,2
ENG125604-ENG125681-Passenger_failure_detection_multi-contour_seat-s_Leckageerkennung,Security access required,2
ENG125604-ENG125678-Passenger_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,Security access required,2
ENG125604-ENG125679-Passenger_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,Security access required,2
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,Security access required,2
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,Security access required,2
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125667-Passenger_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125666-Passenger_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125668-Passenger_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125673-Passenger_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125672-Passenger_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125674-Passenger_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125670-Passenger_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125669-Passenger_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125671-Passenger_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125676-Passenger_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125675-Passenger_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125677-Passenger_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125664-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125663-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125665-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125667-Passenger_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125666-Passenger_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125668-Passenger_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125673-Passenger_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125672-Passenger_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125674-Passenger_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125670-Passenger_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125669-Passenger_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125671-Passenger_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125676-Passenger_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125675-Passenger_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125677-Passenger_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125664-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125663-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125665-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125667-Passenger_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125666-Passenger_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125668-Passenger_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125673-Passenger_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125672-Passenger_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125674-Passenger_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125670-Passenger_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125669-Passenger_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125671-Passenger_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125676-Passenger_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125675-Passenger_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125677-Passenger_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125664-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125663-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125665-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125667-Passenger_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125666-Passenger_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125668-Passenger_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125673-Passenger_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125672-Passenger_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125674-Passenger_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125670-Passenger_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125669-Passenger_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125671-Passenger_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125676-Passenger_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125675-Passenger_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125677-Passenger_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125664-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125663-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125665-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG133366-ENG133471-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB1_LM,Security access required,2
ENG133366-ENG133472-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB1_LU,Security access required,2
ENG133366-ENG133473-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB1_SH,Security access required,2
ENG133366-ENG133475-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_LM,Security access required,2
ENG133366-ENG133474-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_LO,Security access required,2
ENG133366-ENG133476-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_LU,Security access required,2
ENG133366-ENG133477-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_SH,Security access required,2
ENG133366-ENG133483-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_LM,Security access required,2
ENG133366-ENG133482-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_LO,Security access required,2
ENG133366-ENG133484-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_LU,Security access required,2
ENG133366-ENG133485-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_SH,Security access required,2
ENG133366-ENG133486-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV2_LO,Security access required,2
ENG133366-ENG133488-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV2_LU,Security access required,2
ENG133366-ENG133489-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV2_SH,Security access required,2
ENG133366-ENG133534-Passenger_multi-contour_seat_Alfmeier_1-OffsetPB1_LO,Security access required,2
ENG133366-ENG134733-Passenger_multi-contour_seat_Alfmeier_1-OffsetPP1 3,Security access required,2
ENG133366-ENG134734-Passenger_multi-contour_seat_Alfmeier_1-OffsetPP2 4,Security access required,2
ENG133366-ENG133487-Passenger_multi-contour_seat_Alfmeier_1-OffsetPV2_LMy,Security access required,2
ENG133366-ENG133478-Passenger_multi-contour_seat_Alfmeier_1-OffsetT1,Security access required,2
ENG133366-ENG134732-Passenger_multi-contour_seat_Alfmeier_1-OffsetT2 2,Security access required,2
ENG133366-ENG133490-Passenger_multi-contour_seat_Alfmeier_1-p_function_feedback_timeout,Security access required,2
ENG133366-ENG133491-Passenger_multi-contour_seat_Alfmeier_1-p_longpush_time,Security access required,2
ENG133366-ENG133497-Passenger_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_eins,Security access required,2
ENG133366-ENG133498-Passenger_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_zwei,Security access required,2
ENG133366-ENG133494-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_drei,Security access required,2
ENG133366-ENG133492-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_eins,Security access required,2
ENG133366-ENG133496-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_fuenf,Security access required,2
ENG133366-ENG133495-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_vier,Security access required,2
ENG133366-ENG133493-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_zwei,Security access required,2
ENG133366-ENG133458-Passenger_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Befuellen,Security access required,2
ENG133366-ENG133460-Passenger_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Druckmessung,Security access required,2
ENG133366-ENG133459-Passenger_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Entlueften,Security access required,2
ENG133366-ENG133469-Passenger_multi-contour_seat_Alfmeier_1-s_Faktor_Druck_Entlueftung_Seitenhalt,Security access required,2
ENG133366-ENG133464-Passenger_multi-contour_seat_Alfmeier_1-s_IntervallUmgebungsbedingungen,Security access required,2
ENG133366-ENG133465-Passenger_multi-contour_seat_Alfmeier_1-s_MaxIntervall,Security access required,2
ENG133366-ENG133461-Passenger_multi-contour_seat_Alfmeier_1-s_Messdauer_Initialisierung,Security access required,2
ENG133366-ENG133462-Passenger_multi-contour_seat_Alfmeier_1-s_Messdauer_Kurzzeitmessung,Security access required,2
ENG133366-ENG133463-Passenger_multi-contour_seat_Alfmeier_1-s_Messdauer_Langzeitmessung,Security access required,2
ENG133366-ENG133468-Passenger_multi-contour_seat_Alfmeier_1-s_Sitzvariante,Security access required,2
ENG133366-ENG133467-Passenger_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Linearbereich,Security access required,2
ENG133366-ENG133466-Passenger_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Startbereich,Security access required,2
ENG133366-ENG133532-Passenger_multi-contour_seat_Alfmeier_1-s_Uebernahmedruck_PUe_u,Security access required,2
ENG133366-ENG133533-Passenger_multi-contour_seat_Alfmeier_1-s_UebernahmedruckP_u,Security access required,2
ENG125606-ENG125687-Passenger_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,Security access required,2
ENG125606-ENG125689-Passenger_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,Security access required,2
ENG125606-ENG125685-Passenger_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,Security access required,2
ENG125606-ENG125688-Passenger_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,Security access required,2
ENG125606-ENG125686-Passenger_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,Security access required,2
ENG125605-ENG126871-Passenger_pressure_values_multi-contour_seat-s_Druckschwelle_Nachlauf,Security access required,2
ENG125605-ENG126855-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_m,Security access required,2
ENG125605-ENG126854-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_o,Security access required,2
ENG125605-ENG126856-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_u,Security access required,2
ENG125605-ENG126857-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Sitzlehnenwangen,Security access required,2
ENG125605-ENG126863-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Ueberlastschutz,Security access required,2
ENG125605-ENG126870-Passenger_pressure_values_multi-contour_seat-s_Maximaler_Differenzdruck_LRD_VorZurueck,Security access required,2
ENG125605-ENG126859-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_m,Security access required,2
ENG125605-ENG126858-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_o,Security access required,2
ENG125605-ENG126860-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_u,Security access required,2
ENG125605-ENG126864-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Massage,Security access required,2
ENG125605-ENG126869-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Sitzlehnenwangen,Security access required,2
ENG125605-ENG125683-Passenger_pressure_values_multi-contour_seat-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,Security access required,2
ENG133835-PLA_Dev_Msg,Security access required,2
ENG133834-ENG134724-PLA_New_Functions-StatusNewFunction1,Security access required,2
ENG133834-ENG134725-PLA_New_Functions-StatusNewFunction2 2,Security access required,2
ENG133834-ENG134726-PLA_New_Functions-StatusNewFunction3 3,Security access required,2
ENG133834-ENG134727-PLA_New_Functions-StatusNewFunction4 4,Security access required,2
ENG133834-ENG134728-PLA_New_Functions-StatusNewFunction5 5,Security access required,2
ENG133834-ENG134729-PLA_New_Functions-StatusNewFunction6 6,Security access required,2
ENG133834-ENG134730-PLA_New_Functions-StatusNewFunction7 7,Security access required,2
ENG133834-ENG134806-PLA_New_Functions-StatusNewFunction8 8,Security access required,2
ENG153928-PMS_CL_Adresse,Security access required,2
ENG118121-ENG100673-Rear_Lid_Assistance_Adaption-corner_boundary_offset,Security access required,2
ENG118121-ENG99594-Rear_Lid_Assistance_Adaption-monitored_area,Security access required,2
ENG118121-ENG98988-Rear_Lid_Assistance_Adaption-Timer,Security access required,2
ENG133845-ENG134759-regulator_parameter-ki_axial,Security access required,2
ENG133845-ENG134760-regulator_parameter-ki_vertical,Security access required,2
ENG133845-ENG134757-regulator_parameter-kp_axial,Security access required,2
ENG133845-ENG134758-regulator_parameter-kp_vertical,Security access required,2
ENG125614-Reset_Blower_1_Backrest_Left,Security access required,2
ENG153935-Reset_Blower_1_Backrest_Left_fond,Security access required,2
ENG125615-Reset_Blower_1_Backrest_Right,Security access required,2
ENG153936-Reset_Blower_1_Backrest_Right_fond,Security access required,2
ENG125613-Reset_Blower_1_Cushion_Left,Security access required,2
ENG153937-Reset_Blower_1_Cushion_Left_fond,Security access required,2
ENG125616-Reset_Blower_1_Cushion_Right,Security access required,2
ENG153938-Reset_Blower_1_Cushion_Right_fond,Security access required,2
ENG125623-Reset_Blower_2_Backrest_Left,Security access required,2
ENG153939-Reset_Blower_2_Backrest_Left_fond,Security access required,2
ENG125624-Reset_Blower_2_Backrest_Right,Security access required,2
ENG153940-Reset_Blower_2_Backrest_Right_fond,Security access required,2
ENG125621-Reset_Blower_2_Cushion_Left,Security access required,2
ENG153941-Reset_Blower_2_Cushion_Left_fond,Security access required,2
ENG125622-Reset_Blower_2_Cushion_Right,Security access required,2
ENG153942-Reset_Blower_2_Cushion_Right_fond,Security access required,2
ENG122927-RLS_close_glazing,Security access required,2
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,Security access required,2
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,Security access required,2
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,Security access required,2
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,Security access required,2
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,Security access required,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,Security access required,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,Security access required,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,Security access required,2
ENG122929-RLS_LIN_Communication,Security access required,2
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,Security access required,2
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,Security access required,2
ENG122930-RLS_tunel_gateway_recognize,Security access required,2
ENG122935-RLS_Washer_Front,Security access required,2
ENG122926-RLS_wiper_position_parking,Security access required,2
ENG108935-Set_PLA_Activate_Brake_Function_Development,Security access required,2
ENG108937-Set_PLA_WPCA_Min_Change_Limit_Development,Security access required,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
ENG153972-SuFK_developement_massages,Security access required,4
ENG116832-ENG116697-Wischgeschwindigkeiten-Dauerwischen_Stufe 1 Zyklen_pro_ Minute,Security access required,4
ENG116832-ENG116698-Wischgeschwindigkeiten-Dauerwischen_Stufe 2 Zyklen_pro_Minute,Security access required,4
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,Security access required,4
Elapsed Time: 02:03
;SW:8W0-907-468-F   HW:8W0-907-468 ---  19: CAN Gateway
;Component:Gateway       H04 0613, Coding:030100010000064029070000005900124C180007100000000100008E00000000
;EV_Gatew31xAU65x,003250,EV_Gatew31xAU65x_AU49.rod
;Saturday,18,April,2026,17:46:23:01662
;VCDS Version: 26.3.0.0 (x64)  Data version: 20260320 DS375.1
;VCID: 47CCB87E0F2D93D24E9-8012
IDE00001-IDE00332-Production mode-Buttons for multi-function steering wheel,Deactivating ,3
IDE00001-IDE10279-Production mode-Onboard data collector,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS11109-Production mode-Wireless network connection,Deactivating ,3
IDE00002-Transport mode,not activated ,1
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE01996-IDE14867-Installation list: specified installations-Subgateway as firewall control module,Not coded ,32
IDE01996-IDE15844-Installation list: specified installations-Fuel cell drive control module,Not coded ,32
IDE01996-MAS00796-Installation list: specified installations-Engine/Motor Control Module,coded ,32
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00007-Installation list: specified installations-Display/control head,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-HVAC electronics,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00012-Installation list: specified installations-Rear Axle Steering 2,Not coded ,32
IDE01996-SFT00017-Installation list: specified installations-Engine electronics 2,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,coded ,32
IDE01996-SFT00027-Installation list: specified installations-Active Steering,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00039-Installation list: specified installations-Display/operating unit rear,Not coded ,32
IDE01996-SFT00040-Installation list: specified installations-Rear A/C control head,Not coded ,32
IDE01996-SFT00042-Installation list: specified installations-Control module for inductive charging,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32
IDE01996-SFT00067-Installation list: specified installations-Brake Electronics 2,Not coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00070-Installation list: specified installations-Convenience system central module,coded ,32
IDE01996-SFT00070-Installation list: specified installations-Convenience system central module,Not coded ,32
IDE01996-SFT00072-Installation list: specified installations-Seat adjustment: rear driver's side,Not coded ,32
IDE01996-SFT00080-Installation list: specified installations-Seat adjustment 3rd seat row,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32
IDE01996-SFT00090-Installation list: specified installations-Automated longitudinal control,Not coded ,32
IDE01996-SFT00091-Installation list: specified installations-Seat adjustment: rear passenger's side,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32
IDE01996-SFT00107-Installation list: specified installations-Aerodynamic control module,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,Not coded ,32
IDE01996-SFT00113-Installation list: specified installations-Battery Charger,Not coded ,32
IDE01996-SFT00116-Installation list: specified installations-Chassis Control,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32
IDE01996-SFT00129-Installation list: specified installations-Shift lever,coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00132-Installation list: specified installations-Night vision system,Not coded ,32
IDE01996-SFT00139-Installation list: specified installations-Distance regulation 2,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for driver assistance systems,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for driver assistance systems,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32
IDE01996-SFT00172-Installation list: specified installations-Reducing Agent Metering System,Not coded ,32
IDE01996-SFT00186-Installation list: specified installations-Subframe mount,Not coded ,32
IDE01996-SFT00195-Installation list: specified installations-Electric drive 3,Not coded ,32
IDE01996-SFT00196-Installation list: specified installations-Voltage converter,Not coded ,32
IDE01996-SFT00203-Installation list: specified installations-Rear Axle Steering,Not coded ,32
IDE01996-SFT00205-Installation list: specified installations-Laser for adaptive cruise control,Not coded ,32
IDE01996-SFT00206-Installation list: specified installations-Electric drive 2,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistance 2,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistance 2,coded ,32
IDE01996-SFT00208-Installation list: specified installations-Front Axle Lift System,Not coded ,32
IDE01996-SFT00219-Installation list: specified installations-Front Corner Radar 1,Not coded ,32
IDE01996-SFT00220-Installation list: specified installations-Front Corner Radar 2,Not coded ,32
IDE01996-SFT00221-Installation list: specified installations-Sunroof control module 2,Not coded ,32
IDE01996-SFT33028-Installation list: specified installations-High voltage converter,Not coded ,32
IDE01996-SFT33031-Installation list: specified installations-Antenna module,Not coded ,32
IDE01996-SFT33032-Installation list: specified installations-Control unit for hood ornament,Not coded ,32
IDE01996-SFT33041-Installation list: specified installations-Right exterior rear view mirror,Not coded ,32
IDE01996-SFT33042-Installation list: specified installations-Left exterior rear view mirror,Not coded ,32
IDE01996-SFT33043-Installation list: specified installations-HV battery charging unit 2,Not coded ,32
IDE01996-SFT33044-Installation list: specified installations-High voltage converter 2,Not coded ,32
IDE01996-SFT33045-Installation list: specified installations-Remote Multifunction Module,Not coded ,32
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,Not coded ,32
IDE01996-SFT271904-Installation list: specified installations-Sunroof control module,coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,75 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,die ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 00 00 00 00 ,6
IDE04159-Deactivation of start/stop function,regular operation ,1
IDE06748-Break recommendation,activated ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,10.20 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,40.10 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,100 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,10 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,990 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,24 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,23.10 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,23.10 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,23.10 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,23.10 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,23.10 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,23.10 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),24.10 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,10.30 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,23.30 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,23.10 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,6.10 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,10.20 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,10.20 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,10.20 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,10.20 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,10.20 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,10.20 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,10.20 l/100km,48
IDE10351-MAS05767-Message mirroring-port,00 00 ,21
IDE10351-MAS09111-Message mirroring-IP address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,21
IDE10351-MAS10445-Message mirroring-Data bus CAN 1,not active ,21
IDE10351-MAS10446-Message mirroring-Data bus CAN 2,not active ,21
IDE10351-MAS10447-Message mirroring-Data bus CAN 3,not active ,21
IDE10351-MAS10448-Message mirroring-Data bus CAN 4,not active ,21
IDE10351-MAS10449-Message mirroring-Data bus CAN 5,not active ,21
IDE10351-MAS10450-Message mirroring-Data bus CAN 6,not active ,21
IDE10351-MAS10451-Message mirroring-Data bus Flexray A,not active ,21
IDE10351-MAS10452-Message mirroring-Data bus LIN 1,not active ,21
IDE10351-MAS10453-Message mirroring-Data bus LIN 2,not active ,21
IDE10351-MAS10454-Message mirroring-Data bus LIN 3,not active ,21
IDE10351-MAS10460-Message mirroring-Target bus,not active ,21
IDE10351-MAS11107-Message mirroring-Data bus CAN 7,not active ,21
IDE10351-MAS13143-Message mirroring-FlexRay B data bus,not active ,21
IDE10351-MAS17841-Message mirroring-Data bus CAN 8,not active ,21
IDE10400-High-voltage system: locking,regular operation ,1
IDE11688-IDE08958-Autonomous operation request-H-V system: start request,regular operation ,3
IDE11688-MAS08040-Autonomous operation request-Automatic recharging of starter battery,regular operation ,3
IDE11688-MAS13088-Autonomous operation request-Preconditioning of the interior,regular operation ,3
IDE11689-48V-System: locking,regular operation ,1
IDE14111-MAS02165-Routing groups-Group 1,activated ,2
IDE14111-MAS02166-Routing groups-Group 2,not activated ,2
IDE14111-MAS05859-Routing groups-Group 3,not activated ,2
IDE14111-MAS05860-Routing groups-Group 4,not activated ,2
IDE14111-MAS05861-Routing groups-Group 5,not activated ,2
IDE14111-MAS05862-Routing groups-Group 6,not activated ,2
IDE14111-MAS05863-Routing groups-Group 7,not activated ,2
IDE14111-MAS05864-Routing groups-Group 8,not activated ,2
IDE14111-MAS17847-Routing groups-Group 9,not activated ,2
IDE14111-MAS17848-Routing groups-Group 10,not activated ,2
IDE14111-MAS17849-Routing groups-Group 11,not activated ,2
IDE14111-MAS17850-Routing groups-Group 12,not activated ,2
IDE14111-MAS17851-Routing groups-Group 13,not activated ,2
IDE14111-MAS17852-Routing groups-Group 14,not activated ,2
IDE14111-MAS17853-Routing groups-Group 15,not activated ,2
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,12.10 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,12.10 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,12.10 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,12.10 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,12.10 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,12.10 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,12.10 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,12.10 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,12.10 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,12.10 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,12.10 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,12.10 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,12.10 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,12.10 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,12.10 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,12.10 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,12.10 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,12.10 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,12.10 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,12.10 kWh/100 km,40
IDE14168-Energy management additional components,00 00 00 00 00 00 00 00 ,8
IDE14222-Test number length: authentic time,16 B,1
IDE14223-Authentic time maximum deviation,5 min,1
IDE15326-IDE06096-BAP display control module coding-Interior lights,not installed ,32
IDE15326-IDE15327-BAP display control module coding-Exterior lighting,installed ,32
IDE15326-IDE15334-BAP display control module coding-Wiper convenience,installed ,32
IDE15326-IDE15373-BAP display control module coding-Exterior rearview mirror setting,not installed ,32
IDE15326-IDE15374-BAP display control module coding-Driver seat setting,installed ,32
IDE15326-IDE15375-BAP display control module coding-Adjustment of units,not installed ,32
IDE15326-IDE15376-BAP display control module coding-Pneumatic driver seat,not installed ,32
IDE15326-IDE15377-BAP display control module coding-Connection manager setting,not installed ,32
IDE15326-IDE15378-BAP display control module coding-Setting display,not installed ,32
IDE15326-IDE15379-BAP display control module coding-Virtual exterior rearview mirror,not installed ,32
IDE15326-IDE15380-BAP display control module coding-Door: driver setting,not installed ,32
IDE15326-IDE15381-BAP display control module coding-Door: front passenger setting,not installed ,32
IDE15326-MAS03420-BAP display control module coding-Head-Up-Display,not installed ,32
IDE16534-MAS25727-Local hazard alert: transmitter-Local hazard alert: traction loss,Write only channel ,0
IDE16534-MAS25728-Local hazard alert: transmitter-Local hazard alert: hazard lights,Write only channel ,0
IDE16534-MAS25729-Local hazard alert: transmitter-Local hazard alert: stability control active,Write only channel ,0
IDE16534-MAS25730-Local hazard alert: transmitter-Local hazard alert: heavy braking,Write only channel ,0
IDE16534-MAS25731-Local hazard alert: transmitter-Local hazard alert: tire pressure loss,Write only channel ,0
IDE16534-MAS25732-Local hazard alert: transmitter-Local hazard alert: breakdown,Write only channel ,0
IDE16534-MAS25733-Local hazard alert: transmitter-Local hazard alert: airbag deployment,Write only channel ,0
IDE16534-MAS25734-Local hazard alert: transmitter-Local hazard alert: ABS active,Write only channel ,2
ENG137256-Adaption_high_voltage_zero_potential,regular operation ,1
ENG153814-download_eem,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,256
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,13
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,120 ,13
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,13
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,13
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,13
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,13
ENG118777-ENG136172-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Number_of_Keys,1 ,13
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,13
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,500 ms,13
ENG118777-ENG136168-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_1,800 ms,13
ENG118777-ENG136169-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_2,1000 ms,13
ENG118777-ENG136170-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_3,0 ms,13
ENG118777-ENG136171-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation_4,0 ms,13
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,6000 ms,13
ENG135872-EM_inside_fan_reduction,regular operation ,1
ENG118775-energy_management_deactiv_stage,regular operation ,1
ENG137255-HVK_Warning,regular operation ,1
ENG244867-Routing_matrix_generation,01 ,2
ENG118451-ENG118685-Switch_on_ban_independent_car_heater-Set_point_target_time,80 min,2
ENG118451-ENG118684-Switch_on_ban_independent_car_heater-Switch_on_ban_activation,regular operation ,2
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,2
ENG118774-ENG136195-WakeUpMonitor_Activation-Activation_Bus_Activity,activated ,2
ENG118774-ENG136134-WakeUpMonitor_Activation-Activation_Cluster_Sleep,activated ,2
ENG118774-ENG136135-WakeUpMonitor_Activation-Activation_Cluster_Start,activated ,2
ENG118774-ENG136197-WakeUpMonitor_Activation-Activation_CWUP,activated ,2
ENG118774-ENG136130-WakeUpMonitor_Activation-Activation_Keeping_Awake,activated ,2
ENG118774-ENG136196-WakeUpMonitor_Activation-Activation_Knock_Out,activated ,2
ENG118774-ENG136131-WakeUpMonitor_Activation-Activation_Logical_Wakeup,activated ,2
ENG118774-ENG136198-WakeUpMonitor_Activation-Activation_NFU,activated ,2
ENG118774-ENG136132-WakeUpMonitor_Activation-Activation_Physical_Wakeup,activated ,2
ENG118774-ENG136199-WakeUpMonitor_Activation-Activation_SBU,activated ,2
ENG118773-ENG136190-WakeUpMonitor_Configuration-Max_Num_Cluster_Sleep,20 counts,13
ENG118773-ENG136191-WakeUpMonitor_Configuration-Max_Num_Cluster_Start,20 counts,13
ENG118773-ENG136192-WakeUpMonitor_Configuration-Max_Num_CWUP,30 counts,13
ENG118773-ENG136189-WakeUpMonitor_Configuration-Max_Num_Knock_Out,3 counts,13
ENG118773-ENG136187-WakeUpMonitor_Configuration-Max_Num_Logical_Wakeup,40 counts,13
ENG118773-ENG136193-WakeUpMonitor_Configuration-Max_Num_NF,20 min,13
ENG118773-ENG136188-WakeUpMonitor_Configuration-Max_Num_Physical_Wakeup,10 counts,13
ENG118773-ENG136194-WakeUpMonitor_Configuration-Max_Num_Sb,20 min,13
ENG118773-ENG136186-WakeUpMonitor_Configuration-Max_Time_Keeping_Awake,20 min,13
ENG118773-ENG109064-WakeUpMonitor_Configuration-Start_Delay,0 s,13
ENG118773-ENG136185-WakeUpMonitor_Configuration-Wake_Delay,20 min,13
Elapsed Time: 00:57
;SW:8W5-920-790-J   HW:8W5-920-790-J ---  17: Instruments
;Component:FBenRDW------ H08 0063, Coding:83CF29C12A88D7050200E3601800080008000800
;EV_DashBoardAU65X,002018,EV_DashBoardAU65X_002_AU49.rod
;Saturday,18,April,2026,17:45:42:01662
;VCID: 49C8BE46193965A258D-801C
IDE00301-Distance,83831 km,3
IDE00343-Language variant,US English ,1
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,No automatic reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,No automatic reset ,3
IDE00819-Day counter,2335 d,2
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,0.00 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,1.20 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,0.00 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature, F ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
IDE03346-MAS03034-Units adjusted-Pressure,kPa ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,km per kWh ,3
IDE03372-Source for synchronization of time,internal clock ,1
IDE06922-No-voltage display,Display ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE07221-Cylinder shut-off,No display ,1
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE11086-Service notification,0 d,1
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,Display ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,not active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,Display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,Display ,4
IDE11472-MAS19085-Configuration of displayable contents-Tailgate position,Variant 1 ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Red ,4
IDE11472-MAS23291-Configuration of displayable contents-Color switch-over,not active ,4
IDE11472-MAS29086-Configuration of displayable contents-Predicted charging capacity,not active ,4
IDE11472-MAS29097-Configuration of displayable contents-Overtake button,not active ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12467-Tubes illustration,Variant 2 ,1
IDE12792-Personalization of user account 1,D7 05 20 C0 00 00 00 00 00 00 00 00 00 01 10 00 0D 0D 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12794-Personalization of user account 2,D7 05 20 C0 64 00 00 20 00 00 00 00 00 01 10 00 0D 0D 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12796-Personalization of user account 3,D7 05 20 C0 00 00 00 00 00 00 00 00 00 01 10 00 0D 0D 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12798-Personalization of user account 4,D7 05 20 C0 00 00 00 00 00 00 00 00 00 01 10 00 0D 0D 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12800-Personalization of user account 5,D7 05 20 C0 00 00 00 00 00 00 00 00 00 01 10 00 0D 0D 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12802-Personalization of user account 6,D7 05 20 C0 00 00 00 00 00 00 00 00 00 01 10 00 0D 0D 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,70
IDE12804-IDE00301-Personalization of user account 7-Distance,miles ,70
IDE12804-MAS01230-Personalization of user account 7-Date,mm_dd_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Miles per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature, F ,70
IDE12804-MAS02957-Personalization of user account 7-Time,12h AM_PM ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,gallons (US) ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,kPa ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,km per kWh ,70
IDE12804-Personalization of user account 7-,active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,not active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,not active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,not active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,not active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,not active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,not active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,not active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,not active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,not active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,1 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,13 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,13 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,13 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,1 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG155906-Personalization of user account 7-Speed 2,0 ,70
IDE12804-ENG155907-Personalization of user account 7-Speed_warning_unit_mph_/_kmh,Miles per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,0 km,2
IDE12963-Oil: thermal loading,11200 km,2
IDE12964-Oil: driven distance since last oil service,3900 km,3
IDE12965-Oil: time since last oil service,58 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),14500 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),14500 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,32032 km,3
IDE12979-Inspection: time until next inspection,730 d,2
IDE12980-Inspection: distance driven since the last inspection,21900 km,3
IDE12981-Inspection: time since the last inspection,240 d,2
IDE12982-Inspection: distance reset value,30000 km,2
IDE12983-Inspection: time reset value,1095 d,2
IDE13031-MAS03935-Long-term store-Driving time,47442 min,44
IDE13031-MAS15517-Long-term store-Travel distance,30013669 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,30013642 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,46274 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,30013642 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,2830674 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.00 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.00 kWh,44
IDE13275-IDE00301-Personalization default value-Distance,miles ,70
IDE13275-MAS01230-Personalization default value-Date,mm_dd_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Miles per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature, F ,70
IDE13275-MAS02957-Personalization default value-Time,12h AM_PM ,70
IDE13275-MAS03032-Personalization default value-Volume,gallons (US) ,70
IDE13275-MAS03034-Personalization default value-Pressure,kPa ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,km per kWh ,70
IDE13275-Personalization default value-,active ,70
IDE13275-ENG154881-Personalization default value-Active_design,2 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,not active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,not active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,not active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,not active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,not active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,not active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,not active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,not active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,not active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,not active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,not active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,not active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,not active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,not active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,not active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,1 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,13 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,13 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,13 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,1 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG155906-Personalization default value-Speed 2,0 ,70
IDE13275-ENG155907-Personalization default value-Speed_warning_unit_mph_/_kmh,Miles per hour ,70
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE14123-MAS01129-Design variant activation-Variant 1,active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,Yes ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,0 s,1
MAS01758-IDE00500-Date / time-Hour,17 H,6
MAS01758-IDE00501-Date / time-Minute,47 min,6
MAS01758-IDE00502-Date / time-Year,2026 yr,6
MAS01758-IDE00503-Date / time-Month,4 Months,6
MAS01758-IDE00504-Date / time-Day,18 d,6
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG99320-Developers_menu,not active ,1
ENG119880-ENG101574-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X1,00 ,12
ENG119880-ENG99557-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X2,00 ,12
ENG119880-ENG102140-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X3,00 ,12
ENG119880-ENG102936-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X4,00 ,12
ENG119880-ENG103548-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X5,00 ,12
ENG119880-ENG113992-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-X6,00 ,12
ENG119880-ENG99777-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y1,00 ,12
ENG119880-ENG100480-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y2,00 ,12
ENG119880-ENG100773-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y3,00 ,12
ENG119880-ENG100631-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y4,00 ,12
ENG119880-ENG102174-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y5,00 ,12
ENG119880-ENG113993-dimming_characteristic_curve_adjustment_bargraph_annulus_ACC-Y6,00 ,12
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,00 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,00 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,00 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,00 ,12
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,00 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,00 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,00 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,00 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,00 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,00 ,12
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,00 ,12
ENG119881-ENG101574-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X1,00 ,12
ENG119881-ENG99557-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X2,00 ,12
ENG119881-ENG102140-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X3,00 ,12
ENG119881-ENG102936-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X4,00 ,12
ENG119881-ENG103548-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X5,00 ,12
ENG119881-ENG113992-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-X6,00 ,12
ENG119881-ENG99777-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y1,00 ,12
ENG119881-ENG100480-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y2,00 ,12
ENG119881-ENG100773-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y3,00 ,12
ENG119881-ENG100631-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y4,00 ,12
ENG119881-ENG102174-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y5,00 ,12
ENG119881-ENG113993-dimming_characteristic_curve_adjustment_bargraph_speed_setting_ACC-Y6,00 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,00 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,00 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,00 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,00 ,12
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,00 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,00 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,00 ,12
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,00 ,12
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,00 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,00 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,00 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,00 ,12
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,00 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,00 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,00 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,00 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,00 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,00 ,12
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,00 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,00 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,00 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,00 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,00 ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,00 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,00 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,00 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,00 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,00 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,00 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,00 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,00 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,00 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,00 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,00 ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,00 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,00 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,00 ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,00 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,00 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,00 ,12
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 00 ,20
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 00 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 00 ,20
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,00 00 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 00 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 00 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 00 ,20
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 00 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,DC ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,2.00 ,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,2.00 ,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,6.00 ,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,10.00 ,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,80.00 ,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,100.00 ,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.00 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.00 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.00 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.00 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.00 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.00 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.00 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.00 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.00 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.00 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.00 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.00 %,24
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
ENG102605-ENG261672-outside_temperature-at_ITM_Kuehlmittel,No ,16
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4  C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6  C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25  C,16
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00  C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
ENG126284-parameter_animations,28 14 14 0A 00 19 00 00 0F 00 B4 00 32 10 0E 0F 3C 50 50 32 64 18 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,1000
ENG126283-ENG154870-parameter_hmi-Abdunklung_Grid,0 ,150
ENG126283-ENG154871-parameter_hmi-Abdunklung_PopUp,0 ,150
ENG126283-ENG154872-parameter_hmi-Abdunklung_Reiter,0 ,150
ENG126283-ENG98345-parameter_hmi-Activation,not_active ,150
ENG126283-ENG154904-parameter_hmi-Animationsrastung,0 ,150
ENG126283-ENG154905-parameter_hmi-Animationsrastungs-Nachlauf,0 ,150
ENG126283-ENG154906-parameter_hmi-Anzahl_Peaks_Leistung_Drehmoment,0 ,150
ENG126283-ENG154966-parameter_hmi-bev_mv_totalisator_aktiv,0 ,150
ENG126283-ENG154976-parameter_hmi-color_bl,00 00 00 ,150
ENG126283-ENG154977-parameter_hmi-color_FZG,00 00 00 ,150
ENG126283-ENG154978-parameter_hmi-color_ge,50 50 32 ,150
ENG126283-ENG154979-parameter_hmi-color_gn,64 18 78 ,150
ENG126283-ENG154980-parameter_hmi-color_rt,0E 0F 3C ,150
ENG126283-ENG154981-parameter_hmi-color_ws,00 00 00 ,150
ENG126283-ENG155016-parameter_hmi-DDS_Dir_BC,0 ,150
ENG126283-ENG155075-parameter_hmi-Drehmoment_Steigungsbegrenzung,0 %/s,150
ENG126283-ENG155092-parameter_hmi-Eintraege_fuer_Scrollbar,0 ,150
ENG126283-ENG155104-parameter_hmi-fade_zeit_peak_marker,00 00 00 00 00 00 00 00 00 00 ,150
ENG126283-ENG155127-parameter_hmi-gMeter_begr,0.00 g,150
ENG126283-ENG155128-parameter_hmi-gMeter_filterkonstante_lookup_x,00 00 00 00 ,150
ENG126283-ENG155129-parameter_hmi-gMeter_filterkonstante_lookup_y,00 00 00 00 ,150
ENG126283-ENG155130-parameter_hmi-gMeter_schweif_horizont,0.00 s,150
ENG126283-ENG155131-parameter_hmi-gMeter_schweif_laenge,0 ,150
ENG126283-ENG155133-parameter_hmi-Gurtwarnung_Fond_Farblogik_aus,0 ,150
ENG126283-ENG155139-parameter_hmi-hysterese_Leistung_Drehmoment_Gefaelle,0 %,150
ENG126283-ENG155140-parameter_hmi-hysterese_Leistung_Drehmoment_Steigung,0 %,150
ENG126283-ENG155245-parameter_hmi-Ladedruck_digital_Updaterate,0 ms,150
ENG126283-ENG155265-parameter_hmi-LD_Daempfung,00 ,150
ENG126283-ENG155266-parameter_hmi-Leistung_Steigungsbegrenzung,0 %/s,150
ENG126283-ENG155279-parameter_hmi-MainWizard_Returnverhalten,0 ,150
ENG126283-ENG155350-parameter_hmi-MFL_Dir_BC1,0 ,150
ENG126283-ENG155351-parameter_hmi-MFL_Source,0 ,150
ENG126283-ENG155392-parameter_hmi-NV_PopUp_Transparenz,0 %,150
ENG126283-ENG155393-parameter_hmi-NV_videobild_skalierung,0 %,150
ENG126283-ENG155394-parameter_hmi-NV_y-offset-Video,0 px,150
ENG126283-ENG155396-parameter_hmi-OptionMenuBehaviour,0 ,150
ENG126283-ENG155570-parameter_hmi-phev_e_Powermeter_Anzeige_aktiv,0 ,150
ENG126283-ENG155571-parameter_hmi-phev_e_Verbraeuche_Anzeige_aktiv,0 ,150
ENG126283-ENG155572-parameter_hmi-phev_graf_reichweite_erw_ausgrauen_aktiv,0 ,150
ENG126283-ENG155573-parameter_hmi-phev_graf_reichweite_km_schwelle,0 ,150
ENG126283-ENG155574-parameter_hmi-phev_graf_reichweite_pixel_fuer_km_schwelle,0 ,150
ENG126283-ENG155575-parameter_hmi-phev_graf_reichweite_streckungsfunktion_aktiv,0 ,150
ENG126283-ENG155576-parameter_hmi-phev_mv_totalisator_aktiv,0 ,150
ENG126283-ENG155598-parameter_hmi-powermeter_obere_e_grenze_statisch,0 %,150
ENG126283-ENG155599-parameter_hmi-powermeter_untere_e_grenze_statisch,0 %,150
ENG126283-ENG155600-parameter_hmi-powermeter_zustart_dynamisch,0 ,150
ENG126283-ENG155651-parameter_hmi-schaltblitz_blinkfrequenz,0.00 Hz,150
ENG126283-ENG155893-parameter_hmi-Seitenmenue_Variante,0 ,150
ENG126283-ENG155894-parameter_hmi-SelectionMenuBehaviour,0 ,150
ENG126283-ENG155925-parameter_hmi-t_BCZA,15 s,150
ENG126283-ENG155926-parameter_hmi-t_BCZAMclose,0 ms,150
ENG126283-ENG155927-parameter_hmi-t_car_outline_popup_uebernahmezeit,3 s,150
ENG126283-ENG155928-parameter_hmi-t_Cursor1_Wait,0 ms,150
ENG126283-ENG155929-parameter_hmi-t_DDGS,500 ms,150
ENG126283-ENG155930-parameter_hmi-t_Delay_NAV_Buehne,0 ,150
ENG126283-ENG155931-parameter_hmi-t_Designumschaltung,0 s,150
ENG126283-ENG155932-parameter_hmi-t_dLVDSLock,20 s,150
ENG126283-ENG155933-parameter_hmi-t_DReiter,4.00 s,150
ENG126283-ENG155934-parameter_hmi-t_DummyMenuTimeout,4 s,150
ENG126283-ENG155935-parameter_hmi-t_FondGurt,5 s,150
ENG126283-ENG155936-parameter_hmi-t_Hinweistext_Beruhigter_Screen,0 ms,150
ENG126283-ENG155937-parameter_hmi-t_Hinweistext_Beruhigter_Screen_KL15,0 ,150
ENG126283-ENG155938-parameter_hmi-t_Ladeanim_blinken_aus,0.00 s,150
ENG126283-ENG155939-parameter_hmi-t_Ladeanim_blinken_ein,0.00 s,150
ENG126283-ENG155940-parameter_hmi-t_Ladeanim_impuls_aus,0.00 s,150
ENG126283-ENG155941-parameter_hmi-t_Ladeanim_impuls_ein,0.00 s,150
ENG126283-ENG155942-parameter_hmi-t_Ladeanim_pulsieren_aus,0.00 s,150
ENG126283-ENG155943-parameter_hmi-t_Ladeanim_pulsieren_ein,0.00 s,150
ENG126283-ENG155944-parameter_hmi-t_Ladeanim_pulsieren_rampe_ab,0.00 s,150
ENG126283-ENG155945-parameter_hmi-t_Ladeanim_pulsieren_rampe_auf,0.00 s,150
ENG126283-ENG179272-parameter_hmi-t_LS,0 s,150
ENG126283-ENG155946-parameter_hmi-t_MenuTimeout,16 s,150
ENG126283-ENG155947-parameter_hmi-t_Nachlauf,5 min,150
ENG126283-ENG155948-parameter_hmi-t_NextWarning,0 s,150
ENG126283-ENG155949-parameter_hmi-t_NV_load_icon_rotate_time,0 s,150
ENG126283-ENG155950-parameter_hmi-t_P1Pause,0 s,150
ENG126283-ENG155951-parameter_hmi-t_P2Pause,0 s,150
ENG126283-ENG155952-parameter_hmi-t_Quit,0 s,150
ENG126283-ENG155953-parameter_hmi-t_SammelReiter,12 s,150
ENG126283-ENG155954-parameter_hmi-t_SbW_Popup_Anzdauer,0.00 s,150
ENG126283-ENG155955-parameter_hmi-t_scrollbar_fadeout,0 s,150
ENG126283-ENG155956-parameter_hmi-t_TOMMI,0 s,150
ENG126283-ENG155957-parameter_hmi-t_TWSAnz,0 s,150
ENG126283-ENG155958-parameter_hmi-t_USZ,200 ms,150
ENG126283-ENG155959-parameter_hmi-t_vze_warnung_blinken,8 s,150
ENG126283-ENG155960-parameter_hmi-t_WSGS,32 s,150
ENG126283-ENG155961-parameter_hmi-t_WSkurz,0 ms,150
ENG126283-ENG155962-parameter_hmi-Telefon_Adressbuch,0 ,150
ENG126283-ENG155986-parameter_hmi-Touchfreischaltung,0 ,150
ENG126283-ENG155989-parameter_hmi-transparenz_peak_gueltig,0 %,150
ENG153922-ENG98345-parameter_hmi_VW-Activation,not_active ,150
ENG153922-ENG154996-parameter_hmi_VW-d_LVDS_LOCK,2.50 s,150
ENG153922-ENG155155-parameter_hmi_VW-KBI_NV_Reiter_Sperrzeit,0.20 s,150
ENG153922-ENG155391-parameter_hmi_VW-NV_Dauer_Zwangsaufschaltung,5.00 s,150
ENG135292-phev_stat_intervall-,5.00 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.00 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.00 s,7
ENG135292-phev_stat_intervall-,00000000 00010000  ,7
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms,17
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,17
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,17
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,17
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:35
You may find this useful:
PS: Please lubricate your Caps Lock key. It appears to be stuck.
drmonks1159
C?ID=641168
Thank you, yes, ive since messed up and used this feature. the issue im having now happened before my new laptop and the files i saved on a hard drive did not hold the adaptations..... its about to the point im going to test drive anothe a4 to get its adaptions lol
