2019 Seat leon lost coding
AC2026
C?ID=646183
Hi all,
vehicle registration TU60 LAU
VIN VSSZZZ5FZKR063962
i have lost some coding some how and tried to fix but to no avail, please could somebody try and help me as i am in a pickle.
i have attached the scan from after the first read and i notice coding missing, if any of you could help i would really appreciate it.
Thanks in advance :thumbs:
not sure how to make the information i am sending is the correct of doing this as its the first time posting. :):banghead:
thanks again Che
Westbury, UK
Please post an Auto-Scan properly as text not a series of screenshots - to make this easy VCDS saves a text file in C:\Ross-Tech\VCDS\Scans.
AC2026
C?ID=646183
ok thanks dave ill take a look :thanks:
AC2026
C?ID=646183
hi all, i have lost some coding some how and tried to fix but to no avail, please could somebody try and help me as i am in a pickle.
Thanks Dave :thanks: :)
Saturday,18,April,2026,22:27:29:41908
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: VSSZZZ5FZKR063962   License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F
VIN: VSSZZZ5FZKR063962   Mileage: 90976km-56529miles
Address 01: Engine (J623-DGTE)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 HT    HW: 04L 907 445 G
   Component: R4 1.6l TDI   H01 6591
   Revision: 22102001
   Coding: 01254032432501092000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM16TDI03004L906056HT 004006
   ROD: EV_ECM16TDI03004L906056HT_SE37.rod
   VCID: 065275E678AD167AF5F-8052
   VINID: 9A38EAAAA156A9B8801832460827127C22
25126 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 90976 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 23 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 13.820 V
                    Acceleration: 0.000 m/s²
                    Average vehicle speed: 0.00 km/h
                    Cruise Control System (CCS): status: Initialization
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: Yes
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
                    Drivetrain coordinator: brake fault status-ESP system malfunction: No
Readiness: N/A
   Part No SW: 0CW 300 043 E    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1603
   Revision: 00005008    Serial number: CU501901145367 CVN: A8376DEB
   Shop #: WSC 00049 770 00128
   ROD: EV_TCMDQ200021.rod
   VCID: 3928CE1A79D3A982C8D-806C
   Part No SW: 5Q0 614 517 EH    HW: 5Q0 614 517 BR
   Component: ESC           H82 0107
   Revision: 00000000    Serial number: 60119000001043
   Coding: 20EE8A922026096F8780060660C52404510490E1600624733042F074D2024B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 7BA41412336F5B929A1-802E
7 Faults Found:
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
8277 - Databus
          U1122 00 [00001000] - Implausible Message
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 170
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
33000 - Longitudinal Acceleration
          C10B1 29 [10001001] - Signal Implausible
          [IPB-Sensor: Longitudinal acceleration sensor failure]
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
   Part No SW: 5F0 907 426 AB    HW: 5F0 907 426 AB
   Component: AC Manuell    H03 1601
   Revision: 00001K09
   Coding: 00100104200110001000000000001000
   Shop #: WSC 00049 770 00105
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 6A8A21564CF5D21A717-803E
   Part No SW: 5Q0 937 084 DB    HW: 5Q0 937 084 CE
   Component: BCM MQBAB M   H38 0273
   Serial number: 00001902100215 Dataset Number: V03935293LQ 0001
   ROD: EV_BCMBOSCH_019_SE37.rod
   Subsystem 1 - Part No SW: 5F2 955 119 A    HW: 5F2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 181120  041 0574
   Serial number:         190109053358
   Coding: 0BC5FD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY182611XRP
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000299114
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 507 B    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000020011904400764
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019008 Dataset Number: V03935268GT 0002
   Coding: 0471051011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC687CE26412C2A63B-8018
13637426 - Databus
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Dataset Number: V03935269FJ 0001
   Coding: 3500000151FF8428949C814500300400000000000000000000
   VCID: 44D6AFEE0E11E46AABB-8010
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
                    Control Module temperature: 40 °C
                    Voltage terminal 15: 13.8 V
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:28
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2P09ZUJT Dataset Number: V03935263XZ 0001
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW21TS6VW48X_VW41.rod
   VCID: 0B4444D263CF6B12AA1-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 000 301 19
   Serial number: 35700000000E8021873F
   Subsystem 2 - Part No SW: -----------    HW: 454 000 201 19
   Serial number: 3580000000033B31873C
   Subsystem 3 - Part No SW: -----------    HW: 454 801 001 19
   Serial number: 351000D5467170000009
   Subsystem 4 - Part No SW: -----------    HW: 454 800 901 19
   Serial number: 35200B1225A170000006
   Subsystem 5 - Part No SW: -----------    HW: 454 801 201 19
   Serial number: 3550042F22A17000000D
   Part No SW: 5F0 920 951 F    HW: 5F0 920 951 F
   Component: KOMBI         312 2511
   Coding: 27A402082380060001886A011001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009066
   VCID: 2B04E452838F0B124A1-807E
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009086212 Dataset Number: V03935279TD 0003
   Coding: 030100F40F086A00EA000040140F00010001070000000000000000000000
   GVL: 01443C0000000000400C80000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_SE37.rod
   VCID: 6E822D46701D3E3A2DF-803A
   Generator:
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5F0 959 537 E    HW: 5F0 959 537 E
   Serial number: 000000000H0537050119
   Coding: 002000
   Serial number: 75886003001812291ED5
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
   Component: TSG FS        006 0247
   Serial number: 0000350808619  Dataset Number: V03935292GL 0001
   Coding: 00100220C001020000001000
   ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
   VCID: 4DC08ACADD5B2522745-8018
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000026725771
   Coding: 2D0000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935283CZ 0001
   Coding: 01170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B63F2E1E3114EADBB-8020
15873 - Steering angle sensor
          B1168 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:27
                    Motor status: 00
                    Supply voltage: 13.75 V
                    Temperature: 28.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 13.80 V
                    uAdSensI_SwitchedKl30_xdu16: 13.81 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.16
                    Time: 17:58:27
                    Motor status: 00
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 7F
                    uioUdNotFilt_xdu16: 13.97 V
                    uAdSensI_SwitchedKl30_xdu16: 13.96 V
   Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0247
   Serial number: 0000361532704  Dataset Number: V03935276VJ 0001
   Coding: 00100020C001020000001000
   ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000026689926
   Coding: 350000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5F0 035 877 A    HW: 5F0 035 877 A
   Component: MU-S-ND-ER    H50 0514
   Serial number: SEZAZ2W0221702 Dataset Number: V03935289FR 0001
   Coding: 04738001D70A000011110101008808002F0100C601200500CE
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SK25.rod
   VCID: 2A0AE1568C75121AB17-807E
   Subsystem 1 - Part No SW: 5F0 919 606     HW: 5F0 919 606
   Component: ABTm-2_8-CR  H41 1042
   Serial number: SEZ8Z9W6C064UB
   Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
   Component: ECE1 2018/19  --- 1030
End----------(Elapsed Time: 01:17, VBatt start/end: 12.5V/12.5V)-----------
------------------------------15 Faults Found------------------------------
AC2026
C?ID=646183
In what module do you think it was lost, and how did that happen?
Hiya Uwe, in the ABS and I’m really not sure how or why….i was in the Abs module with my autel as it was out….because he said the abs wasn’t coming on he kept locking up brakes up when braking then the light would come on….maybe a faulty unit.
Sorry I can’t give you more info….i wish I could and wish I would have just started the job with vcds but im a novice with vcds. Sorry
Thanks for responding Uwe :confused:
Vdub
C?ID=57533
ABS has coding, your 09 BCM doesnt have.
You need to perform the sensors basic settings to get it fault free.
ABS has coding,
Not only does it have coding, but it doesn't complain about being incorrectly coded either. I think you are correct that it only needs Basic Settings.
Right, but this being a 2019 MQB chassis car ("Mk7.5" generation), 09 is expected to have a string of all zeros for coding because everything that can be changed in those modules is now in Adaptation.
AC2026
C?ID=646183
Thanks VDUB really appreciate you taking the time out to reply.
Thanks again and enjoy your Sunday 👍🏻✅
thank you both 🙏🏻💪🏻 💙🫵🏻
AC2026
C?ID=646183
hiya i seem to go 2 steps forward 3 steps back and cant seem to find the correct solution.
i have uploaded the latest scan to see if you can see where i may need to look.
thanks in advance Che
Sunday,19,April,2026,20:57:30:41908
VIN: VSSZZZ5FZKR063962   License Plate: TU60 LAU
Mileage: 90976km-56529mi   Repair Order:
   Revision: 22102001
          U0416 00 [00100011] - -
                    Mileage: 90976 km
                    Date: 2026.04.17
                    Time: 20:44:32
                    Coolant temperature: 55 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.992 V
Readiness: N/A
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.17
                    Time: 20:36:10
   Revision: 00001K09
   Coding: 0BC5FD
12307 - License Plate Light
          B12CA 01 [00001001] - Electrical Failure
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.17
                    Time: 20:35:57
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: operated
                    Low beams: Not operated
                    Voltage: 12.0 V
                    Outside temperature: 10.0 °C
   Coding: 0471051011
13637426 - Databus
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.17
                    Time: 20:36:10
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.17
                    Time: 20:36:10
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 12.0 V
2101 - Databus
                    Reset counter: 130
                    Mileage: 90976 km
                    Date: 2026.04.17
                    Time: 20:36:10
   Generator:
   Coding: 002000
   Coding: 2D0000
   Coding: 01170000
   Coding: 350000
End----------(Elapsed Time: 01:19, VBatt start/end: 13.4V/13.4V)-----------
------------------------------6 Faults Found-------------------------------
Vdub
C?ID=57533
why 3 steps back, only the Brake Pressure sensor is not in Basic Settings.. you had 7 faults, now only one
AC2026
C?ID=646183
Thanks 2kaa52
I’m pretty competent but I can’t see the wood through the trees ….heads totally blown looool :banghead:
AC2026
C?ID=646183
AC2026
C?ID=646183
AC2026
C?ID=646183
Quick update…..
it was as simple as inputting basic settings (which was suggested ) into brake pressure sensor which I did with my autel…..I did try that with vcds but I’m sure I was getting security access error….my head was scrambled at that time so im not sure what was going on so moving forward what security access code should i have been looking for to do brake pressure sensor reset, Just in case I come across it again….also it has front assist not available error which wasn’t there before 100%…..I have a friend with ADAS so it’s not an issue but would like to know why or how to solve without adas or if any of you people have come across this before.
thanks to all that tried to help me its really appreciated, so out of respect too all i thought i would reply with the solution.
thanks again all :o:thanks::thumbs:
