2015 S3 8V High Beam Assist
ians63
C?ID=242121
Car was supplied in Nov 15 but with grey headlining instead of black (don't ask). Car was returned to dealer to have black interior fitted but they have failed to code the new HBA / rear view mirror module. Can anybody tell me what the coding should be rather than an 80 mile round trip back to dealer. Scan attached.
Thursday,25,February,2016,19:20:11:23144
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WAUZZZ8V7GA074311   License Plate:
Mileage: 2247km-1396mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 05 08 09 10 14 15 16 17 19 20 22 2B 42 44 52 55 5F 6C
          A9
VIN: WAUZZZ8V7GA074311   Mileage: 2247km-1396miles
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CJXC)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1900122426010B3004
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0208V0906259F 001004
   ROD: EV_ECM20TFS0208V0906259F.rod
   VCID: 438572AFCACFB02623-8016
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62815000004758
   Coding: 32F193A254272A70017A070141C4694CC92A5480E08296F6024100F88008
   VCID: 79F9D047F8833AF639-802C
   Revision: 00021000    Serial number: 0383125722
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A7B0F4BBD05F1EE70-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000762335
   Coding: 03100004000000011000000000001100
   VCID: 3365226F9A6F00A6B3-8066
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061529400933
   Coding: 07050D46C24106FD03844004B31C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 0919A087A8632A7629-805C
   Slave 1:
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150818  042 0580
   Serial number:         151015131132
   Coding: 0A47F7
   Slave 2:
   Serial number: 20822377
   Coding: 00006C
   Slave 3:
   Serial number: 03 08 2015  00000181
   Serial number: 000000000ZY151672YJ8
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000033390078
534549 - Databus
                    Reset counter: 120
                    Mileage: 1727 km
                    Date: 2016.02.03
                    Time: 13:31:29
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391528802911
   Coding: 0010150001
   ROD: EV_EPHVA18AU3700000_AU37.rod
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       161015040
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide_AU37.rod
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R15WNYK
   Coding: 98CCC0000C0000005C5400CA00C800000065
   VCID: 4B955A8FE29F7866DB-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 3576700000022C19F61X
   Subsystem 2 - Part No SW: -----------    HW: 480 001 510 15
   Serial number: 3586700000000C19F61U
   Subsystem 3 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3516502A91CF1D1181AI
   Subsystem 4 - Part No SW: -----------    HW: 480 402 010 15
   Serial number: 3526502A71CF1D156109
   Subsystem 5 - Part No SW: -----------    HW: 480 403 108 15
   Serial number: 3556502AB1C1EFA3918Z
   Pedestrian protection crash sensor; driver side:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 210 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 22865029F1CF2DA142AX
   Pedestrian protection crash sensor; front passenger side:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 210 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502C11D25F734025
   Subsystem 8 - Part No SW: -----------    HW: 480 400 210 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C31D25F71F039
   Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 21101504221462
   Coding: A408
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 7F0D3E5FE6A714C607-802A
   Part No SW: 8V0 920 972 A    HW: 8V0 920 972 A
   Component: KOMBI         H03 6420
   Coding: 27AD08123B8026000101E8001000000000000000
   VCID: 3C770953B731CFDE62-8068
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004063868
   Coding: 030100043F085A005B000268880B00000001010000000000000000000000
   ROD: EV_GatewLear.rod
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 07 10 2015  B0016978
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001510240427
131632 - High Beam Assistant Control Module
          U1070 00 [008] - No Communication
                    Reset counter: 120
                    Mileage: 1727 km
                    Date: 2016.02.03
                    Time: 13:31:31
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Part No SW: 8S0 857 511 C    HW: 8S0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 0000000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_AU37.rod
   VCID: 39791047B803FAF679-806C
15466752 - Control module not coded
          U1013 00 [009] - -
                    Reset counter: 250
   Serial number: HA1-00031.08.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4A9B5F8BEDE5616EE0-801E
   Revision: 00000000    Serial number: 15000228292009
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 346721739F61079EAA-8060
   Serial number: 050615BF314822
   Coding: 00109A205C01040000001002
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   Serial number: 130615BFB02543
   Coding: 001092205E01040000001002
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 428B77ABD5D5B92E28-8016
   Component: AFS-ECU       H01 0110
   Coding: 01A600002B200200
   VCID: 3F8D7E5FA627D4C647-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 C    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    042 0461
   Serial number: A7F01610150021
   Coding: 01730301FF0A000021111101000A00032F0005060100010006
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   Engine Control Module 2:
   Subsystem 1 - Part No SW: 8V0 919 866 D    HW: -----------
   Component:  ECE 2016  --- 0054
   Seat Adjustment Driver Side:
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30DTJZ
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000026081500020143
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 306F2D636B793BBECE-8064
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 151008200845
   VCID: 7DF1C457ECAB06D615-8028
End-------------------------(Elapsed Time: 04:52)--------------------------
