- Apr 17, 2026
- 5
- 3
- Minnesota, USA
- C?ID=635084
Hi All,
Having trouble with this A7 with the "death countdown"
Car originally had the following DTC's (sorry did not save the original auto-scan)
-P0401 EGR insufficient flow
-P229F Nox sensor rear circuit range/performance
-P20F4 Nox reductant consumption too low (Won't clear)
-P207F Reductant quality performance (Won't clear)
This is the most recent:
The following repairs have been made, all with OE parts from the dealer
1. Replaced a faulty reductant pump. (Pump was not building pressure, 30hpa. I have 5000hpa with the new pump)
2. Replaced the EGR cooler. (P0401 no longer sets after multiple test drives)
3. Drained and filled SCR tank with Ad blue from the dealer
After those 3 repairs, I performed the following:
-SCR metering quantity test. (Filled my measuring cup to 30ml)
-Resetting of SCR tank level detection
-Reset SCR lock
-Resetting of learning values for reductant agent metering system
-SCR efficiency test
The problem I am having is I cannot get the LTA for reductant dosing to reset. Looking through other posts I believe this number should be at 1. This car is at 4.16 which I believe is way too high. I've taken it for multiple, long test drives (50+ miles) at steady cruise on the freeway.
Some data I observed while testing:
-During SCR efficiency test:
Reductant injector activation 6-9% (would cycle from 0 to 6-9%)
Reductant pump pressure 5000hpa
SCR catalyst temp 290-310C
Nox1-290ppm
Nox2-50ppm
-During long test drive on freeway (steady cruise):
Reductant injector activation 0-70% (would usually cycle from 0-10% but would go up to 70% depending on throttle)
SCR catalyst temp 310C
Nox1- 80ppm
Nox2- 300 to 400ppm
After seeing the Nox readings on my multiple test drives I decided to install a new rear Nox sensor (OE from the dealer). Pretty much the same Nox readings as previous test drives, and the LTA for reductant dosing does not get much better. I'm thinking the SCR catalyst is bad??? Not sure of a good way to prove it, or if there is something else I'm missing...
Side note:
The customer has a obd2 code reader sitting on the seat. I did find out by just checking for DTCs, the SCR lock will reset. Thinking maybe that is how they were "getting by" for awhile. Possibly damaged the SCR catalyst? Or skewed the adaptions so badly they cannot be reset?
Cheers Everyone!!!
VIN: WAU2MAFC9EN017116 License Plate:
Mileage: 142173km-88342mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
53 55 56 5F 62 6C 6D 72 8F 90 AC
VIN: WAU2MAFC9EN017116 Mileage: 142173km-88342miles
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 N HW: 4G0 907 401 E
Component: 3.0TDI FSA H14 0016
Revision: 58H14--- CVN: FC1A821BCEF5C587D45710C1755A21130E1FC39E
Coding: 1A2A4012052601050000
Shop #: WSC 64597 003 1048576
ASAM Dataset: EV_ECM30TDI0114G0907401N 002016
ROD: EV_ECM30TDI0114G0907401N_002.rod
VCID: 2E0E7C68E09981CA6DF-807A
VINID: 9D19427515932557800470411841B6E619
9954 - NOx Reductant Consumption too Low
P20F4 00 [00100111] - -
Mileage: 142173 km
Date: 2026.04.17
Time: 14:01:16
Engine speed: 0.00 /min
Coolant temperature: 74 C
Intake air temperature: 21 C
Voltage terminal 30: 13.360 V
Long-term adaptation of reduction agent dosage: 4.16
Measured NOx conversion range 1: 0.000
Efficiency threshold of NOx conversion range 1: 0.000
Mean temperature of SCR catalyst: 31.8 C
NOx sensor 1: NOx concentration: 0 ppm
NOx sensor 2: NOx concentration: 0 ppm
Particle filter: unburned fuel calculated: 0.134
9953 - Reductant Quality Performance
P207F 00 [00100111] - -
Mileage: 142173 km
Date: 2026.04.17
Time: 14:01:16
Readiness: 0 0 0 1 1
Part No SW: 4G0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H16 1008
Revision: --H16--- CVN: 13B31F1C
VCID: 3C2A462026E5635AD3B-8068
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 27A79703E4E5E9C04B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004039
VCID: 3A2640382CD15D6AC17-806E
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Coding: 0DAA2046000000000000
VCID: 7BA8853C63EBA4629A1-802E
Serial number: 2313000100989006
02823 - Requirements for Locking the Steering Column Lock not met
Reset counter: 96
Mileage: 141671 km
Date: 2026.03.25
Time: 17:26:17
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0087
Serial number: 07061300041626
Coding: 368320BA49
ASAM Dataset: EV_AirCondiComfoUDS 002040
VCID: 6398DD5CFBDB7CA2B21-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001736045
Coding: 0D072091073E9FE081000884A0003820CF9CD208A6090225800308457B00
VCID: 6FB0A16C2793C8C2269-803A
Component: WWS57X 130525 H36 0080
Serial number: 130605152056
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21401811
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 05 06 2013 00001063
Component: USHL4.2 H30 0030
Serial number: 0000002274555R6DKJ02
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0061836889
Coding: 853000
Subsystem 6 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A31 LED Mod1L H02 0002
Serial number: 00000000001305272057
Subsystem 7 - Part No SW: 4G0 907 472 HW: 4G0 907 472
Component: A27 LED Mod1R H02 0002
Serial number: 00000000001305271619
Subsystem 8 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA105523000003772933
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: C508CFA6000000000001
Subsystem 10 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A32 LED Mod2L H02 0002
Serial number: 00000000001305130540
Subsystem 11 - Part No SW: 4G0 907 472 A HW: 4G0 907 472 A
Component: A28 LED Mod2R H02 0002
Serial number: 00000000001305130114
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061316800308
Coding: A8C304
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 71B4A7143127DE3230D-8024
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D80033SFU Dataset Number: 4G8909602D 0004
Coding: 303145313131303030394A55304C34473853
VCID: 33386D1C0BBBAC22021-8066
Seat occupant detection:
Serial number: 6940000Y130000UTLR0Z
Serial number: 3575HRB401450I7EC0IT
Serial number: 3585HRB4063217O018JM
Serial number: 3515JRB400Q50IBOQPOJ
Serial number: 3525JRB400Q50IBOKPND
Serial number: 3554VRB400O50ITUGHCQ
Serial number: 3564VRB400O50ITUHPL2
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MFA001B4
Coding: 000414
VCID: 38225A30125D4F7A373-806C
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0010
Serial number: 11 04 2013 A1151592
Part No SW: 4G8 920 984 HW: 4G8 920 984
Component: TDieUsa Nv H80 0618
Revision: 30460230 Serial number: 658070613596019
Coding: 0BE602060B43D705020100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 73B8AD1C4B3BEC22C21-8026
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000975341 Dataset Number: 4G8909515J 0062
Coding: 00CD077D00
GVL: FDA1E84CFE63600F0000
ASAM Dataset: EV_GatewPkoUDS 001018
Control module for battery monitoring:
Serial number: 6480170803
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1304150000000000027C
5603 - No Communication with Control Module for SCR Reductant
U010E 00 [00001000] - -
Reset counter: 96
Mileage: 141672 km
Date: 2026.04.06
Time: 08:52:23
Voltage terminal 30: 13.1 V
Voltage terminal 15: 13.4 V
Control Module temperature: 27 C
System status: Terminal 15 on
Engine is running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0087
Serial number: 08061300040145
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
VCID: 3720590C1FC340023E9-8062
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [00001001] - Signal Amplitude Too High
Reset counter: 61
Mileage: 127286 km
Date: 2024.10.23
Time: 12:26:00
Voltage terminal 30: 13.64 V
Outside temperature: 12.0 C
Right Rear Upper Body Vent Motor-Actual value: 11706
Right Rear Upper Body Vent Motor-Specified value: 11706
Right Rear Upper Body Vent Motor-Stop open: 11405
Right Rear Upper Body Vent Motor-Stop closed: 10000
0034 - Motor for Rear Right Upper Body Vent
B10D4 21 [00001000] - Signal Amplitude Too Low
Fault Frequency: 41
Reset counter: 88
Mileage: 139933 km
Date: 2026.01.12
Time: 11:12:05
Voltage terminal 30: 14.60 V
Outside temperature: 3.5 C
Right Rear Upper Body Vent Motor-Actual value: 9399
Right Rear Upper Body Vent Motor-Specified value: 9399
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000063752535
Coding: C0581B008F006001000001010101102030303232203232
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA8203UKS% Dataset Number: 4G8909573A 0001
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 363E540818C9B90A25F-8062
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH04 0060
Revision: 00H04000 Serial number: 6PZ 010 287-08
Coding: 0000007
VCID: 363E54081449B90A25F-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H04 0060
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F30.05.1300H04000AMS15157
Subsystem 4 - Serial number: S15157
Component: TSG FA H04 0507
Coding: 011F5F025E00628002000412
VCID: 45DC23C455AF2292BC5-8010
02124 - Exterior Door Handle Switch
Reset counter: 85
Mileage: 141418 km
Date: 2026.03.15
Time: 13:25:10
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0007565167 Dataset Number: 4G8909852J 0027
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 32366818F4A1A52A097-8066
Revision: 00002001 Serial number: 0309548521
Coding: 0126023A20FAF08580A00A8402030D470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000156639
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO2224135-
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Serial number: 0000000AP00003678975
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA106023000003814324
Subsystem 6 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
Serial number: 93027824
03976 - Control Module for Rear Lid/Hatch Opening: Play Protection Active
Reset counter: 99
Mileage: 141892 km
Date: 2026.04.10
Time: 13:31:20
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000003362
Coding: 030000
VCID: 1D6CABA49DBF0A52C45-8048
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011F5F025E00628002000402
VCID: 44DA3EC05E951B9AABB-8010
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000719759 Dataset Number: 4G8909522C 0006
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C0A7660D685F3DA43B-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 130612-0002-109
Coding: 1223A6601002A500
ROD: EV_HeadlRegulBasic_AU35.rod
VCID: 2D0C7B64ED9FFAD2545-8078
Revision: AB001007 Serial number: 156F-0D7813325
Coding: 020007010000000001
VCID: 241A9E40BED53B9A8BB-8070
Part No SW: 4G0 035 746 E HW: 4G0 035 746 E
Component: H-BNT-NA H40 0735
Revision: -------- Serial number: 194F/0D7535920
Coding: 090200040003E1EF55128B1E00000003100001000000000000
VCID: 29048F74D9F7E6F2B8D-807C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD001QXSU
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349MFA00127
Component: CD-Database 5298
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0507
Coding: 010F1F024000628002000002
VCID: 47C029CC6FA330824E9-8012
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H07--- Serial number: 525 PA8J35GAF8
Coding: 1080013
VCID: 261E8448C4E9C98A95F-8072
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 101300170 Dataset Number: 4G8909541F 0023
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571_AU57.rod
VCID: 44DA3EC05E151B9AABB-8010
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Dataset Number: 4G0909614C 0001
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 31346714F1A79E3270D-8064
Component: RGS-VR H13 0080
Dataset Number: 4G0909615C 0001
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 230460039
ROD: EV_RDCMA00100.rod
VCID: 2F30616CE79388C2669-807A
End----------(Elapsed Time: 02:58, VBatt start/end: 13.4V/13.1V)-----------
------------------------------8 Faults Found-------------------------------
-Reset SCR lock
Nox1-290ppm
Nox2-50ppm
Nox1- 80ppm
Nox2- 300 to 400ppm
Side note:
Cheers Everyone!!!
