Hey all, bought a 2013 Audi S4 sight unseen from what I thought was a decent dealer.
Turns out they got me good. Bought the car back in December and have had the issues since.
Some are resolved, the car had undisclosed water intrusion from a failed or improperly installed windshield.
The e380 (mmi control panel) is still dead.
Things I've done so far = Replace the J794 (5f) with a known working unit from eBay, and had Component Protection removed.
Then, I recoded the 5f to my old s4's settings to restore the navigation and other features.
So, I now can control the MMI directly with my steering wheel, audio, volume, station etc.
I replaced ALL wiring from the 5f to the e380 16 pin connector.
I replaced the e380 and I also have 2 spare e380s at this point.
Voltage is as follows:
Ground is perfect 0.0 ohm
Power is 12-13v
Wake is fluctuating
LIN to/from static around 5v
Res BT gets fluctuating voltage around 1-3v
Res MU gets 0v and always has
The e380 does not light up and I cannot navigate through the MMI with the control panel, but the reset command (setup + center knob + top right button) does reset the 5f.
Since I've replaced the 5f, the e380 and the wiring, what the hell else could be going on? Unless my wiring is weird somehow, although I bought the correct terminals and did confirm I wired everything properly.
Maybe the 16 pin connector itself is causing some issues?
Note: SVM fault code only appeared after Audi removed CP from the "new" 5f unit and they must have updated firmware.
Any ideas are welcome.
Also, secondarily: Cylinder 6 keeps intermittently misfiring. I've already replaced the coil packs with upgraded ECS tuning coil packs and changed out spark plugs.
So... next, potentially fuel injectors? Although I'd expect it to be more of a consistent misfire if it was fuel related. The other thing is carbon or vacuum. Idk. Thoughts appreciated before I dig in this weekend..
Power is 12-13v
Wake is fluctuating
Friday,17,April,2026,19:32:41:09783
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.5
VIN: WAUBGAFLXDA104827 License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
72 A9
VIN: WAUBGAFLXDA104827 Mileage: 160600km-99792miles
Address 01: Engine (J623-CGXC) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 E HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0004
Revision: --H07--- CVN: 2EBC860F
Coding: 0A250034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
ROD: EV_ECM30TFS0218K5907551E.rod
VCID: 382ECA5A52D1E8BA373-806C
VINID: 9D19525D159CA144410042021CF86237EC
7123 - Cylinder 6
P0306 00 [01100101] - Misfire Detected
Mileage: 160592 km
Date: 2026.04.17
Time: 00:18:45
Engine speed: 3784.00 /min
Normed load value: 21.6 %
Vehicle speed: 32 km/h
Coolant temperature: 90 °C
Intake air temperature: 45 °C
Voltage terminal 30: 13.202 V
Engine speed: actual: 3776 /min
MAF_ENVD: 294.14117 mg/stroke
Coolant temperature (unfiltered): 90.75 °C
Engine: operating status: PL
T_AST_ENVD: 77.10 s
Vehicle speed: actual: 32 km/h
6333 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
P1117 00 [10101111] - Short to Ground
Mileage: 160562 km
Date: 2026.04.15
Time: 01:02:29
Engine speed: 1322.00 /min
Normed load value: 50.2 %
Vehicle speed: 52 km/h
Coolant temperature: 87 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.796 V
Engine speed: actual: 1248 /min
MAF_ENVD: 152.51764 mg/stroke
Coolant temperature (unfiltered): 10.50 °C
Engine: operating status: IS
Battery voltage: 11.679688 V
STATE_LS_ENVD[1]: 1
6336 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2
P1121 00 [10101111] - Short to Ground
Mileage: 160562 km
Date: 2026.04.15
Time: 01:02:29
STATE_LS_ENVD[2]: 1
Readiness: 0000 0100
Part No SW: 8K2 927 156 M HW: 0B5 927 156 J
Component: 0B5 30TFSINAR H01 0012
Revision: --H01--- CVN: 00007545
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501021 001025
ROD: EV_TCMDL501021.rod
VCID: 40DEA2BA0A01A07A8F3-8014
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK
Component: ESP8 quattro H09 0100
Coding: 291D18
VCID: 04566EAA5E197C5AEBB-8050
02214 - Tire Pressure Warning
Reset counter: 187
Mileage: 160436 km
Date: 2026.04.11
Time: 00:04:57
Hex Value: 0x00C0
Hex Value: 0x4702
Hex Value: 0x0021
Hex Value: 0x1F9D
Hex Value: 0x0000
Part No SW: 8K0 907 064 GM HW: 8K0 907 064 FM
Component: BCM2 2.0 H11 0621
Coding: 0D814000000000000000
VCID: 015867BE410B6972C0D-8054
Subsystem 1 - Part No SW: 8K0 959 754 BB HW: 8K0 959 754 BB
Serial number: 0512000043291021
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000155039012
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01140720120323
Coding: 6600228000
VCID: 3928CF5E695BF1B2C8D-806C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000447744202
Coding: 26000091863CAFC00000484300003D0D0F1C5308A2090221000008004000030100000030000000
Shop #: WSC 99999 999 2097151
VCID: 78AE0A5A12D128BAF73-802C
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 120712 H07 0080
Serial number: SWF12070126177
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20418586
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000507121490
Serial number: 69588B36000000000001
02258 - Door Opener Transmitter
Reset counter: 184
Mileage: 160562 km
Date: 2026.04.15
Time: 01:02:38
Reset counter: 224
Mileage: 160570 km
Date: 2026.04.15
Time: 01:21:04
Part No SW: 8K0 959 655 P HW: 8K0 959 655 P
Serial number: 003KJD90FE6D Dataset Number: 8K0909602VA 0001
Coding: 303844354730303030304A55304C384B3053
Shop #: WSC 40720 001 1048576
VCID: 4ACA80923C3D6A2A517-801E
Seat occupant detection:
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1200009H8K
Serial number: 6334MSME6F452D73S
Serial number: 6344MSME6F527160G
Serial number: 6352QSME441A4566H
Serial number: 6362QSME2F1A0874P
Serial number: 63732SME6C1C25723
Serial number: 63832SME6C1C1F46E
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120716000823
Coding: 000036
VCID: 4FFC9186C7DF4F02069-801A
Part No SW: 8K0 920 982 L HW: 8K0 920 982 L
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBN72WD7D
Coding: 8BB709000301D705020000
VCID: 3D20DB4E7D73CD92E45-8068
Part No SW: 8R0 907 468 H HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0051
Revision: 1Y050025 Serial number: 2541Y12702024D
Coding: 80C303FF00
VCID: 44D6AEAA1E99BC5AABB-8010
Serial number: 8549867701
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000033047059
Coding: 00581B00000000000000
VCID: 3B24D5566367C3A2DA1-806E
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C13204E00410001
VCID: 56F264E2F8053ECAC5F-8002
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0020286248 Dataset Number: 8K0909852H 0023
Coding: 100000000001
Shop #: WSC 06324 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3436FE6A4EB90CDA1BB-8060
Revision: 00002001 Serial number: 0179874643
Coding: 0106023A00FA400580B0013200000000
Component: GTO BF H01 0080
Serial number: 00000000000000545201
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS050 H08 0043
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55F063EEE50335D2CC5-8000
Fault Status: 01101100
Reset counter: 187
Mileage: 160603 km
Date: 2026.04.18
Time: 01:23:41
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000120673
ROD: EV_ParkiBrake_AU48.rod
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156G 0C7614094
Coding: 020007020100000001
VCID: 2118073EE1CB8972E0D-8074
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 184
Mileage: 160562 km
Date: 2026.04.15
Time: 01:02:33
Voltage: 13.10 V
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Fault Status: 00101011
Reset counter: 224
Mileage: 160562 km
Date: 2026.04.15
Time: 01:02:33
Voltage: 13.10 V
Part No SW: 8R1 035 746 G HW: 8R1 035 746 B
Component: H-BNT-NA H43 0901
Revision: -------- Serial number: 204FW0C7506527
Coding: 110200000206A1EF41028B4E00000403140000000000000000
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130K10BS053231
Subsystem 3 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Reset counter: 186
Mileage: 160603 km
Date: 2026.04.17
Time: 02:01:09
Text: ARU9471,TNR,A,1,172,1
00658 - Control Head
Reset counter: 186
Mileage: 160603 km
Date: 2026.04.17
Time: 02:00:48
Voltage: 11.70 V
Reset counter: 187
Mileage: 160603 km
Date: 2026.04.17
Time: 02:09:52
Voltage: 12.60 V
Bin. Bits: 001
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C13204000210001
VCID: 59E86FDE891B11B2E8D-800C
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2590LF
Coding: 1000006
VCID: 382ECA5A5E51E8BA373-806C
Component: TSG HR H07 0304
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 120623201064
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
VCID: 72BA3872742D42EAC97-8026
End----------(Elapsed Time: 01:49, VBatt start/end: 13.6V/13.7V)-----------
------------------------------12 Faults Found------------------------------
