Adaptation of differential pressure sensor?
goingloopy
Nebraska, USA
C?ID=557145
Hi,
I put a new differential pressure sensor on my 2012 Touareg TDI. I would like to run the adaptation which should follow, but I can't seem to locate it. I have been told in the past I have non-UDS car? so that seems to make it harder to find correct instructions online. Anyhow here is my scan and if anyone can direct me I would really appreciate it.
Friday,17,April,2026,16:00:44:04925
VCDS Version: 25.3.3.0 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20260227 DS365.0
VIN: WVGFK9BP6CD002590   License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 65 69 6D 72
VIN: WVGFK9BP6CD002590   Mileage: 308151km-191476miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI FSA    H17 0008
   Revision: 56H17---    CVN: 66FD96005C3E0D04D45710C1
   Coding: 292A4012233600050000
   Shop #: WSC 04938 444 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
   ROD: EV_ECM30TDI0117P0907401J_002.rod
   VCID: 363E488358C64E6A647-8062
   VINID: 9E65D66C94A019350000214900D6A4E4B3
16871 - Particulate Filter; Differential Pressure Sensor
          P2453 00 [11101000] - Implausible Signal
                    Mileage: 307166 km
                    Date: 2026.04.09
                    Time: 19:29:15
                    Engine speed: 1870.50 /min
                    Normed load value: 67.8 %
                    Vehicle speed: 113 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.380 V
                    Exhaust gas jet volume in particle filter: 448.1 m³/h
                    Particle filter: difference pressure: 74 hPa
                    Particle filter: soot mass measured: 7.45 g
                    Particle filter: soot mass calculated: 5.24 g
                    Exhaust gas temperature sensor 3: 488.2 °C
                    Exhaust gas temperature sensor 4: 582.0 °C
5171 - Boost Pressure Regulation
          P0299 00 [01100000] - Control Range Not Reached
9580 - NOx Sensor 1 Bank 1
          P2201 00 [01100000] - Implausible Signal
8863 - Particulate Filter
          P2459 00 [01100000] - Regeneration Frequency
                    Mileage: 305227 km
                    Date: 2026.03.17
                    Time: 17:56:06
                    Engine speed: 1700.00 /min
                    Normed load value: 86.3 %
                    Vehicle speed: 103 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 2 °C
                    Voltage terminal 30: 14.740 V
                    Unlearning counter according OBD: 2
                    Exhaust gas jet volume in particle filter: 360.6 m³/h
                    Particle filter: difference pressure: 120 hPa
                    Particle filter: soot mass measured: 33.76 g
                    Particle filter: soot mass calculated: 12.33 g
                    Exhaust gas temperature sensor 3: 327.2 °C
                    Exhaust gas temperature sensor 4: 298.8 °C
5162 - Particulate Filter; Differential Pressure Sensor
          P2453 00 [01100000] - Implausible Signal
                    Mileage: 308151 km
                    Date: 2026.04.14
                    Time: 09:30:50
                    Engine speed: 0.00 /min
                    Coolant temperature: 35 °C
                    Intake air temperature: 25 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 12.420 V
                    Sensor for particle filter differential press: raw value: 900 hPa
                    Particle filter: difference pressure: 900 hPa
                    DPF: offset for differential pressure: 0 hPa
                    Outside temperature: 18.5 °C
                    Particle filter: soot mass measured: 25.18 g
                    Particle filter: soot mass calculated: 20.55 g
12896 - Boost Pressure Regulation
          P0299 00 [00100000] - Control Range Not Reached
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 3407
   Serial number:                CVN: CB5A7D50
   Coding: 001368
   Shop #: WSC 04766 004 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 30327E9BBAA2605A3EB-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 420810010EC010 Dataset Number: 7P0012v____ 7P13
   Coding: 5B7613C349242555DAF9C89C92D2A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 45DC3F4F1520D5F2FDD-8010
   Part No SW: 4H0 907 064 BK    HW: 4H0 907 064 BK
   Component: BCM2 2.0      H31 0330
   Coding: 0D860000000000000000
   VCID: 73B8B1970BB41B42839-8026
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000151059015
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 248
                    Mileage: 295036 km
                    Date: 2025.12.03
                    Time: 17:30:50
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BA    HW: 7P6 907 040 BA
   Component: Klima 2 Zonen H20 1203
   Coding: B686200A80
   VCID: 74BAB28B0E3A1C7A9A3-8020
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001000] - -
                    Fault Frequency: 11
                    Reset counter: 72
                    Mileage: 304261 km
                    Date: 2026.02.28
                    Time: 19:49:58
   Part No SW: 4H0 907 063 BD    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0100
   Revision: 15012002    Serial number: 00000001170794
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6B88A9F75384C3824B9-803E
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110708  31  0020
   Serial number: 90243400110726231903
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10212526
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001208110014
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0L6P06
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0021
   Revision: --------    Serial number: 28291120295761
   Coding: 110501
   ASAM Dataset: EV_VW526ParkiAssis2 001011
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 42D62453040EE2CAD8F-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag025 H05 0023
   Revision: --------    Serial number: 003JX003MZJ5 Dataset Number: 7P6003v____ 0785
   Coding: 000000000000000000000000000000003235
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 40D22E5B0A02F0DACEB-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1142704U6W
   Serial number: 3575LRB404R0NLV2GGRZ
   Serial number: 3585LRB40530N3MK78IL
   Serial number: 3515RRB40650LCOQCGTJ
   Serial number: 3525RRB40650LCOQA8BZ
   Serial number: 3555NRB40630I3GUJH0N
   Serial number: 3565NRB40630I3GUE103
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 90815KH800056
   Coding: 000C15
   VCID: 382246BB5252B81A76B-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0100960
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 980 N    HW: 7P6 920 980 N
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658140811592041
   Coding: 8B7733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 47C035472F2CC7E20F1-8012
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000212877
   Coding: 0001037500
   GVL: FB4F40455D7B000000
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 382246BB52D2B81A76B-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650207026
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000010903588
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 343A728B4E3A5C7A5A3-8060
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000118382777
   Coding: 011D17205E00453005080000
   VCID: 44DA224B1E9AECFAEA3-8010
   Revision: 00002001    Serial number: 0155532234
   Coding: 0186123A28B9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 188117986
   Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Serial number:     WOO12801590
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Serial number:     WOO12810590
   Coding: 191100
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 211
                    Mileage: 292925 km
                    Date: 2025.11.04
                    Time: 13:14:23
   Part No SW: 7P6 035 466     HW: 7P6 035 466
   Component: DSP Prem      H01 0090
   Revision: 00001001    Serial number: 10811000807103
   VCID: 75BC8F8F05C00572ADD-8020
                    Fault Status: 00101011
                    Reset counter: 217
                    Mileage: 304669 km
                    Date: 2026.03.08
                    Time: 19:31:37
                    Voltage: 12.60 V
                    Temperature: 12.0°C
                    Temperature: 13.0°C
                    Bin. Bits: 00000100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000118707924
   VCID: 3B2859B7636493029B9-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: A11725003D4    Dataset Number:             A001
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0008
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CAA9AAB266A543AD23-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H52 0076
   Revision: AB001007    Serial number: 156HZ0B7540192
   Coding: 020007010000000001
   VCID: 1F108D27D7BCEF22971-804A
   Part No SW: 7P6 035 664 B    HW: 7P6 035 664
   Component: H-BN-NA       H44 0319
   Revision: --------    Serial number: 445H10B7518628
   Coding: 020200050040E1ED41022B0E00000003F0000101
   VCID: 372045875F4CB7627F1-8062
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H25 0045
   Serial number: VWZ8Z9L79002H4
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000118761045
   Coding: 011C17200000253005080000
   VCID: 3A265CB36C5EAA0A80F-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000039368 Dataset Number: 7P6096v____ 0016
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FD02DA777FC8F22B71-806A
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000155069774
   Coding: 020D000000000000
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 22010001    Serial number: 213100028 Dataset Number: 7p0771v____ 0009
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000118759261
End----------(Elapsed Time: 02:08, VBatt start/end: 13.4V/14.2V)-----------
------------------------------10 Faults Found------------------------------
Whoever told you that was mistaken.
Basic Settings:
IDE00468 -- Resetting of learned values of difference pressure sensor
goingloopy
Nebraska, USA
C?ID=557145
I tried that and it didnt clear. Do I do it with key on but engine not running?
