ABS Unit Coding - Bentley Continental GT 2005
rynaqui
Malta
C?ID=608947
Hello all,
This is my first post here, I purchased VCDS a little over a year ago from a European distributor (I am from Malta) as it was recommended to me by another Bentley owner in the hopes of troubleshooting a recurring fault which we have now pinpointed to a dead ABS unit (t was taking down the whole network).
We could not communicate with the vehicle at all even using VCDS until we disconnected the ABS unit, we were then able to communicate with the vehicle accordingly. Subsequently, we purchased a second hand ABS unit and can confirm that with this ABS unit connected, VCDS recognizes the vehicle successfully. Now my query is how to get the unit coded, I do not have the original coding due to the module being dead, we even sent it out for repair but basically received the unit back the same as it was, unresponsive. The module part number is 3W0614517D. Also, as a note, the part number matches the one originally in the vehicle if that helps.
Thank you in advance!
Ryan Aquilina
Dr Sheldon
Windsor UK
C?ID=334979
First Post an Autoscan - The solution to you problem is well known and documented but I need to see the scan to verify some things.
rynaqui
Malta
C?ID=608947
Will get to that first thing in the morning, thank you!
That's not unheard of. ABS modules of that vintage (I'm thinking this is likely a Bosch 5.3..?) have a failure mode where they clamp the K-line to ground, which prevents communications to all modules in the car.
rynaqui
Malta
C?ID=608947
Hello guys, I have just done the Autoscan (without clearing of any faults if this matters). Thank you.
Saturday,18,April,2026,10:06:03:06882
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20260227 DS365.0
VIN: SCBCE63W05C029119   License Plate: KBL447
Mileage: 33670km-20921mi   Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W05C029119   Mileage: 33670km-20921miles
Address 01: Engine        Labels: 07C-906-018-BEB1.clb
   Part No: 07C 906 018 AQ
   Component: BY-6.0L-TT      G  ª6520
   Revision: 08ÿTT       Serial number:  000-00008.01.
   Coding: 0000173
   VCID: 74B50D8F62AA818A9A3-5160
   VINID: 8D34935460E70054C008904124EFB91AB3
28793 - No Communication with ABS Brake Control Module
            U0121 - 008 -  - Intermittent
16455 - Sensor for Ambient Air Temperature (G17)
            P0071 - 004 - Implausible Signal
18331 - Please Check DTC Memory of ECU Number 2
            P1923 - 008 -
16929 - Sensor 1 for Exhaust Temp Bank 1 (G235)
            P0545 - 002 - Short to Ground - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.clb
   Part No SW: 09E 927 760 G    HW: GS1 904 1
   Component: AG6 09E 6.0L W12TT  1905
   Coding: 0000101
   Shop #: WSC 00083 000 00000
   VCID: 3435CD8F222AC18A5A3-5160
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Status: 00110000
                    Mileage: 33670 km
                    (no units): 30.0
                    (no units): 153.0
                    Temperature: 17.0°C
                    T.B. Angle: 0.0°
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.clb
   Part No: 3W0 614 517 D
   Component: ESP 5.7 4WD     H01 0021
   Coding: 0000000
   VCID: 3631F7873456D39A647-5160
   Part No SW: 3D0 909 135 Q    HW: 5WK 470 22
   Component: 13 Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0E3306517
   Coding: 0159981
   VCID: 3337CE932724C6B2439-5160
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
            001 - Upper Limit Exceeded
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 G
   Component:    ZAB COCKPIT      0223
   Coding: 0400335
   VCID: 303DC19FD632FDAA3EB-5160
00384 - Optical Databus
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 C
   Component: Climatronic BY614   2009
   Coding: 0000101
   VCID: 313BC49BDD38F4A2315-5160
            010 - Open or Short to Plus
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000107
   VCID: 2F3FC2E3CB0CE252271-5160
7 Faults Found:
01494 - Bulb for Parking Lamps; Left (M1)
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
52784 - Unknown Error Code
            Unknown - 001 -  - Intermittent
00000 - End of output
Address 11: Engine II        Labels: 07C-906-018-BEB2.clb
   Revision: 96ÿTT       Serial number:  000-00008.01.
   Coding: 0000173
   Part No: 3D0 909 601 E
   Component: 0P Airbag 8.4E+ H10 0936
   Coding: 0012368
   VCID: 251320CB99F0A802DDD-5160
01218 - Side Airbag Igniter; Passenger Side (N200)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
00592 - Seat Belt Switch; Passenger (E25)
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 D
   Coding: 0000012
   VCID: 2E01DFE7CC06EB5A2C7-5160
Address 17: Instruments        Labels: 3Wx-920-xxx-17.clb
   Part No: 3W0 920 840 R
   Component: KOMBIINSTRUMENT RB8 0514
   Coding: 0021403
   VCID: 43D79E5377847632D39-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70BD019F16B2BDAA7EB-5160
00461 - Control Module for Seat Memory; Passenger (J521)
Address 34: Level Control        Labels: 3D0-907-553-V1.clb
   Part No: 3W0 907 553
   Component: LUFTFDR.-CDC- 3C1V0 7014
   Coding: 0015500
   VCID: 77AF3A8373DCEA92BF1-5160
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000002
   Shop #: WSC 00092 106 68669
   VCID: 3FDF92A31B6C12D2B71-5160
9 Faults Found:
00997 - Motor for Driver's Seat Position; Fore/Aft (V48)
01174 - Driver Seat Height Adjustment Motor (V138)
00998 - Motor for Driver's Seat Recline (V45)
01903 - Seat Tilt Adjustment Motor (V231)
01895 - Motor for Steering Column Adjustment; Vertical (V123)
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 C
   Component: Dachmodul           0703
   Coding: 0000157
Address 46: Central Conv.        Labels: 3D0-959-933.clb
   Part No: 3D0 959 933 F
   Component: 20 HSG              0101
   Coding: 0000032
   VCID: 3337CE932724C6B2439-4B28
   Subsystem 1 - Part No: 3W2 959 701
   Component: Tuersteuergeraet FS 0702
   Subsystem 2 - Part No: 3W2 959 702
   Component: Tuersteuergeraet BF 0702
   Subsystem 3 - Part No: 3W3 959 703 A
   Component: Tuersteuergeraet HL 0702
   Subsystem 4 - Part No: 3W3 959 704 A
   Component: Tuersteuergeraet HR 0702
   Subsystem 5 - Part No: 7L0 907 719
   Part No: 3W0 035 456 C
   Component: 12K-AUDIOVERST      4121
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 B    HW: 3W0 907 801 B
   Component: EPB  BC6HX23    HC6 X230
   Coding: 0022413
   VCID: 3533F08B2950D8826DD-5160
                    Fault Frequency: 17
                    Reset counter: 126
                    Voltage: 12.11 V
                    Count: 242
Address 54: Rear Spoiler        Labels: 1C0-959-733.clb
   Part No: 1C0 959 733 H
   Component: Heckspoiler         0002
   VCID: 303DC19FD332FDAA3EB-5210
Address 57: TV Tuner        Labels: 3D0-919-146.lbl
   Part No: 3D0 919 146
   Component: TV Tuner        H07 1205
   Coding: 0000010
   VCID: 659360CBD97068021DD-5160
Address 65: Tire Pressure        Labels: 3D0-907-273-V2.clb
   Part No: 3D0 907 273 D
   Component: Reifendruckueberw.  0025
   Coding: 0181300
   VCID: 270F2AC3E3FCBA12EF1-5160
01312 - Powertrain Data Bus
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 C
   Component: Wische*
   Shop #: WSC 00000 725 65552
   VCID: 372FFA83335C2A927F1-5160
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 C
   Component: Batteriemanagement  2700
   VCID: 23173ED397C45632B39-5160
Address 76: Park Assist        Labels: 3W0-919-283-V1.clb
   Part No: 3W0 919 283 A
   Component: 02 Einparkhilfe     0303
   VCID: 3B27E6B30F740EF29B9-5160
Address 77: Telephone        Labels: None
   Part No: 3W0 035 729 D
   Component: Telefon             0119
   VCID: 382DF9BF3E4225EA76B-5160
End----(Elapsed Time: 07:33, VBatt start/end: 11.5V/11.4V. VIgn 0.0V)------
------------------------------53 Faults Found------------------------------
That produces a very poor signal-to-noise ratio.
Please clear fault codes in all modules that have them and let's see what comes back.
PS: Please Get Verified.
rynaqui
Malta
C?ID=608947
Noted, just completed a second scan with the faults cleared, the seat faults are due to the seat being removed as we initially thought there may be water ingress under the carpet. I just registered the HEX-V2 via the app and it should be waiting for approval so I can finalize on the app. I appreciate your guidance. EDIT: Just went to re-scan and grab the code directly, hope this is better.
Sunday,19,April,2026,14:01:51:06882
   Coding: 0000173
            P1923 - 008 -  - Intermittent
   Coding: 0000101
   Coding: 0000000
   Coding: 0159981
   Coding: 0400335
00857 - CD Changer Unit (R41)
   Coding: 0000101
   Coding: 0000107
8 Faults Found:
00967 - Left Turn Signals
60960 - Unknown Error Code
            Unknown - 000 -  - Intermittent
   Coding: 0000173
   Coding: 0012368
   Coding: 0000012
   Coding: 0021403
   Coding: 0000006
   Coding: 0015500
   Coding: 0000002
   Coding: 0000157
   Coding: 0000032
   Coding: 0022413
   Coding: 0000010
   Coding: 0181300
   Component: Wische*
End----(Elapsed Time: 07:36, VBatt start/end: 12.7V/12.5V. VIgn 0.0V)------
------------------------------35 Faults Found------------------------------
Your first scan was posted correctly. But for this one, you used the [Print] function in VCDS. Please don't do that; it's much less readable here than the original text that VCDS produces.
Yep. I've moved this to Car Repair Support.
rynaqui
Malta
C?ID=608947
Sorry about that, I'll use the original text next time.
Dr Sheldon
Windsor UK
C?ID=334979
Either Edit or repost the scan - It makes a huge difference to those reading it.
rynaqui
Malta
C?ID=608947
Just rescanned and edited my previous post, hope it's ok now.
OK, watch this video for a general overview of how coding this ABS works.
Then try Login / Coding II:
03121 = Bentley Continental Flying Spur (3W2/BY611)
02121 = Bentley Continental GT/Cabrio (3W3/BY614 - 3W4/BY615)
02321 = Bentley Continental GT Diamond Series (3W3/BY614)
Coding:
0006878 = Bentley Continental Flying Spur (3W2/BY611)
0007878 = Bentley Continental GT/Cabrio (3W3/BY614 - 3W4/BY615)
0007678 = Bentley Continental GT Diamond Series (3W3/BY614)
I'm no sure which set of these is applicable to this car.
And don't forget to calibrate the steering angle sensor or you will lose the coding.
rynaqui
Malta
C?ID=608947
Thank you for the quick response. It is a 2005 Bentley Continental GT Coupe so I guess the 02121 and 0007878 will apply? I'll take a good look at the video and get back to you on my results.
