VW CADDY ISSUES!!!
Syg85
Barrow in Furness, UK
C?ID=596919
A FAMILY MEMBER HAS HAD A RECENT HEAD REBUILD AND THE VAN SAT FOR ABOUT 3 YEARS GIVE OR TAKE AND IN DOING SO IT HAS BROUGHT UP SOME FAULTS THAT REALLY NEED DOING ASAP SO HERE I AM FOR ANY SUGGESTIONS BEFORE SPENDING POINTLESS TIME AND MONEY ON THE WRONG SOLUTIONS
THE VAN HAS STARTED UP EASY ENOUGH FROM THE OFF WITH A NEW BATTERY. I'VE LOOKED OVER THE GROUNDS WHERE I CAN SEE AND SEEM FINE AND CHECKED FUSES WHICH COME BACK GOOD MAINLY FOR ABS FAULT. THE OBVIOUS SAYS TO ME REPLACE GLOW PLUGS AS THEY MAY BE ORIGINAL FROM NEW SO 16 YEAR OLD SO WILL BE BOUGHT REGARLESS, NEW OEM CAMSHAFT SENSOR AND ABS CONTROL MODULE(THIS IS WHAT I DONT WANT TO HAVE TO REPLACE AS ITS NOT JUST PLUG AND PLAY) BUT I'M HAPPY TO CHECK WIRING HARNESSES ETC IF I KNOW WHERE TO LOOK/TEST TO CONFIRM IF IT HAS TO HAVE A NEW ONE. ALSO A STRANGE ISSUE WITH COOLANT LIGHT COMES ON RANDOMLY EVEN THOUGH ITS FILLED CORRECTLY WITH NO FAULT LOGGED AND THE TURBO HAS AN OVERBOOST SO COULD BE THAT A LINE IS LEAKING AS ITS HAD A BRAND NEW TURBO ON RECENTLY. THE N75 VALVE I'LL BE LOOKING OVER TO SEE IF THAT'S WORKING CORRECTLY.
AGAIN THIS ISN'T MY VAN AS I'M HERE TO TRY HELP A BROTHER OUT SO THERE WILL BE BITS I'VE MISSED OFF MOST LIKELY SO I CAN GET FURTHER INFO IF NEEDED WHEN I CAN GET ACCESS AGAIN TO VAN
SO YEAH ANY HELP WOULD BE GREATLY APPRECIATED
Tuesday,14,April,2026,18:35:15:07743
VCDS Version: 25.3.1.2  HEX-V2 CB: 0.4671.5
Data version: 20250604 DS365.0
 MORE
VIN: WO HELP V1ZZZ2KZAX146500   License Plate: DN60 BWO
Mileage: 134433   Repair Order:
Chassis Type: 2K (7N0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZAX146500
03-ABS Brakes -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 PD    HW: 03G 906 021 CG
   Component: R4 1,9L EDC  000SG  2387
   Revision: --H13---    Serial number: VWX7Z0J53NP043
   Coding: 0000031
   Shop #: WSC 01286 386 08256
   VCID: 70BE089656A2F07A7F9-8024
   VINID: 9E606AAAA09BA91A01106140003C7F2285
012295 - Camshaft Position Sensor (G40)
               P3007 - 000 - No Signal - Intermittent
                    Fault Status: 00110000
                    RPM: 168 /min
                    Speed: 2.0 km/h
                    Voltage: 9.65 V
                    Bin. Bits: 00000100
                    Idle Stabilization: 0.0°KW
                    (no units): 32.0
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
                    Fault Status: 01110000
                    Mileage: 215349 km
                    Time: 00:02:18
                    RPM: 1008 /min
                    Speed: 8.0 km/h
                    Load: 0.8 %
                    Voltage: 14.29 V
                    Bin. Bits: 00000100
                    Temperature: 6.3°C
                    Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 215349 km
                    Time: 00:02:18
                    RPM: 1008 /min
                    Speed: 8.0 km/h
                    Load: 0.8 %
                    Voltage: 14.29 V
                    Bin. Bits: 00000100
                    Temperature: 6.3°C
                    Bin. Bits: 10110000
000564 - Boost Pressure Regulation
               P0234 - 000 - Limit Exceeded (Overboost Condition)
                    Mileage: 215842 km
                    Time: 08:43:15
                    RPM: 2352 /min
                    Speed: 130.0 km/h
                    Load: 100.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00000000
                    Absolute Pres.: 2162.4 mbar
                    Absolute Pres.: 2529.6 mbar
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller
                    Fault Frequency: 69
                    Mileage: 216353 km
                    Time: 16:09:24
                    Voltage: 11.32 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
Readiness: 1 1 0 0 X
Address 03: ABS Brakes
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 01000004063314
   Coding: 00884F030004100057000000000000000008FB075C000120000000000000
   Shop #: WSC 12345 111 45725
   VCID: 323AC29E982E826A49D-8066
   Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
   Shop #: WSC 12345
9 Faults Found:
                    Fault Status: 00101100
                    Fault Frequency: 11
                    Reset counter: 167
                    Mileage: 214659 km
                    Voltage: 11.15 V
02071 - Local Databus
                    Reset counter: 160
                    Mileage: 215339 km
                    Voltage: 12.50 V
                    Reset counter: 161
                    Mileage: 215320 km
                    Voltage: 8.05 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 129
                    Mileage: 215694 km
                    Voltage: 13.90 V
                    Fault Status: 00100001
                    Reset counter: 161
                    Voltage: 15.65 V
                    Reset counter: 167
                    Mileage: 215320 km
                    Voltage: 7.45 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 160
                    Mileage: 215339 km
                    Voltage: 12.50 V
01598 - Drive Battery Voltage
                    Reset counter: 158
                    Mileage: 215317 km
                    Voltage: 13.85 V
00926 - Terminal 30
                    Fault Status: 00101011
                    Reset counter: 160
                    Mileage: 215339 km
                    Voltage: 5.00 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 2Q AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR082NY4
   Coding: 0012881
   Shop #: WSC 35110 377 00159
   VCID: 7DA021A211F08D12E4F-8028
   Part No SW: 1K0 953 549 DA    HW: 1K0 953 549 DA
   Component: J0527           053 0111
   Coding: 0000002
   Shop #: WSC 35110 377 08192
   VCID: 74B6048622BACC5A9B1-8020
Address 17: Instruments
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 0602
   Revision:   H27       Serial number: 120610F2001230
   Coding: 89801F0200020200007401
   VCID: 6D8011E241901D9254F-8038
                    Reset counter: 127
                    Mileage: 216353 km
                    Time: 16:09:24
                    Reset counter: 24
                    Mileage: 208724 km
                    Time: 12:56:55
                    Reset counter: 161
                    Mileage: 215349 km
                    Time: 22:44:35
   Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
   Component: IMMO            VDD 1222
   Revision: V0002000    Serial number: VWX7Z0J53NP043
   VCID: 2C06DCE6BA0AD49A031-8078
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   VCID: 76B23E8E34C6DE4AA55-8022
   Part No: 1K0 959 433 CP
   Coding: 008A0C087F2D84054858030000C0
   Shop #: WSC 00000 000 2088960
   VCID: 005E58566602E0FA8F9-8054
01312 - Powertrain Data Bus
            013 - Check DTC Memory
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75B0398229C0D552ACF-8020
Address 56: Radio
End----------(Elapsed Time: 00:51, VBatt start/end: 12.5V/12.5V)-----------
------------------------------19 Faults Found------------------------------
Jef
HQ
No need to shout at us, we are all right here in the same forum.
I'm not 100% certain I'm finding the correct wiring diagram for the ABS module here, but lets see how this plays out.
  • SB1 >>> T46a/30 (red/white)
  • SB2 >>> T46a/1 (red/yellow)
  • SB17 >>> T46a/31 (red/black)
Those look to be terminal 30 (always have power), verify they can carry load (light up a test light at the very least).
T46a/35 (black/violet) looks to be the terminal 15 signal, ignition on to wake up the ABS, very it has power with ignition.
  • T46a/14 (brown)
  • T46a/46 (brown)
Those are your grounds, again, verify they can carry load.
  • T46a/42 >>> CAN high (orange/blue)
  • T46a/43 >>> CAN low (orange/brown)
With ignition on, check voltages to ground on each one, the 2 values should add up to about 5V in total.
Repair as needed, but the holy trinity (powers/grounds/data) are good, time to replace the ABS module.
Syg85
C?ID=596919
  • T46a/14 (brown)
  • T46a/46 (brown)
I certainly ain’t shouting at you guys, maybe a lot of that being done towards the fault finding haha
Thanks for the heads up as I can try testing with this info and report back.
Have a great weekend
Reactions: Jef
