2012 Audi Q7 TDI
DomD
South Carolina, USA
C?ID=551590
Ok fellas I need some help! Had to get our Q7 towed the other day. It was running rough and had no throttle response at all. Felt like it was missing on several cylinders. Finally got vcds hooked to it and pulled and recorded codes before start up and cleared and after start up. Also, checked cam phase start and end and recorded the chart, but i am unsure of what I should be looking for with that as good and not good values. I put links at the bottom to the 3 records to help out I also took a video but I think the mic distorts too much of it to really get a clear sound of it running. I just had tires put on it and it was running fine for a day or two then yesterday morning it threw in the towel.
When I cleared the codes before I started it this code came back immediately, feel like it could be the issues not allowing the engine to breathe. I feel like it does have a slight timing chain rattle at initial start up (could also be more of me being paranoid) but I feel like it had other codes active and either a hard knock or a no start.
Any help would be great because we use this primarily for a family car and need to get it backup and running as soon as possible. Just wanted to get some more feed back.
Thank you in advance!
https://drive.google.com/file/d/1uGXW2FiMUkf-Fo5_J2hd6mO-ag_JgSOL/view?usp=drivesdk
https://drive.google.com/file/d/1YpzPdivqCeCIm0Y0L0ZnIvaesVTKMhM6/view?usp=drivesdk
https://drive.google.com/file/d/1udYFDj53ryTP65cMaNi1c4qm6cdwTWaW/view?usp=drivesdk
DomD
South Carolina, USA
C?ID=551590
Thursday,16,April,2026,13:45:22:01480
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 26.3.0.0 (arm64)  HEX-V2 CB: 0.4701.4
VIN: WA1VMAFE3CD010600   License Plate:
                Address 01: Engine       Labels: 059-907-401-V2.clb
Control Module Part Number: 4L2 910 401     HW: 4L0 907 401 D
  Component and/or Version: 3.0TDI FSA    H18 0009
           Software Coding: 2A2A4012253600050000
            Work Shop Code: WSC 30957 003 1048576
              ASAM Dataset: EV_ECM30TDI0114L2910401 002008 (AU56)
                       ROD: EV_ECM30TDI0114L2910401_002.rod
                      VCID: 619FB707E1C9F682A0D-8035
5585 - Particulate Filter (Bank 1)
          P242F 00 [00101111] - Restricted/Clogged
                    Mileage: 316891 km
                    Date: 2026.04.16
                    Time: 13:31:05
                    Engine speed: 0.00 /min
                    Coolant temperature: 24 �C
                    Intake air temperature: 28 �C
                    Voltage terminal 30: 11.380 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Exhaust gas jet volume in particle filter: 0.0 m�/h
                    Particul.filter diff.pressure: 4 hPa
                    Particle filter: oil ash volume: 0.50 l
                    Exh t Adap T Oxi Cat Ds: 27.8 �C
                    P Flt Ld fac Ash Cor: 0.5457
19186 - Fuel Injector #4 (N33)
          P0272 00 [11101101] - Contribution/Balance Fault
                    Mileage: 316891 km
                    Date: 2026.04.16
                    Time: 13:32:06
                    Engine speed: 861.00 /min
                    Normed load value: 88.2 %
                    Coolant temperature: 23 �C
                    Intake air temperature: 27 �C
                    Voltage terminal 30: 13.240 V
                    Accelerator pedal: sensor voltage 1: 737.8 mV
                    Accelerator pedal: sensor voltage 2: 371.2 mV
                    Accelerator pedal: switch positions-Bits 0-7: 8
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 17
                    Limitation: torque: 211.8 Nm
                    Control Module temperature: 34.3 �C
19187 - Fuel Injector #3 (N32)
          P0269 00 [11101101] - Contribution/Balance Fault
                    Mileage: 316891 km
                    Date: 2026.04.16
                    Time: 13:32:06
                    Engine speed: 962.50 /min
                    Normed load value: 82.4 %
                    Voltage terminal 30: 13.340 V
                    Limitation: torque: 214.2 Nm
19184 - Fuel Injector #6 (N84)
          P0278 00 [01100101] - Contribution/Balance Fault
                    Mileage: 316891 km
                    Date: 2026.04.16
                    Time: 13:32:08
                    Engine speed: 968.00 /min
                    Normed load value: 74.9 %
                    Voltage terminal 30: 13.280 V
                    Unlearning counter according OBD: 79
                    Limitation: torque: 212.4 Nm
19188 - Fuel Injector #2 (N31)
          P0266 00 [11101101] - Contribution/Balance Fault
                    Mileage: 316891 km
                    Date: 2026.04.16
                    Time: 13:32:06
                    Engine speed: 913.50 /min
                    Normed load value: 87.5 %
                    Voltage terminal 30: 13.300 V
                    Limitation: torque: 211.9 Nm
