A4 B8 facelift - ACC retrofit
diskoboy
Denmark
C?ID=50403
I've been trying to find the correct codeing for my ACC, but it's not possible.
Can anyone help me please?
Instrument is beeing replaced with the correct one within this or next week.
I've coded 01, 16 and 19, but I'm missing something in 13 (and perhaps in other modules ;))
Thursday,25,February,2016,12:38:51:21096
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: WAUZZZ8K3DA04xxxx   License Plate: A4
Mileage: xxx km-xxx mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 03 05 08 09 13 15 16 17 19 42 44 46 52 53 56 5F 62 69 72
VIN: WAUZZZ8K3DA04xxxx   Mileage: xxx km-xxx miles
Address 01: Engine (B8-PA-CDHA)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K1 907 115 N    HW: 8K1 907 115 N
   Component: 1.8l R4/4V TF H04 0002
   Revision: PBH04---
   Coding: 12190013045401022000
   Shop #: WSC 06208 123 12345
   ASAM Dataset: EV_ECM18TFS0118K1907115N 001004
   ROD: EV_ECM18TFS011.rod
   VCID: 3972996DB80BFAF651-806C
Readiness: 1110 0101
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 019544
   Shop #: WSC 06334 123 12345
   VCID: 0004348993516B3E56-8054
   Part No SW: 8K0 907 064 FC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H10 0602
   Coding: 03A20000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 76E85251C195558E7C-8022
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Component: KLIMA 3 ZONEN H04 0036
   Revision: C1000000    Serial number: 01220320120348
   Coding: 642002C000
   Shop #: WSC 06335 123 12345
   VCID: 336EAB45926700A69B-8066
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000789001102
   Coding: 2600C0308134AFE00481000300001D0D4F9C260826080301000008000000020000000000000000
   VCID: 78F45C69CB8123FE6E-802C
   Component: WWS 250312  H07 0070
   Coding: 00FD11
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Component: AQ_Hum_Sensor  H02 0002
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Fault Status: 01101100
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:42
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H11 0100
   Coding: 00F2D1
   VCID: 3162A14D687B32B6E9-8064
00234 - Sensor for Automatic Distance Regulation Misadjusted
            000 -  -
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:40
                    Temperature: 14.0°C
                    Voltage: 12.29 V
                    Hex Value: 0x0031
                    Lateral Accel.: 0.00 m/s^2
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:40
                    Temperature: 14.0°C
                    Voltage: 12.29 V
                    Hex Value: 0x007F
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:40
                    Temperature: 14.0°C
                    Voltage: 12.29 V
                    Hex Value: 0x00B7
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:40
                    Temperature: 14.0°C
                    Voltage: 12.29 V
                    Hex Value: 0x00D8
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD91YZKL
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 05298 002 1048576
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4894ECA9F3E1937EDE-801C
   Serial number: 6334MSME6C112A41A
   Serial number: 6344MSME6D740409H
   Serial number: 6352QSME530F354AM
   Serial number: 6362QSME570F3F6E0
   Serial number: 63732SME7E0F586CN
   Serial number: 63832SME7A0F22665
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LAA00140
   Coding: 0000DF
   VCID: 448CF899C7C9B71E32-8010
   Component: E221 - MFL  H03 0003
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 900 S    HW: 8K0 920 900 S
   Component: KOMBIINSTR.   H09 0540
   Revision: 00200000    Serial number: MVH430C3D
   Coding: 0F0F100002010008010000
   VCID: 3A708661B50DF1EE58-806E
   Part No SW: 8T0 907 468 AE    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0117
   Revision: FC100058    Serial number: 5800F11504061D
   Coding: 00CB07
   VCID: 040C38998749771E72-8050
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 Q    HW: 8K0 959 793 Q
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000027168465
   Coding: 011002204000410001
   VCID: 4E98DAB119854D4E94-801A
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0010433530
   Coding: 100000000001
   Shop #: WSC 17369 000 1048576
   ROD: EV_RCEPSAU48X.rod
   VCID: 346CA8599F69079E82-8060
3158792 - Function Restriction due to Implausible Message(s)
          U1112 00 [009] - -
                    Reset counter: 0
   Revision: 00002001    Serial number: 0173622348
   Coding: 0100062020B900408130023680000000
   Part No SW: 8K0 959 792 Q    HW: 8K0 959 792 Q
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000027164387
   VCID: 4D9ADDBD14837656ED-8018
Styreenhed  53: Parking Brake (----)     Labels: NEZ\8K0-907-801-V2.clb
   Part No SW: SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component	: EPB-4         H01 0001
   Revision: --------    Serial number: 30000000034229
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 366892518915158EB7-8062
   Part No SW: 4G0 035 061 E    HW: 4G0 035 061
   Component: Radio U DAB   H52 0099
   Revision: AB001007    Serial number: 109FV0B7526224
   Coding: 010105020100000001
   Shop #: WSC 31414 790 00001
   VCID: 1F4657F50EEFB4C64F-804A
02982 - Connection between Radio and Impedance Converter 2
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:32:18
                    Voltage: 12.30 V
02877 - Digital Radio Antenna (R183)
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:32:18
                    Voltage: 12.30 V
   Part No SW: 8R1 035 670 K    HW: 8R1 035 670 C
   Component: H-BNT-EU      H46 0941
   Revision: --------    Serial number: 207GZ0D7554081
   Coding: 160100010106CBEC0180EF5C00000403040000000100000100
   VCID: 3B7E8365BA37C8E643-806E
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  5298
            000 -  -
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:45
                    Text: DUA130,Front,M,0,0,6
            000 -  -
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:52
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000100
                    Bin. Bits: 00000000 00000001
02168 - Left Front Microphone (R140)
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:45
                    Voltage: 12.10 V
02169 - Front Right Microphone (R141)
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:45
                    Voltage: 12.10 V
02612 - Audio Wire Adapter Set
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:53
                    Voltage: 12.10 V
03623 - Invalid Secruity/Release Code
            000 -  -
                    Reset counter: 230
                    Mileage: 42047 km
                    Date: 2016.02.25
                    Time: 12:31:43
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000027010898
   Coding: 010002204000210001
   VCID: 438EFB85C2C7B0260B-8016
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000172587953
   Coding: 010D000000000000
   Shop #: WSC 25381 000 00000
   VCID: 366892518115158EBC-8062
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000027010090
End-------------------------(Elapsed Time: 03:00)--------------------------
NEtech
Denmark
C?ID=56995
While looking through many Autoscan, I would say you need an 8K0 907 379 CN ABS.
How adaptation channels are in [03-ABS] I don't know, a secure access is needed.
Then coding in [13-Auto Dist.] could be: 00A4B1
diskoboy
Denmark
C?ID=50403
Thank you very much! The coding was accepted :-)
However changing the ABS unit was not part of the plan :( I can see that " CN " ABS unit also supports TPMS and Hill Hold, so I'll get 3 functionalities when I'm changing it :)
XPepino
Czech Republic
C?ID=91614
Hello Diskoboy
I made same retrofit on Audi A6 2012, but there it is more complicated. System in A4 is more simple. You dont need to change door switch, instrument cluster is also ok for ACC (8T4) (but there is error from instrument cluster in radar, hope it is only due coding instrument cluster.) I saw also error in 5F (hope you retroffited it too)
This message
Can be clean by Vag Can Pro in one click or by Vin Patcher:
http://uloz.to/xN4udNw8/vin-patcher-sw-zip
Use instructions
1. Select "Create SD" in menu option and select the free SD card.
2. Insert SD into MMI/RNS and run the script
3. Press "open" button and select the texts.jar file from root of SD
4. Type you VIN number to the VIN field
5. Press "Patch" button
6. Wait for Patch OK message
7. Press "Update SD" in menu
8. Turn on MMI and insert SD card, wait for script run
XPepino
Czech Republic
C?ID=91614
I am not sure if you really need to swap ABS... In Etka there is no difference between ABS assign to 8T4 PR code.
Try secure access in ABS - 61378
diskoboy
Denmark
C?ID=50403
Thanks. The security Code is allready shown in VCDS.
What should I've change in 03-ABS ?
XPepino
Czech Republic
C?ID=91614
Hello Diskoboy
Are you sure, that you have wire to ABS from ACC ?
In long coding helper is not in VCDS more infos about coding ?
Try these coding for ABS: (after security access)
031544
160504
179D4C
Try ACC coding:
007DA8
I found somewhere some more infos but not in English:
Activation acc adaptive cruise control + (Audi braking guard)
Encodings possible to change 00EEF0, 00EEE9 00A0D0 0079C0 /// ??? Not sure for what module he mean.
ACC activation, enter the hidden menu, car> cardevicelist> ACC and AWV, cardmenuoperation> ACC and AWV put the value 5, restart MMI
Module 1 Engine: Byte 5 - 6 bits from 0 to 1 (if you have cruise control, remove the bit 5); This is long coding: 12194012234403080000, I have a 2.0 TDI engine from 120 hp;
Form 19 can-gateway: Installation List add to the module 13 (radar), then I left the encoding you had (000,303); my original was 00CF07;
16 steering module: Byte 2, in addition to bit 2 (cruise control) is also turned on bit 3 (ACC); 00001F is instead of 000017 (CCS);
17 instruments module: 4 bytes bit 2 to be activated;
56 radio module; 4 8-bit bytes to be activated (ACC), and byte 10 bit 6 to be activated (Audi braking guard);
13 Radar: I left the code that was (0079C0), (OK 00EEF0) though they had seen on the internet and tried to accept other codes. Maybe I'll try later to see what happens. I also added: Adaptation - channel 7 - 0 to 1 - save ... .so you can adjust the default value of the distance by which part of the ACC.
diskoboy
Denmark
C?ID=50403
Thanks XPepino. I'll test the codings tomorrow and give some feedback :)
Looking in ElsaWin there should be no wire from ACC to ABS.
The only wires are:
T8a/1 - Ground
T8a/2 - Can Extended High
T8a/3 - Can Extended Low
T8a/8 - Fuse SC 9
Since the car was born without Cruise Control, it could be that I'm missing a wire from T94/45 (ECU) to T16f/5 (Steering Colum). I'll have to check that tomorrow as well.
Mrclopec
Nipomo, CA
C?ID=149231
No. He does need to change his ABS unit. His current one is 1AS. He needs one with pr code 1AT. 1AT is required on cars with ACC, hill hold, etc.
Zenerdiode
Newcastle, England
C?ID=24330
Quite correct; as the functionality mentioned (ACC, hill hold, braking guard etc.) all require an ABS module that can supply its own hydraulic pressure. The 1AS unit does not have the hardware to pressurise the hydraulic circuit.
diskoboy
Denmark
C?ID=50403
Just bought a almost new ABS unit on eBay. Now lets see when it's arriving.
Thank you all.. This thread will continue when the ABS unit arrives. ;)
Mrclopec
Nipomo, CA
C?ID=149231
Which unit did you go with?
diskoboy
Denmark
C?ID=50403
The one Netech suggested: 8K0 907 379 CN
Found whats looks to be a new one on eBay for 255€ (approx 290 USD) including shipping
Mrclopec
Nipomo, CA
C?ID=149231
The CN would most likely work, but it is incorrect for your vehicle's build date. I would have gone with the CH version. Just my .02
diskoboy
Denmark
C?ID=50403
Well - now it's bought and shipped so let's see how it goes.
BTW - I've really like your signature :-)
diskoboy
Denmark
C?ID=50403
Finally I think I have time to change the ABS unit this weekend.
Can I take the coding from the old unit to just copy/paste it or is special (online) coding needed ?
Does the ABS unit have component protection?
Mrclopec
Nipomo, CA
C?ID=149231
ABS unit shouldn't have CP. I would start a new thread with a new autoscan regarding the changing of your ABS unit. Never assume coding is the same when going from one unit to another. Online services shouldn't be needed but hopefully someone at RT can generate the new coding string for you based on your current one (if needed).
Franky_D
Denmark
HC826109
Hi,
I can see you replied on few threads about ACC, i hope i pick you brain re my issue. :)
I've got a 2016 A5 sportback (8T), 1.8tfsi Multitronic. From new, I have been experiencing a strange "tick" or "knock" sound from behind the dash, left side (above pedals, where various relays are or from behind firewall??). Every time i accelerate, i can here it at approx 15-17 km/h, kus one single "tick" or "knock". I mean not only the first time i accelerate after i start the engine (in which case breaking system does something to calibrate), but every single time.
The only time i do not hear it is when i breakdown using gears (not breaks) , after that no tick during acceleration. I even though that it was something to do with pads in the front. The dealer took pads off, used paste, etc. put it together and said everything was fine there.
Interestingly enough, when they were working on my car, i got a loaner Q5 and i could hear the same sound, not as pronounced though. Maybe because it was diesel and general noise from the engine was higher.
I've had A4 and Q5 (both FL, 2013-2015) before without ACC and never experienced such annoying sound before. I tend to think that this "tick" or "knock" sound is due to the ACC installed on the car. The Q5 loaner was also equipped with ACC. I am therefore questioning, what is the difference under the dash (or that direction, possibly straight behind the firewall?) between a car (A4/A5/Q5) with and without the ACC? Any additional relays use by ACC? Different ABS module or different logic of ABS operation? Anything different in the breaking system otherwise? In the ACC system, is there something special happening around 15-17 km/h (anything activating/deactivating or engaging/disengaging)?
I would appreciate any thoughts! :)
Thank you!
