Battery coding
golf_golf_7
C?ID=646973
Hi,
The car battery to be installed should arrive tomorrow - It may not be the best! but hopefully it'll be OK - It is a Yuasa YBX3110 - I've researched / found the procedure to code the battery from within the VCDS software so I'm not asking about the whole procedure, just part of it for when it is time to code it.
Battery Adaptation Manufacturer, shows 3 digits for this - What would be the best or appropraite value to insert as the stored value?
I'm just prepping for the eventual coding - Thank you.
EDIT - I've seen an option for "unknown" ?
From what I have read here in the past (and what I have done on a 2009 B8 S5) with this procedure, is be sure all battery data is the same or very close to what was originally present (CC Amps and Ah for example). That way you can just leave the current data in those fields.
But, the serial number is what indicates to the vehicle that the battery was changed. So, if you change the SN by one digit all should be accepted.
golf_golf_7
C?ID=646973
Hi,
The three digit code, for example Exide is TU3. The battery going in is a YUASA [never heard of these] - So if there is no value within VCDS for this batery is it acceptable to select "unknown"? for the battery adaptation manufacturer
golf_golf_7
C?ID=646973
but you're buying one? :confused:
Hi - They are actually a very well known brand - but due to me not being an "auto expert" and not having heard of them doesn't mean they are not well known!
Just change the SN (last digit) ; leave the rest of the fields alone.
I'm well aware of them, just trying to understand why someone who's never heard of brand proceeds to buy it, only to then mention that they've never heard of it. Why bring it up?
The brand is very popular in motorcycles, atvs, etc.
golf_golf_7
C?ID=646973
OK - But if the manufacturer is different lets say EXIDE is the old battery with the TU3 inside VCDS and along comes new battery that is not EXIDE - Are you suggesting leaving TU3 in place?
The new battery is 760A CCA - The old one was 640A CCA - Does VCDS have a field for this data to be input?.
I'll find out when I connect it all to the car but am just trying to prepare mentally for the task to attempt to ensure a good outcome
Please post a complete Auto-Scan so the forum can see what module and vehicle you are asking about.
Yes, it should.
Since your new specifications are different, yes, you will need to enter the new data. First, you should find out what the vehicle had originally , what specifications. It sounds like you are Increasing battery capabilities.
Note: The Serial number change , that I mentioned above, is only recommended if you are replacing the battery with the oem specs. And, that is what is presently in the vehicle. That is why I mentioned you should first determine what the factory originally specified in this vehicle.
Also, per your screen shot..... don't you think it is time for a update! :eek:
golf_golf_7
C?ID=646973
Hi - Thanks for the video - More information.
The aspect I've already looked at is 19 - The CAN gateway. It appears there are more aspects to this as well so I'll play the video several times - Thanks
The video link is very useful and will be referenced when needed to input the data into the appropriate "address" numbers within VCDS
OK - I've got the new battery which does have a QR code but there is not BEM code - There is a serial number for the battery - but no vendor code or BEM code that can be seen but I'll check it again. What is the best course of action for VCDS with reference to not having a BEM code and no vendor code - Is it alright to select "unknown" for battery manufacturer?
golf_golf_7
C?ID=646973
We need a new member category, where a user can't post anymore until they at least have code tags in their message :popcorn:
Hi - An Autoscan will be done but this is not possible right now due to having a dead battery. I've bought a HEX V2 USB - Never used one yet - but am learning quite quickly - The battery needs to be installed and coded as well as possible - Surely you can see the difficulty with this situation where you wish to prevent people from posting - The car is without power - You must know Autoscan is not possible right now but will be when this is accomplished - Thank you for your understanding [hopefully]
Eric
HC800000
Cool story. Put battery in car, autoscan, post here.
It's not a question whether VCDS has a field for something; it's a question whether the control module has a field for it.
But the answer is: No. The CCA rating is not something the BMS in these cars cares about. It cares about capacity (Amp-hours) and possibly the type of battery (flooded vs EFB vs AGM etc.). The manufacturer code has no functional effect on anything. The serial number also has no functional effect, except that when you change it, the BMS takes that to mean you've installed a new battery.
golf_golf_7
C?ID=646973
Hi,
I got the new battery put in and there is power to the car so this part of the procedure has gone quite well considering. Also I've attached a charger to keep the battery charged.
I've performed a system Autoscan:
It has been notcied within the directory C:/ Ross-Tech / VCDS - within the main application folder there is a logs folder pertaining the Autoscan. Also there is another folder for Scans - Each of these folders contains a text file that must have been produced by the Autoscan itself.
I did have a look at coding something but the appearance of the available modules looked a little different or one or two items may have been missing [possibly] but at this point my brain freezes over with the newness of this and the risk of making a bad mistake so I backed off.
Do you wish me to upload those text files here? - or something else.
Nutshell is the car was without power so all sytems may be reset and there are error codes galore.
The new battery is in - This is an achievement in itself! - But there is more to do - And I'll wait to hear back here before proceeding - Thanks
Do a full auto scan, save it as a .txt file and copy/paste it. Then do a full CAN clear and re-read. If any red lines come back, go into the controller and manually clear the codes. Then go back to the auto scan screen and do a full scan again, if anything thing comes back, save and post the scan. Have you done the battery coding in the CAN BUS? There is no manufacturer code for Yuasa, just use JCB or VAO. Include the VIN.
All Auto-Scans are automatically saved to the Scans folder. If you use the [Save] button on the Auto-Scan screen, the scan will also be saved to the Logs folder.
Yes, open one of them with Notepad, then copy & paste the contents here, preferably between CODE tags, as described HERE.
golf_golf_7
C?ID=646973
Hi Uwe and all - The engine started, was left on for a little while then put back. The petrol cap opens from the inside - The boot opens from the inside - The keyfob remote doesn't work but did a few years back. I've put all the Autoscan in code brackets - I hope this is correctly done.
I've not coded anything for the battery yet - I went to have a look for a certain layout but when I got onto the screen one of the option boxes was missing - Right now my brains frozen a little bit because there are many errors - but lets look at the positive, a new battery is installed and the car started - so thats gotta be progress! - But what to do next well - I'm not sure! EDIT - The battery has a charger connected just in case there are any power sapping activities going on! - :)
EDIT - If I remember correctly - There was an adaptation box [10] that was expected to be seen in VCDS but was absent - I did watch the video for battery engine management - three components within VCDS, one of which is stand alone whilst the other two are found at address 19 The Can Gateway -
Friday,17,April,2026,16:23:00:22932
VCDS Version: 25.3.2.0  HEX-V2 CB: 0.4671.5
VIN: TRUZZZ8J0D1900434   License Plate:
Chassis Type: 8J-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 37 3D 42 44 46 47 52 55
          56 61 77
VIN: TRUZZZ8J0D1900434   Mileage: 77840km-48367miles
3D-Special Function -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine (CEP)       Labels:. 07K-907-404-CEP.clb
   Part No SW: 8J0 907 404 M    HW: 8J0 907 404 M
   Component: 2.5l R5/4V TFSI     0020
   Revision: F7H07---    Serial number: AUX7Z0L6FNQ0D7
   Coding: 0113000C180F0160
   Shop #: WSC 01236 785 00200
   VCID: 372CC9C583481DF27F9-8062
   VINID: 92296AAAA21A01404900010310FEFB13C8
               P1602 - 002 - Voltage too Low
                    Fault Status: 01100010
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 910 517 A    HW: 8J0 614 517 F
   Component: ESP MK60E1          0020
   Revision: 00H60001
   Coding: 0608151
   VCID: 2A0AE0B140FAB01AF07-807E
                    Reset counter: 0
                    Count: 297
Address 08: Auto HVAC        Labels: 8J0-820-043.clb
   Part No SW: 8J0 820 043 BB    HW: 8J0 820 043 BB
   Component: J255  Klima 1 Zone  0110
   Revision: 00H09006    Serial number: 00000001221355
   Coding: 1573893
   VCID: 678C598593684D722F9-8032
                    Reset counter: 127
                    Mileage: 77842 km
                    Voltage: 7.80 V
                    Fault Status: 01101000
                    Reset counter: 87
                    Mileage: 77842 km
                    Date: 2022.03.13
                    Time: 00:00:09
   Part No SW: 8P0 907 063 AB    HW: 8P0 907 063 AB
   Component: BCM PQ35  H   112 0715
   Revision: AA112715
   Coding: 46000B2FA805F1202070C1E00180084CD2F658AAB020D928DC000E440045
   Shop #: WSC 01236 758 00200
   VCID: 74B63EC9DEBEB6EA9AB-8020
   Subsystem 1 - Part No SW: 8J2 955 119 A    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H10 0080
   Coding: 00FD10
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 02492C
10 Faults Found:
02740 - Bulb for Tail Light 2; Left
                    Fault Status: 00101010
                    Reset counter: 125
                    Mileage: 77708 km
                    Date: 2020.01.08
                    Time: 08:45:18
                    Voltage: 14.80 V
                        Term 50 Off
                    Fault Frequency: 18
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.13
                    Time: 00:00:55
                        Term 15 Off
                    Voltage: 15.20 V
                        Term 50 Off
                    Fault Status: 00100001
                    Reset counter: 127
                    Mileage: 77842 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 14.65 V
                        Term 50 Off
                    Reset counter: 87
                    Mileage: 77842 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 14.60 V
                        Term 50 Off
                    Fault Frequency: 12
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.15
                    Time: 00:20:29
                        Term 15 Off
                    Voltage: 8.30 V
                        Term 50 Off
                    Fault Frequency: 9
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.18
                    Time: 00:00:58
                        Term 15 Off
                    Voltage: 8.40 V
                        Term 50 Off
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.23
                    Time: 00:50:42
                        Term 15 Off
                    Voltage: 8.60 V
                        Term 50 Off
03020 - Local databus 2
                    Fault Status: 01101100
                    Fault Frequency: 14
                    Reset counter: 87
                    Mileage: 77842 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.30 V
                        Term 50 Off
03156 - Sensor for Anti-Theft System (G578)
                    Fault Frequency: 22
                    Reset counter: 87
                    Mileage: 77842 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 13.30 V
                        Term 50 Off
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 87
                    Mileage: 77842 km
                    Date: 2022.04.09
                    Time: 21:15:11
                        Term 15 Off
                    Voltage: 11.65 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 M    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0140
   Revision: 11001001    Serial number: 36861219102415
   Coding: 00000B
   VCID: 48CEBA39F2B6620A063-801C
                    Reset counter: 127
                    Temperature: 6.0°C
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -t Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K00649AF
   Coding: 0011636
   VCID: 79A80FFDF5DCCB82C9D-802C
   Subsystem 1 - Serial number: 6332DRB40EC29296.
   Subsystem 2 - Serial number: 6342DRB40EC3CF9CI
   Subsystem 3 - Serial number: 63747RB406C9F60B%
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Component: J0527           H38 0070
   Coding: 0004041
   VCID: 46D2B401F4A2747AF4F-8012
   Component: E0221           H06 0030
01426 - Controls in Steering Wheel (E221)
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 981 F    HW: 8J0 920 981 F
   Component: KOMBIINSTR. VDO H03 0760
   Revision: D0H03004    Serial number: 2246L004000029
   Coding: 0005428
   Shop #: WSC 12345 001 1048576
   VCID: 3530C3CD9944EFE26D5-8060
                    Fault Frequency: 11
                    Mileage: 77842 km
                    Date: 2022.03.15
                    Time: 01:11:43
                    Mileage: 77842 km
                    Date: 2022.03.20
                    Time: 23:46:09
   Part No SW: 7N0 907 530 S    HW: 7N0 907 530 J
   Component: J533  Gateway H43 1632
   Revision:   H43       Serial number: 130712F1002033
   Coding: 354101
   VCID: 40DEA219DA865A4ACE3-8014
                    Fault Status: 00101011
                    Fault Frequency: 101
                    Reset counter: 127
                    Mileage: 76569 km
                    Date: 2019.06.26
                    Time: 11:40:08
                    Fault Status: 00110100
                    Reset counter: 126
                    Mileage: 77724 km
                    Date: 2020.05.31
                    Time: 18:42:05
                    Reset counter: 126
                    Mileage: 77724 km
                    Date: 2020.05.31
                    Time: 18:42:05
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.20
                    Time: 23:46:10
   Part No SW: 2K0 907 554 D    HW: 2K0 907 554 D
   Component: Haldex 4Motion      5010
   Coding: 0000005
   Shop #: WSC 40002 000 1048576
   VCID: 2F3CF1A57B18D532279-807A
   Revision: D0H03004    Serial number: AUX7Z0L6FNQ0D7
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8P0 035 785     HW: 8P0 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020202
                    Fault Frequency: 11
                    Reset counter: 127
                    Fault Frequency: 17
                    Fault Frequency: 15
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8J0 035 193 D    HW: 8J0 035 193 D
   Component: RNS-E PU EU     H07 0220
   Revision: 0000013S    Serial number: AUZBZ7MD403286
   Coding: 0610725
   VCID: 2B04E5B54F00A9120B1-807E
                    Fault Frequency: 9
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.15
                    Time: 13:29:57
                    Voltage: 13.70 V
                    Fault Frequency: 20
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.13
                    Time: 22:42:23
                    Voltage: 13.70 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.22
                    Time: 02:39:02
                    Mileage: 77840 km
                    Count: 804
                    Clock: 19:32
02444 - Disk Drive Load / Eject Malfunction
                    Reset counter: 116
                    Mileage: 77535 km
                    Date: 2019.07.31
                    Time: 09:44:56
Address 3D: Special Function        Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 A    HW: 8K0 907 440
   Component: STS             H04 0030
   Revision: S0H04000    Serial number: 00000000062113
   Coding: 01010101000000000000000101
   VCID: 2C06E6A94A0EAE2A02B-8078
                    Fault Frequency: 41
                    Reset counter: 39
                    Mileage: 77842 km
                    Date: 2022.03.13
                    Time: 00:41:25
                    Fault Status: 00101101
                    Fault Frequency: 8
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.13
                    Time: 00:46:26
                    Fault Frequency: 23
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.20
                    Time: 23:46:10
   Part No SW: 8J8 959 801 J    HW: 8J8 959 801 J
   Component: Tuer-SG         004 0102
   Coding: 0000565
   VCID: 44D6AE09C29E466AEAB-8010
01706 - Switch for Mirror-Adjust (E43)
   Part No: 8J0 909 144 P
   Component: EPS_ZFLS Kl. 239    3305
   Revision: 00H22000
   VCID: 3D20DBEDA17437A2A55-8068
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 0.0 V
                        PD
                    Temperature: -70.0°C
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 47: Sound System (J525)       Labels:* 8J0-035-223.lbl
   Part No SW: 8J0 035 223 F    HW: 8J0 035 223 F
   Component: Audi TT Amp5K H05 0170
   Revision: --------    Serial number: BP208321091906
   Coding: 070101060002
   ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
   ROD: EV_AudioAmpli5ChannBNO1_003.rod
   VCID: 270C19855F688D72EF9-8072
12608512 - Infotainment CAN Bus (SAE Bus E)
          U0064 00 [00001000] - Malfunction
          [Datenbus Infotainment: Defekt]
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.04.08
                    Time: 19:32:20
          U1400 00 [00001000] - -
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.20
                    Time: 23:45:11
   Part No SW: 8J8 959 802 J    HW: 8J8 959 802 J
   Coding: 0000564
   VCID: 45D0B30DC9A47F62FD5-8010
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0012
   Serial number: 120718-0002-002
   Coding: 11A4A51010002400
   ROD: EV_HeadlRegulBasic_AU35.rod
   VCID: 42DAA811D40A485AD87-8016
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0610725
                    Fault Frequency: 9
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.15
                    Time: 13:29:57
                    Voltage: 13.70 V
                    Fault Frequency: 20
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.13
                    Time: 22:42:23
                    Voltage: 13.70 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.03.22
                    Time: 02:39:02
                    Mileage: 77840 km
                    Count: 804
                    Clock: 19:32
                    Reset counter: 116
                    Mileage: 77535 km
                    Date: 2019.07.31
                    Time: 09:44:56
   Part No SW: 7N0 907 534     HW: 7N0 907 530 J
   Component: Batt.regelung H43 1632
   Coding: F326015A
   VCID: 71B837DDA1AC83C271D-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790864403
02256 - Quiescent Current
                    Fault Status: 00110001
                    Reset counter: 127
                    Mileage: 77842 km
                    Date: 2022.04.10
                    Time: 05:51:14
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005560355
   Coding: 0011422
                    Reset counter: 127
                    Reset counter: 127
End----------(Elapsed Time: 01:49, VBatt start/end: 12.8V/12.8V)-----------
------------------------------47 Faults Found------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
Here in the Uk Yuasa are a known brand and considered a premium product. Certainly not a bad battery !
