- Mar 19, 2025
- 14
- 2
- Rosenberg, TX, USA
- C?ID=613711
Thursday,16,April,2026,13:34:20:47494
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4701.5
VIN: 3VW507AT6FM807388 License Plate:
Chassis Type: AT-VW32 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 26 2B 2E 44 56 75 77 B8
VIN: 3VW507AT6FM807388 Mileage: 138660km-86159miles
B8-Elect. Roof 2 -- Status: OK 0000
Address 01: Engine (J623-CPKA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 997 071 D HW: 06K 907 425 C
Component: R4 1.8l TFS H13 9369
Revision: --H13--- CVN: F3295DBC
Coding: 001A0012242400161000
Shop #: WSC 00066 790 00071
ASAM Dataset: EV_ECM18TFS02006K997071D 001004
ROD: EV_ECM18TFS02006K906071AB.rod
VCID: 363E549448CCE5DA25F-8062
VINID: 0E69C50074641967480070C820EC02D148
17178 - Implausible Data Received from ESP Control Module
U0416 00 [00101111] - -
Fault Frequency: 24
Mileage: 138471 km
Date: 2026.02.26.
Time: 17:22:24
Engine speed: 720.50 /min
Normed load value: 11.0 %
Coolant temperature: 65 °C
Intake air temperature: 35 °C
Voltage terminal 30: 13.750 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system malfunction: No
15072 - Engine Start Blocked by Immobilizer
P1570 00 [00100000] - -
[Engine Control Module (ECM) locked]
Mileage: 138640 km
Engine speed: 1272.50 /min
Normed load value: 11.8 %
Coolant temperature: 36 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.347 V
FRF_IMMO_SNAPSHOT_BYTE1: 148
FRF_IMMO_SNAPSHOT_BYTE2: 148
FRF_IMMO_SNAPSHOT_BYTE3: 138
FRF_IMMO_SNAPSHOT_BYTE4: 43
FRF_IMMO_SNAPSHOT_BYTE5: 16
FRF_IMMO_SNAPSHOT_BYTE6: 0
Engine: operating status: IS
26384 - Databus
U1123 00 [01101101] - Received Error Message
Mileage: 138471 km
Date: 2026.02.26.
Time: 17:42:13
Engine speed: 1296.25 /min
Normed load value: 25.9 %
Vehicle speed: 16 km/h
Coolant temperature: 72 °C
Intake air temperature: 38 °C
Voltage terminal 30: 13.925 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 28 s
MAP_MES_SAE: 58 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.953 V
FAC_TPS_1_SAE: 15.625000 %
FUP_H_SAE: 14810.0 kPa
Address 02: Auto Trans (J217) Labels:* 09G-927-749-V1.clb
Part No SW: 09G 927 749 HW: 09G 927 749
Component: AISIN AG6 G3 104 2857
CVN: DC2957C4
Coding: 000348
ASAM Dataset: EV_TCMAQ250031 001004
ROD: EV_TCMAQ250031_001.rod
VCID: 76BE9494084CA5DAE5F-8022
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 00066 790 00072
VCID: 045AFE5C4E10874AEBB-8050
Reset counter: 97
Date: 2026.04.16.
Time: 13:22:03
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 41216
Count: 65024
Fault Status: 01100101
Reset counter: 97
Mileage: 138651 km
Date: 2026.04.16.
Time: 13:22:02
Count: 3
Count: 12
Count: 20480
Count: 212
Count: 41216
Count: 65024
Count: 512
Reset counter: 97
Mileage: 138651 km
Date: 2026.04.16.
Time: 13:22:02
Count: 3
Count: 12
Count: 20480
Count: 279
Count: 41216
Count: 65024
Count: 512
Reset counter: 97
Mileage: 138651 km
Date: 2026.04.16.
Time: 13:22:02
Count: 3
Count: 12
Count: 20480
Count: 295
Count: 41216
Count: 65024
Count: 512
Reset counter: 97
Mileage: 138651 km
Date: 2026.04.16.
Time: 13:22:02
Count: 3
Count: 12
Count: 20480
Count: 270
Count: 41216
Count: 65024
Count: 512
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0348185993 Dataset Number: 5C0116v____ 0005
Coding: 030C0C
Shop #: WSC 00066 000 00019
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 372059904FC61CD23E9-8062
1057035 - Antenna for Keyless Entry System; Drivers Side
B116F 13 [00001000] - Open Circuit
Reset counter: 137
Mileage: 138651 km
Date: 2026.04.16.
Time: 17:40:15
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CC HW: 5C0 820 047 CC
Component: J301 Klimaanlage 0207
Revision: 2001101S Serial number: 00000002433179
Shop #: WSC 00066 000 00000
VCID: 6398DDC0A75E2072B21-8036
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 L HW: 5C0 937 087 A
Component: BCM25 JLB H3 H36 0424
Revision: B2036001 Serial number: 09003309140801
Coding: 3BAC292808AB080000FC3800240984C5F0C2402F60000000B2B054002000
VCID: 363E5494484CE5DA25F-8062
Subsystem 1 - Part No SW: 6R0 959 801 BE HW: 6R0 959 801 BE Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 8672
Serial number: KU0KU007081442191825
Coding: 0010A4
Subsystem 2 - Part No SW: 6R0 959 802 BL HW: 6R0 959 802 BL Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 8672
Serial number: KU0KU011091442547714
Coding: 1010A4
Subsystem 3 - Part No SW: 5C0 959 442 C HW: 5C0 959 442 C
Component: E221__MFL-8LP H02 0103
Serial number: 00000000000000963380
Coding: E20000
Subsystem 4 - Part No SW: 5C3 959 811 C HW: 5C3 959 811 C
Component: J388__TSG_HL 009 1044
Serial number: 14102550130924124042
Coding: 800000
Subsystem 5 - Part No SW: 5C3 959 812 D HW: 5C3 959 812 D
Component: J389__TSG_HR 024 1073
Serial number: 14102749160713212150
03302 - Response Closing Status of Passenger's Door
Reset counter: 138
Mileage: 138651 km
Date: 2026.04.16.
Time: 17:39:42
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD037DZ1 Dataset Number: 5C0003V____ 0188
Coding: 00004234
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72B6A8846424B9FAC97-8026
Seat occupant detection:
Serial number: 6940000Y1400018T6D0T
Coding: 303134
Serial number: 3572MSME1A300849ZZZS
Serial number: 3582MSME1C2F0849ZZZ2
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME32031531ZZZC
Subsystem 5 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME4F744031ZZZX
Part No SW: 5C5 920 970 R HW: 5C5 920 970 R
Component: KOMBI H42 0309
Revision: X0042003 Serial number:
Coding: 251E01
Shop #: WSC 00066 000 00125
ASAM Dataset: EV_KombiUDSMM9RM10 A04802
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 3A2640A47CD401BAC17-806E
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H36 0424
Revision: B2036001
Coding: 502000
VCID: 70B2A28C6AA88BEA3F3-8024
Part No SW: 5K0 953 234 HW: 5C5 920 970 R
Component: IMMO H42 0309
Coding: 000007
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
VCID: 6A86B0E44CF4713A717-803E
Address 26: Auto Roof (J256) Labels:* 5C3-871-601.clb
Part No SW: 5C3 871 601 A HW: 5C3 871 601
Component: VSG-MASTER 015 0353
Dataset Number: 5C3122v____ 0007
ASAM Dataset: EV_VSGWEBASVW36X 005002
ROD: EV_VSGWEBASVW36X_005.rod
VCID: 23189DC0EB5E6072F21-8076
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000302766005
Coding: 4900000000000000
Shop #: WSC 00066 790 50316
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 3032628CAAA8CBEA7F3-8064
Address 2E: Media Player 3
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 39245FA875520AA2C8D-806C
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 180 AH HW: 1K0 035 180 AH
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3635185
Coding: 01000400040003
VCID: 669EC4D4586C555A55F-8032
Reset counter: 98
Mileage: 138651 km
Date: 2026.04.16.
Time: 13:22:11
Reset counter: 97
Mileage: 138651 km
Date: 2026.04.16.
Time: 13:22:10
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140529 Dataset Number: V03935196FH 0010
Coding: 02230502C21654107F1606C00000
Shop #: WSC 01383 790 50316
ROD: EV_OCULow_001_VW12.rod
VCID: 53F80D00FB7ED0F2221-8006
2103041 - Control Module
B1788 F0 [00001001] - Start Prohibition Deactivated
Fault Priority: 8
Reset counter: 98
Mileage: 138667 km
Date: 2026.04.16.
Time: 23:10:57
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 G HW: 5N0 035 729 G
Component: TELEFON H08 0593
Revision: 1B001001 Serial number: 00007666529607 Dataset Number: 5N0035729G 0001
Coding: 0A10031080010110
ROD: EV_UHVUMI.rod
VCID: 343A6E9C5EB0F7CA1BB-8060
Address B8: Elect. Roof 2 (J256) Labels: 5C3-871-601.clb
Component: VSG-SLAVE 015 0353
ASAM Dataset: EV_VSG2WEBASVW36X 005002
ROD: EV_VSG2WEBASVW36X_005.rod
End----------(Elapsed Time: 01:38, VBatt start/end: 13.8V/13.8V)-----------
------------------------------13 Faults Found------------------------------
