ABS MODULE Coding option
senna1
C?ID=231631
Vw Caddy Van 2011, second hand ABS Module fitted from a Audi A3, the scan list it as a ESP MK60EC1
for both vehicles, But when i go to ABS 03 select coding 07 the screen shows the second hand coding as all 00000 zero's and i cant edit them to change the code i know this Audi A3
has, coding info, you can see on the audi scan the coding is there, i had a choice of by vcds a pop up option to use Default 12345/123 etc and also go back edit manually but it wont edit .
here are 2 scans one Vw caddy, One Audi A3
Monday,13,April,2026,12:13:20:51242
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4701.5
VIN: WV1ZZZ2KZCX052487   License Plate:
Mileage: 216680km-134638mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
Vw Caddy
VIN: WV1ZZZ2KZCX052487   Mileage: 216680km-134638miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-907-425-V1.clb
   Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 0869
   Revision: --H43---    Serial number: 00000000000000 CVN: 36C18CF2
   Coding: 00114010030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PC 003002
   ROD: EV_ECM16TDI02103L906023PA.rod
   VCID: 76BE8932E84BBF1AE5F-8022
   VINID: 9E606AAAA09BA93A001421081CCC8F7386
6260 - Engine Start Blocked by Immobilizer
          P1570 00 [00100000] - -
                    Mileage: 216305 km
                    Date: 2026.04.13.
                    Time: 05:55:46
                    Engine speed: 0.00 /min
                    Coolant temperature: 19 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 11.746 V
                    Unlearning counter according OBD: 34
                    Immobilizer snapshot A: 94
9859 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [10101101] - Signal too High
                    Mileage: 216305 km
                    Date: 2026.04.13.
                    Time: 05:55:47
9860 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [00100100] - Malfunction
                    Mileage: 216580 km
                    Date: 2026.04.13.
                    Time: 12:04:22
                    Coolant temperature: 16 °C
                    Voltage terminal 30: 11.068 V
Readiness: 0100 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V2.clb
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Coding: 433C400D092703FCC20F02EC9020C081300000
   Shop #: WSC 35110 377 08192
   VCID: 79A4820ED9D5D06288D-802C
                    Fault Status: 00101100
                    Reset counter: 101
                    Mileage: 216409 km
                    Date: 2020.09.03.
                    Time: 05:59:57
                    Count: 4608
                    Count: 56
                    Count: 51200
                    Count: 3861
                    Count: 2048
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 411A583A8025182A08800082900000640301728852020060648000000040
   VCID: 72B6B52284A3A33AC97-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 07091  26  0512
   Coding: 009795
                    Fault Status: 00101010
                    Reset counter: 138
                    Mileage: 216409 km
                    Date: 2020.09.03.
                    Time: 05:57:18
                    Voltage: 11.65 V
                    Reset counter: 141
                    Mileage: 216467 km
                    Date: 2020.09.03.
                    Time: 08:00:29
                    Voltage: 14.45 V
                    Reset counter: 140
                    Mileage: 216409 km
                    Date: 2020.09.03.
                    Time: 05:57:18
                    Voltage: 11.65 V
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL007LASL Dataset Number: 2KC003v____ 0221
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 353C4E3EB5CDF4022C5-8060
   Part No SW: 1K5 953 507 M    HW: 5K0 953 549
   Revision: --------    Serial number:  90422KIF001B5 Dataset Number: 1K5953507M  D005
   Coding: 0080060000
   ROD: EV_SMLSNGKUDS_A05_VW32.rod
   VCID: 3B28580693E92272DA1-806E
   Part No SW: 2K0 920 965 E    HW: 2K0 920 965 E
   Component: KOMBI         H03 0606
   Coding: 480001
   VCID: 31347A2E41A5D82270D-8064
9453330 - Outside temperature sensor
          B103F 1B [00001001] - Resistance Too High
                    Reset counter: 95
                    Mileage: 216409 km
                    Date: 2026.04.13.
                    Time: 05:55:50
9453842 - Oil Level Thermal Sensor
          B1041 35 [00001001] - Signal High Time > Maximum
                    Reset counter: 95
                    Mileage: 216409 km
                    Date: 2026.04.13.
                    Time: 05:55:51
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 110911F1003288
   Coding: 357401
   VCID: 353C4E3EB54DF4022C5-8060
                    Reset counter: 95
                    Mileage: 216409 km
                    Date: 2020.09.03.
                    Time: 05:55:58
   Component: IMMO          H03 0606
   VCID: 6A86AD42ACF36BFA717-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 74 0160
   Coding: 0000000
   VCID: 76BE8932E4CBBF1AE5F-8022
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 343A733AB237ED0A1BB-8060
                    Fault Status: 00101101
                    Reset counter: 141
                    Mileage: 216684 km
                    Date: 2020.09.03.
                    Time: 09:30:33
                    Voltage: 11.38 V
                        DU
                    Temperature: 6.0°C
                    RPM: 1037 /min
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   VCID: 75BC8E3EF9CDB402EC5-8020
Address 56: Radio        Labels:
   VCID: 55FCEEBE1C0DD402CC5-FFFE
   Note: Excessive Comm Errors
End----------(Elapsed Time: 01:12, VBatt start/end: 12.0V/12.0V)-----------
------------------------------11 Faults Found------------------------------
A
Wednesday,15,April,2026,15:31:20:51242
VIN: WAUZZZ8P0BA005728   License Plate: A3 CONNER BRAKES
Mileage: 277740km-172579mi   Repair Order:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61
VIN: WAUZZZ8P0BA005728   Mileage: 277740km-172579miles
04-Steering Angle -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Malfunction 1010
Address 01: Engine (J623-CAYC)       Labels:. 03L-907-425-V1.clb
   Part No SW: 03L 906 023 M    HW: 03L 906 023 L
   Component: 1,6l R4 CR td H23 8790
   Revision: --H23---    Serial number: AUX7Z0J5FN70GN CVN: E16EEB95
   Coding: 00114014030501080000
   Shop #: WSC 06314 000 00000
   ASAM Dataset: EV_ECM16TDI02103L906023M 003009
   ROD: EV_ECM16TDI02103L906023DR_003_VW32.rod
   VCID: 30327F2A4AAFD12A7F3-8064
   VINID: 9D196AAAA2200124400051C220DDE8AB61
8 Faults Found:
10156 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [00101101] - Electrical Fault
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:00:03
                    Engine speed: 986.00 /min
                    Normed load value: 49.8 %
                    Coolant temperature: 10 °C
                    Intake air temperature: 9 °C
                    Glow status-STATE_GLOW: 48
                    Fuel temperature-TFU: 13 °C
                    Sensor for engine block temperature: raw value-Coolant temperature: 12 °C
10158 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [00100101] - Electrical Fault
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:00:21
                    Engine speed: 1534.00 /min
                    Normed load value: 48.6 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 14 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.633 V
10162 - Cylinder 4 Glow Plug Circuit (Q13)
          P0674 00 [00100101] - Electrical Fault
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:04:50
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 11.407 V
6056 - No Communications with HVAC Control Module (J301)
          U0164 00 [00100000] - -
                    Fault Frequency: 37
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Engine speed: 1863.25 /min
                    Vehicle speed: 50 km/h
                    Coolant temperature: 42 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.682 V
                    Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 24 °C
6060 - Body Control Module (Central Electric 2)
          U0141 00 [00100000] - No Communications
                    Fault Frequency: 33
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Engine speed: 1878.00 /min
                    Vehicle speed: 51 km/h
7319 - Body Control Module (Central Electric)
          U0140 00 [00100000] - No Communications
                    Fault Frequency: 27
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:44
                    Engine speed: 1832.00 /min
                    Coolant temperature: 43 °C
7455 - Door Control Module - Driver's Door
          U0199 00 [00100000] - No Communications
                    Fault Frequency: 32
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Engine speed: 1862.00 /min
7345 - Particulate Filter; Differential Pressure Sensor
          P2455 00 [10100101] - Short to Plus
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:04:46
                    Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 8.89 g
                    Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 20.64 g
                    Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 724 km
                    Counter for regeneration time of particulate filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 0.0000 s
                    Particle filter: difference pressure-DIP_PF: 1105.87 hPa
                    Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 14 °C
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V1.clb
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 13422012092200FFC81204E690210091380800
   VCID: 045AE3FAAE179D8AEBB-8050
                    Fault Status: 00100001
                    Reset counter: 51
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:20:18
                    Count: 2
                    Count: 29184
                    Count: 129
                    Count: 52992
                    Count: 64769
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:03
                    Count: 2
                    Count: 20992
                    Count: 166
                    Count: 40960
                    Count: 65281
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Count: 20992
                    Count: 8213
                    Count: 41472
                    Count: 65281
Address 08: Auto HVAC        Labels: 8P0-820-047.clb
   Part No SW: 8P0 820 047 D    HW: 8P0 820 047 D
   Component: J255  Klima Man H08 0060
   Revision: 00H08004    Serial number: 00000000000000
   VCID: 31347A2E4D25D82270D-8064
   Part No SW: 8P0 907 063 G    HW: 8P0 907 063 G
   Component: BCM PQ35  M   107 0615
   Revision: 00107 AF
   Coding: 46000A2FA005F000207041E00000014C421A23AA004DC122E4008F800041
   VCID: 3822470AA25F096A373-806C
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 4 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
19 Faults Found:
                    Reset counter: 92
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 17:22:18
                    Voltage: 11.00 V
                        Term 50 On
                    Reset counter: 86
                    Mileage: 277407 km
                    Date: 2025.08.23
                    Time: 12:45:12
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Fault Status: 01101010
                    Reset counter: 52
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 18:48:56
                    Voltage: 12.30 V
                        Term 50 On
                    Reset counter: 78
                    Mileage: 276387 km
                    Date: 2025.07.21
                    Time: 12:16:22
                    Voltage: 14.65 V
                        Term 50 On
                    Reset counter: 92
                    Mileage: 277739 km
                    Date: 2025.08.29
                    Time: 13:26:22
                        Term 15 Off
                    Voltage: 7.95 V
                        Term 50 Off
                    Reset counter: 92
                    Mileage: 277739 km
                    Date: 2025.08.29
                    Time: 13:38:41
                        Term 15 Off
                    Voltage: 17.75 V
                        Term 50 Off
                    Reset counter: 92
                    Mileage: 272885 km
                    Date: 2025.03.03
                    Time: 13:05:17
                    Voltage: 12.00 V
                        Term 50 On
                    Fault Frequency: 16
                    Reset counter: 92
                    Mileage: 273216 km
                    Date: 2025.03.13
                    Time: 15:04:57
                    Voltage: 14.95 V
                        Term 50 On
                    Fault Frequency: 9
                    Reset counter: 75
                    Mileage: 273382 km
                    Date: 2025.03.19
                    Time: 15:02:52
                    Voltage: 14.65 V
                        Term 50 On
                    Fault Frequency: 22
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 12.15 V
                        Term 50 Off
                    Fault Frequency: 14
                    Reset counter: 83
                    Mileage: 274036 km
                    Date: 2025.04.08
                    Time: 18:44:35
                    Voltage: 14.30 V
                        Term 50 On
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 01:15:31
                        Term 15 Off
                    Voltage: 9.05 V
                        Term 50 Off
00323 - Vehicle Inclination Sensor (G384)
                    Reset counter: 92
                        Term 15 Off
                    Voltage: 10.70 V
                        Term 50 Off
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
01598 - Drive Battery Voltage
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FB007FNB% Dataset Number: 8P0909602M  0003
   Coding: 303142413039303030384A55305238503053
   ROD: EV_Airba10AURB4_AU35.rod
   VCID: 4FF01CD63751AED2069-801A
   Serial number: 34928RB4000058DA439Y
   Serial number: 35028RB40000594A85BQ
   Serial number: 35128RB4000058DA42EV
   Serial number: 35228RB40000594A913H
   Serial number: 35547RB4000059C5857V
   Serial number: 35647RB4000059C57F3.
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0002012
   VCID: 46DE39F2D4AB6F9AB5F-8012
   Component: E0221           H04 0100
   Part No SW: 8P0 920 982 H    HW: 8P0 920 982 H
   Component: KOMBIINSTR. VDO H01 0080
   Revision: D0H01002    Serial number: 2245J002000885
   Coding: 0260428
   Shop #: WSC 11111 067 57207
   VCID: 3E2E51128C7B375AFDF-806A
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 239113 km
                    Date: 2022.01.12
                    Time: 12:50:11
   Part No SW: 8P0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H33 0302
   Revision:   H33       Serial number: 070510F1000299
   Coding: E9801F0600020204000101
11 Faults Found:
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Fault Status: 00110100
                    Fault Frequency: 8
                    Reset counter: 92
                    Date: 2025.08.29
                    Time: 00:01:38
                    Fault Status: 00101110
                    Fault Frequency: 15
                    Mileage: 273178 km
                    Date: 2025.03.12
                    Time: 08:37:34
                    Fault Frequency: 17
                    Reset counter: 90
                    Mileage: 274036 km
                    Date: 2025.04.08
                    Time: 18:44:34
                    Fault Frequency: 12
                    Reset counter: 86
                    Mileage: 274083 km
                    Date: 2025.04.11
                    Time: 08:29:22
                    Fault Status: 00101011
                    Reset counter: 92
                    Mileage: 277388 km
                    Date: 2025.08.21
                    Time: 17:06:02
                    Reset counter: 92
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 17:20:05
                    Reset counter: 92
                    Mileage: 272879 km
                    Date: 2025.02.26
                    Time: 21:03:19
                    Reset counter: 86
                    Mileage: 277034 km
                    Date: 2025.08.17
                    Time: 14:57:10
                    Reset counter: 82
                    Mileage: 275475 km
                    Date: 2025.05.28
                    Time: 20:02:56
   Revision: D0H01002    Serial number: AUX7Z0J5FN70GN
   Shop #: WSC 00720 210 82115
   Part No SW: 8P0 035 152 E    HW: 8P0 035 152 E
   Component: R Chorus2+      H03 0280
   Revision: 00H03000    Serial number: AUZ1Z2K6146779
   Coding: 0200021
   VCID: 2D0C665E511DBCC2545-8078
                    Fault Frequency: 54
                    Reset counter: 78
                    Mileage: 273004 km
                    Date: 2025.03.08
                    Time: 15:22:40
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 01:16:25
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H33 0302
   Coding: 030B085A
   VCID: 74BAB33AFEB7AD0ADBB-8020
   Subsystem 1 - Part No SW: 1K0 915 181 E    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650200645
02252 - Generator
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:01:13
End----(Elapsed Time: 01:44, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
------------------------------48 Faults Found------------------------------
Audi A3
8 Faults Found:
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:00:03
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:00:21
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:04:50
                    Fault Frequency: 37
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Fault Frequency: 33
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Fault Frequency: 27
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:44
                    Fault Frequency: 32
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:04:46
   Revision: 00H30001
                    Reset counter: 51
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:20:18
                    Count: 2
                    Count: 29184
                    Count: 129
                    Count: 52992
                    Count: 64769
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:03
                    Count: 2
                    Count: 20992
                    Count: 166
                    Count: 40960
                    Count: 65281
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Count: 20992
                    Count: 8213
                    Count: 41472
                    Count: 65281
   Revision: 00107 AF
   Coding: 00DD13
19 Faults Found:
                    Reset counter: 92
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 17:22:18
                    Voltage: 11.00 V
                        Term 50 On
                    Reset counter: 86
                    Mileage: 277407 km
                    Date: 2025.08.23
                    Time: 12:45:12
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Reset counter: 52
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 18:48:56
                    Voltage: 12.30 V
                        Term 50 On
                    Reset counter: 78
                    Mileage: 276387 km
                    Date: 2025.07.21
                    Time: 12:16:22
                    Voltage: 14.65 V
                        Term 50 On
                    Reset counter: 92
                    Mileage: 277739 km
                    Date: 2025.08.29
                    Time: 13:26:22
                        Term 15 Off
                    Voltage: 7.95 V
                        Term 50 Off
                    Reset counter: 92
                    Mileage: 277739 km
                    Date: 2025.08.29
                    Time: 13:38:41
                        Term 15 Off
                    Voltage: 17.75 V
                        Term 50 Off
                    Reset counter: 92
                    Mileage: 272885 km
                    Date: 2025.03.03
                    Time: 13:05:17
                    Voltage: 12.00 V
                        Term 50 On
                    Fault Frequency: 16
                    Reset counter: 92
                    Mileage: 273216 km
                    Date: 2025.03.13
                    Time: 15:04:57
                    Voltage: 14.95 V
                        Term 50 On
                    Fault Frequency: 9
                    Reset counter: 75
                    Mileage: 273382 km
                    Date: 2025.03.19
                    Time: 15:02:52
                    Voltage: 14.65 V
                        Term 50 On
                    Fault Frequency: 22
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 12.15 V
                        Term 50 Off
                    Fault Frequency: 14
                    Reset counter: 83
                    Mileage: 274036 km
                    Date: 2025.04.08
                    Time: 18:44:35
                    Voltage: 14.30 V
                        Term 50 On
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 01:15:31
                        Term 15 Off
                    Voltage: 9.05 V
                        Term 50 Off
                    Reset counter: 92
                        Term 15 Off
                    Voltage: 10.70 V
                        Term 50 Off
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
   Coding: 0002012
   Coding: 0260428
            014 - Defective
                    Mileage: 239113 km
                    Date: 2022.01.12
                    Time: 12:50:11
11 Faults Found:
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Fault Frequency: 8
                    Reset counter: 92
                    Date: 2025.08.29
                    Time: 00:01:38
                    Fault Frequency: 15
                    Mileage: 273178 km
                    Date: 2025.03.12
                    Time: 08:37:34
                    Fault Frequency: 17
                    Reset counter: 90
                    Mileage: 274036 km
                    Date: 2025.04.08
                    Time: 18:44:34
                    Fault Frequency: 12
                    Reset counter: 86
                    Mileage: 274083 km
                    Date: 2025.04.11
                    Time: 08:29:22
                    Reset counter: 92
                    Mileage: 277388 km
                    Date: 2025.08.21
                    Time: 17:06:02
                    Reset counter: 92
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 17:20:05
                    Reset counter: 92
                    Mileage: 272879 km
                    Date: 2025.02.26
                    Time: 21:03:19
                    Reset counter: 86
                    Mileage: 277034 km
                    Date: 2025.08.17
                    Time: 14:57:10
                    Reset counter: 82
                    Mileage: 275475 km
                    Date: 2025.05.28
                    Time: 20:02:56
   Coding: 0200021
                    Fault Frequency: 54
                    Reset counter: 78
                    Mileage: 273004 km
                    Date: 2025.03.08
                    Time: 15:22:40
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 01:16:25
   Coding: 030B085A
02252 - Generator
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:01:13
Vdub
C?ID=57533
edit your post and put both scans in a different </>
The ABS-units are different according to partslink
Caddy: 1K0 614 517 DD BEF
A3 1K0 614 517 CB BEF
senna1
C?ID=231631
VIN: WAUZZZ8P0BA005728   License Plate: A3  BRAKES
8 Faults Found:
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:00:03
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:00:21
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:04:50
                    Fault Frequency: 37
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Fault Frequency: 33
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Fault Frequency: 27
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:44
                    Fault Frequency: 32
                    Mileage: 258024 km
                    Date: 2025.08.28
                    Time: 11:29:43
                    Mileage: 258088 km
                    Date: 2025.08.29
                    Time: 00:04:46
   Revision: 00H30001
                    Reset counter: 51
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:20:18
                    Count: 2
                    Count: 29184
                    Count: 129
                    Count: 52992
                    Count: 64769
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:03
                    Count: 2
                    Count: 20992
                    Count: 166
                    Count: 40960
                    Count: 65281
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Count: 20992
                    Count: 8213
                    Count: 41472
                    Count: 65281
   Revision: 00107 AF
   Coding: 00DD13
19 Faults Found:
                    Reset counter: 92
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 17:22:18
                    Voltage: 11.00 V
                        Term 50 On
                    Reset counter: 86
                    Mileage: 277407 km
                    Date: 2025.08.23
                    Time: 12:45:12
                        Term 15 Off
                    Voltage: 12.75 V
                        Term 50 Off
                    Reset counter: 52
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 18:48:56
                    Voltage: 12.30 V
                        Term 50 On
                    Reset counter: 78
                    Mileage: 276387 km
                    Date: 2025.07.21
                    Time: 12:16:22
                    Voltage: 14.65 V
                        Term 50 On
                    Reset counter: 92
                    Mileage: 277739 km
                    Date: 2025.08.29
                    Time: 13:26:22
                        Term 15 Off
                    Voltage: 7.95 V
                        Term 50 Off
                    Reset counter: 92
                    Mileage: 277739 km
                    Date: 2025.08.29
                    Time: 13:38:41
                        Term 15 Off
                    Voltage: 17.75 V
                        Term 50 Off
                    Reset counter: 92
                    Mileage: 272885 km
                    Date: 2025.03.03
                    Time: 13:05:17
                    Voltage: 12.00 V
                        Term 50 On
                    Fault Frequency: 16
                    Reset counter: 92
                    Mileage: 273216 km
                    Date: 2025.03.13
                    Time: 15:04:57
                    Voltage: 14.95 V
                        Term 50 On
                    Fault Frequency: 9
                    Reset counter: 75
                    Mileage: 273382 km
                    Date: 2025.03.19
                    Time: 15:02:52
                    Voltage: 14.65 V
                        Term 50 On
                    Fault Frequency: 22
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 12.15 V
                        Term 50 Off
                    Fault Frequency: 14
                    Reset counter: 83
                    Mileage: 274036 km
                    Date: 2025.04.08
                    Time: 18:44:35
                    Voltage: 14.30 V
                        Term 50 On
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 01:15:31
                        Term 15 Off
                    Voltage: 9.05 V
                        Term 50 Off
                    Reset counter: 92
                        Term 15 Off
                    Voltage: 10.70 V
                        Term 50 Off
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
                    Reset counter: 92
   Coding: 0002012
   Coding: 0260428
            014 - Defective
                    Mileage: 239113 km
                    Date: 2022.01.12
                    Time: 12:50:11
11 Faults Found:
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:00:02
                    Fault Frequency: 8
                    Reset counter: 92
                    Date: 2025.08.29
                    Time: 00:01:38
                    Fault Frequency: 15
                    Mileage: 273178 km
                    Date: 2025.03.12
                    Time: 08:37:34
                    Fault Frequency: 17
                    Reset counter: 90
                    Mileage: 274036 km
                    Date: 2025.04.08
                    Time: 18:44:34
                    Fault Frequency: 12
                    Reset counter: 86
                    Mileage: 274083 km
                    Date: 2025.04.11
                    Time: 08:29:22
                    Reset counter: 92
                    Mileage: 277388 km
                    Date: 2025.08.21
                    Time: 17:06:02
                    Reset counter: 92
                    Mileage: 272865 km
                    Date: 2025.02.25
                    Time: 17:20:05
                    Reset counter: 92
                    Mileage: 272879 km
                    Date: 2025.02.26
                    Time: 21:03:19
                    Reset counter: 86
                    Mileage: 277034 km
                    Date: 2025.08.17
                    Time: 14:57:10
                    Reset counter: 82
                    Mileage: 275475 km
                    Date: 2025.05.28
                    Time: 20:02:56
   Coding: 0200021
                    Fault Frequency: 54
                    Reset counter: 78
                    Mileage: 273004 km
                    Date: 2025.03.08
                    Time: 15:22:40
                    Reset counter: 92
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 01:16:25
   Coding: 030B085A
02252 - Generator
                    Reset counter: 52
                    Mileage: 277740 km
                    Date: 2025.08.29
                    Time: 00:01:13
The pt numbers on the scan are very similar and the same type ABS unit, My point is why have the coding disappeared, Revision is different but one is slightly different year of module, i have had ABS module less accurate but the coding for the module is there, whether it excepts it is debaitable
The part number have probably been superseded,
senna1
C?ID=231631
A3 Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Vw Caddy Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
if the Hardware is incompatible the swap is probably not going to work, but im wondering why the coding is all zeros, does it need reset using security access to edit the code zeros.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
If I understand correctly, you need to write the coding in Caddy.
Use this: 433C400D092703FCC20F02EC9020C081300000
Copy / paste in new coding this string. Belong to Caddy 2K, VIN: WV1ZZZ2KZCX052487
senna1
C?ID=231631
Hi My friend, the problem is although i have the original coding for both ABS modules, when i go to do the coding the Donar ABS module that is fitted to change the coding it does not show its original coding it is all zeros 00000 etc and it wont let me edit it, to put in its original coding that i have , then to finish to use the original ABS module coding, if you check the scans i have both inc 433C400D092703FCC20F02EC9020C081300000
It appears that your replacement ABS unit is a earlier version of the present unit. From what I've observed/read here, generally replacement units are "newer" PN''s (suffix).
Your attempting a BH to a AT (??).
Vdub
C?ID=57533
.., but im wondering why the coding is all zeros, does it need reset using security access to edit the code zeros.
if you connect a new/used ABS module, Instrument Cluster etc to another VIN it always zeros.
  • Agree
senna1
C?ID=231631
Yes a few months different in model year,going to try with other kit as its all fitted, otherwise get another correct unit
senna1
C?ID=231631
I have replaced other Vag Abs modules example Vw T5 and i could see the Donar code,? is it just the vin causing the module to zero in the module.
Spacewalker
Poland
C?ID=159607
we talking about Mk60EC1, Mk100...
T5 also use this type of ABS ?
if not - no point to mention that
Boki Ar
C?ID=57300
If everything is fine, just connect the new (used) module to the car. Coding should be accepted.
No matter what in the current coding field, you put the desired coding in the [New Coding] field. Best way is copy/paste.
senna1
C?ID=231631
Hi the module is all coded with Launch x431 scanner, the A3 data showed under the launch & also once coded it showed information in the Caddy as current. i did the Steering G85 angle sensor and the other pressure sensor etc, with vcds , next will be to finish bleed the brakes and test, why did it not show in Vcds initially instead of all zero,
no problems on T5 that was just a example. the point now is it is all done ?
Boki Ar
C?ID=57300
I'm glad you made it.
Please let us know when you've finished everything and post new, fresh Auto Scan. :thumbs:
senna1
C?ID=231631
I should be going back to the persons garage soon and will do a full scan, to post so the evidence can be seen, The garage owner has a lot of things to go through as he has only just bought the van, i did a new key etc for it, it would of been nice if the complete job was done with vcds, which i used to finish once the coding had been placed and accepted, i was going to use my locksmith tools to do the coding, if the launch failed. the brakes have been blead and it is being used , i will go back and check G85 once the tracking has been done ,so keep those positive vibs, dont give up,
