Mk5 Golf MK60EC1 ABS Coding
FastStuff
Australia
C?ID=194115
Hi guys, been using VCDS for a few years now but new to the forum here.
Currently have a Mk5 Golf which we replaced a faulty ABS module in due to it intermittently losing communication.
We managed the retrieve the coding out of it to copy into the replacement second-hand module however when we apply this coding to it, after telling us it's "Accepted" it, it reverts back to all zero's after exiting the module and re-entering it.
I understand the MK60EC1 is usually coded online using SVM through the dealer tool but copying the original coding should work?
I've attached a auto-scan and some info about the replacement module...
Any help would be greatly appreciated!
Avo.
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Fast Stuff Pty Ltd
Wednesday,24,February,2016,15:00:24:41982
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WVWZZZ1KZ9U002385   Mileage: 121340km-75397miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H43NE84M
   Coding: 0403004318070160
   Shop #: WSC 00046 412 00000
   VCID: 3467F0915798919EA5-8060
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
                    Mileage: 121343 km
                    Time: 02:27:03
                    Temperature: 55.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 0101
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 163B600D092200FC680E06EC901E00813400
   VCID: 74E73091D718D19E65-8020
                    Fault Status: 00101100
                    Reset counter: 32
                    Mileage: 121343 km
                    Count: 2
                    Count: 2
                    Count: 12800
                    Count: 266
                    Count: 44288
   Part No SW: 1K0 907 044 DD    HW: 1K0 907 044 DD
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6CD728F14F28095EBD-8038
   Revision: 00H54000    Serial number: 00000008473655
   Coding: E58D0F2700041500471400001400000000087F075C000100000000000000
   VCID: 3365F38D529696A6BC-8066
   Component: Wischer 040708 020  0501
   Coding: 00049109
   Shop #: WSC 00046
   Component: RLS     180608 046  0204
   Coding: 00208933
   Shop #: WSC 00046
   Component: 1P AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD213UNM
   Coding: 0012624
   VCID: 3D71D5B564D250D65A-8068
   Subsystem 1 - Serial number: 6332MSME3A1547023
   Subsystem 2 - Serial number: 6342MSME29411232$
   Subsystem 3 - Serial number: 6352QSME62794975Q
   Subsystem 4 - Serial number: 6362QSME5A7A4409R
   Part No SW: 1K0 953 549 CB    HW: 1K0 953 549 CB
   Component: J0527           752 0101
   Coding: 0002022
   VCID: 74E730911718D19E65-8020
   Part No SW: 1K6 920 874     HW: 1K6 920 874
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H43NE84M
   Coding: 0003103
   Shop #: WSC 30024 959 88134
   VCID: 70EF3C816300EDBE81-8024
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 190508F1002082
   Coding: E9807F061002020003
   VCID: 3561CD955CE2889692-8060
   Component: IMMO            VDD 2216
   Component: Tuer-SG         006 1210
   Coding: 0000692
   VCID: 387FC4A14BF075FE89-806C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A5BEEE9855CD76E0F-807E
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 121343 km
                    Time: 00:06:12
                    Battery Volts: 12.4 V
                        DD
                    Temperature: 32.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 819002005103087F2D04840570085FC690FC00
   VCID: 0305634D42B6E6266C-8056
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No SW: 1K6 035 456 B    HW: 1K6 035 456 B
   Component: 08K Audioverst.     0006
   Revision: 00004000    Serial number: 00000008137332
   VCID: 2B55EBED8AA6CE66F4-807E
   Coding: 0000692
   VCID: 3979C1A570FA6CF676-806C
   Part No SW: 3C0 035 195 C    HW: 3C0 035 195 C
   Component: Radio PM6       012 0020
   Revision: 00012000    Serial number: VWZ5Z7H1163043
   Coding: 0010011
   VCID: 204F0CC1F3601D3E51-8074
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0000144
End-------------------------(Elapsed Time: 01:36)--------------------------
Wednesday,24,February,2016,14:48:54:41982
Control Module Part Number: 1K0 907 379 AD
  Component and/or Version: ESP MK60EC1   H35 0106
           Software Coding: 000000000000000000000000000000000000
            Work Shop Code: WSC 59462
Advanced Identification
     Identification: TT1-000
     Revision: 00H35001
     Date: 08.02.09
     Manufacturer number: 0303
     Test stand number: 00B8
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
VCDS Info:
FastStuff
Australia
C?ID=194115
Awesome. Worked a treat, knew I must've been overlooking something simple.
I was focusing on why it wouldn't keep the coding before moving on to carrying out the basic settings.
Thanks!
