2015 Q5 TDI limp mode
TRAUDI1
Maplewood, MN USA
C?ID=642292
The car has Rawtech Delete and Tunezilla tune. Had some codes before and replaced boost sensor and was fine for a while. Codes and limp mode came back and figured it was wastegate actuator. Replaced that and was fine for a while. I'm able to go into Output tests and stroke the actuator but if I go into Basic Settings, I'm not finding where I can try and adapt actuator to wastegate. Little help is needed. Thanks
Wednesday,15,April,2026,15:32:28:46502
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: WA1CMAFP6FA063029   License Plate:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
          6C 6D 72 AC
VIN: WA1CMAFP6FA063029   Mileage: 163050km-101314miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 401 AC    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    X14 0010
   Revision: 58X14---    CVN: EFA893770000000000000000755A21130E1FC39E
   Coding: 2A2A4012052603050000
   Shop #: WSC 23116 035 00000
   ASAM Dataset: EV_ECM30TDI0118K5907401AC 002010
   ROD: EV_ECM30TDI0118K5907401AC_002.rod
   VCID: 71B83642812240E230D-8024
   VINID: 9D10537515A019644018300224D4956A41
5567 - Torque Intervention to Protect Turbocharger
          P100E 00 [00101100] - -
                    Mileage: 163056 km
                    Date: 2026.04.13
                    Time: 18:54:44
                    Engine speed: 2265.00 /min
                    Normed load value: 58.8 %
                    Vehicle speed: 46 km/h
                    Coolant temperature: 36 °C
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 13.640 V
                    Regulation factor: total: 0.7598
                    Exhaust gas temperature sensor 1: 333.8 °C
                    Mean injection quantity: 31.37 mg/stroke
                    Engine control module reset status-Bits 0-7: 48
                    Engine control module reset status-Bits 0-7: 63
                    Fuel temperature: 22.2 °C
                    Engine oil temperature: 29.5 °C
9126 - Actuator Module for Turbocharger 1
          P00AF 00 [11101100] - Stuck
                    Mileage: 163056 km
                    Date: 2026.04.13
                    Time: 18:54:47
                    Engine speed: 2155.50 /min
                    Normed load value: 42.7 %
                    Vehicle speed: 56 km/h
                    Coolant temperature: 37 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 13.540 V
                    Accelerator pedal travel: 32.45 %
                    Charge Pressure Actuator: activation: 0.00 %
                    Charge air pressure actuator: acknowledgment: 77.50 %
                    Turbocharger boost control: offset closed: 0.00 %
                    Turbocharger boost control: offset open: 0.00 %
                    High press turbocharger actuator: actual uncond volt value: 3440.8 mV
Readiness: 1 1 0 1 X
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1007
   Revision: --H19---    CVN: 1B30E95F
   VCID: 4BC484AAC34E4A326A1-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Coding: 231D1C03
   Shop #: WSC 06335 000 00000
   VCID: 117856C2E16220E250D-8044
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Coding: 0DA54040000000000000
   VCID: 084E7BA69238612A873-805C
   Serial number: 3214000121341006
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01211020141285
   Coding: 3621228000
   VCID: 77AC085AEFC61ED2FE9-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000926221601
   Coding: 26000091813CAFE00E01404300003D0C4F9C4708A6090321000008004000030100000034000000
   Shop #: WSC 06335 123 12345
   VCID: 78AE0B66E2D811AAF73-802C
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 141003  H12 0050
   Serial number: 90243014140925175910
   Coding: 01DD13
   Serial number: 23334034
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001010141316
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z009C7FDB
   Serial number: 0A080557000000000001
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 101
                    Mileage: 163055 km
                    Date: 2026.04.13
                    Time: 18:48:11
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12P8LO   Dataset Number: 8R0909602F  0002
   Coding: 303634313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4CC687B6C6404D0A63B-8018
   Seat occupant detection:
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R140000MC5H
   Serial number: 6334MSME495D127CQ
   Serial number: 6344MSME485D196DX
   Serial number: 6352QSME46464964K
   Serial number: 6362QSME4F471A48V
   Serial number: 63732SME5F462B447
   Serial number: 63832SME5F4624744
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NJL000AA
   Coding: 000017
   VCID: 48CEBBA6D2B8A12A473-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
   Component: KOMBIINSTR.   H35 0564
   Revision: 00300000    Serial number: ZD673TFAF
   Coding: 83BF22000201D705020100
   VCID: 3928CE629952C8A2C8D-806C
                    Reset counter: 101
                    Mileage: 163055 km
                    Date: 2026.04.13
                    Time: 18:48:14
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z14A1201E0
   Coding: 80CF07FF00
   VCID: 4CC687B6C6C04D0A63B-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 0969734703
   Serial number: 14289000346011200181
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000120154822
   Coding: 01581B00000000000000
   VCID: 42DAA98EF4848B7A997-8016
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0349537601 Dataset Number: 8R0909535F  0021
   Coding: 010211
   Shop #: WSC 06334 000 00000
   ROD: EV_LaneChangAssis_AU48.rod
   VCID: 3FDCA07A87F6E692F69-806A
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0347947518
   Coding: 010211
730117 - Control Module 2 for Lane-Change Assist
          C1115 F0 [00001001] - Automatic Calibration Not Possible
                    Reset counter: 101
                    Mileage: 163055 km
                    Date: 2026.04.13
                    Time: 18:48:19
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000121519192
   Coding: 011D13215E00440004
   VCID: 4FFC90BA37D67612069-801A
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0003054832 Dataset Number: 8R0909852H  0021
   Coding: 100000010001
   Shop #: WSC 06334 123 12345
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
2305 - Function Restriction due to Start Voltage Interruption
          U1410 00 [00001000] - -
          [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit]
                    Reset counter: 141
                    Mileage: 163056 km
                    Date: 2026.04.13
                    Time: 18:55:27
                    2048.00 /min
   Revision: 00002001    Serial number: 0349360621
   Coding: 01260E3820FA709587A005360004004F
   Component: GTO BF  H01 0080
   Serial number: 00000000000000899698
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000121935482
   VCID: 4EC28DBE30DC7F1A0DF-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000443176
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2AD16E9CD4C3BAC17-806E
   Revision: AB001007    Serial number: 156J00E8082508
   Coding: 020007020100000001
   VCID: 24160F160ED0A54A8BB-8070
   Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0812
   Revision: --------    Serial number: 204J20E7686426
   Coding: 160200060005A1EF51028B5E00000403140000000000000000
   VCID: 3A2AD16E9C54C3BAC17-806E
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Component: DU7 High  H42 0104
   Serial number: A130JP0E3161307
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002011557
   Component: CD-Database  5950
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000122423233
   Coding: 010C13204000240004
   VCID: 46D2B59ED8ACB75AB5F-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J48A17H
   Coding: 1020010
   VCID: 3436FF56B23035CA1BB-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D20DA728D7AF482E45-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000122418259
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 142730427 Dataset Number: 8R0909571F  0017
   ROD: EV_RDCMA00100.rod
   VCID: 2D00EA325D9A6402545-8078
End----(Elapsed Time: 02:25, VBatt start/end: 11.7V/11.9V. VIgn 11.9V)-----
------------------------------6 Faults Found-------------------------------
Does this engine actually have a wastegate, or does it use a variable geometry turbocharger?
My guess is it's this Basic Setting:
IDE00457 -- Test of turbocharger
TRAUDI1
Maplewood, MN USA
C?ID=642292
Stock turbo with VGT and electric actuator
Did the test and it was aborted/safety reasons, malfunction. I'm just trying to see if it's an actuator issue or maybe a unison ring issue when it gets spooled up. Car is driven hard often with 101K miles on it.
What were the test conditions?
Given that your scan shows: "Actuator Module for Turbocharger 1 - Stuck" I would suppose there is still some mechanical problem.
Log EGT1, requested & actual boost, lambda, turbo actuator activation & requirement.
The FF data suggests the VGT is getting hung up, and potentially a tune issue or flaky EGT sensor as well.
Need more info.
TRAUDI1
Maplewood, MN USA
C?ID=642292
KOEO. I'll try running it again with KOER this evening. I was under the assumption the test would just do an electronic sweep of the actuator. When I manually activate it with just igniton on, it goes from 0.55% to 98.58%. (measures in % vs voltage?) Please let me know anymore info you'll need and I'll accomodate.
Vdub
C?ID=57533
do you have coolant loss?
TRAUDI1
Maplewood, MN USA
C?ID=642292
No coolant loss. I did the IDE00457 -- Test of turbocharger with car running. Had me put foot on brake and on accel. It did it's thing but didn't show any results. Would idle for few seconds then it would just get louder with no power for a few seconds and continued doing that over and over.
Vdub
C?ID=57533
those % are within specs i think.
Can you post the values of the DPF? or is it gone?
So we are just going to ignore #5? :confused:
TRAUDI1
Maplewood, MN USA
C?ID=642292
Ended up putting new turbo/Vgt on. Can you walk me through how to get the actuator recalibrated?
