Hi all,
I've been chasing this issue for a while on and off. I'm getting P0367 signal low, and once in a while P0366 implausible signal on the exhaust cam sensor (Sensor B, Bank 1).
Latest round was getting multiple misfires so was hoping the plugs were the issue, new plugs, no more misfires but still codes.
I've swapped the sensors around to see if it followed it and was confident that it didn't, but that was a long time ago so I just did it again today. Stays in the position and doesn't follow the sensor. Harnesses that I can see and connectors look fine, but I can see usually a drop in the reading but there is a spike in it too. I haven't quite gotten to the point of back probing the +5v/Ground/Output or jumping them from a different source or the ECM directly to bypass the wiring.
I'm wondering if anyone else has seen this before? I don't think the oil control would make it spike, or worse a physical problem with the engine. I have 133k miles and the timing belt is original but very much on my radar. I'm thinking if the belt was weird I'd get issues on both cams, and it would drop/spike versus just be wrong and have other drivability problems. Except during the drops/spikes, engine is smooth. When the EPC light is on can't go over 3k RPM as expected. Seems to have full power otherwise around that. Car has been in the family since new, oil changes at 5k since 40k on the odo, was 10k before that at the dealer. Now I do them myself. Always use Castrol 5w-30 Euro.
Thanks for your help!
Wednesday,15,April,2026,15:23:00:40418
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.4
VIN: 3VWDB7AJ6JM249944 License Plate:
Mileage: 214660km-133383mi Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 5F
VIN: 3VWDB7AJ6JM249944 Mileage: 214660km-133383miles
Address 01: Engine (J623-CZTA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 BK HW: 04E 907 309 AP
Component: R4 1.4l TSI H22 5007
Revision: X5H22--- CVN: 811724E5
Coding: 011A0012232400000000
Shop #: WSC 00066 790 00209
ASAM Dataset: EV_ECM14TFS01104E906023BK 005006
ROD: EV_ECM14TFS011_VW32.rod
VCID: 6A8DD4934CF6377A717-803E
VINID: 0E69D448745A19A7421092441038625A2E
4511 - Camshaft Position Sensor B Bank 1 (G300)
P0366 00 [01100100] - Implausible Signal
Mileage: 214664 km
Date: 2026.04.15.
Time: 15:15:35
Engine speed: 920.50 /min
Normed load value: 23.5 %
Coolant temperature: 95 C
Intake air temperature: 46 C
Voltage terminal 30: 13.782 V
Starter control: Interlock- or P/N-signal-Bits 0-7: 17
Brake actuated status-Bits 0-7: 0
Selector lever position-Bits 0-7: 8
Adaptation status of neutral position sensor-Bits 0-7: 0
Engine status: COENG_RUNNING
5534 - Camshaft Position Sensor B Bank 1 (G300)
P0367 00 [01100101] - Signal too Low
Mileage: 214664 km
Date: 2026.04.15.
Time: 15:07:26
Engine speed: 916.00 /min
Normed load value: 22.0 %
Coolant temperature: 94 C
Intake air temperature: 42 C
Voltage terminal 30: 13.900 V
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 BA HW: 09G 927 158
Component: AISIN AG6 G3 202 3117
CVN: EDA05DDC
Coding: 010100000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW23.rod
VCID: 73B3C9F71B3CF6B2C21-8026
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A14B400C49260003851402E8921D004120100012
Shop #: WSC 00066 000 00000
VCID: 75B7F7EF15C8E882EC5-8020
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 DA HW: 5C0 820 047 DA
Component: J301 Klimaanlage 0211
Revision: 2001401S Serial number: 00000004317361
VCID: 629DBCB3B8466F3AB97-8036
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 189 B HW: 7E0 937 189 B
Component: BCM PQ25 MMI3 H82 0752
Revision: BA082001 Serial number: 58227222174701
Coding: 7B994B1808AB0B0000392080240884C54BC6720E60A551F0B00010032844
VCID: 333309F75B3CB6B2021-8066
Subsystem 1 - Part No SW: 6R0 959 801 DF HW: 6R0 959 801 DF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 022 1467
Serial number: 14102743170919054334
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 DJ HW: 6R0 959 802 DJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 022 1467
Serial number: 14102742170919165817
Coding: 820000
Subsystem 3 - Part No SW: 6C0 959 442 G HW: 6C0 959 442 G
Serial number: 2291714454700328BE1B
Coding: 280000
Subsystem 4 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1467
Serial number: 14102745170925221945
Subsystem 5 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1467
Serial number: 14102744170925021001
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 008 0210
Serial number: 003RXM0CMXBY Dataset Number: V03935250PX 0001
Coding: 8CCCF000000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 6393B9B7ABDC6632B21-8036
Seat occupant detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007UAXEB
Coding: 303146
Subsystem 2 - Part No SW: ----------- HW: 480 001 108 17
Serial number: 357000000003D3ECF62/
Subsystem 3 - Part No SW: ----------- HW: 480 001 108 17
Serial number: 35800000000CE438872V
Subsystem 4 - Part No SW: ----------- HW: 480 022 007 17
Component: SideSensor_Dr 000 0148
Serial number: 3510001AF260B434A6C7
Subsystem 5 - Part No SW: ----------- HW: 480 021 406 17
Component: SideSensor_Pr 000 0148
Serial number: 3520001A925B1D23E533
Subsystem 6 - Part No SW: ----------- HW: 480 022 706 17
Component: FrontSensor_D 000 0189
Serial number: 3550001A324FDE42E1CM
Subsystem 7 - Part No SW: ----------- HW: 480 022 706 17
Component: FrontSensor_P 000 0189
Serial number: 3560001A324FDE42464A
Part No SW: 5C6 920 956 A HW: 5C6 920 956 A
Component: KOMBI H02 1107
Coding: 220A010000
Shop #: WSC 00066 790 00320
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 2E051883B09E9B5A6DF-807A
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 189 B
Component: GW-K-CAN TP20 H82 0752
Revision: BA082001
Coding: 102201
VCID: 6889AE9B527A056A673-803C
Component: IMMO H02 1107
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 305 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F3BDF75504CE2C8D-806C
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 561 035 150 B HW: 561 035 150 B
Component: MU-E--ER 056 7227
Serial number: 21081700011096 Dataset Number: V03935264AG 0001
Coding: 02630100AA00000041220001001000009F0000D40000010000
ROD: EV_MUEnt4CGen2LGE_VW36.rod
VCID: 0C41B20B66C2894AA3B-8058
End----------(Elapsed Time: 01:07, VBatt start/end: 12.3V/12.2V)-----------
------------------------------2 Faults Found-------------------------------
