- Jan 14, 2022
- 6
- 2
- Anglesey, Wales, UK
- C?ID=492558
Good evening. My friend recently purchased a 2017 Audi A6 from a dealer in the midlands. he has had the car back to them to resolve a couple of issues, primarily with the DPF, I have scans from before it went to them for this work, but it has been back and appeared to be fine until this week when the traction control, ABS, TPMS, Parking brake fault and adaptive headlamp warnings all came up on the dash. I have scanned the car, done some simple tests and have not been able to diagnose the problem. despite a front right wheel speed sensor fault being present and the most obvious starting point, a correct reading appeared to be coming from the sensor. I had a new sensor to hand and swapped it out just to see if that affected the issue however all codes remained the same.
I am wondering if anyone has seen a similar issue?
Thank you in advance for any help.
Wednesday,15,April,2026,18:05:40:29179
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4701.5
VIN: WAUZZZ4G7HN106465 License Plate: GM17UGW
Mileage: 126678km-78714mi Repair Order: jaime
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
5F 62 6D 72 AC 47
VIN: WAUZZZ4G7HN106465 Mileage: 126678km-78714miles
Address 01: Engine (J623-DDDA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 HA HW: 04L 907 309 AA
Component: R4 2.0l TDI H20 4166
Revision: 8DH20--- CVN: 27146149C19C7771D45710C1
Coding: 12254012242401080000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01104L906021HA 004005
ROD: EV_ECM20TDI011_AU57.rod
VCID: 6B88AFB86302EFE20A1-803E
VINID: 9D196AAAA1171D8781006106146E6304B8
Readiness: 0 0 0 0 X
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 B HW: 0CJ 927 156
Component: 0CK 20TDI RdW H03 0004
Revision: --H03--- Serial number: 0000000940 CVN: 41377A85
Coding: 100001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU57.rod
VCID: 290495B0A97E3DF2B8D-807C
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071170045001426
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A29E41604579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41D42D10310ED5B280D-8014
124416 - Function Restriction due to Faults in Other Modules
U1113 00 [00101111] - -
[Ldm_ApbFailureState]
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:43
VzRef: 00
Bit Info 1: C0
Bit Info 2: 0F
Bit Info 3: 22
Bit Info 4: 1F
Uz: 83
93440 - Front Right Wheel Speed Sensor
C101B 14 [10101111] - Open or Short to Ground
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:47
VzRef: 00
Bit Info 1: C0
Bit Info 2: 43
Bit Info 3: 22
Bit Info 4: 1F
Uz: 92
94208 - Front Right Wheel Speed Sensor
C101B 01 [00100010] - Electrical Failure
203776 - Front Right Wheel Speed Sensor
C101B 01 [10101111] - Electrical Failure
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:43
VzRef: 00
Bit Info 1: C0
Bit Info 2: 0F
Bit Info 3: 20
Bit Info 4: 1F
Uz: 80
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 BCM2 2.0 H61 08250825
Coding: 01B9704E000000000000
VCID: 7CAA9CE416EC785A93B-8028
No Faults Found
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 23021700041358
Coding: 34220978210000
VCID: 6398C7988BD2A7A2B21-8036
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001598743902
Coding: 0105001440349FE04101408380001800CF9DC7082F08020100000894E100140200400024030000
VCID: 74BAB4C43EBC301ADBB-8020
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 161203 H38 0080
Serial number: 170118061600
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 24046157
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 24 02 2017 00000089
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: B898059800PAG0MUFU03
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:47
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:52
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100CX5A3 Dataset Number: 4G0909602M 0003
Coding: 30333130313630323639554A305234473053
VCID: 3B285FF853E2BF62DA1-806E
Serial number: 3575HRB401857GU2FP3J
Serial number: 3585HRB400I57HGCE0TQ
Serial number: 3515JRB400I599BCJPS$
Serial number: 3525JRB400Q599U0B9AD
Serial number: 3554VRB4055485R6F856
Serial number: 3564VRB4055485R628RG
1049350 - Databus
[CAN: 0x103 ESP_03 error value ESP_VR_Radgeschw]
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:45
1049605 - Databus
U1123 00 [10001001] - Received Error Message
[CAN: 0x084 ESP_06 error value ESP_v_ref]
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:57:41
B13BC F2 [10001001] - No function
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:57
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 91560QBL000DU
Coding: 000035
VCID: 3B285FF85362BF62DA1-806E
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 13 02 2017 D0028451
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:45
Part No SW: 4G8 920 987 R HW: 4G8 920 987 R
Component: TDieGb H15 0225
Revision: 15001308 Serial number: 658210217592031
Coding: 33A615000B412600010000
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 48C230341234E4FA473-801C
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Revision: -------- Serial number: 00000002542398 Dataset Number: 4G0909515N 0025
Coding: C0CD074418
GVL: FD81C948DC21600300040000
VCID: 3D2C51E04DF6B152E45-8068
Control module for battery monitoring:
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 7414583004
Voltage stabilizer:
Serial number: 161227000000000001D6
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 6780D3887F6ACB826E9-8032
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 23021700040713
Coding: 22
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000241514596
Coding: 0078130000006001000001010101102030303232203232
VCID: 77A083C82FCA5B02FE9-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720VUCKA Dataset Number: 4G0909573C 0006
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 333877D87BB27722021-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011F16015E01620002080002
VCID: 47C033081FAAEB824E9-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000656624 Dataset Number: 4G0909852L 0038
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A265AFC5CD8866AC17-806E
3164944 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[Fehlerwert "Radgeschwindigkeiten"]
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:47
0D 00 00 00 00 00 00 00 00 00
Component: BCM2 2.0 H61 0825
Revision: 00002001 Serial number: 0433410520
Coding: 013B0622A0B93080C320098400010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 B
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Serial number: 0000000AP00030355310
Component: TSG BF H03 0511
VCID: 46DE3E0C18A0F28AB5F-8012
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002125945 Dataset Number: 4G0909522G 0001
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 323672DC84A87E2A097-8066
459776 - Function Restriction due to Faults in Other Modules
U1113 00 [10001001] - -
[FC_SIGNAL_ESP_FR_RADGESCHW_ERROR_VALUE]
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:43
Voltage terminal 30: 10.4 V
Internal Fault ID: 140
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
Internal Parking Brake state: static
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 4G0909865D 0019
Coding: 04FE02102A630200
VCID: 343A74C47EBC701A1BB-8060
Coding: E01E00
Coding: E01E00
13705986 - Databus
[Empfangener Fehlerwert im Signal ESP_VR_Radgeschw: CAN Message ESP_03]
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:56:47
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 P HW: 4G1 035 021 D
Component: MU-H-LND-EU 053 1425
Serial number: A733B0H2511412 Dataset Number: 4G1909545G 0040
Coding: 017502010000000013111102000A00332F0006E7F1700100DF
VCID: 27009388BF6A0B82AE9-8072
Subsystem 1 - Part No SW: V03 959 801 FC HW: -----------
Component: ECE 2017 --- 0157
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY807AVE
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349QBL000D7
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 GG HW: -----------
Component: Gracenote2 --- 1021
B201A 00 [00001001] - -
Reset counter: 183
Mileage: 126676 km
Date: 2026.04.15
Time: 17:39:38
Voltage terminal 30: 11.9 V
Status_Software_Version_Management-module_name: MKBD_FC7/KBD
Component: TSG HL H03 0511
Coding: 010F14004001620002080002
VCID: 49C4353009BE1DF258D-801C
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0152
Revision: 14005001 Serial number: 024701676 Dataset Number: 4G0909541E 0005
Coding: 093205C010
ROD: EV_HDSGAu571_AU57.rod
VCID: 363E4ECC68C0620A25F-8062
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 170270348 Dataset Number: 4G0909571H 0017
ROD: EV_RDCMA00100.rod
VCID: 2F307BA8979A53C2669-807A
Part No SW: 4G5 035 223 E HW: 4G5 035 223
Component: MIB2_amp_P H03 0440
Serial number: 00000000017195 Dataset Number: 4G1909510Q 0013
Coding: 01750208018AF02A5A0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 241A8484CE5CE09A8BB-8070
End----------(Elapsed Time: 02:25, VBatt start/end: 14.1V/14.3V)-----------
------------------------------14 Faults Found------------------------------
