Volkswagen Scirocco (13) - 2010 - Cruise Control Retrofit
Abbott Automotive
Mansfield, Nottinghamshire, UK
C?ID=248870
I was just wondering if anyone could help me identity the correct module that I will need to retrofit cruise control on my (2010 Volkswagen Scirocco)
I've already purchased the cruise control stalks (part number: 5K0 953 502 M), but I am being told different part numbers by different people for the correct module that I will need to carry out this retrofit.
I have also been told that because I already have a highline module installed (exiting module part number: 5K0 953 569 D) that I "might" not need to change the module, could this be a possibility?
I thought it may be good to add this little bit of information too, as I think it’s relevant to the post ... It's the model with the MFSW
Please note: This is my first post of the Forum so please go easy on me if I've missed anything ;)
I have also copied a full auto scan below
Thank you, in advance
Thursday,03,December,2015,19:33:37:48548
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WVWZZZ13ZAV436850   License Plate:
Mileage: 90520km-56246mi   Repair Order:
Chassis Type: 13 (1K0)
Scan: 01 03 08 09 14 15 16 17 19 25 2E 42 44 46 52 56
VIN: WVWZZZ13ZAV436850   Mileage: 90520km-56246miles
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 KD    HW: 03L 906 022 G
   Component: R4 2,0L EDC 0000SG  6166
   Revision: 13H03---    Serial number:
   Coding: 0001072
   Shop #: WSC 00020 790 00000
   VCID: 71E99DD16814BEB694-8024
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 763B40F5492500006E1302E992190082300000
   Shop #: WSC 00020 790 12345
   VCID: 78FFA0F5CB6EEFFE53-802C
   Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00020 999 00000
   VCID: 7DF1B1E1EC4CCAD600-8028
9475349 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [008] - Open or Short to Plus
                    Reset counter: 13
                    Mileage: 90245 km
                    Date: 2015.11.28
                    Time: 13:37:03
   Part No SW: 5K0 937 086 C    HW: 5K0 937 086 C
   Component: BCM PQ35 M    011 0028
   Revision: BC011001
   Coding: 4E100A38F027E100408800843400812E43513B88536D81605C8000000000
   VCID: 346754C59786CB9EBF-8060
   Subsystem 1 - Part No: 1K8 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 17120  22  0614
   Coding: 009795
   Component: RLS 160210 05  54  0403
   Coding: 0730ED
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
                    Fault Status: 00101010
                    Reset counter: 248
                    Mileage: 88566 km
                    Date: 2010.04.06
                    Time: 16:55:53
                    Voltage: 14.00 V
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 08021004490002
   Coding: 000180
   Shop #: WSC 47951 001 1048576
   VCID: 275DB3895650B0060A-8072
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0H AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D023NCR
   Coding: 0012360
   VCID: 6FED9BA97E20A84682-803A
   Subsystem 1 - Serial number: 6332MSME4E7242419
   Subsystem 2 - Serial number: 6342MSME4E7300718
   Subsystem 3 - Serial number: 6352QSME4F4E0122J
   Subsystem 4 - Serial number: 6362QSME324C1C36L
   Part No SW: 5K0 953 521 T    HW: 5K0 953 569 D
   Component: LENKS.MODUL   009 0122
   Revision: FF010035    Serial number: 20100211200732
   Coding: 1082040000
   ASAM Dataset: EV_SMLSNGVOLWS A01002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D7171E1ACCC0AD640-8068
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Coding: 820000
   Part No SW: 1K8 920 971 C    HW: 1K8 920 971 C
   Component: KOMBI         H05 0305
   Coding: 170B00
   Shop #: WSC 00020 999 12345
   VCID: 336557D99A88CCA6A6-8066
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K102160B97
   Coding: E9881F06000212004001
   VCID: 69D9F5B140C44676DC-803C
   Component: IMMO          H05 0305
   VCID: 6ADB8ABD8DC24D6ED5-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667802323
   VCID: 2643BE8D515AA90E31-8072
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2124
   Coding: 0016949
   VCID: 397965F170E436F66C-806C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 178    3001
   Revision: 00H17000
   VCID: 31695DD1A894FEB6D4-8064
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0016948
   VCID: 3A7B7AFD75E23DEE65-806E
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3K6360226
   Coding: 0100040004
   VCID: 65C1F9816CDC6216F8-8030
End-------------------------(Elapsed Time: 02:05)--------------------------
AIB Wolfgang
Hi,
searched for informations and found this:
Address 16: Steering wheel (J527) HW: 5K0 953 569 D >> without CCS
Part number 5K0 953 569 L >> PR 8T1/2 >> assisted CCS
otherwise 5K0 054 691 E >> retofit kit for CCS
Abbott Automotive
C?ID=248870
Thank you for your reply
I am being told the modules that will work are ... 5K0 953 569 E, H, T (and 'AL' which is apparently the old H)
I believe this information is based on the chart below
Abbott Automotive
C?ID=248870
Here's just a quick update for anyone else is looking for this informatiom (the above info on my last post is correct)
My current non CCS module is 5K0 953 569 D, this has to be changed to 5K0 953 569 E, H or T (the 'AL' being the old 'H' is also fine)
Thank you to them who took time to take a look at my post :thumbs:
