Seeking clarification on a few long coding option in VCDS
NitrousOxide
Jamaica
C?ID=269481
What does it mean below by: "Siren configuration blocked"? This is the setting that I got the car with. I know that the car alarm's siren is physically missing altogether, but I'm trying to understand the meaning of that option below. This is in controller #46 for my MK5 Golf.
Is there any way to have the car alarm make the audible note through the car's (driving) horn instead of the (non-existent) siren? My MK5 Golf is one of those models where the horn doesn't work unless the ignition is ON. Is there any way of enabling that circuit (for the horn) to always remain HOT in VCDS (without having to have the car re-wired)?
As it relates to Byte 17, Bit 2: What type of transmission is being referenced here? I know it has nothing to do with the gearbox or DSG, so I assume that it must be some sort of signal.
As customary, I've posted my log below: I restored a few values in some of the controllers to get rid of some of the errors I was experiencing.
Wednesday,24,February,2016,18:06:56:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ1KZ8W111078   License Plate:
Mileage: 146390km-90962mi   Repair Order:
                Address 09: Cent. Elect.       Labels: 3C0-937-049-30-H.lbl
Control Module Part Number: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
  Component and/or Version: Bordnetz-SG     H54 2202
           Software Coding: E78F8F2700041500471400001400000000097F075C100100000000000000
            Work Shop Code: WSC 11111 111 45725
           Additional Info: 1K2955119E  Wischer 300807 021  0501   1K0955559AF RLS     130907 046  0204
                      VCID: 71C72C48683532B681-8024
02498 - Left Low Beam Reflector Motor (V294)
02499 - Right Low Beam Reflector Motor (V295)
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
00317 - Rear Lid Control Module (J605)
Address 09: DTCs cleared
Address 09-02:1K0 955 559 AF recoded (Short coding) from 00208933 to 00221517  (11111/111/45725)
Address 15: DTCs cleared
Address 15:1K0 909 605 T recoded (Short coding) from 0013121 to 0013121  (01269/785/00200)
                Address 19: CAN Gateway       Labels: 1K0-907-530-V3.clb
Control Module Part Number: 1K0 907 530 L    HW: 1K0 907 951
  Component and/or Version: J533  Gateway   H07 0052
           Software Coding: ED811F060002030001
            Work Shop Code: WSC 12345 785 00200
                      VCID: 3041E94CA3BF7BBECE-8064
02010 - Left Entry Assistance Control Module (J572)
Address 19: DTCs cleared
Address 19:1K0 907 530 L recoded (Long Coding) from ED811F060002030001 to ED811F060002020001  (12345/785/00200)
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46:1K0 959 433 BT recoded (Long Coding) from 9890020851030C7F42CC8F0F70085A2690BC00 to 819002085103087F2D04840570085A0690BC00  (11111/111/45725)
Address 03: DTCs cleared
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 55 56
VIN: WVWZZZ1KZ8W111078   Mileage: 146390km-90962miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070060
   Shop #: WSC 80182 411 444102
   VCID: 354FD8585CDD5E969D-8060
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 146101 km
                    Time: 20:10:32
                    RPM: 758 /min
                    Load: 25.9 %
                    Temperature: 93.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 146101 km
                    Time: 20:10:42
                    RPM: 750 /min
                    Load: 23.5 %
                    Temperature: 93.0°C
                    Temperature: 65.0°C
                    Voltage: 13.716 V
Readiness: 0110 0101
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 04808020    Serial number: 00000907050136
   Shop #: WSC 09537 809 89632
   VCID: 1C192DFCDF37EFDE82-8048
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 00000 785 00200
   VCID: 73CB2640122900A673-8026
7 Faults Found:
01487 - System Function Test
            000 -  -  - Intermittent
01486 - System Function Test Activated
            000 -  -
            013 - Check DTC Memory
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79D7146830457AF639-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 01000007456322
   Shop #: WSC 11111 111 45725
   Component: Wischer 300807 021  0501
   Coding: 00038805
   Shop #: WSC 11111
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 11111
                    Fault Status: 01111100
                    Reset counter: 0
                    Mileage: 146104 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.60 V
                    Reset counter: 0
                    Mileage: 146104 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.60 V
                    Fault Status: 01101001
                    Reset counter: 0
                    Mileage: 146395 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.75 V
                    Fault Status: 01110100
                    Reset counter: 0
                    Mileage: 146355 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.65 V
                    Reset counter: 0
                    Mileage: 146101 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.25 V
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86D655-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
            007 - Short to Ground - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012102
   VCID: 01277C885895223671-8054
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0004103
   Shop #: WSC 12345 111 45725
   Revision:   H07 01    Serial number: 040907F1000254
   Shop #: WSC 12345 785 00200
                    Reset counter: 248
                    Mileage: 146211 km
                    Time: 16:47:55
                    Reset counter: 252
                    Mileage: 146355 km
                    Time: 19:30:29
                    Reset counter: 252
                    Mileage: 146355 km
                    Time: 19:34:10
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000564
   VCID: 3851D16C4BCFA3FE86-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   VCID: 2F43EA30BE816446D7-807A
01312 - Powertrain Data Bus
                    Fault Status: 00101110
                    Reset counter: 33
                    Mileage: 146211 km
                    Time: 20:59:37
                    Voltage: 13.50 V
                        DU
                    Temperature: 60.0°C
                    RPM: 1498 /min
                    Speed: 2.0 km/h
                    Speed: 2.0 km/h
                    Count: 3
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 238
                    Mileage: 146101 km
                    Time: 20:10:39
                    Battery Volts: 13.9 V
                        DU
                    Temperature: 56.0°C
                    Count: 5
                    Steering Angle: -0.70°
                    Count: 1
                        SteerAng Init
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 9890020851030C7F42CC8F0F70085A2690BC00
   VCID: 032B76804289302663-8056
                    Reset counter: 238
                    Mileage: 146101 km
                    Time: 20:10:39
00950 - Central Locking Motor - tailgate (V53); UNLOCK
                    Fault Status: 01100111
                    Reset counter: 239
                    Mileage: 146114 km
                    Time: 18:00:03
Address 4F: Centr. Electr. II (J533)       Labels: 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 00000000
   VCID: 66ED4F1491FBE50EE4-8032
   Coding: 0000564
   VCID: 3957D46870C5BAF679-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74C9255C1727079E6A-8020
01533 - Terminal 56 (High Beams)
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       018 0035
   Revision: 00018000    Serial number: VWZ5Z7G2174742
   Coding: 0040400
   VCID: 2A75FB248563016E00-807E
                    Fault Status: 00111011
                    Reset counter: 37
                    Mileage: 146241 km
                    Time: 14:51:21
End-------------------------(Elapsed Time: 01:07)--------------------------
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
                    Mileage: 146101 km
                    Time: 20:10:32
                    RPM: 758 /min
                    Load: 25.9 %
                    Temperature: 93.0°C
                    Temperature: 66.0°C
                    Voltage: 13.716 V
                    Mileage: 146101 km
                    Time: 20:10:42
                    RPM: 750 /min
                    Load: 23.5 %
                    Temperature: 93.0°C
                    Temperature: 65.0°C
                    Voltage: 13.716 V
   Revision: 00H11001
   Coding: 0004738
            000 -  -
   Coding: 00038805
   Shop #: WSC 11111
   Coding: 00221517
   Shop #: WSC 11111
                    Reset counter: 1
                    Mileage: 146395 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.20 V
   Coding: 0013121
            007 - Short to Ground - MIL ON
   Coding: 0012102
   Coding: 0004103
   Coding: ED811F060002020001
   Coding: 0000564
   Revision: 00H15000
                    Reset counter: 33
                    Mileage: 146211 km
                    Time: 20:59:37
                    Voltage: 13.50 V
                        DU
                    Temperature: 60.0°C
                    RPM: 1498 /min
                    Speed: 2.0 km/h
                    Speed: 2.0 km/h
                    Count: 3
                    Reset counter: 0
                    Mileage: 146395 km
                    Time: 18:19:01
                    Battery Volts: 14.5 V
                        DU
                    Temperature: 38.0°C
                    Count: 5
                    Steering Angle: 15.27°
                        SteerAng Init
   Coding: 819002085103087F2D04840570085A0690BC00
                    Reset counter: 238
                    Mileage: 146101 km
                    Time: 20:10:39
                    Reset counter: 239
                    Mileage: 146114 km
                    Time: 18:00:03
   Coding: 0000564
   Coding: 0000003
   Coding: 0040400
                    Reset counter: 37
                    Mileage: 146241 km
                    Time: 14:51:21
End-------------------------(Elapsed Time: 01:02)--------------------------
