2023 NAR Tiguan SE Auto Hold retrofit
bikergeek
C?ID=320172
Had success activating this feature.
ABS unit HW: 5Q0-614-517-BP
Got the parking brake switch with the Auto Hold feature from AliExpress.
Went into Module 03 ABS, Security Code 20103, toggled item "IDE05263-AUTO HOLD functionality" from "not activated" to "activated".
Long coding, toggled Byte 23 bit 0 to "1". (This is not in Long Coding Helper; I found this on the internet.)
Cycled the ignition to clear the error messages on the dash. It works!
There is however no green indicator on the dash to show the system is active when you're stopped, though. I guess because it's the NAR dash that uses the word "PARK" instead of the universal pictogram with a "P" in a circle for the parking brake? (FMVSS sez you have to use the word "BRAKE" for brake warning, and "PARK" for the parking brake, rather than the universal pictograms. Yet another case of USA automotive equipment regulations being "different and incompatible, but not better".) I was hoping I'd at least get the "PARK" indication in green, or something.
I am told there are some MQB NAR Tiguans that are missing two needed wires between the switch and the ABS module, supposedly they're positions 10 & 12 in the connector. If you don't have wires in those positions this may not work. I've read about this applying to non-SEL cars only, model years '18-'19, but maybe there are others, who knows. Your mileage will almost certainly vary.
Westbury, UK
Is this a continuation of a previous thread about this vehicle? If it is then please post a link.
From the information above it's impossible to help, we need to see a complete Auto-Scan.
iichel
Netherlands, Operation Market Garden
C?ID=284912
does your instrument cluster have something like autohold in the coding?
also, did you verify the presence of the two wires you mention? /10 and /12 on the button and /23 and /32 on the ABS controller
bikergeek
C?ID=320172
Not looking for help, reporting success. But thanks!
Westbury, UK
Without knowing the configuration of your vehicle it's not possible to tell how relevant your success is to other owners, hence the request for an Auto-Scan.
bikergeek
C?ID=320172
Auto scan. A lot of "Low voltage" errors--the car isn't driven frequently and is only driven for short distances so the battery never really gets fully charged up.
Wednesday,15,April,2026,18:11:12:10877
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
VIN: 3VVMB7AX4PM070237   License Plate:
Mileage: 19394km-12050mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 3C 42 44 52 5F 6C 75 A5 BB
          BC CA
VIN: 3VVMB7AX4PM070237   Mileage: 19394km-12050miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DTEA)       Labels:. 06K-907-309-V2.clb
   Part No SW: 83A 907 115 K    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0001
   Revision: 1DH31000    CVN: 4B20557F
   Coding: 012A00122466012FB4000000000000000000000000000000
   Shop #: WSC 00066 790 00142
   ASAM Dataset: EV_ECM20TFS01183A907115K 001002
   ROD: EV_ECM20TFS01183A907115K.rod
   VCID: 2E05F0084095E2AA6DF-807A
   VINID: 0E699D4874681207401C00831C34A78A0B
42452 - Voltage Supply 1 for Control Module
          U3501 00 [01101000] - Too Low
                    Fault Frequency: 36
                    Mileage: 16724 km
                    Date: 2025.08.31
                    Time: 19:23:30
                    Engine speed: 1074.50 /min
                    Normed load value: 35.7 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 17 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 10.700 V
                    Engine status: COENG_RUNNING
23765 - Control unit for information electronics 1
          U1054 00 [00100000] - No Communication
          [Information electronics control module 1No Communication]
                    Mileage: 17934 km
                    Date: 2025.12.30
                    Time: 18:37:25
                    Engine speed: 1168.00 /min
                    Normed load value: 25.5 %
                    Vehicle speed: 45 km/h
                    Coolant temperature: 55 °C
                    Intake air temperature: 5 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 14.720 V
                    Unlearning counter according OBD: 35
                    Com st X Set2 Val1-Bits 0-7: 0
                    Com st X Set2 Val2-Bits 0-7: 0
                    Com st X Set2 Val3-Bits 0-7: 0
                    Com st X Set2 Val4-Bits 0-7: 0
                    Com st X Set2 Val5-Bits 0-7: 0
                    Com st X Set2 Val6-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 1
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 09G 927 158 GN    HW: 09G 927 158
   Component: AISIN AQ8     206 3938
   CVN: AF232F96
   Coding: 0000000100000000000000000000000000000000
   Shop #: WSC 00066 790 00405
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 05576FA4B5A381F2FC5-8050
   Part No SW: 5Q0 614 517 GB    HW: 5Q0 614 517 BP
   Component: ESC           H35 0114
   Revision: 00000000    Serial number: 52902000001764 Dataset Number: V03935346AW 0001
   Coding: 0BFA6BA450271B6CC5790303A2CA49D0D60AD8A3C045927518415558D2AA4A0B00402F641A1B1311145E833B485266E4
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049_VW37.rod
   VCID: 77AB156CFF4FE362FE9-8022
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0607776037 Dataset Number: V03935340QJ 0001
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   VCID: 48C9A690C2315C9A473-801C
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 222
                    Mileage: 19351 km
                    Date: 2026.04.12
                    Time: 17:54:59
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 8.587 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 148.5 /min
                    Status of vehicle locking: Vehicle unlocked at single door
                    Coding information: coded
                    Coding information: Not coded
                    Driver´s door: closed
                    Passenger´s door: closed
                    Rear left door: closed
                    Rear right door: closed
                    Active_LF_scans: Keyminder_Scan
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NN 907 044 AF    HW: 5NN 907 044 AF
   Component: AC Automat    H36 4901
   Revision: 20K04000    Serial number: 00000D00746426
   Coding: 0002002420011C001004004012111416
   Shop #: WSC 00066 790 00449
   ASAM Dataset: EV_ACClimaPrehVW37X 002030
   VCID: 10794EF0FAE1D45A5F3-8044
   Part No SW: 5Q0 937 085 CJ    HW: 5Q0 937 085 CJ
   Component: BCM MQBAB MNA H44 0511
   Serial number: 3004017101ÿÿÿÿ Dataset Number: V03935387SY 0001
   Shop #: WSC 00066 790 00454
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW37.rod
   VCID: 035371BCBB97BFC2D21-8056
   Subsystem 1 - Part No SW: 5NN 955 119 B    HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 221221  041 0374
   Serial number: 22121821080430
   Coding: 064DDD
   Subsystem 2 - Part No SW: 81D 955 555 A    HW: 81D 955 555
   Component: G397_RLFSS  H06 0004
   Serial number: 40642781X81D955555A0
   Coding: 0000DE
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 KK    HW: 5Q1 953 569 H
   Component: Lenks.Modul  H04 0190
   Serial number: 0300310120230C200123
563221 - Databus
          [OCU Datenbus fehlende Botschaft]
                    Reset counter: 218
                    Mileage: 19306 km
                    Date: 2026.04.06
                    Time: 19:34:38
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    Voltage: 12.0 V
                    Outside temperature: 7.5 °C
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935389RR 0001
   Coding: 320007D118FF8728749C810580409700000000000000000034
   Shop #: WSC 00066 790 00277
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 73B3217CEB378F42C21-8026
2082 - Databus
          [FAULT_EPB_SWITCH_FAIL]
                    Reset counter: 222
                    Mileage: 19351 km
                    Date: 2026.04.11
                    Time: 17:04:54
                    Voltage terminal 15: 11.5 V
                    Control Module temperature: 16 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.44 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
196740 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_SENSOR_BLOCKAGE]
                    Reset counter: 185
                    Mileage: 18483 km
                    Date: 2026.02.20
                    Time: 18:05:24
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 26 °C
                    Vehicle speed: 10.37 m/s
                    Longitudinal acceleration: 0.47 m/s²
1389 - Function Restricted due to Insufficient Voltage
          [FAULT_VBAT_BUSMON_LOW]
                    Reset counter: 222
                    Mileage: 19351 km
                    Voltage terminal 15: 10.4 V
                    Control Module temperature: 10 °C
                    Longitudinal acceleration: 0.41 m/s²
                    Adaptive distance regulation: status: ACC_Init
   Part No SW: 5Q0 959 655 CB    HW: 5Q0 959 655 CB
   Component: AirbagVW21    010 0421
   Serial number: 003J4M0CZ9J. Dataset Number: V03935355MG 0001
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 025D74B8A48DB6CAD97-8056
   Component: BF-Gewichtss.  H16 0022
   Serial number: IBH00000000000JOA2BQ
   Coding: 303553
   Subsystem 2 - Part No SW: -----------    HW: 480 000 511 22
   Serial number: 35700000000B7299536O
   Subsystem 3 - Part No SW: -----------    HW: 480 000 511 22
   Serial number: 358000000005E4F0B36V
   Subsystem 4 - Part No SW: -----------    HW: 480 400 410 22
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001AA9EDCF81036P
   Subsystem 5 - Part No SW: -----------    HW: 480 402 809 22
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A89EC8C21254C
   Subsystem 6 - Part No SW: -----------    HW: 480 400 510 22
   Component: FrontSensor_D  003 6149
   Serial number: 3550001BD0AF4DF4476U
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 510 22
   Component: FrontSensor_P  005 6149
   Serial number: 3560001B09EDCF8332AT
   Part No SW: 5NA 920 410 B    HW: 5NA 920 410 B
   Component: KOMBI         060 4846
   Coding: 08A40008E788CF050288720B10000000A0200F02
   ASAM Dataset: EV_DashBoardJCIMQBAB 010007
   ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
   VCID: 3635D868B8C5DA6A25F-8062
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [00001000] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 34
                    Mileage: 17934 km
                    Date: 2025.12.30
                    Time: 18:37:29
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 34
                    Mileage: 17934 km
                    Date: 2025.12.30
                    Time: 18:37:29
16777022 - Function Restricted due to Interrupted Communications
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 34
                    Mileage: 17934 km
                    Date: 2025.12.30
                    Time: 18:37:29
16777056 - Function Restricted due to Interrupted Communications
          [BAP_SDS_0x46 keine Kommunikation]
                    Reset counter: 34
                    Mileage: 17934 km
                    Date: 2025.12.30
                    Time: 18:37:29
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5502
   Serial number: 06022300840721 Dataset Number: V03935370EU 0001
   Coding: 030D00347F085B00FB0322581E0F00010001070000000000000000000000
   GVL: 01C03C000000040040CC80008002C80010000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFD4CD77FDB22B69-802A
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 AE    HW: 3G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-YLG  H07 0120
   Serial number: YLG-0700092015230078
   Coding: 2C2B00
   Component: J367-BDMHella  H11 9070
   Serial number: 3603609500
131687 - No Communications with Emergency Call Module
          U10E1 00 [00001000] - -
          [Timeout Knoten 0x67 / 75 - Notrufmodul]
                    Reset counter: 218
                    Mileage: 19306 km
                    Date: 2026.04.06
                    Time: 19:34:40
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: OFF
131699 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 218
                    Mileage: 17934 km
                    Date: 2025.12.30
                    Time: 18:37:27
                    Terminal 30 power supply: 14.7 V
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [00001000] - Warning Triggered
                    Fault Frequency: 31
                    Reset counter: 189
                    Mileage: 17649 km
                    Date: 2025.12.06
                    Time: 20:26:00
                    Terminal 30 power supply: 11.6 V
                    Terminal 15: On
Address 22: AWD (-----)       Labels:| 0CQ-907-554-V1.clb
   Part No SW: 5WA 907 554 P    HW: 5WA 525 130
   Component: 4Motion       H65 0724
   Serial number: HA1-00004.10.22
   Coding: 0101
   ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
   ROD: EV_AllWheelContrHA1VW37X_005.rod
   VCID: 5BE369DC63A72702FA1-800E
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 11230053814828  Dataset Number: V03935352AH 0001
   Coding: 5294C640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW37.rod
   VCID: 392FD35489DB3512C8D-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 11230054076822
2240558 - Databus
          [databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
                    Reset counter: 39
                    Mileage: 19351 km
                    Date: 2026.04.11
                    Time: 17:27:58
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 393 P    HW: 5Q4 959 393 P
   Component: TSG FS        009 0911
   Serial number: 85018234602644 Dataset Number: V03935381RR 0001
   Coding: 003013200000048008000000
   VCID: 50F98EF03A61945A1F3-8004
   Subsystem 1 - Part No SW: 5Q6 959 811 B    HW: 5Q6 959 811 B  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  001 0006
   Serial number: 00000000000015003301
   Coding: 011000
   Part No SW: 5QM 907 144 D    HW: 5QM 907 144
   Component: BASGEN1MQB37  102 1063
   Serial number: 01856817 Dataset Number: V03935378EA 0001
   Coding: 01000000010000010001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
   ROD: EV_SteerAssisBASGEN1MQB37_010.rod
   Part No SW: 5Q4 959 392 P    HW: 5Q4 959 392 P
   Component: TSG BFS       009 0911
   Serial number: 86018234201364 Dataset Number: V03935381RS 0001
   Coding: 003013200C00048000000000
   VCID: 4FFB8D8C275F8BA2069-801A
   Subsystem 1 - Part No SW: 5Q6 959 812 B    HW: 5Q6 959 812 B  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  001 0006
   Serial number: 00000000000015010059
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 842 G    HW: 3G5 035 842
   Component: MU-O-NS-US    H56 0835
   Serial number: WG8LGM040223000 Dataset Number: V03935382LZ 0001
   Coding: 23260000002020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_001_VW37.rod
   VCID: 2C01FA00768990BA43B-8078
   Subsystem 1 - Part No SW: 5NN 919 605 C    HW: 5NN 919 605 C
   Component: ABT_Std-2      285 8304
   Serial number: VWZ6ZMB0265671
   Subsystem 2 - Part No SW: V03 959 817 SQ    HW: -----------
   Component: NAR 2023       --- 8073
0021 - Functional Limitation due to Energy Management
          B10CD 00 [00001000] - -
          [Function restriction via shutoff stage Q2]
                    Fault Priority: 9
                    Fault Frequency: 34
                    Reset counter: 1
                    Voltage terminal 30: 11.8 V
7201 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Mileage: 14732 km
                    Date: 2025.03.16
                    Time: 15:45:38
                    BAP: 00
                    Voltage terminal 30: 11.6 V
   Dataset Number: V03935347PY 0001
   Coding: 0123060120002017300040
   Part No SW: 5WA 035 285 E    HW: 5WA 035 285
   Component: OCUGen3High   H12 0329
   Serial number: 0000000208VICL8 Dataset Number: V03935357PG 0001
   Coding: 023260201968AC209005460160102607
   ASAM Dataset: EV_OCUGen3High 002125
   ROD: EV_OCUGen3High_002_VW37.rod
   VCID: 49CFA394D93BA59258D-801C
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Reset counter: 34
                    Mileage: 19306 km
                    Date: 2026.04.08
                    Time: 18:15:03
                    Voltage terminal 30: 14.8 V
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1401
   Serial number: EA1567403223180 Dataset Number: V03935374AH 0001
   Coding: 00000A88116E4020089F10000020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
1122626 - Databus
          [Timeout_Mainunit_01]
                    Reset counter: 34
                    Mileage: 17933 km
                    Date: 2025.12.30
                    Time: 18:37:29
1122664 - Databus
          [TIMEOUT_PSD_04]
                    Reset counter: 34
                    Mileage: 17933 km
                    Date: 2025.12.30
                    Time: 18:37:25
   Dataset Number: V03935361DS 0001
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B71F64E5439172EC5-8020
End----(Elapsed Time: 01:23, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
------------------------------20 Faults Found------------------------------
nabeelr
Ottawa, Canada
C?ID=395028
I was about to create a post asking about this for my 2020 e-Golf.
Is it safe to try these coding changes on it? I don't have the button, and I'm hoping to add the menu to the MIB display. I also have a 2019 Golf R that I'd like to enable the MIB menu item for Auto Hold to, as well (it already has the physical button, but the menu to chose to always have it on, off or last setting would be nice). But the long coding for my ABS module is already what it's supposed to be in my Golf R for the menu to be in the MIB, yet it's not there. I suspect I need to change something in the MIB too to make it visible.
Would love some input if anyone's got it. I want to start with the e-Golf, since my Golf R is in the shop at the moment.
Here's my Auto Scan. It's slightly out of date though, because I've done a few coding changes since then. Getting data off my VCDS computer is a pain in the ass, because it's a SnapOn Verus running XP. :S
Monday,19,October,2026,18:08:08:56773
VCDS Version: 26.3.0.0  HEX-NET CB: 0.4713.4
VIN: WVWPR7AU3LW902593   License Plate:
Mileage: 48549km-30166mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 23 29 2B 39 3C 42 44 4B 51 52
          5F 8C A5 BD C0 C5 C6 D6 D7
VIN: WVWPR7AU3LW902593   Mileage: 48549km-30166miles
29-Left Light -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
Address 01: Engine (J623-EBSA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 AA    HW: 0EA 907 309 A
   Component: E-Vehicle     H24 7205
   Revision: WMH24---    CVN: 6D3325DD
   Coding: 000D0016006400003000
   ASAM Dataset: EV_VCU00XXX0110EA906016AA 005002
   ROD: EV_VCU00XXX011_VW37.rod
   VCID: 6E90ED5FB14AC0EF21-803A
   VINID: 9E69E08874650DC9C90021490C65111F31
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 DB    HW: 5Q0 614 517 AH
   Component: ESC           H62 0856
   Revision: 00000000    Serial number: 62059000000141 CVN: E2304CF2
   Coding: 01FA40A12C20216E857C0209A1C62980023484A14085943238915058C2E203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003.rod
   VCID: 74A4FF37DF66EA3FD7-8020
8400 - Databus
          U1123 00 [00100000] - Received Error Message
          [FCAN: AB_Gurt_FA signal is invalid]
16401 - Tire Pressure Warning
          C102D 00 [00100000] - -
32832 - Switch for Electric Parking Brake
          C100C 07 [00100000] - Mechanical Failure
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0526213481 Dataset Number: V03935271XV 0001
   Coding: 132C0C0723
   VCID: 45C272F3C47C23B7B0-8010
   Part No SW: 5GE 907 044 AN    HW: 5GE 907 044 AN
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0002220020011001050500020010142B
   VCID: 085CBBC7B3EEFEDF8B-805C
   Air quality sensor:
   Part No SW: 5Q0 937 085 CB    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H40 0312
   Serial number: 01001921900163 Dataset Number: V03935297QG 0001
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 7BB6D40BF238A54796-802E
   Component: WWS    190729  043  0551
   Serial number:         190814115545
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: SBY19M08D08H19M49S29
   Coding: 0008DD
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000023081904221628
204290 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 66
                    Mileage: 47427 km
                    Date: 2026.07.31
                    Time: 18:37:32
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.1 V
                    Outside temperature: 29.5 °C
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000150057319239 Dataset Number: V03935292DH 0001
   Coding: 2271167811
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   VCID: 55E2A2B334DC9337C0-8000
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
   Dataset Number: V03935290LZ 0001
   Coding: 7D0000C159FFC728949C810580400600000000000000000014
   VCID: 44C46FF7CF461ABFA7-8010
   Serial number: 003GCR0C6392 Dataset Number: V03935255DQ 0001
   Coding: 8CCCFC00002000005000001AC20800000065
   VCID: 47DE78FBFE7031A742-8012
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000BR7CW6
   Coding: 303139
   Subsystem 2 - Part No SW: -----------    HW: 480 000 309 19
   Serial number: 3570000000068B1D1F3U
   Subsystem 3 - Part No SW: -----------    HW: 480 000 109 19
   Serial number: 358000000003B949504I
   Subsystem 4 - Part No SW: -----------    HW: 480 400 409 19
   Serial number: 3510001C2F27DCC51106
   Subsystem 5 - Part No SW: -----------    HW: 480 400 409 19
   Serial number: 3520001C4F02F966996I
   Subsystem 6 - Part No SW: -----------    HW: 480 400 209 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B4F20D055EA8F
   Subsystem 7 - Part No SW: -----------    HW: 480 400 209 19
   Serial number: 3560001B4F20D055DADK
   Part No SW: 5G1 920 795 B    HW: 5G1 920 795 B
   Component: KOMBI         403 4193
   Coding: 0BF4701A6F8888090288690B5701002080000000
   VCID: 2F2E305B76C089E76A-807A
                    Fault Frequency: 167
                    Reset counter: 80
                    Mileage: 39905 km
                    Date: 2025.07.05
                    Time: 11:54:21
9456681 - Key
          B104C 29 [00001000] - Implausible Signal
                    Mileage: 40342 km
                    Date: 2025.07.21
                    Time: 12:18:39
   Part No SW: 3Q0 907 530 AD    HW: 3Q0 907 530 D
   Component: GW MQB EV     621 6383
   Serial number: 14081911600073 Dataset Number: V03935294VK 0001
   Coding: 0201001704F81000FB001210081D00000001070100030000000300000000
   GVL: 01463C000000060854CC80003000481800000000000200000000000000000000
   VCID: 71AAF623A074DF173C-8024
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39190001306320119221
   Coding: 2CFFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Serial number: 1148162405
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 5QE 909 059 H    HW: 5QE 909 059 B
   Component: EBKV          H14 0230
   Serial number:   085460013633
   Coding: 06720100321A00010002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 005002
   ROD: EV_BrakeBoostBoschMQBOMG_005_VW37.rod
   VCID: 53E65CAB3A288D072E-8006
   Brake pressure reservoir:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861260819100922
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Supply voltage - lower limit exceeded]
                    Reset counter: 106
                    Mileage: 48521 km
                    Date: 2026.09.28
                    Time: 16:23:18
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000237031013
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A362360F49F177C-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0524809190 Dataset Number: V03935258DF 0001
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D321A13ACAC6B77E8-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0525456430
   Coding: 020111
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0320
   Serial number: YE007SH612507 Dataset Number: V03935306UB 0001
   Coding: 003E13208000040000000000
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 49DA7EC3E864C7D754-801C
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000033116350
   Coding: 111000
196665 - Switch for Central Locking
          B122D 29 [00001000] - Signal Implausible
                    Reset counter: 105
                    Mileage: 48507 km
                    Date: 2026.09.19
                    Time: 09:57:02
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Dataset Number: V03935302SB 0001
   Coding: D30A0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 25081911601518 Dataset Number: V03935292KB 0001
   Coding: 000000050900054A00310301040000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 373E083B8E90412732-8062
Address 51: Electric Drive (J841)       Labels:. 5QE-907-080.clb
   Part No SW: 5QE 907 080 M    HW: 5QE 907 080 M
   Component: LE Gen 3.3H16 2202
   Revision: 00H16000    CVN: AF42017C
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM10030115QE907080M 001002
   ROD: EV_DMCM10030115QE907080M.rod
   VCID: 50EC53A70B3EF61F13-8004
31789 - System Voltage
          P0562 00 [00100000] - Too Low
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0320
   Serial number: YE007SGP13876 Dataset Number: V03935306UD 0001
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 48DC7BC7F36E3EDF4B-801C
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164   Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000033244554
   Coding: 091000
                    Reset counter: 95
                    Mileage: 48124 km
                    Date: 2026.08.31
                    Time: 10:20:48
   Part No SW: 5NA 035 047 E    HW: 5NA 035 047
   Component: MU-H-NS-US    H55 1418
   Serial number: A852H0KS003174 Dataset Number: V03935299LU 0001
   Coding: 02738002FF00000041220001001828009F0105F401200405DE
   VCID: 3C341717B7B6627FDF-8068
   Subsystem 1 - Part No SW: 5G6 919 606 B    HW: 5G6 919 606 B
   Component: ABT_High-2  H60 9214
   Serial number: VWZ6ZJW2250453
   Subsystem 2 - Part No SW: V03 959 806 G    HW: -----------
   Component: NAR 2019  --- 0069
   Compact disc data bank:
   Component: Gracenote2  --- 3013
                    Reset counter: 173
                    Mileage: 36794 km
                    Date: 2025.03.17
                    Time: 16:12:48
                    Voltage terminal 30: 13.3 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Address 8C: HV Battery (J840)       Labels:. 5QE-915-227.clb
   Part No SW: 5GE 915 225 B    HW: 5GE 915 225 B
   Component: K8C           005 0400
   Serial number: 08071901010416 CVN: 624110320000000028B0002C972676B7972676B7972676B7972676B7972676B7
   ASAM Dataset: EV_BECM08820215GE915225B 001004
   ROD: EV_BECM08820215GE915225B_VW37.rod
   VCID: 3B36140BB2B86547D6-806E
   High-Voltage Battery Switch Box:
   Subsystem 1 - Part No SW: 5GE 915 316 B    HW: 5GE 915 316 B
   Component: A2 HVSMBJBECU  011 0311
   Serial number: 00000017071901011236
   Cell module control module 1:
   Subsystem 2 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J991Battmod1  H08 0322
   Serial number: 19511Y18AH0803222447
   Cell module control module 2:
   Subsystem 3 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J992Battmod2  H08 0322
   Serial number: 19510Y18AH0803224488
   Cell module control module 3:
   Subsystem 4 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J993Battmod3  H08 0322
   Serial number: 19511Y18AH0803222891
   Cell module control module 4:
   Subsystem 5 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J994Battmod4  H08 0322
   Serial number: 19511Y18AH0803222463
   Cell module control module 5:
   Subsystem 6 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J995Battmod5  H08 0322
   Serial number: 19510Y18AH0803222723
   Cell module control module 6:
   Subsystem 7 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J996Battmod6  H08 0322
   Serial number: 19510Y18AH0803222457
   Cell module control module 7:
   Subsystem 8 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J997Battmod7  H08 0322
   Serial number: 19511Y18AH0803222393
   Cell module control module 8:
   Subsystem 9 - Part No SW: 5QE 915 599 AH    HW: 5QE 915 599 AH
   Component: J998Battmod8  H08 0322
   Serial number: 19511Y18AH0803222256
32512 - 14V Power System Voltage
          P0A8D 00 [00100000] - too Low
32526 - System Voltage
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 22071915P24342 Dataset Number: V03935291JZ 0001
   Coding: 000307000000020100222354C150490084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40CC63E7DB5E069F83-8014
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022-V2.clb
   Part No SW: 5QE 915 022 BP    HW: 12E 915 022 H
   Component: LMSG          H20 1100
   Serial number: 01148000730042 Dataset Number: V03935268XK 0001
   Coding: 4A4914040400
   ASAM Dataset: EV_HVChargManagVWMQB 003004
   ROD: EV_HVChargManagVWMQB.rod
   VCID: 106C93A7CBBEB61F53-8044
2098176 - DC Quick-Charge; Charging Station Initialization Error
          P33E5 00 [00001000] - -
                    Reset counter: 103
                    Mileage: 48376 km
                    Date: 2026.09.18
                    Time: 12:20:09
                    Chademo version-Vehicle: 0
                    Chademo version-Charging Station: 0
                    DC charging PLC-Malfunction status: 0
                    DC charging PLC-Current: actual value: 0.0 A
                    DC charging PLC-Connection status: Not available
                    DC charging PLC-Minimum voltage: 0.0 V
                    DC charging PLC-Maximum voltage: 0.0 V
                    DC charging PLC-Minimum current: 0.0 A
                    DC charging PLC-Maximum current: 0.0 A
                    DC charging PLC-Actual Voltage: 0.0 V
                    DC charging PLC-Status: 0
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 M    HW: 5QE 035 335 B
   Component: E_SOUND_SG    H11 0225
   Serial number: EN193156490000 Dataset Number: 5QE035335M  0210
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 007015
   ROD: EV_ENoiseS1NNVW3707_007_VW37.rod
   VCID: 4BD644CBE218D5C766-801E
Address C5: Therm. mgt. (J1024)       Labels:* 5GE-907-458.clb
   Part No SW: 5GE 907 458 C    HW: 5GE 907 458
   Component: TME-Min       H20 0203
   Serial number: 0116586
   Coding: 02
   ASAM Dataset: EV_ThermContrVISAU49X 001021
   ROD: EV_ThermContrVISAU49X_VW37.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR192343003810000188
   A/C compressor sub:
   Subsystem 3 - Part No SW: 5QE 816 803 G    HW: 5QE 816 803 G
   Component: J842 eKK  H04 0011
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   A/C pressure/coolant temperature sensor 3:
   Subsystem 5 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G827 pT-Sens3  H11 0010
   A/C pressure/coolant temperature sensor 4:
   Subsystem 6 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G828 pT-Sens4  H11 0010
   A/C pressure/coolant temperature sensor 5:
   Subsystem 7 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G829 pT-Sens5  H11 0010
   Expansion valve 1 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N636 EV1_KaMi  H12 0102
   Serial number: 00000000000120983673
   Refrigerant Expansion Valve 2:
   Subsystem 9 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000120983685
   Expansion valve 3 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N638 EV3_KaMi  H12 0102
   Serial number: 00000000000120983661
   Refrigerant Shut-Off Valve 1:
   Subsystem 11 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: V424 AV1_KaMi  H12 0102
   Serial number: 00000000000140858256
   Refrigerant Shut-Off Valve 4:
   Subsystem 12 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000140858246
   Refrigerant Shut-Off Valve 5:
   Subsystem 13 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000140858574
37024 - A/C Compressor
          U103B 00 [00100000] - No Communication
59040 - Refrigerant Pressure/Temperature Sensor 4
          P1C62 00 [00100000] - Faulty
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 N    HW: 5QE 915 681 N
   Component: OBC Delta-ES  H74 1750
   ASAM Dataset: EV_OBCTwoPhaseDT2MQB13B 001002
   ROD: EV_OBCTwoPhaseDT2MQB13B_VW37.rod
   VCID: 57FEA8BB2ED0A127D2-8002
16711737 - Coolant Inlet Temp Sensor
          P31C5 00 [00001000] - Over-Temp
                    Reset counter: 67
                    Mileage: 47427 km
                    Date: 2026.07.31
                    Time: 18:28:52
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
   VCID: 393A0E03B8845757C4-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481_VW37.rod
End----------(Elapsed Time: 02:26, VBatt start/end: 13.1V/13.1V)-----------
------------------------------17 Faults Found------------------------------
Cuzoe
C?ID=279487
@nabeelr About the Golf R... I'll have a look at the MIB coding I don't remember having to add anything for that.
As for your eGolf... Maybe someone here has more knowledge but I would be surprised if you can enable auto hold at all if you don't have at least the button.
The menu doesn't turn Auto hold on/off. It just sets the status of it when ignition is turned on (at journey start).
nabeelr
Ottawa, Canada
C?ID=395028
That's a good point, Re. the menu.
I just tried the coding for auto hold in my e-Golf and it's not happy about the missing button.
Do I have to take the whole centre console apart to get at the button? I heard some people mention that you can sometimes get at it via the shift boot and pop it out.
I want to see if my connector has the extra wires for auto hold or not.
Cuzoe
C?ID=279487
Makes sense to me, haha.
So the technical answer is no, although this looks quite difficult... But doing it this way you may or may not have the necessary slack to disconnect the plug and check wiring.
This way is with removal of the (top of) center console. The car in the video is very dusty, not sure what's going on there, haha...
nabeelr
Ottawa, Canada
C?ID=395028
Thanks for all your input @Cuzoe !
I really appreciate it.
I checked the main harness going to the ABS computer, and the harness connector had all its pins populated. I've heard some mark 7.5s have the wire in place already, and others don't. If on the ABS module side, all the pins are populated, does that mean the wire at the switch is definitely there? Or would Volkswagen put in a pin in that harness without a wire behind it?
Cuzoe
C?ID=279487
VW (and not VW exclusively) doesn't typically include much/if any wiring for features that cars don't have. That said, maybe VW only made one of this specific harness set because it was cheaper than having two versions. I didn't even know there were any Golfs with EPB without Autohold.
If the wires are there on the ABS side then (cautiously) I might not be surprised to see them on the switch side. Are you looking at specific pins per the wiring diagram?
Pins 23 and 32 at the ABS go to the Autohold button.
nabeelr
Ottawa, Canada
C?ID=395028
I wasn't looking for specific pins, but literally every pin was populated on the harness plug, that connects to the ABS module. I visually checked each one individually. I didn't open the back of the connector and undo the ziptie to see if there was a wire in place too, but I expected to see a "missing" pin in some of the locations with no metal contact. Normally I see unpopulated pins as missing a contact, and on the back side, there's a rubber plug where the wire would go to weather seal it, but on this connector each one has a metal contact.
nabeelr
Ottawa, Canada
C?ID=395028
Apparently, I forgot to hit submit on that other reply.
Anyways, I just took the center console apart, and 4 pins are unpopulated in the connector that plugs into the EPB switch.
According to the wiring diagram of my Golf R, pins 12, 11, and 10 are "Singal, Auto-hold", "Power (15)", and "Auto-Hold Solenoid (-)"
I don't even know where these would run to, since my ABS module seemed to have all its pins populated.
Sounds like it isn't even possible with new wires run?
I'll see if I can find a wiring diagram for the e-Golf ABS module.
nabeelr
Ottawa, Canada
C?ID=395028
Just looking at the ABS pinout. like a quarter of the pins are unpopulated... and there are indeed pins there for auto hold.
which leads me to wonder, why are there metal contacts in every hole in the connector? super weird, unless it's something else reflecting back, that I mistook for contacts. all the contacts looked the same though, so IDK.
On the plus side, if I want to run three wires, I could have auto hold, it seems.
The module accepted the coding, and the adaptions... the pins are there... the only thing that's missing are three wires.
Cuzoe
C?ID=279487
Not exactly related, but in aviation we often fill the whole connector with pins. It provides spares if repairs are ever needed.
I don't know what's going on with the ABS, but I would expect to run wires for anything the car didn't come with.
nabeelr
Ottawa, Canada
C?ID=395028
I was hoping it was more of a bus topology, or was heavily multiplexed so both switches could be interchanged. Guess not!
Cuzoe
C?ID=279487
VAG don't run wires for any option not fitted, with one exception of US satellite radio receivers.
Yea that's the truth. The early NAR Mk7s (like my 2015 TDI) had the GPS/XM shark fin antenna. My S Trim (base model) with MIB 1 did have XM radio. It did not have navigation although it could show compass direction (once enabled in coding and/or adaptations). Probably helped that early on our Mk7s (even base trim) had CarNet which I think was no longer included in base trim some while later, maybe with the Mk7.5. And some those base cars got a dummy shark fin antenna with no wires, haha.
In any case when I did MIB 2 retrofit I initially did not go with nav unit. Found out more info that confirmed I had the hardware (wiring and antenna) I went with a nav unit... and have been using my phone with Android Auto ever since :D.
To pretend to be on topic here... well, @bikergeek is no longer on the forum I guess so maybe it doesn't matter, haha.
nabeelr
Ottawa, Canada
C?ID=395028
Great, the most annoying of all features. The one that throws a perpetual error code the moment you cancel your subscription. 😂😭
I bought the switch, and I'll put it on my to-do list, and consider adding it sometime in the future. or, consider paying my local shop to run the wires for me, because my hands are still sore from taking apart the center console yesterday. those snaps and clips are so tight, that I can't believe they don't break the first time you take things apart.
