Audi Q5 Fy 2018 Camera retrofit problem
CCAHybrid
Waterlooville, UK
C?ID=596864
I have been working on a 2018 Q5 Fy and the customer bought a camera that replaces the boot handle. It wires in to the canbus in the car and the video and power go into back of the 5f unit.
We added 6c to the install list and did the bits in adaptions in the 5f. Added camera into 09. Camera only shows if you reset radio then cuts out when radio comes on.
The car has factory front and rear sensors but for some reason they don't come up on his display. When you put the car into reverse the radio screen stays on the radio. If you reset the radio by holding the buttons up and press the middle button the screen goes blank and while the radio boots back up you can see the camera image with moving gridlines but on the right there are still no sensors displayed. As soon as the radio comes back in then then camera disappears and will only show radio screen.
Should this car have OPS? As everything seems to say active in the adaptions. How can we code the car to get both the camera and the sensors on the screen while in reverse.
Thanks in advance
Monday,13,April,2026,13:35:55:38327
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.5
VIN: WAUZZZFY7J2231611   License Plate:
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 22 29 2B 39 42 44 46 52 5F 6C 6D
          81 A5 AC BB BC D6 D7
VIN: WAUZZZFY7J2231611   Mileage: 170691km-106062miles
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 QC    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H35 7773
   Revision: B1H35---    CVN: 64977278D33A0CA3500CA509500CA509
   Coding: 2A6540322526050834080000000000000000000000000000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026QC 005008
   ROD: EV_ECM20TDI01104L906026QC.rod
   VCID: 7BA42FBD436C3BA29A1-802E
   VINID: 9D196AAAA5A91DA0820C1181041D985B8E
   Part No SW: 80A 927 155 BB    HW: 0HK 927 156 B
   Component: 0CJ 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000001798 CVN: 17F7499A
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 6A8A1AF93CF6B22A717-803E
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180173000486
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 80A 907 379 J    HW: 80A 907 379
   Component: ESP9 Plus     H11 0775
   Dataset Number: 80B909504T  0005 CVN: 74740AC1
   Coding: 48AA48BE28A50A9791A45892207E5292E5B5D212121450891A044A49A7AD4B
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 3632FE8938CE26CA25F-8062
   Part No SW: 80A 820 043 N    HW: 80A 820 043 N
   Component: Klima Zone 3  H60 0251
   Coding: 641800295544440D02000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 280E20F1E27A403AA73-807C
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002363004
   Humidity sensor: exterior:
   Serial number: 3A239B2900PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 80B909517F  0030
   Coding: 07501143E11800CD054587149FAE80F9110B3108000000000000000020001A810A450122025609
   VCID: 025A525924864A6AD97-8056
   Subsystem 1 - Part No SW: 80C 955 119     HW: 80C 955 119
   Component: 426 RL 180611  040 0570
   Serial number: 00000001806032203076
   Coding: 5FC7F7
   Serial number: 21648854X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 24 07 2018  82050091
   Serial number: GX1CE110071823810362
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 G    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00039888
   Coding: 0D0104
   Subsystem 6 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000142378007
Address 15: Airbags (J234)       Labels:| 80A-959-655-V1.clb
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    051 0605
   Serial number: 003WBM05XVU  Dataset Number: 80A909602G  0014
   Coding: AACCF0C00C800000585400FFF08C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 3E22E6A910FEEE8AFDF-806A
   Subsystem 1 - Part No SW: -----------    HW: 480 002 306 18
   Serial number: 3570000000061548BD2M
   Subsystem 2 - Part No SW: -----------    HW: 480 002 306 18
   Serial number: 35800000000E05057E2K
   Subsystem 3 - Part No SW: -----------    HW: 480 033 006 18
   Serial number: 351001C10F409A30AF7A
   Subsystem 4 - Part No SW: -----------    HW: 480 033 006 18
   Serial number: 352001C101CBF1D0AF4K
   Subsystem 5 - Part No SW: -----------    HW: 480 031 506 18
   Serial number: 355001C103A0AC20A9C9
   Subsystem 6 - Part No SW: -----------    HW: 480 031 506 18
   Serial number: 356001C103A86C905AFK
   Subsystem 7 - Part No SW: -----------    HW: 480 031 605 18
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C10EEE0920AF6H
   Subsystem 8 - Part No SW: -----------    HW: 480 001 504 18
   Serial number: I0M0000000004034CCA%
   Subsystem 9 - Part No SW: -----------    HW: 480 001 504 18
   Serial number: I0N0000000044034CCA4
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 805 18
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001992919B9365F2
   Part No SW: 80A 907 129 BE    HW: 80A 907 129 BE
   Component: Lenks.Modul   H02 0005
   VCID: 6C861CE13602AC1A03B-8038
   Part No SW: 80A 920 971 A    HW: 80A 920 971 A
   Component: MMQ5T18DIEUK  H04 0519
   Revision: 0519v1.0    Serial number: 0FK291027L7U
   Coding: 25A48ED4A88006000123E9E01000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   VCID: 26122EC9E86E564A95F-8072
   Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
   Component: Gateway       H43 0123
   Revision: 7A000002    Serial number: 0287A520218502 Dataset Number: 80B909515F  0045
   Coding: 03010001000086404107000000590032483A0007100000000175078E10000000
   GVL: 01D03C0008040200408C08000002C80000080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   VCID: 4CC6BC6156424C1A63B-8018
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0004
   Serial number: 20180705200253 01236
   Serial number: 3114076000
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 80A 927 755     HW: 0CJ 927 749 A
   Component: Q5_DL3_N_SD5H01 0006
   Serial number: 18176B2783
   Coding: 01070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 B    HW: 80A 907 397 B
   Component: LCM_MLBevo    H07 0022
   Dataset Number: 80B909519C  0009
   VCID: 2E02D6E9C09E1E0A6DF-807A
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000100916017
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 323AC299D4A63AEA097-8066
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 80B909520C  0009
   Part No SW: 8W1 959 593     HW: 8W1 959 593
   Component: TSG FS001 0737
   Serial number: CLSM1RH300QR7 Dataset Number: 80B909872C  0029
   Coding: 001F8A014001040000001002
   ROD: EV_DCU2DriveSideMAXHKLO_AU49.rod
   VCID: 084E407102BA603A873-805C
Address 44: Steering Assist (J500)       Labels:* 4N0-909-144-V1.clb
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000665446 Dataset Number: 80B909852K  0001
   Coding: 90002001000100
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 3436C4812EB234DA1BB-8060
   Part No SW: 4N0 907 064 BM    HW: 4N0 907 064 M
   Component: BCM2 MLBevo H14 0143
   Dataset Number: 80B909501G  0032
   Coding: 013500002FB100406301A0000400980233020010804306502F00000000040030001F0001000000
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008_AU49.rod
   ID - sensor:
   Subsystem 1 - Part No SW: 4M0 959 754 T    HW: 4M0 959 754 T
   Component: ID-Geber  H40 0105
   Serial number: 3618000091948020
   Serial number: 000000000ZY181200MKA
   Serial number: 00000000000099489352
   Rear spoiler control module:
   Part No SW: 8W1 959 592     HW: 8W1 959 592
   Component: TSG BFS001 0737
   Serial number: CLSM1RH400RQI Dataset Number: 80B909873C  0032
   Coding: 001F8A014001040000001000
   ROD: EV_DCU2PasseSideMAXHKLO_AU49.rod
   VCID: 074C434D0FA46F428E9-8052
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 H    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  050 0213
   Serial number:                Dataset Number: 80B909545P  0023
   Coding: 01240601FF0A000053111101000A00102F0019E601F00100EE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 3B24EFBD03ECFBA2DA1-806E
   Subsystem 1 - Part No SW: 8W0 919 866 AB    HW: -----------
   Component: ECE 2018  --- 0032
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 80A 919 604     HW: 80A 919 604
   Component: AU426_DU_STD  H42 0008
   Serial number: AUZ8Z9JBM01XJC
   Subsystem 3 - Part No SW: 80A 919 614 A    HW: 80A 919 614 A
   Component: ControlUnit_B  H20 0200
   Serial number: AMXAM129061800010075
          B201A 00 [00001001] - -
                    Reset counter: 161
                    Mileage: 170617 km
                    Date: 2026.04.10
                    Time: 15:50:18
                    Voltage terminal 30: 11.4 V
                    Status_Software_Version_Management-module_name: C
0532 - Subwoofer
          B106C 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
                    Reset counter: 154
                    Mileage: 170593 km
                    Date: 2026.04.09
                    Time: 12:00:40
3084 - GSM antenna 2
          B1533 13 [00001001] - Open Circuit
                    Fault Frequency: 15
                    Reset counter: 157
                    Mileage: 170593 km
                    Date: 2026.04.09
                    Time: 12:00:35
   Component: RVC Compact   H18 0250
   Dataset Number: 80D909460B  0001
   Coding: 0224060102002001C20040
   Shop #: WSC 79104 790 00001
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 3334C79D2BBC33E2021-8066
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: A2-C748-5750-5 Dataset Number: 80B909541C  0009
   Coding: 0710
   VCID: 48CE8071423AA03A473-801C
   Part No SW: 80C 713 041 AA    HW: 80C 713 041 N
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20180718000192
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 5DE04125FDB8D592845-8008
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H17 0050
   Dataset Number: 80B909466D  0023
   Coding: 0404020600000401024023A0A50000FE00F0C020C000
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 241634C19E52A45A8BB-8070
Address AC: Reductant Control (J880)       Labels: 80A-907-355.clb
   Part No SW: 80A 907 355 F    HW: 80A 907 355 D
   Component: SCR-Stg-G4H07 0004
   Dataset Number: 80B909571J  0001
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   VCID: 2C06DCE1F6826C1A43B-8078
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 8W1 959 595     HW: 8W1 959 595
   Component: TSG HFS001 0737
   Serial number: CLSM1RH400T0V Dataset Number: 80B909897C  0029
   Coding: 000F88000001040000001000
   ROD: EV_DCU2RearDriveMAXHKLO_VW41.rod
   VCID: 0A4A7A791CB6122A917-805E
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS001 0737
   Serial number: CLSM1RH400TVV Dataset Number: 80B909896C  0029
   ROD: EV_DCU2RearPasseMAXHKLO_VW41.rod
   Dataset Number: 80B909471B  0004
   VCID: 176C130D5F04FFC21E9-8042
   Dataset Number: 80B909472B  0004
End----------(Elapsed Time: 01:53, VBatt start/end: 12.0V/12.0V)-----------
------------------------------3 Faults Found-------------------------------
downtime
Finland
C?ID=280813
I’m pretty sure the backup camera is for previous gen Q5. The part number does not match on any of the other modules.
CCAHybrid
Waterlooville, UK
C?ID=596864
Thanks for the reply.
I think the camera module is correct as I've checked it against other 2018 Q5 6C modules and they look the same. What I would like to know is if the car can be made to show the ops. I've seen other cars with it on the screen. I think if the car does that then I think the reverse camera should work. We followed the instructions to code the camera in and it does show it when the radio is resetting but then cuts out.
The top image is what we are trying to acheive but can only get camera image by resetting the radio. Do you think its an adaption problem or does the can need new software?
WhatsApp Image 2026-04-17 at 09.17.48.jpegWhatsApp Image 2026-04-17 at 08.20.33.jpegWhatsApp Image 2026-04-17 at 08.20.32.jpeg
downtime
Finland
C?ID=280813
What bits did you change in 5F?
CCAHybrid
Waterlooville, UK
C?ID=596864
6C was added to the gateway
5F Infotainment -> Adaptation ->
o Car_function_List BAP Gen2-VPS_oxoB -> ACTIVATED
o Car_function_List_BAP_ Gen2-VPS_ oxo B_ msg_ bus- >Terminal 15
Then added camera to cent elec 19
The car had previously been to audi for coding with odis but they couldn't turn it on. Turned out the kit was for a Q3 not Q5. It came back with 6C already on. Customer can't remember if it had ops when he got it. Do you think its worth getting reset to standard with odis and starting again?
What setting in the 5f would trigger the display to change over to camera
downtime
Finland
C?ID=280813
That setting should do it. Maybe camera has wrong dataset?
matt_brnout
Czech Republic
C?ID=639924
hmmmm, can you send here your settings from
Car_Function_List_B9_Gen2-parking_assist_0x0A, Car_Function_Adaptations_Gen2-menu_display_pdc, Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high (It should be activated but who knows)
Vdub
C?ID=57533
Normally a dealership cant/wont code anything without the Activation document.
Check if there is a RVC-version of Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high
CCAHybrid
Waterlooville, UK
C?ID=596864
Thanks for your help
Car_Function_List_B9_Gen2-parking_assist_0x0A is Activated
Car_Function_Adaptations_Gen2-menu_display_pdc is Activated
Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high - changed this from Not activated to Activated but made no difference. I did a reset on the unit.
Thank you
HxK
C?ID=619420
Have you checked over the 6C Long Coding to see if it matches the cars specification? Gearbox type, PDC/OPS etc.
Is it a genuine sourced module, or the Ali Express "Genuine" ones?
I'm gonna assume the reason for OPS not displaying is gonna be the same reason why the camera won't show either.
downtime
Finland
C?ID=280813
Could be the BCM is not OPS capable. Audi is a bit weird on these component setups
vastechnics
C?ID=143747
on Q5 canbus dont go behind 5F but go to gateway!! Rewire it back to gateway. To 5F only the video wire and positiv feed
Reactions: TTT
