- Feb 25, 2014
- 2,884
- 4,668
- Garrettsville, OH
- C?ID=25607
Tried to reset SRI today, couldn't. No label file for 17. I assure you this car has been lovingly, aggressively, exhaustively labeled by Team Phaeton.
I see at some point the label file was renamed from 3D0-909-xxx-17.lbl to 3D0-909-INS-V1.LBL (note the uppercase LBL). I tried renaming to lowercase lbl, and back to the original name, and VCDS still didn't want to find it. Sadly the CLB Fun Police have come for the 3D-17 redirect. I considered trying to find an old copy, or make a new plaintext 3D-17 redirect by hand. But then I remembered, I have people for this. So here I am. Help me to tell my car I love her and I care and I would never neglect her. Please and thank you.
Before (19.9.2.0):
Now (26.3.0.0):
Full Scan:
Before (19.9.2.0):
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No: 3D0 920 982 B
Component: KOMBIINSTRUMENT RB8 0521
Coding: 0004221
Shop #: WSC 08607 444 00001
VCID: A71EBDB117A5A77632-5160
Now (26.3.0.0):
Address 17: Instruments Labels: None
Coding: 0004221
VCID: 270090D533F14022AE9-5160
Full Scan:
Sunday,12,April,2026,23:28:55:50497
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4709.5
VIN: WVWAK03D868005728 License Plate:
Mileage: 202430km-125784mi Repair Order:
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAK03D868005728 Mileage: 202430km-125784miles
Address 01: Engine Labels: 07C-906-018-BAP1.lbl
Part No SW: 07C 906 018 AJ HW: 000 000 000 00
Component: D1-6.0L-AT-LEV2 G ª8188
Revision: --H01--- Serial number: VWZ3Z0F7470400
Coding: 0000173
Shop #: WSC 03738 444 38140
VCID: 6D8CA2FDD18DAA72145-513C
VINID: 9E69D16C00D42062000051C2200EC208EB
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Mileage: 202240 km
RPM: 1556 /min
Load: 59.2 %
Speed: 80.0 km/h
Temperature: 87.0°C
Temperature: 17.0°C
Absolute Pres.: 970.0 mbar
Voltage: 12.446 V
001299 - Incorrect Immobilizer Key
P0513 - 008 - - Intermittent
Mileage: 202409 km
RPM: 1263 /min
Load: 32.5 %
Temperature: 25.0°C
Temperature: 29.0°C
Voltage: 11.303 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 202433 km
Temperature: 61.0°C
Temperature: 50.0°C
Voltage: 12.065 V
Address 02: Auto Trans Labels: 3D0-927-156.lbl
Part No: 3D0 927 156 AB
Component: AG5 01L 6.0lW12 USA 1010
Coding: 0000002
VCID: 6882D3E9FE6F8F5A673-5160
18265 - Load Signal
P1857 - 003 - Error Message from ECU - Intermittent
17090 - Transmission Range Sensor (F125)
P0706 - 003 - Implausible Signal - Intermittent
18161 - Tiptronic Switch (F189)
P1753 - 003 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H33 0047
Coding: 0008397
Shop #: WSC 01065 000 00000
VCID: 6B88ACE5EF99A4420A1-51A8
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 C HW: 5WK 484 97
Component: G1 Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F7470400
Coding: 0213228
Component: ELV XXXX
00087 - Terminal 30 for Starting Relevant Consumers
00184 - Control Circuit for Engine Start/Stop Switch
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 CA
Component: Sitzmemory D1 BF 1720
Coding: 0000003
VCID: 77A08095A3D110A2FE9-5160
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3D0 035 008 QX
Component: ZAB COCKPIT 9923
Coding: 0500305
Shop #: WSC 03207 444 84420
VCID: 0052EB49F61F571ACF3-5160
9 Faults Found:
00384 - Optical Databus
00385 - Positive Output Audio Channel for Speech/Telephone
00386 - Negative Output Audio Channel for Speech/Telephone
00387 - Plus Output Audio Channel for Navigation Announcements
00388 - Negative Output Audio Channel for Navigation Messages
00856 - Radio Antenna
00823 - Line-Output; Front Left
00859 - Line-Output; Front Right
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 J
Component: Climatronic D1 2031
Coding: 0000002
VCID: 251C9ADD49FD52329C5-5160
00716 - Air recirculation Flap Positioning Motor (V113)
00445 - Loss of Refrigerant
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000003
VCID: 2F3078F51B011862669-5160
Address 11: Engine II Labels: 07C-906-018-BAP2.lbl
Coding: 0000173
012952 - Catalyst System; Bank 3
P3298 - 002 - Efficiency Below Threshold
Fault Status: 01100010
Mileage: 202240 km
RPM: 1550 /min
Load: 57.2 %
Speed: 81.0 km/h
Temperature: 107.0°C
Temperature: 51.0°C
Voltage: 12.192 V
012953 - Catalyst System; Bank 4
P3299 - 002 - Efficiency Below Threshold - MIL ON
Mileage: 202240 km
RPM: 1961 /min
Load: 58.0 %
Speed: 105.0 km/h
Temperature: 19.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.573 V
Mileage: 202409 km
RPM: 1323 /min
Load: 30.6 %
Temperature: 25.0°C
Temperature: 29.0°C
Voltage: 10.795 V
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 04 Airbag 8.4E++H01 0554
Revision: BB38727 Serial number: 0006635<
Coding: 0012340
VCID: 280293E93EEF4F5AA73-5160
Subsystem 1 - Part No: 3D0 959 339
Component: BF-Gewichtsens. 006 0005
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 E
Component: Lenksäulenmodul 3401
Coding: 0000232
Coding: 0004221
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B2BB89C6BF479A3F3-5160
Address 28: HVAC, Rear Labels: 3D0-919-158.lbl
Part No: 3D0 919 158 F
Component: Klima-Bedienteil D1 0117
VCID: 2E0E65F11C0B116A6DF-5160
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) 0001
Coding: 0000001
VCID: 669EDDD1F47B992A55F-513C
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005531
Shop #: WSC 53212 053 999999
01437 - Control Position not Learned
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 CA
Component: Sitzmemory D1 F 1720
Coding: 0000004
VCID: 6FB0B8F5DB815862269-5160
Address 37: Navigation Labels: 3D0-919-887.lbl
Part No: 3D0 919 887 F
Component: NAVIGATION 9968
Coding: 0400000
VCID: 37204095E351D0A23E9-5160
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 C
Component: Dachmodul 0708
Coding: 0000015
VCID: 231884C547C9AC02F21-5160
00220 - Connection to Sunroof
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000001
VCID: 6780D0D5F37180226E9-5160
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 F
Component: X3 HSG 0102
Coding: 0000040
Shop #: WSC 03325 444 13946
VCID: 33387485F7293C82021-4B00
Subsystem 1 - Part No: 3D1 959 701 L
Component: Tuersteuergeraet FS 6001
Subsystem 2 - Part No: 3D1 959 702 L
Component: Tuersteuergeraet BF 6001
Subsystem 3 - Part No: 3D0 959 703 K
Component: Tuersteuergeraet HL 6001
Subsystem 4 - Part No: 3D0 959 704 K
Component: Tuersteuergeraet HR 6001
Subsystem 5 - Part No: 3D0 909 610 C
Component: 3L HDSG 2330
Subsystem 6 - Part No: 7L0 907 719 A
Component: Neigungssensor 0020
11 Faults Found:
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
01816 - Exterior Door Handle Switch in Drivers Door (F272)
00323 - Vehicle Inclination Sensor (G384)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3D0 035 466 A
Component: 12K-AUDIOVERST 0118
VCID: 20128BC956DFB71AEF3-5160
Address 65: Tire Pressure Labels: 3D0-907-273-V2.clb
Part No: 3D0 907 273 G
Component: Reifendruckueberw. 0026
Coding: 0411224
Shop #: WSC 08607 444 08607
VCID: 2A0669E120E37D4AB17-5160
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V1.clb
Part No: 3D1 955 119 A
Component: Front Wiper 2005
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: 241A87D942C7AB3A8BB-5160
00086 - Parallel Battery Connection Relay (J581)
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 D
Component: 03 Einparkhilfe 0907
VCID: 2B086CE52F1964424A1-5160
End----(Elapsed Time: 07:27, VBatt start/end: 12.8V/12.9V. VIgn 0.0V)------
------------------------------47 Faults Found------------------------------
Sucks that we can't have nice things, but I understand why. Was mainly just trying to figure out what happened and got stuck there. I think I could have renamed the label file to the exact instrument cluster part number and gotten working that way, but it's been ten years or more since I've needed to make manual label file or redirect edits, didn't think of it at the time.
