- Mar 17, 2024
- 103
- 33
- Netherlands
- C?ID=521878
Hi all,
I have a VW Polo AE1 here with crash damage. The car has been repaired but the electric power steering does not work.
There was also another fault in the car, as soon as the hood switches are closed, the engine turns off and the car starts tripping. After some research, it turns out that the ground on the left chassis beam was not good.
The steering wheel is still very heavy. I tried resetting with Odis, parameters, even reflashing but it fails.
The control module shows an internal fault short circuit.
I have a feeling that due to the ground problem before and the car tripping, the electric power steering module went defect and needs to replaced. Before changing components, I want to ask if someone has different ideas what to check/do
Thanks in advance!
Full scan of the car:
Thanks in advance!
Friday,10,April,2026,15:41:15:40745
VCDS Version: 25.3.3.0 (x64) HEX-NET2 CB: 0.4701.5
Data version: 20260227 DS365.0
VIN: WVWZZZAWZNU058313 License Plate: POLO_AE1
Mileage: 11298km-7020mi Repair Order:
Chassis Type: AW-VW27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 55 5F 75 A5 A9 D6 D7
VIN: WVWZZZAWZNU058313 Mileage: 11298km-7020miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DNND) Labels: Redir Fail!
Part No SW: 82A 907 115 HW: 06Q 907 309 A
Component: R4 2.0l TFS H80 0003
Revision: J5H80000 CVN: FFA65CF4
Coding: 012540122464050B04000000000000000000000000000000
Shop #: WSC 31414 790 00200
ASAM Dataset: EV_ECM20TFS01182A907115 001005
ROD: EV_ECM20TFS01182A907115.rod
VCID: 6296C52E94C6438AF8F-8036
VINID: 9E69EAAAA467A9E9401480C10CACB7624A
17919 - Cruise Control Switch (E45)
P0568 00 [00101111] - Implausible Signal
Mileage: 11298 km
Date: 2025.09.25
Time: 21:45:19
Engine speed: 0.00 /min
Coolant temperature: 17 C
Intake air temperature: 15 C
Voltage terminal 30: 11.680 V
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 2
Cruise control switch actuation-Bits 0-7: 33
Cruise control switch actuation-Bits 0-7: 128
ACC variants (coding)-Bits 0-7: 3
5604 - Park/Neutral Switch Input Circuit
P0850 00 [00100111] - Open or Short to Plus
Mileage: 11298 km
Date: 2025.09.25
Time: 22:11:14
Coolant temperature: 36 C
Intake air temperature: 19 C
Voltage terminal 30: 11.380 V
Outside temperature: 14.0 C
Outside air temperature via CAN: 13.5 C
Engine oil temperature: 16.6 C
Virtual_SigXSet_TiOff_tiStrtEnd_Off: 376 s
Requirements for basic setting-Bits 0-7: 50
Rear cat conv temp main cat conv model value: 129.1 C
Coolant temperature at engine start: 36.7 C
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [00101111] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Fault Frequency: 16
Mileage: 11298 km
Date: 2025.09.25
Time: 21:45:19
Communication status: area 2 measured value 1-Bits 0-7: 0
Communication status: area 2 measured value 2-Bits 0-7: 0
Communication status: area 2 measured value 3-Bits 0-7: 4
Communication status: area 2 measured value 3-Bits 0-7: 0
Communication status: area 2 measured value 4-Bits 0-7: 0
Communication status: area 2 measured value 5-Bits 0-7: 0
Communication status: area 2 measured value 6-Bits 0-7: 0
Communication status: area 2 measured value 7-Bits 0-7: 0
Communication status: area 2 measured value 7-Bits 0-7: 1
24604 - No Communications with Power Steering Control Module
U0131 00 [00100110] - -
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:18
Coolant temperature: 39 C
Intake air temperature: 21 C
Voltage terminal 30: 13.280 V
Communication status: area 1 measured value 1-Bits 0-7: 0
Communication status: area 1 measured value 2-Bits 0-7: 0
Communication status: area 1 measured value 3-Bits 0-7: 0
Communication status: area 1 measured value 4-Bits 0-7: 0
Communication status: area 1 measured value 5-Bits 0-7: 0
Communication status: area 1 measured value 6-Bits 0-7: 0
Communication status: area 1 measured value 6-Bits 0-7: 2
Communication status: area 1 measured value 7-Bits 0-7: 0
Communication status: area 1 measured value 7-Bits 0-7: 1
Readiness: 1110 0001
Part No SW: 0GC 300 046 K HW: 0GC 927 711 H
Component: GSG DQ381 H06 2802
Revision: 00H06V13 CVN: B35C42A3
ASAM Dataset: EV_TCMDQ381061 001001
ROD: EV_TCMDQ381061.rod
VCID: 3236756E84A6930A48F-8066
No subsystems:
21223 - No Communications with Power Steering Control Module
U0131 00 [00101100] - -
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:19
Clutch: primary stat: New
selected gear: GANG_R
Driving position: P
Engine torque: 0 Nm
Control Module temperature: 20 C
Accelerator pedal position: 13.7 %
DTC memory status: 77
21193 - No Communication with Cruise Control Module
U0104 00 [00101111] - -
Fault Frequency: 14
Mileage: 11298 km
Date: 2025.09.25
Time: 21:45:19
Driving position: P
Engine torque: 0 Nm
Control Module temperature: 15 C
DTC memory status: 79
Address 03: ABS Brakes (J104) Labels:. 2Q0-614-517.clb
Part No SW: 2Q0 614 517 AQ HW: 2Q0 614 517 M
Component: ESC_high_vFGS H34 0362
Serial number: 08513092220218
Coding: 0A034E64754650B572FFAE1745DD62A649125506336A245824A4335545A246659248AA60CC56241A2425CCAAA269D74BFF96EBD2FF242424242424
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
ROD: EV_Brake1BOSCHESPMQBA0_005_VW27.rod
VCID: 7DAC96520D789C72E5D-8028
1200 - Databus
[ComScl_ACC_07_Timeout]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1152 - Databus
[ComScl_ACC_10_Timeout]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
0469 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[ComScl_LH_EPS_03_Timeout]
Fault Frequency: 9
Mileage: 11298 km
Date: 2025.09.25
Time: 21:55:51
0067 - Function Restricted due to Missing Message(s)
[ComScl_LWI_01_Timeout]
Fault Frequency: 9
Mileage: 11298 km
Date: 2025.09.25
Time: 21:55:51
1360 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [10001001] - -
[LWI_SensorNotCalibrated]
Reset counter: 56
Mileage: 11298 km
Date: 2025.04.21
Time: 01:41:19
Address 08: Auto HVAC (J255) Labels:| 2GN-907-044-V1.clb
Part No SW: 2GN 907 044 A HW: 2GN 907 044 A
Component: Climatronic H24 0106
Coding: 012000000800010011100800024401150110000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0Touch 001008
ROD: EV_ACClimaBHBMQBA0Touch.rod
VCID: 40D22FA63A0A319ACEB-8014
524545 - AC Compressor First Run-In
B109E F0 [00001001] - Not Performed
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
262914 - Refrigerant Pressure
B10AB F0 [00001001] - Too Low
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
Compressor current: actual value: 0.01 A
Temperature downstream of evaporator: 14.0 C
Refrigerant pressure: 0.8 bar
System run time-Terminal 15 on: 31 s
Address 09: Cent. Elect. (J519) Labels: 2QX-937-BCM-V1.clb
Part No SW: 2Q0 937 090 D HW: 2Q0 937 090 C
Component: BCM A0 Std+ H12 0954
Serial number: 01102203901012 Dataset Number: V03935364GC 0001
ASAM Dataset: EV_BCMA0 207001
ROD: EV_BCMA0_207_VW27.rod
VCID: 3338706A7BBC9A02439-8066
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SAY22M02D15H18M22S20
Coding: 0018DD
Driver door control module:
Subsystem 2 - Part No SW: 2Q1 959 405 E HW: 2Q1 959 163 D
Component: FHSG_DRV 002 0003
Serial number: 00000000000057545300
Coding: 130037
Front passenger door control module:
Subsystem 3 - Part No SW: 2Q1 959 406 E HW: 2Q1 959 164 D
Component: FHSG_PSG 002 0003
Serial number: 00000000000057557515
Coding: 098037
Subsystem 4 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000070343157
Coding: 030000
Subsystem 5 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000070409011
Coding: 1B0000
13 Faults Found:
9738 - Bulb for Left Parking Lamp
B12E8 15 [00001001] - Open or Short to Plus
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
9994 - Bulb for Right Parking Lamp
B12E9 15 [00001001] - Open or Short to Plus
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
556053 - Databus
[LH_EPS_02_alt aktiv]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:22
Zusaetzliche Umgebungsdaten-voltage measurement: 13.6 V
566550 - Databus
[LCM links - unplausibler Datensatz]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
567062 - Databus
[LCM links - Tagfahrlicht defekt]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
567574 - Databus
[LCM links - Shutter defekt]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
568086 - Databus
[LCM links - Blinker defekt]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
569092 - Databus
[LCM links Kein Signal/Kommunikation]
Fault Frequency: 21
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:54
578838 - Databus
[LCM links - Sidemarker defekt]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
579350 - Databus
[LCM links - Standlicht defekt]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
579606 - Databus
[LCM rechts - Standlicht defekt]
Fault Frequency: 15
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
590853 - Window Regulator; Front Drivers Side
B14D1 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
592133 - Window Regulator; Front Passenger Side
B14D2 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058322038 Dataset Number: V03935352CF 0001
Coding: 8471051011
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 53F810EADB7CBA02639-8006
13638913 - Databus
[Steuerger t f r Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:19
13638914 - Databus
[Steuerger t f r Lenkhilfe-J500 - LWI_01 - kein Signal/keine Kommunikation]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:19
13637426 - Databus
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
Address 13: Auto Dist. Reg
Address 15: Airbags (J234) Labels:| 2Q0-959-655.clb
Part No SW: 2Q0 959 655 AS HW: 2Q0 959 655 AS
Component: VW22Airbag 020 0411
Revision: -------- Dataset Number: V03935354QR 0001
Coding: 88CCCCC0808000035C5400CF000C40FC0065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001036
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0E4EC19E30DE97EA0C7-805A
Subsystem 1 - Part No SW: ----------- HW: 442 062 601 22
Serial number: 3577Y52B70773501409V
Subsystem 2 - Part No SW: ----------- HW: 442 060 304 23
Serial number: 3587Y22B10CA9831234$
Subsystem 3 - Part No SW: ----------- HW: 442 0B0 502 22
Serial number: 3517710A708C8323F3BK
Subsystem 4 - Part No SW: ----------- HW: 442 0B3 012 21
Serial number: 3527711BD0893AB6F2E%
Subsystem 5 - Part No SW: ----------- HW: 442 132 112 21
Component: FrontSensor_D 290 118A
Serial number: 355AG23A2C76E933729%
1050112 - Databus
[NWD: 0x086 LWI_01 Timeout]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:21
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1060608 - Databus
[NWD: 0xTBD SDF_PSF_01 Timeout]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
B13BC F2 [10000001] - No function
Part No SW: 2G0 920 320 B HW: 2G0 920 320 B
Component: KOMBI 524 6220
Dataset Number: V03935352JR
Coding: 04AD00086D840008018862431000000000600400
Shop #: WSC 05745 128 28889
ASAM Dataset: EV_DashBoardVDDMQBA0 001048
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 1B68B8CAF32C32427B9-804E
7 Faults Found:
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [00001001] - -
[BAP_AWV_0x1B keine Kommunikation]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
16776960 - Databus
[ACC_02 keine Kommunikation]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:49
16776961 - Databus
[ACC_04 keine Kommunikation]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:49
16776962 - Databus
[Airbag_01 keine Kommunikation]
Reset counter: 119
16776968 - Databus
[ESP_24 keine Kommunikation]
Reset counter: 119
16776978 - Databus
[LH_EPS_01 keine Kommunikation]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:05:51
16776988 - Databus
[TSK_07 keine Kommunikation]
Reset counter: 119
Part No SW: 3Q0 907 530 AL HW: 3Q0 907 530 E
Component: GW MQB High 524 5463
Serial number: 09022210800750 Dataset Number: V03935357XH 0001
Coding: 030900046F085B00FB108278180F00010001270000000000000000000000
GVL: 01443C1000000000408090008000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 79A482421950A052C95-802C
Generator:
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218120492201690
Coding: 2D2F00
Subsystem 3 - Part No SW: 2Q0 915 181 A HW: 2Q0 915 181 A
Component: J367-BDMBOSCH H03 2011
Serial number: 10015000
131602 - Power Steering Control Module
U101D 00 [00001000] - No Communication
[Timeout Knoten 0x12 / 44 - Steuerger t f r Lenkhilfe]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:21
Terminal 30 power supply: 13.4 V
Terminal 15: On
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [00001001] - -
[Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:50
Terminal 30 power supply: 12.1 V
Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00001000] - -
[Timeout Knoten 0x76 / 01 - Motorsteuerger t]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:11:14
Terminal 30 power supply: 11.5 V
Terminal 15: On
131703 - No Communication with Transmission Control Module
U0101 00 [00001000] - -
[Timeout Knoten 0x77 / 02 - Steuerger t f r Getriebe]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:12:20
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [00001000] - Warning Triggered
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:26:01
Terminal 30 power supply: 12.2 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 2Qx-909-144-V1.clb
Part No SW: 2Q1 909 144 S HW: 2Q1 909 144 S
Component: TRW_G4L_MQBA0 612 6042
Serial number: 01M274A3CB4N095
Coding: 000000000000000000000201010001010000010001
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 42D625AE3406238AD8F-8016
7 Faults Found:
10531840 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 22:29:37
Engine speed: 0 /min
System status: Malfunction
Voltage terminal 30: 13.62 V
Power steering current consumption: 0.5 A
max.value: 0.5 A
End stage temperature: 19 C
Steering assistance: engine output: 100 %
Engine angle: 0
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.0 Nm
Steering torque: 0.0 Nm
11608832 - Internal Fault
B200F F0 [10001001] - -
[DEM_PU_SSPIR_SHORT_CIRCUIT1_FAULT]
Reset counter: 79
Vehicle speed: 6 km/h
Voltage terminal 30: 13.58 V
max.value: 0.5 A
Engine angle: 0
10551296 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[DEM_CODING_DSR_FAULT]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 22:29:42
Voltage terminal 30: 13.61 V
max.value: 0.5 A
Engine angle: 0
10551552 - Control Module Incorrectly Coded
[DEM_CODING_PLA_FAULT]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 22:29:42
max.value: 0.5 A
Engine angle: 0
10552064 - Control Module Incorrectly Coded
[DEM_CODING_HCA_FAULT]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 22:29:42
max.value: 0.5 A
Engine angle: 0
10532608 - No End-of-Line Programming
B2013 00 [00001001] - -
[DEM_NO_VW_EOL_PROGRAMMING_FAULT]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 22:29:37
max.value: 0.5 A
Engine angle: 0
10512640 - Steering End Stops Not Learned
C10AC F0 [10001001] -
[DEM_BOTH_ENDSTOP_NOT_KNOWN]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 22:29:37
max.value: 0.5 A
Engine angle: 0
Part No SW: 2G0 907 357 HW: 7P6 907 357 B
Component: MxB-ECU 001 0305
Revision: -------- Serial number: -------------- Dataset Number: V03935348YP 0001
Coding: 19CA000001100200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
ROD: EV_HeadlRegulAUDIMXBAU64X_VW27.rod
VCID: 6882D70672FA29DA26B-803C
9 Faults Found:
13705474 - Databus
[LWI_01 Datenbus fehlende Botschaft]
Reset counter: 119
Mileage: 11298 km
Date: 2025.09.25
Time: 22:31:21
13705992 - Databus
U1123 00 [10001001] - Received Error Message
[Empfangener Fehlerwert im Signal LWI_Lenkradwinkel: CAN Message LWI_01]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
13705999 - Databus
[Empfangener Fehlerwert im Signal Kamera_FDD_Funktionsstatus: CAN Message Kamera_Status]
Fault Frequency: 12
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
13706000 - Databus
[Empfangener Fehlerwert im Signal Kamera_FDD_Eigenblend_Guete: CAN Message Kamera_Status]
Fault Frequency: 12
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
66672 - Control Module for Light Activation/Adjustment; Left
U116E 00 [10001001] - No Communications
[Steuergeraet fuer Lichtsteuerung links keine Kommunikation]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:54
131353 - Power Output Module for LED Headlamps; Left
U1170 00 [10001001] - No Communications
[Leistungsmodul fuer LED-Scheinwerfer links keine Kommunikation]
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:54
5275220 - Headlight
C107E 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
5350720 - Left Matrix High Beam
C1175 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
5350976 - Right Matrix High Beam
C1176 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 79
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 820 H HW: 3G5 035 820 H
Component: MU-O-ND-EU H22 0306
Serial number: VWZAZ2A0372585 Dataset Number: V03935363WH 0001
Coding: 22700000000200000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VW27.rod
VCID: 29049202A970D0D2F95-807C
Subsystem 1 - Part No SW: 5NN 919 605 B HW: 5NN 919 605 B
Component: ABT_Std-2_Nav 381 8304
Serial number: VWZ6ZHA0851539
Subsystem 2 - Part No: V03 959 809 TP
Component: EUR 2022 6053
7173 - Function Restricted due to Interrupted Communications
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
BAP: 02
Voltage terminal 30: 12.0 V
7195 - Function Restricted due to Interrupted Communications
[Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:53
BAP: 02
Address 75: Telematics (J949) Labels:* 5WA-035-28X-V1.clb
Part No SW: 5WA 035 284 E HW: 5WA 035 284 B
Component: OCUGen3High H20 0141
Serial number: 0000000110VIUQC Dataset Number: V03935349VP 0001
Coding: 022700001968A8209005460161002607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 48C23786123A09DA06B-801C
12866049 - Databus
[Airbag: Error value received]
Mileage: 11298 km
Date: 2025.09.25
Time: 22:11:11
Voltage terminal 30: 11.4 V
1644276 - Backup Battery
B1916 F4 [00001001] - Service Life Critical
[Backup battery Service life critical]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:56
7195 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Brake assist system (0x1B) - Funktionseinschr nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
0055 - Databus
[ACC ECU: no communication]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:50
Voltage terminal 30: 12.1 V
7173 - Function Restricted due to Missing Message(s)
[ACC (0x05) - Funktionseinschr nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:50
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 C HW: 2Q0 980 653
Component: MQB MFK 3.0 H16 1302
Serial number: E80320002220470 Dataset Number: V03935357MV 0001
Coding: 00000890114E4020089E00001030008000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
VCID: 353C4E7275C884326DD-8060
10 Faults Found:
0659 - Steering
C10AC F2 [00001001] - Lane-Holding Assistance Not Coded
[HC_interface_at_the_steering_not_activated]
Mileage: 11298 km
Date: 2025.09.25
Time: 22:33:14
1126424 - Internal Fault
B200F F2 [00001000] - -
[Safe_State_Active_lane_change_ready]
Mileage: 11298 km
Date: 2025.09.25
Time: 22:28:28
1126423 - Internal Fault
[Safe_State_Active_directional_blinking]
Mileage: 11298 km
Date: 2025.09.25
Time: 22:28:28
1122599 - Local Data Bus
U1169 00 [00001001] - Missing Message
[Timeout_RDR1_Obj_02]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1124134 - Local Data Bus
[TIMEOUT_RDR1_Obj_01]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1122902 - Databus
[TIMEOUT_ACC_02]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1124193 - Local Data Bus
[TIMEOUT_RDR1_ObjGegen_02]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1124192 - Local Data Bus
[TIMEOUT_RDR1_ObjGegen_01]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1122601 - Local Data Bus
[Timeout_RDR1_Obj_04]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
1122600 - Local Data Bus
[Timeout_RDR1_Obj_03]
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:51
Part No SW: 2G0 907 159 A HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0004
Serial number: 220128290387
ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
Address D6: Light Ctrl Left 2
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1R H08 9202
Dataset Number: V03935431JQ 0001
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 659CDE3285E834B21DD-8030
140547 - Bulb for Parking Light
C123B 13 [10101111] - Open Circuit
Reset counter: 0
Mileage: 11298 km
Date: 2025.09.25
Time: 21:54:52
End----------(Elapsed Time: 01:22, VBatt start/end: 14.3V/12.2V)-----------
------------------------------79 Faults Found------------------------------
