2012 Sharan 2.0TDI DSG: Adblue top-up reset not working.
rayhoop
C?ID=288499
Hi,
Long time VCDS user, but 1st post!
I'm having trouble after the Sharan presented a "600mile" adblue warning out of the blue - and after a refil is not resetting.. Heres some info on the vehicle and the timeline of events.
2012 Sharan 7N, 2.0TDI DSG (CFFB engine)
Owned since: July 2013 (11k miles)
Status of car: Stock.
Dieselgate: Dealer "fix" applied when VW contacted us around 2016. A few weeks later, a fault developed with the NOx sensor, which was replaced (under good-will).
Dec 2024: VW Dealership carried out an Adblue heater replacement due to fault codes (sensor level).
No issues when topping up the Adblue fluid before or since Dec 2024.
Various other issues not related to emissions: Ignition barrel 2021, Aux heater pump replacement 2024, Air con compressor March 2026, DAB reception dead (ongoing).
End of March 26, the Sharan took the family+luggage on a faultless 600mile round trip. Predominantly motorway speeds of 60-70mph.
Visited friends who previously had a Seat Alhambra, but sold it due to numerous electrical faults and Adblue issues...
I made the mistake of saying out loud "Ours has generally been ok other than general maintenance, semi regular adblue top up and the adblue repair in 2024"
08th April, during a 40 mile motorway trip - Adblue light and warning reads "Fill Adblue, 600 miles until no-start". At one point I had an abnormal warning saying "start stop disabled" (or something like that - I was driving so didnt catch the complete message)
Later that day, 10 litres of Adblue added in one go. However, I made the mistake of not waiting a minute before starting the engine.
Adblue Light remained on and warning still shows on start-up.
Fault codes scanned (saved log) and cleared - SCR tank level detection reset & reset SCR lock.
09th April, I was curious whether the tank needed more (but having performed a reset, felt VCDS would not give a true reading) - so added more fluid... a further 5-6 litres - she must have been very empty!
I repeated my mistake of not waiting a minute before starting the engine. (facepalm)
Attempted SCR Efficiency Test (with pre-reqs met. Engine temp 80+, doors/hood shut, park, handbrake, drivers seat belt in) - failed, unsafe. Told to turn the engine off then on again
Took it for a 30-40 minute drive: 50-70mph.
most recent log file attached.
I suspect the:
"15733 - SCR NOx Catalyst Bank 1 - P20EE 00 [00100111] - Efficiency too Low"
Is my blocker to running the SCR Efficiency Test. However I wanted to double check with those far more knowledgable than me before spending £300+ on a new NOx sensor :-)
Thursday,09,April,2026,21:07:55:62060
VCDS Version: 25.3.3.0 (x64)  HEX-NET CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: WVWZZZ7NZCV018981   License Plate:
Mileage: 201810km-125398mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 2E 42 44 46 4C 52 53 56
          61 62 72
VIN: WVWZZZ7NZCV018981   Mileage: 201810km-125398miles
   Part No SW: 03L 906 018 HJ    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H26 9979
   Revision: 44H26---    Serial number:                CVN: 37EEA91CD45710C1
   Coding: 001D001A040501080000
   Shop #: WSC 00674 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HJ 003014
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 79BA3E80F82B3E539C-802C
   VINID: 9E69EAAAA1DEA9398004824804A8491B53
7144 - Diagnostic Gateway Module
          U0447 00 [00101111] - Implausible Signal
          [Invalid Data Received From Serial Data Gateway Module "A"]
                    Mileage: 201775 km
                    Date: 2026.04.09.
                    Time: 18:23:54
                    Engine speed: 779.50 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 80 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 14.200 V
                    ACC specified acceleration: 0.000 m/s²
                    ACC control module: received status-Bits 0-7: 0
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_RUNNING
                    Mileage: 201798 km
                    Date: 2026.04.09.
                    Time: 20:45:31
                    Engine speed: 2281.50 /min
                    Normed load value: 0.8 %
                    Vehicle speed: 110 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 13 °C
                    Long-term adaptation of reduction agent dosage: 1.00
                    Measured NOx conversion: 0.184
                    Calculated efficiency of NOx conversion: 0.831
                    Efficiency threshold of NOx conversion: 0.300
                    Current temperature with NOx Reduction CAT: 252.6 °C
   Part No SW: 02E 300 054 S    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2701
   Revision: 05351113    Serial number: 00001109090158
   Shop #: WSC 00020 790 00000
   VCID: 260025FC911561AB81-8072
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 N    HW: 7N0 614 109 N
   Component: J104   C3 450M VD4E 0021
   Revision: --H07---    Serial number: 00000004436542
   Coding: 0028186
   VCID: 383CFB844BA1E75B23-806C
   Part No SW: 5K0 907 044 FK    HW: 5K0 907 044 FK
   Component: Clima-Sharan  H18 0204
   Revision: 00001002
   Coding: 0200004409
   Shop #: WSC 00020 999 00000
Address 09: Cent. Elect.
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0012
   Revision: --------    Serial number: 28261223601573
   Coding: 100101
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 393AFE80B8ABFE53DC-806C
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag01K H07 0013
   Serial number: 003GFPKFS6FE Dataset Number: 7N0003v____ 0255
   Coding: 00314B
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E30ED9CA185D96BE9-806A
   Serial number: 3493ETS60BE540915DD%
   Serial number: 3503ETS60B27A0315DDO
   Serial number: 3513ETS601A3D0A159DP
   Serial number: 3523ETS609EFA01159D
   Serial number: 35540TS600B15D9149DH
   Part No SW: 5K0 953 521 AN    HW: 5K0 953 569
   Revision: FF010040    Serial number: 20110903100740
   Coding: 5880040000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 78BC3B84C321275BE3-802C
   Part No SW: 7N0 920 960 E    HW: 7N0 920 960 E
   Component: KOMBI         H03 0605
   Coding: 440F01
   VCID: 3424CFB49FC9033B0F-8060
   Part No: 7N0 963 271 C
   Component: Zuheizer        051 2730
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   Shop #: WSC 59508 004 1048576
   VCID: 3424CFB457C9033B0F-8060
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 220911F1000964
   Coding: 468003
   VCID: 373EF8B886BFE8232A-8062
   Component: IMMO          H03 0605
   VCID: 6A9811CC8D8D85CB65-803E
   Revision: A1001003    Serial number: 7660928834
   VCID: 291A2EC0400B4ED3AC-807C
   Part No SW: 7N0 959 793 D    HW: 7N0 959 793
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000120077719
   Coding: 011006208001411011
   VCID: 43C69C68C267B48386-8016
   Part No: 7N0 909 144 M
   Component: EPS_ZFLS Kl. 275    3201
   Revision: 00H20000
   VCID: 3D32EA906483C273F0-8068
Address 46: Central Conv.
   Part No SW: 7N0 959 792 D    HW: 7N0 959 792
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000119601359
   VCID: 42C8996CDD7DBD8B8D-8016
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000260694
   Coding: 0024167
   VCID: 3522F2B05CB31A3338-8060
   Part No SW: 5M0 035 186 K    HW: 5M0 035 186 K
   Component: Radio RCD310  031 0075
   Revision: 01000001    Serial number: VWZ1Z2L7483696
   Coding: 0100040004000D
   VCID: 3424CFB497C9033B0F-8060
   Component: Batt.regelung H43 1620
   Coding: 030B185A
   VCID: 71AA06A0A85B761324-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900656565
02252 - Generator
                    Reset counter: 76
                    Mileage: 201775 km
                    Date: 2020.08.30.
                    Time: 18:23:52
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000119902637
   Coding: 010004200001411001
   VCID: 45C28270CC538AB3A8-8010
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000119798580
End----------(Elapsed Time: 01:15, VBatt start/end: 12.3V/12.3V)-----------
------------------------------3 Faults Found-------------------------------
I suspect the:
Seems likely.
Log data from the NOx sensor(s) to see what's going on there.
rayhoop
C?ID=288499
Seems likely.
Logging was (is still) planned for this weekend, and I've been watching the count-down drop to "500 miles until..."
Miraculously, this morning the Adblue warning is no where to be seen on the dashboard. No warning message, no "bong", no adblue bottle illuminated. I've not plugged in the VCDS since last week. Car has been driven as normal.
Mystery... (for now)
I'll still get logging done and rescan for codes. I'd like to see if there are potential issue(s) bubbling below the threshold that might need attention in the future.
Vdub
C?ID=57533
the best thing to do with the Adblue system (coding out ;) ) is DONT wait till the screen tells you to top up and than drive 2000kms to do so.
The ureum is very crystalising and the lower the level the better it makes crystals and will block/break the parts.
So fill it up more often/on a higher level instead of waiting till the last fumes..
rayhoop
C?ID=288499
Update: other priorities rose to the top of the list of life, and logging dropped out from the immediate range - that was until I paid the Sharan a compliment, and 10 mins later the fault reappeared.
I ran some logs on Monday (yes, it's taken me until 4am on Thursday to share them!
To start - the full scan on Monday:
Monday,27,April,2026,20:08:51:62060
Mileage: 202820km-126026mi   Repair Order:
          61 62 72
VIN: WVWZZZ7NZCV018981   Mileage: 202820km-126026miles
                    Fault Frequency: 119
                    Mileage: 201815 km
                    Date: 2026.04.27.
                    Time: 21:13:00
                    Engine speed: 1040.00 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 12.180 V
9567 - NOx Sensor 2 Bank 1
          P229F 00 [01100000] - Implausible Signal
          P20EE 00 [11101101] - Efficiency too Low
                    Fault Frequency: 9
                    Mileage: 202384 km
                    Date: 2026.04.27.
                    Time: 18:53:28
                    Engine speed: 2238.50 /min
                    Normed load value: 51.8 %
                    Vehicle speed: 107 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 25 °C
                    Measured NOx conversion: 0.221
                    Calculated efficiency of NOx conversion: 0.880
                    Current temperature with NOx Reduction CAT: 275.0 °C
Readiness: 1 1 0 0 0
   Component: J104   C3 450M VD65 0021
   Coding: 0028186
   Revision: 00001002
   Coding: 0200004409
9601321 - Humidity sensor
          B1281 29 [00001000] - Signal Implausible
                    Reset counter: 133
                    Mileage: 202331 km
                    Date: 2026.04.27.
                    Time: 15:13:54
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0048
   Revision: BA011001
   Coding: 46180A3B8125F1C0400000C0100000E443011308424D29626480872000C1
   VCID: 3522F2B09CB31A3338-8060
   Subsystem 1 - Part No SW: 7N2 955 119 A    HW: 7N2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110802  31  0032
   Serial number:         110820154515
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y11M09D21h11m55s37S1
   Coding: 4280BB
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
                    Reset counter: 101
                    Mileage: 202805 km
                    Date: 2020.09.17.
                    Time: 15:43:25
                    Voltage: 11.90 V
                    Fault Status: 00101010
                    Reset counter: 135
                    Mileage: 201817 km
                    Date: 2020.09.17.
                    Time: 21:44:12
                    Voltage: 12.60 V
                    Reset counter: 138
                    Mileage: 202243 km
                    Date: 2020.09.17.
                    Time: 08:39:46
                    Voltage: 11.65 V
   Coding: 100101
   Coding: 00314B
   Coding: 5880040000
   Coding: 440F01
   Coding: 0000041
   Coding: 468003
   Revision: 00H20000
   Coding: 0024167
   Coding: 030B185A
02252 - Generator
                    Reset counter: 78
                    Mileage: 201815 km
                    Date: 2020.09.17.
                    Time: 21:12:58
End----------(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.2V)-----------
------------------------------8 Faults Found-------------------------------
Monday,27,April,2026,20:14:13:62060
                Address 01: Engine  (03L 906 018 HJ)
20:14:04
  IDE00021   Engine speed 781 /min
  IDE00196   Engine oil temperature 86.5 °C
  IDE00427   Particle filter: difference pressure 7 hPa
  IDE00433   Particle filter: oil ash volume 0.00 l
  IDE00434   Particle filter: soot mass calculated 8.21 g
  IDE00435   Particle filter: soot mass measured 5.98 g
  IDE00436   Particle filter: kilometers since last regeneration 15766 m
  IDE00581   EGR specified value 83.9 %
  IDE01259   EGR Solen.val.: actual value 15.87 %
  IDE03135   Sensor for reducing agent tank temperature: temperature 22.6 °C
  IDE03136   Sensor for reducing agent fill level: fill level 79.88 %
Attached, 2x csv log files.
I ran logging 3 times, but I guess I messed up between the 2nd and 3rd. Let me know if you need the data from the 2nd run and I'll repeat it during the bank holiday weekend.
Monday	27	April	2026	21:21:23:62060-VCID:79BA3E80F82B3E5784-802C	VCDS Version: Release 26.3.0 (x64)	Data version: 20260320 DS375.1
03L 906 018 HJ	ADVMB	R4 2.0l TDI   H26 9979
		G004	F0	G205	F0	G206	F0	G207	F0	G208	F0	G214	F0	G221	F0	G299	F0	G452	F0	G503	F0	G000	F0	G000	F0
Marker	TIME	Loc. IDE00021	TIME	Loc. IDE03129	TIME	Loc. IDE03130-ENG188621	TIME	Loc. IDE03131	TIME	Loc. IDE03132	TIME	Loc. IDE03139	TIME	Loc. IDE03146	TIME	Loc. IDE03243	TIME	Loc. IDE05232	TIME	Loc. IDE06254-ENG188621
	STAMP	Engine speed	STAMP	Reducing agent pump: activation	STAMP	Reducing agent purge valve: activation-Bits 0-7	STAMP	Reducing agent injector: activation	STAMP	Pressure sensor for reducing agent: measured pressure	STAMP	Reducing agent injector: resistance	STAMP	Pressure sensor for reducing agent: voltage	STAMP	Reducing agent injector: current saturation phase	STAMP	Reducing agent fill level	STAMP	Status of a reducing agent warning-Bits 0-7
		 /min		 %		 		 %		 hPa		 mOhm		 mV		 mA		 %
	0.08	982	0.16	11.73	0.25	0	0.33	0	0.45	5004	0.5	13480	0.59	3005.8	0.66	863	0.76	99.39	0.02	53
	0.96	981	1.05	12.27	1.15	0	1.24	0	1.34	5000	1.41	13480	1.49	3025.2	1.58	863	1.71	99.39	0.85	53
	1.87	979	1.97	11.95	2.07	0	2.16	0	2.25	5004	2.33	13480	2.45	2991	2.52	863	2.62	99.39	1.77	53
	2.8	979	2.9	12.63	3	0	3.09	0	3.2	4993	3.26	13507	3.34	2986.2	3.46	865	3.52	99.39	2.72	53
	3.71	980	3.81	12.08	3.9	0	3.99	0	4.09	5003	4.17	13507	4.25	3020.4	4.34	865	4.46	99.39	3.62	53
	4.62	978	4.73	12.41	4.83	0	4.96	0	5.02	4997	5.12	13516	5.21	2996	5.31	862	5.4	99.39	4.53	53
	5.59	957	5.67	12.01	5.76	0	5.86	0	5.97	5004	6.07	13516	6.16	2981.4	6.26	862	6.35	99.39	5.5	53
	6.55	980	6.65	12.05	6.74	0	6.84	0	6.95	4994	7.01	13516	7.09	2991	7.21	862	7.27	99.39	6.47	53
	7.46	1161	7.56	12.13	7.65	0	7.74	0	7.83	5005	7.95	13516	8.02	3015.4	8.1	862	8.22	99.39	7.37	53
	8.4	1306	8.49	11.78	8.59	0	8.71	0	8.77	4979	8.85	13516	8.96	2976.4	9.05	862	9.13	99.39	8.32	53
	9.31	1385	9.39	12.23	9.47	0	9.56	0	9.64	5009	9.72	13516	9.83	3005.8	9.9	862	10.02	99.39	9.22	53
	10.2	1555	10.26	11.46	10.36	0	10.48	0	10.57	5013	10.7	13509	10.76	2981.4	10.84	976	10.95	99.39	10.09	53
	11.11	1572	11.23	13.23	11.33	0	11.47	0	11.54	4998	11.64	13509	11.73	3000.8	11.81	976	11.91	99.39	11.03	53
	12.08	1400	12.16	11.77	12.25	0	12.33	0	12.44	5010	12.52	13509	12.58	3020.4	12.7	976	12.76	99.39	12	53
	12.97	1307	13.08	11.89	13.19	0	13.25	0	13.33	5002	13.47	13509	13.53	3015.4	13.62	976	13.73	99.39	12.86	53
	13.95	1225	14.01	12.06	14.11	0	14.23	0	14.32	5000	14.44	13509	14.52	2976.4	14.59	976	14.72	99.39	13.83	53
	14.89	1260	14.98	12.07	15.08	0	15.2	0	15.26	4999	15.34	13509	15.45	2996	15.51	976	15.6	99.39	14.8	53
	15.83	874	15.9	11.79	16	0	16.09	0	16.2	5002	16.26	13509	16.35	3005.8	16.47	976	16.56	99.39	15.73	53
	16.74	968	16.84	12.23	16.96	0	17.02	0	17.11	4995	17.22	13509	17.32	2981.4	17.4	976	17.49	99.39	16.65	53
	17.69	982	17.76	12.1	17.85	0	17.97	0	18.04	4998	18.13	13509	18.23	3020.4	18.3	976	18.4	99.39	17.58	53
	18.58	1004	18.71	12.06	18.77	0	18.87	0	18.96	5006	19.05	13509	19.14	3010.6	19.23	976	19.32	99.39	18.49	53
	19.51	1213	19.58	11.81	19.7	0	19.77	0	19.86	4975	19.97	13457	20.04	2976.4	20.13	981	20.23	99.39	19.44	53
	20.44	921	20.49	12.62	20.59	0	20.7	0	20.76	5004	20.85	13457	20.96	3015.4	21.05	981	21.15	99.39	20.32	53
	21.33	1177	21.46	11.5	21.52	0	21.62	0	21.71	5010	21.8	13457	21.89	3000.8	21.98	981	22.07	99.39	21.24	53
	22.26	979	22.34	12.27	22.46	0	22.52	0	22.61	5003	22.72	13457	22.79	2976.4	22.88	981	22.97	99.39	22.18	53
	23.19	1015	23.24	11.67	23.33	0	23.42	0	23.51	5005	23.59	13457	23.7	2991	23.76	981	23.86	99.39	23.07	53
	24.07	1324	24.15	12.05	24.24	0	24.34	0	24.45	4994	24.51	13457	24.6	3000.8	24.71	981	24.77	99.39	23.97	53
	24.96	1486	25.05	13.98	25.15	0	25.24	0	25.32	4969	25.44	13457	25.51	3000.8	25.58	981	25.7	99.39	24.87	53
	25.86	1281	25.97	12.02	26.07	0	26.18	0	26.26	5008	26.33	13457	26.45	3010.6	26.51	981	26.6	99.39	25.77	53
	26.82	986	26.9	12.01	26.99	0	27.08	0	27.19	5006	27.24	13457	27.32	2991	27.44	981	27.5	99.39	26.72	53
	27.69	988	27.74	11.88	27.83	0	27.96	0	28.01	5007	28.1	13457	28.19	3025.2	28.25	981	28.33	99.39	27.58	53
	28.5	986	28.58	11.61	28.68	0	28.75	0	28.82	5006	28.94	13457	29.01	3025.2	29.08	981	29.21	99.39	28.44	53
	29.35	1270	29.46	12.07	29.55	0	29.64	0	29.72	5000	29.8	13457	29.88	3010.6	29.97	981	30.07	99.39	29.27	53
	30.26	1467	30.33	16.05	30.44	0	30.52	0	30.61	4946	30.72	13458	30.82	3015.4	30.9	991	30.99	99.39	30.18	53
	31.19	1543	31.24	10.98	31.33	0	31.46	0	31.51	5029	31.6	13458	31.71	3000.8	31.8	991	31.89	99.39	31.08	53
	32.04	1578	32.13	13.49	32.22	0	32.3	0	32.38	4985	32.47	13536	32.54	3000.8	32.63	984	32.72	99.39	31.97	53
	32.88	1600	32.97	12.03	33.05	0	33.14	0	33.22	5010	33.3	13536	33.38	3005.8	33.47	984	33.55	99.39	32.8	53
	33.72	1643	33.8	12.14	33.91	0	34.01	0	34.1	5007	34.23	13536	34.33	2996	34.4	984	34.49	99.39	33.64	53
	34.7	1695	34.76	11.86	34.85	0	34.97	0	35.08	5007	35.15	13536	35.24	2991	35.34	984	35.46	99.39	34.59	53
	35.61	1729	35.72	12.18	35.82	0	35.93	0	36.01	4999	36.08	13536	36.2	2996	36.26	984	36.35	99.39	35.52	53
	36.54	1822	36.63	12.53	36.73	0	36.82	0	36.94	5001	36.99	13536	37.08	3010.6	37.21	984	37.27	99.39	36.47	53
	37.46	1929	37.55	12.68	37.65	0	37.74	0	37.82	4997	37.94	13389	38.01	3000.8	38.08	986	38.19	99.39	37.36	53
	38.36	1303	38.47	12.9	38.55	0	38.65	0	38.73	4987	38.82	13554	38.94	2981.4	38.99	982	39.09	99.39	38.27	53
	39.26	1263	39.35	12.86	39.47	0	39.56	0	39.64	5003	39.73	13513	39.82	3000.8	39.9	982	39.99	99.39	39.21	53
	40.2	1203	40.26	11.91	40.35	0	40.47	0	40.57	5016	40.65	13513	40.73	3030.2	40.82	982	40.94	99.39	40.09	53
	41.07	1179	41.19	11.77	41.25	0	41.33	0	41.44	5005	41.5	13513	41.57	3005.8	41.69	982	41.75	99.39	41.01	53
	41.96	1188	42.03	12.31	42.12	0	42.23	0	42.32	5001	42.45	13670	42.51	3010.6	42.59	978	42.72	99.39	41.83	53
	42.89	1252	42.98	13.05	43.08	0	43.22	0	43.28	4987	43.36	13670	43.45	2971.6	43.53	978	43.61	99.39	42.8	53
	43.79	1271	43.88	12.55	43.97	0	44.05	0	44.13	4993	44.22	13670	44.31	2991	44.39	978	44.48	99.39	43.71	53
	44.65	1192	44.75	11.83	44.84	0	44.97	0	45.04	5009	45.14	13670	45.22	2991	45.33	978	45.46	99.39	44.58	53
	45.63	996	45.73	11.88	45.83	0	45.96	0	46.02	5013	46.12	13670	46.22	3000.8	46.31	978	46.4	99.39	45.54	53
	46.58	980	46.66	11.72	46.77	0	46.84	0	46.95	5006	47.03	13670	47.1	2996	47.21	982	47.31	99.39	46.5	53
	47.49	961	47.59	12.22	47.71	0	47.78	0	47.86	4999	47.98	13494	48.07	2981.4	48.15	982	48.24	99.39	47.4	53
	48.45	971	48.51	11.8	48.6	0	48.72	0	48.82	5006	48.9	13494	48.98	3000.8	49.07	982	49.18	99.39	48.34	53
	49.36	1534	49.46	13.87	49.53	0	49.62	0	49.71	4971	49.81	13526	49.89	3000.8	49.98	986	50.07	99.39	49.26	53
	50.26	2002	50.34	12.08	50.47	0	50.55	0	50.64	5007	50.73	13526	50.82	3010.6	50.95	986	51.01	99.39	50.19	53
	51.22	2606	51.33	13.98	51.47	0	51.55	0	51.64	4964	51.73	13526	51.82	3000.8	51.95	986	52.01	99.39	51.11	53
	52.21	2003	52.31	12.14	52.4	0	52.49	40.74	52.58	4997	52.71	13526	52.76	2991	52.85	986	52.97	99.39	52.1	53
	53.14	2386	53.22	13.57	53.32	0	53.44	14.69	53.51	4987	53.58	13526	53.69	3010.6	53.74	986	53.83	99.39	53.05	53
	54.01	1676	54.08	12.73	54.2	0	54.25	0	54.32	5004	54.44	13526	54.5	3015.4	54.58	986	54.68	99.39	53.94	53
	54.82	1829	54.94	14.46	55	0	55.08	0	55.19	4978	55.25	13526	55.32	2981.4	55.44	986	55.52	99.39	54.75	53
	55.69	1979	55.76	13.95	55.86	0	55.97	0	56.08	5009	56.15	13527	56.24	3030.2	56.34	981	56.47	99.39	55.59	53
	56.63	2162	56.73	12.35	56.82	0	56.94	0	57.01	5023	57.09	13502	57.2	3020.4	57.26	984	57.35	99.39	56.54	53
	57.58	2116	57.65	12.63	57.75	0	57.84	0	57.95	5011	58.01	13458	58.1	3010.6	58.22	982	58.33	99.39	57.47	53
	58.51	1685	58.59	14.78	58.71	0	58.78	28.68	58.86	4968	58.97	13529	59.05	2976.4	59.15	982	59.25	99.39	58.45	53
	59.45	1766	59.51	15.29	59.6	0	59.73	21.9	59.82	4980	59.95	13598	60.01	3005.8	60.09	981	60.21	99.39	59.34	53
	60.36	1851	60.48	13.77	60.57	0	60.7	0	60.76	5006	60.84	13543	60.95	3020.4	61.01	981	61.1	99.39	60.28	53
	61.32	1906	61.4	12.94	61.49	0	61.59	0	61.7	5020	61.76	13543	61.85	3025.2	61.96	981	62.03	99.39	61.22	53
	62.21	1899	62.3	12.21	62.4	0	62.49	0	62.58	5023	62.71	13543	62.76	3010.6	62.85	981	62.97	99.39	62.12	53
	63.14	1830	63.23	12.29	63.32	0	63.44	0	63.51	5017	63.58	13543	63.7	2986.2	63.76	981	63.85	99.39	63.05	53
	64.07	1465	64.15	11.53	64.24	0	64.34	0	64.45	5019	64.51	13543	64.6	3015.4	64.71	981	64.77	99.39	63.97	53
	64.96	1236	65.05	11.88	65.15	0	65.24	0	65.32	5000	65.44	13543	65.51	2976.4	65.58	981	65.7	99.39	64.87	53
	65.85	1082	65.97	11.9	66.05	0	66.15	0	66.23	5003	66.32	13543	66.44	3020.4	66.49	981	66.58	99.39	65.77	53
	66.76	1092	66.85	11.89	66.97	0	67.05	0	67.14	4997	67.23	13543	67.29	3015.4	67.38	984	67.48	99.39	66.71	53
	67.69	1094	67.74	12.34	67.83	0	67.96	0	68.01	4996	68.1	13536	68.21	3020.4	68.3	984	68.39	99.39	67.57	53
	68.54	939	68.63	11.83	68.72	0	68.8	0	68.88	5000	68.97	13536	69.07	2996	69.14	984	69.22	99.39	68.47	53
	69.38	997	69.47	11.9	69.57	0	69.69	0	69.75	5001	69.83	13527	69.94	3020.4	70	981	70.08	99.39	69.3	53
	70.3	1033	70.37	12.06	70.45	0	70.53	0	70.6	5000	70.72	13527	70.79	3020.4	70.88	981	70.97	99.39	70.21	53
	71.13	1502	71.22	13.46	71.3	0	71.39	0	71.47	4971	71.55	13527	71.63	2971.6	71.72	981	71.8	99.39	71.05	53
	71.97	1575	72.05	12.44	72.15	0	72.24	0	72.32	5004	72.44	13527	72.51	3005.8	72.58	981	72.7	99.39	71.89	53
	72.85	1590	72.97	13.02	73.05	0	73.14	0	73.22	4971	73.3	13527	73.38	3000.8	73.47	981	73.55	99.39	72.77	53
	73.72	1661	73.8	12.4	73.89	0	73.97	0	74.04	5008	74.13	13527	74.22	3000.8	74.3	987	74.39	99.39	73.64	53
	74.58	1642	74.72	12.63	74.78	0	74.86	0	74.96	5008	75.05	13564	75.15	2991	75.22	987	75.32	99.39	74.5	53
	75.49	1652	75.58	11.92	75.71	0	75.77	0	75.84	5011	75.94	13564	76.02	2981.4	76.1	987	76.22	99.39	75.41	53
	76.4	1635	76.47	12.55	76.57	0	76.66	0	76.74	5000	76.83	13637	76.9	3020.4	76.99	978	77.08	99.39	76.3	53
	77.24	1653	77.33	11.8	77.45	0	77.5	0	77.58	5015	77.66	13577	77.74	3025.2	77.83	981	77.95	99.39	77.2	53
	78.08	1723	78.15	9.46	78.25	0	78.31	9.36	78.38	5030	78.48	13581	78.55	2996	78.65	982	78.75	99.39	78	53
	78.95	1842	79.01	12.1	79.1	0	79.23	8.33	79.32	5004	79.44	13581	79.51	3020.4	79.59	982	79.69	99.39	78.84	53
	79.86	2045	79.97	9.71	80.08	0	80.21	0	80.27	5018	80.39	13581	80.48	2986.2	80.56	982	80.65	99.39	79.78	53
	80.83	2468	80.96	11.02	81.03	0	81.12	0	81.22	4994	81.33	13581	81.46	2991	81.53	982	81.61	99.39	80.75	53
	81.82	1838	81.92	11.91	82.01	0	82.11	33.9	82.22	4958	82.31	13581	82.4	2971.6	82.48	982	82.57	99.39	81.72	53
	82.75	2097	82.84	13.56	82.96	0	83.03	31.8	83.12	4969	83.22	13581	83.31	2991	83.4	982	83.49	99.39	82.67	53
	83.7	2356	83.76	12.96	83.85	0	83.97	0	84.05	4960	84.13	13502	84.21	2981.4	84.3	986	84.4	99.39	83.58	53
	84.58	2609	84.7	16.69	84.78	0	84.87	0	84.96	4951	85.06	13475	85.15	2956.8	85.23	958	85.32	99.39	84.49	53
	85.5	2087	85.59	14.84	85.71	0	85.77	0	85.86	4991	85.97	13745	86.06	3005.8	86.15	974	86.24	99.39	85.42	53
	86.45	2116	86.51	14.39	86.6	0	86.72	0	86.8	5007	86.88	13647	86.96	2966.6	87.05	981	87.15	99.39	86.34	53
	87.33	2238	87.46	14.07	87.53	0	87.62	0	87.71	4990	87.81	13536	87.9	2981.4	87.98	984	88.07	99.39	87.24	53
	88.25	2309	88.34	13.67	88.46	0	88.53	0	88.62	5023	88.72	13536	88.81	3000.8	88.9	984	88.99	99.39	88.17	53
	89.2	1853	89.26	13.44	89.36	0	89.48	0	89.56	4996	89.65	13536	89.74	3010.6	89.82	984	89.91	99.39	89.09	53
	90.09	1890	90.21	13.39	90.27	0	90.37	0	90.46	5023	90.54	13536	90.62	3030.2	90.71	984	90.8	99.39	90.01	53
	90.99	1934	91.07	12.51	91.16	0	91.26	0	91.34	5021	91.46	13536	91.52	2986.2	91.6	984	91.72	99.39	90.9	53
	91.9	1979	91.99	12.4	92.09	0	92.16	0	92.24	5015	92.34	13536	92.4	3010.6	92.49	984	92.59	99.39	91.82	53
	92.78	2020	92.85	12.19	92.97	0	93.06	0	93.15	5013	93.23	13553	93.31	3025.2	93.4	984	93.49	99.39	92.71	53
	93.68	2065	93.76	12.49	93.85	0	93.97	0	94.05	4996	94.13	13559	94.21	2976.4	94.3	986	94.4	99.39	93.59	53
	94.56	2071	94.65	12.89	94.72	0	94.8	0	94.9	4996	94.97	13536	95.05	2991	95.14	984	95.22	99.39	94.47	53
	95.4	1774	95.49	12.22	95.59	0	95.69	0	95.77	5022	95.85	13475	95.96	3030.2	96.05	984	96.15	99.39	95.32	53
	96.34	1796	96.41	10.4	96.5	0	96.58	0	96.65	5027	96.74	13621	96.83	3015.4	96.91	984	97.01	99.39	96.24	53
	97.21	1817	97.3	10.53	97.4	0	97.49	0	97.59	5021	97.66	13621	97.74	3005.8	97.83	984	97.93	99.39	97.1	53
	98.09	1838	98.16	10.83	98.25	0	98.34	8.58	98.4	5012	98.49	13621	98.59	3020.4	98.66	984	98.75	99.39	98	53
	98.95	1857	99	11.2	99.08	0	99.16	0	99.24	4985	99.33	13621	99.44	2996	99.5	984	99.58	99.39	98.83	53
	99.77	1876	99.85	13.24	99.97	0	100.05	0	100.15	4965	100.22	13621	100.3	2981.4	100.38	984	100.47	99.39	99.71	53
	100.65	1893	100.72	12.61	100.8	0	100.89	0	100.96	4985	101.05	13621	101.14	3010.6	101.22	984	101.31	99.39	100.55	53
	101.46	1909	101.55	12.5	101.64	0	101.72	0	101.8	4989	101.89	13553	101.96	2971.6	102.06	984	102.15	99.39	101.39	53
	102.34	1847	102.46	12.64	102.53	0	102.62	0	102.72	4995	102.79	13529	102.88	2996	102.95	987	103.03	99.39	102.25	53
	103.19	1859	103.27	11.67	103.35	0	103.47	0	103.54	5012	103.63	13529	103.72	3015.4	103.82	987	103.94	99.39	103.11	53
	104.1	1820	104.21	11.86	104.27	0	104.37	0	104.46	5005	104.55	13529	104.64	2996	104.73	987	104.82	99.39	104.01	53
	105.01	1780	105.08	11.94	105.21	0	105.27	0	105.36	5007	105.47	13529	105.54	3020.4	105.63	987	105.73	99.39	104.94	53
	105.94	1740	106.01	12.22	106.1	0	106.22	0	106.32	5000	106.4	13529	106.48	3020.4	106.57	987	106.69	99.39	105.82	53
	106.85	1703	106.96	11.88	107.02	0	107.12	0	107.21	4998	107.3	13529	107.39	2986.2	107.47	987	107.57	99.39	106.76	53
	107.76	1670	107.83	11.97	107.96	0	108.02	0	108.1	5001	108.21	13529	108.29	3000.8	108.38	987	108.47	99.39	107.67	53
	108.63	1634	108.72	12.06	108.82	0	108.89	0	108.98	5000	109.06	13529	109.15	2986.2	109.24	987	109.33	99.39	108.57	53
	109.49	1583	109.58	12.1	109.7	0	109.75	0	109.83	5004	109.91	13529	109.99	3020.4	110.08	987	110.2	99.39	109.45	53
	110.33	1516	110.41	11.75	110.51	0	110.61	0	110.73	4999	110.83	13529	110.91	2991	111	987	111.08	99.39	110.25	53
	111.27	1413	111.34	12.01	111.45	0	111.5	0	111.58	4997	111.69	13529	111.77	3015.4	111.87	987	111.98	99.39	111.17	53
	112.16	1294	112.25	12.19	112.33	0	112.44	0	112.55	5000	112.66	13529	112.72	3005.8	112.81	987	112.91	99.39	112.08	53
	113.08	1172	113.22	12.31	113.3	0	113.41	0	113.5	4998	113.59	13529	113.71	2991	113.76	987	113.86	99.39	112.99	53
	114.04	1213	114.14	12.11	114.24	0	114.34	0	114.46	5000	114.52	13529	114.61	3005.8	114.72	987	114.79	99.39	113.98	53
	114.98	1309	115.08	11.78	115.21	0	115.28	0	115.36	5005	115.49	13529	115.58	3000.8	115.72	987	115.79	99.39	114.89	53
	115.99	1355	116.06	11.77	116.14	0	116.23	0	116.3	5005	116.39	13529	116.47	3015.4	116.55	987	116.64	99.39	115.89	53
	116.8	1451	116.89	12.18	116.98	0	117.06	0	117.14	5000	117.23	13529	117.31	3015.4	117.39	987	117.48	99.39	116.73	53
	117.63	1362	117.73	12.24	117.81	0	117.89	0	117.97	4995	118.05	13529	118.16	2976.4	118.22	987	118.3	99.39	117.56	53
	118.47	1294	118.58	12.3	118.65	0	118.75	0	118.82	4997	118.94	13529	119	3000.8	119.11	987	119.2	99.39	118.39	53
	119.38	1197	119.51	11.77	119.61	0	119.7	0	119.78	5002	119.87	13529	119.98	2991	120.04	987	120.14	99.39	119.29	53
	120.35	1116	120.45	12.06	120.54	0	120.64	0	120.75	5000	120.84	13529	120.93	3015.4	121.01	987	121.1	99.39	120.26	53
	121.28	1107	121.37	12.13	121.49	0	121.56	0	121.65	4998	121.76	13491	121.84	2981.4	121.93	991	122.03	99.39	121.2	53
	122.23	1139	122.29	12.34	122.38	0	122.49	0	122.59	4995	122.66	13458	122.75	3010.6	122.84	991	122.93	99.39	122.12	53
	123.11	1228	123.24	14.57	123.3	0	123.4	0	123.49	4964	123.59	13559	123.68	2986.2	123.76	989	123.85	99.39	123.03	53
	124.03	1909	124.12	14.85	124.24	0	124.31	33.16	124.4	4980	124.5	13715	124.58	2986.2	124.68	981	124.77	99.39	123.95	53
	124.98	2828	125.04	13.69	125.13	0	125.26	0	125.34	4988	125.43	13715	125.53	3000.8	125.6	981	125.69	99.39	124.87	53
	125.87	3312	125.99	14.12	126.05	0	126.15	0	126.24	4996	126.34	13715	126.43	3020.4	126.51	981	126.6	99.39	125.79	53
	126.78	2528	126.86	14.15	126.98	0	127.05	0	127.15	5001	127.25	13715	127.33	2991	127.41	981	127.5	99.39	126.69	53
	127.65	2831	127.75	13.68	127.83	0	127.93	0	128.02	5009	128.1	13715	128.18	3010.6	128.27	981	128.36	99.39	127.59	53
	128.53	3123	128.62	13.79	128.75	0	128.81	0	128.9	5005	129.01	13715	129.1	3025.2	129.2	989	129.29	99.39	128.48	53
	129.5	3400	129.59	14.04	129.68	0	129.78	21.3	129.87	5000	129.95	13594	130.03	3010.6	130.12	984	130.24	99.39	129.39	53
	130.4	3617	130.5	14.46	130.58	0	130.68	0	130.74	5000	130.83	13743	130.9	3020.4	131	981	131.08	99.39	130.3	53
	131.25	3814	131.33	13.6	131.42	0	131.51	0	131.58	5003	131.69	13595	131.75	2996	131.86	981	131.97	99.39	131.17	53
	132.15	2763	132.26	14.18	132.36	0	132.45	0	132.53	5000	132.62	13640	132.73	2971.6	132.79	979	132.88	99.39	132.05	53
	133.08	2760	133.18	16.84	133.28	0	133.37	0	133.48	4952	133.54	13726	133.63	2996	133.76	979	133.86	99.39	133	53
	134.03	2152	134.12	13.57	134.24	0	134.3	5.1	134.4	5057	134.5	13726	134.58	3044.8	134.68	979	134.77	99.39	133.95	53
	134.98	2128	135.03	11.88	135.11	0	135.24	0	135.3	5046	135.38	13726	135.49	3020.4	135.58	979	135.68	99.39	134.87	53
	135.86	2120	135.94	12.49	136.03	0	136.11	0	136.22	5026	136.28	13726	136.36	3030.2	136.44	979	136.55	99.39	135.77	53
	136.74	2113	136.84	11.95	136.93	0	137.03	0	137.11	5020	137.24	13726	137.3	2991	137.4	979	137.5	99.39	136.65	53
	137.68	2097	137.76	12.39	137.85	0	137.95	7.59	138.03	5007	138.12	13726	138.23	3020.4	138.29	979	138.38	99.39	137.59	53
	138.59	2079	138.68	12.25	138.77	0	138.86	5.1	138.98	5006	139.04	13594	139.12	3015.4	139.24	984	139.3	99.39	138.51	53
	139.49	1784	139.59	12.66	139.66	0	139.75	0	139.83	4999	139.91	13621	139.99	3020.4	140.08	981	140.18	99.39	139.4	53
	140.33	1698	140.41	12.67	140.5	0	140.6	5.1	140.66	5000	140.75	13724	140.85	2981.4	140.92	981	141	99.39	140.25	53
	141.16	1695	141.24	12.35	141.33	0	141.42	0	141.52	5002	141.61	13587	141.74	3000.8	141.81	982	141.9	99.39	141.08	53
	142.1	1695	142.2	12.57	142.3	0	142.4	6.9	142.5	4996	142.59	13604	142.68	2976.4	142.77	986	142.86	99.39	142.01	53
	143.02	1714	143.11	12.71	143.24	0	143.28	6.9	143.36	4995	143.44	13663	143.52	2991	143.62	986	143.69	99.39	142.94	53
	143.87	1714	143.99	14.04	144.05	0	144.15	0	144.26	4977	144.35	13663	144.43	2991	144.52	986	144.61	99.39	143.79	53
	144.8	1735	144.88	12.75	145	0	145.05	0	145.15	5007	145.24	13663	145.31	3025.2	145.4	986	145.5	99.39	144.74	53
	145.64	1747	145.75	11.97	145.81	0	145.89	0	145.99	5009	146.05	13663	146.14	3010.6	146.25	986	146.31	99.39	145.55	53
	146.51	1764	146.61	11.89	146.75	0	146.81	0	146.9	5007	147.01	13663	147.06	3010.6	147.15	986	147.27	99.39	146.4	53
	147.49	1780	147.54	12.21	147.63	0	147.75	0	147.81	5005	147.9	13632	147.98	2971.6	148.05	982	148.15	99.39	147.37	53
	148.3	1794	148.38	12.29	148.5	0	148.56	0	148.64	4996	148.75	13647	148.82	2981.4	148.92	984	149.02	99.39	148.25	53
	149.19	1811	149.27	12.91	149.36	0	149.45	6.9	149.53	4989	149.61	13708	149.69	2971.6	149.77	989	149.86	99.39	149.12	53
	150.03	1826	150.11	12.93	150.2	0	150.28	6.9	150.35	4993	150.44	13656	150.53	3000.8	150.61	982	150.72	99.39	149.94	53
	150.89	1843	151.01	12.68	151.06	0	151.14	0	151.24	5000	151.3	13553	151.4	2986.2	151.51	963	151.59	99.39	150.83	53
	151.78	1853	151.88	12.64	151.95	0	152.05	0	152.11	5006	152.25	13633	152.3	2996	152.4	982	152.52	99.39	151.69	53
	152.74	1833	152.81	11.96	152.9	0	153.02	0	153.11	5016	153.24	13633	153.3	2996	153.4	982	153.52	99.39	152.62	53
	153.74	1814	153.79	11.77	153.89	0	154.01	0	154.06	5006	154.15	13633	154.26	2976.4	154.35	982	154.45	99.39	153.62	53
	154.62	1808	154.74	11.96	154.8	0	154.9	0	155.01	5000	155.1	13633	155.18	3005.8	155.27	982	155.36	99.39	154.54	53
	155.55	1798	155.63	11.95	155.75	0	155.8	0	155.9	5007	155.99	13633	156.06	3000.8	156.15	982	156.26	99.39	155.49	53
	156.43	1794	156.52	12.25	156.61	0	156.69	0	156.77	4997	156.86	13633	156.98	2991	157.03	982	157.11	99.39	156.35	53
	157.27	1822	157.35	11.99	157.44	0	157.53	0	157.61	4993	157.69	13718	157.77	2976.4	157.86	989	157.98	99.39	157.19	53
	158.11	1847	158.19	12.24	158.27	0	158.34	0	158.42	4996	158.51	13698	158.6	3020.4	158.7	981	158.79	99.39	158.03	53
	159	1872	159.08	12.14	159.19	0	159.3	8.34	159.41	4996	159.5	13577	159.54	3015.4	159.63	991	159.75	99.39	158.89	53
	159.88	1892	160	12.22	160.07	0	160.14	0	160.24	4996	160.3	13684	160.38	2981.4	160.51	982	160.57	99.39	159.82	53
	160.74	1915	160.8	12.29	160.9	0	161.01	0	161.08	5001	161.17	13684	161.25	2986.2	161.33	978	161.43	99.39	160.64	53
	161.58	1938	161.67	12.34	161.76	0	161.84	5	161.92	5000	162.01	13684	162.1	2991	162.2	978	162.3	99.39	161.51	53
	162.49	1955	162.58	12.14	162.64	0	162.75	6.04	162.82	5002	162.92	13684	163.01	3015.4	163.11	978	163.25	99.39	162.39	53
	163.44	1969	163.53	12.41	163.62	0	163.72	0	163.82	4997	163.92	13684	164.02	2996	164.09	978	164.17	99.39	163.33	53
	164.38	1982	164.45	12.6	164.54	0	164.64	0	164.75	4999	164.83	13684	164.93	3010.6	165.03	978	165.12	99.39	164.27	53
	165.32	1971	165.42	12.44	165.52	0	165.62	0	165.74	5003	165.81	13684	165.91	2991	165.99	978	166.05	99.39	165.25	53
	166.24	1951	166.3	11.61	166.39	0	166.5	0	166.55	5006	166.61	13684	166.74	2986.2	166.81	978	166.9	99.39	166.14	53
	167.12	1930	167.2	11.95	167.29	0	167.39	0	167.5	5000	167.57	13684	167.66	3020.4	167.77	978	167.87	99.39	167.02	53
	168.05	1911	168.15	12.01	168.27	0	168.37	0	168.49	5003	168.54	13684	168.62	3015.4	168.73	978	168.81	99.39	167.99	53
	169.01	1889	169.1	12.18	169.2	0	169.29	0	169.38	5002	169.5	13684	169.57	3005.8	169.67	978	169.78	99.39	168.9	53
	169.99	1864	170.06	11.8	170.15	0	170.27	0	170.38	5000	170.44	13684	170.53	2991	170.61	978	170.7	99.39	169.87	53
	170.85	1836	170.94	11.89	171.02	0	171.12	0	171.24	5004	171.3	13684	171.39	3015.4	171.5	978	171.55	99.39	170.78	53
	171.74	1810	171.8	12.03	171.89	0	172	0	172.05	4999	172.15	13684	172.26	3015.4	172.35	978	172.44	99.39	171.64	53
	172.64	1779	172.75	12.02	172.81	0	172.89	0	172.98	5004	173.05	13684	173.16	3020.4	173.26	978	173.32	99.39	172.55	53
	173.51	1751	173.61	12	173.74	0	173.81	0	173.9	4996	174.01	13684	174.06	2981.4	174.15	978	174.27	99.39	173.42	53
	174.49	1718	174.56	12	174.65	0	174.77	0	174.86	4999	174.98	13684	175.05	2981.4	175.15	978	175.27	99.39	174.37	53
	175.49	1681	175.54	11.96	175.64	0	175.76	0	175.81	5000	175.9	13684	176.01	3000.8	176.11	978	176.2	99.39	175.37	53
	176.38	1645	176.51	11.79	176.57	0	176.67	0	176.76	5004	176.86	13684	177	2996	177.04	978	177.14	99.39	176.29	53
	177.31	1604	177.4	11.99	177.52	0	177.62	0	177.74	4996	177.79	13684	177.87	2991	177.99	978	178.06	99.39	177.26	53
	178.23	1565	178.3	11.97	178.4	0	178.51	0	178.59	4999	178.68	13684	178.77	2976.4	178.85	978	178.94	99.39	178.13	53
	179.12	1526	179.24	12.16	179.3	0	179.4	0	179.49	4999	179.55	13684	179.65	2986.2	179.75	978	179.81	99.39	179.04	53
	179.97	1487	180.05	11.89	180.14	0	180.23	0	180.3	5005	180.38	13684	180.49	2996	180.55	978	180.64	99.39	179.89	53
	180.8	1447	180.89	12.02	181	0	181.08	0	181.16	5003	181.26	13684	181.33	2981.4	181.41	978	181.51	99.39	180.75	53
	181.67	1408	181.75	11.91	181.83	0	181.91	0	182	5003	182.08	13684	182.17	3000.8	182.26	978	182.34	99.39	181.59	53
	182.5	1366	182.58	12.06	182.68	0	182.77	0	182.86	4996	182.94	13684	183.02	2996	183.09	978	183.17	99.39	182.42	53
	183.33	1324	183.44	11.48	183.55	0	183.64	0	183.77	5000	183.87	13684	183.96	2991	184.06	978	184.16	99.39	183.26	53
	184.36	1268	184.45	11.97	184.55	0	184.61	0	184.74	4999	184.81	13684	184.91	3000.8	185.01	978	185.08	99.39	184.27	53
	185.27	1201	185.37	11.9	185.49	0	185.56	0	185.65	5002	185.76	13684	185.82	3015.4	185.92	978	186.02	99.39	185.18	53
	186.24	1334	186.29	12.12	186.39	0	186.51	0	186.57	4995	186.67	13684	186.75	3020.4	186.83	978	186.92	99.39	186.12	53
	187.11	1250	187.19	11.67	187.29	0	187.39	0	187.46	5002	187.56	13684	187.64	3010.6	187.76	978	187.82	99.39	187.01	53
	188.01	1268	188.1	12.07	188.2	0	188.29	0	188.39	4997	188.46	13684	188.54	2986.2	188.63	978	188.75	99.39	187.92	53
	188.91	1264	189.01	12.05	189.1	0	189.19	0	189.29	5000	189.36	13684	189.45	3015.4	189.54	978	189.61	99.39	188.82	53
	189.79	1109	189.88	11.94	189.95	0	190.03	0	190.1	5001	190.19	13684	190.26	2976.4	190.35	978	190.44	99.39	189.71	53
	190.6	1404	190.69	12.17	190.77	0	190.86	0	190.94	5001	191.02	13684	191.1	3005.8	191.19	978	191.3	99.39	190.53	53
	191.51	1307	191.61	11.91	191.7	0	191.79	0	191.88	4999	192.01	13684	192.06	2986.2	192.15	978	192.27	99.39	191.4	53
	192.49	1242	192.54	11.7	192.63	0	192.76	0	192.81	5002	192.9	13684	193.01	2981.4	193.1	978	193.2	99.39	192.37	53
	193.37	1197	193.49	12.75	193.56	0	193.65	0	193.76	4993	193.85	13684	193.94	2981.4	194.04	978	194.13	99.39	193.29	53
	194.31	1138	194.4	11.77	194.52	0	194.62	0	194.74	5001	194.79	13684	194.87	2996	194.99	978	195.05	99.39	194.26	53
	195.26	1123	195.35	11.74	195.45	0	195.54	0	195.62	5004	195.74	13637	195.81	3015.4	195.88	978	196.01	99.39	195.15	53
	196.15	1112	196.27	12.28	196.37	0	196.49	0	196.56	4998	196.63	13637	196.74	3010.6	196.8	978	196.9	99.39	196.07	53
	197.12	1147	197.19	12.23	197.27	0	197.37	0	197.49	4998	197.54	13715	197.62	2991	197.74	981	197.81	99.39	197.02	53
	198.01	1187	198.1	12	198.2	0	198.29	0	198.37	5001	198.49	13715	198.56	3005.8	198.63	981	198.76	99.39	197.9	53
	198.91	1261	199.02	11.46	199.12	0	199.24	0	199.3	5008	199.4	13715	199.51	2981.4	199.6	981	199.7	99.39	198.82	53
	199.87	1379	199.98	13.4	200.06	0	200.15	8.8	200.26	4977	200.35	13715	200.44	2986.2	200.54	981	200.64	99.39	199.79	53
	200.81	1513	200.9	12.22	201.02	0	201.12	0	201.24	5001	201.29	13715	201.37	2976.4	201.49	981	201.56	99.39	200.76	53
	201.76	1645	201.85	12.4	201.95	0	202.04	0	202.12	5002	202.24	13715	202.3	3010.6	202.4	981	202.52	99.39	201.65	53
	202.74	1174	202.79	12.19	202.88	0	203.01	0	203.06	5005	203.15	13715	203.26	3010.6	203.35	981	203.45	99.39	202.62	53
	203.62	1235	203.74	11.75	203.81	0	203.9	0	204.01	5000	204.1	13715	204.19	3020.4	204.29	981	204.38	99.39	203.54	53
	204.56	1267	204.65	11.85	204.77	0	204.86	0	204.99	5009	205.03	13715	205.11	2986.2	205.19	981	205.28	99.39	204.51	53
	205.49	1296	205.53	11.84	205.61	0	205.74	0	205.8	5006	205.88	13715	205.99	3010.6	206.05	981	206.15	99.39	205.36	53
	206.3	1315	206.4	11.95	206.5	0	206.57	0	206.65	5000	206.76	13715	206.84	3010.6	206.93	981	207.01	99.39	206.25	53
	207.17	1329	207.27	12.01	207.36	0	207.5	0	207.57	4997	207.67	13715	207.77	3025.2	207.87	981	208	99.39	207.09	53
	208.16	1336	208.27	12.07	208.37	0	208.5	0	208.56	4996	208.65	13715	208.76	2996	208.86	981	208.95	99.39	208.07	53
	209.13	1334	209.26	12.06	209.32	0	209.42	0	209.51	5000	209.6	13715	209.69	2981.4	209.79	981	209.89	99.39	209.04	53
	210.06	1300	210.15	11.85	210.27	0	210.37	0	210.49	4998	210.54	13715	210.63	2986.2	210.76	981	210.82	99.39	210	53
	211.01	1230	211.1	11.85	211.2	0	211.29	0	211.38	5002	211.51	13715	211.56	2991	211.65	981	211.78	99.39	210.92	53
	211.99	1179	212.06	12.02	212.15	0	212.27	0	212.36	5001	212.49	13715	212.55	3010.6	212.65	981	212.77	99.39	211.87	53
	212.99	1080	213.04	12.01	213.14	0	213.26	0	213.31	5001	213.4	13715	213.51	2991	213.6	981	213.7	99.39	212.87	53
	213.88	1002	214.01	11.86	214.07	0	214.17	0	214.26	5003	214.36	13715	214.49	2991	214.54	981	214.64	99.39	213.79	53
	214.82	1310	214.92	12	215.02	0	215.12	0	215.24	5002	215.29	13715	215.38	3005.8	215.51	981	215.57	99.39	214.76	53
	215.76	1309	215.85	11.79	215.95	0	216.04	0	216.12	5007	216.24	13715	216.3	3020.4	216.4	981	216.52	99.39	215.67	53
	216.74	1240	216.79	11.92	216.89	0	217.01	0	217.06	4997	217.15	13715	217.25	3020.4	217.34	981	217.43	99.39	216.62	53
	217.61	1167	217.74	11.97	217.81	0	217.9	0	218.01	5001	218.11	13715	218.24	3010.6	218.29	981	218.39	99.39	217.53	53
	218.56	1088	218.65	11.92	218.77	0	218.87	0	219	4997	219.04	13715	219.13	3010.6	219.26	981	219.32	99.39	218.51	53
	219.51	1011	219.6	11.97	219.7	0	219.79	0	219.87	5002	219.99	13715	220.05	2986.2	220.15	981	220.27	99.39	219.42	53
	220.49	918	220.54	12.02	220.64	0	220.75	0	220.81	5000	220.9	13715	221.01	3000.8	221.11	981	221.24	99.39	220.37	53
	221.4	925	221.51	11.84	221.57	0	221.67	0	221.76	5004	221.85	13715	221.94	3005.8	222.04	981	222.14	99.39	221.31	53
	222.31	930	222.4	11.97	222.52	0	222.62	0	222.74	5002	222.79	13715	222.87	2986.2	222.99	981	223.05	99.39	222.26	53
	223.26	852	223.35	12.47	223.44	0	223.54	0	223.62	4988	223.74	13655	223.81	3000.8	223.88	968	224.01	99.39	223.15	53
	224.15	872	224.27	12.1	224.37	0	224.44	0	224.52	4999	224.61	13655	224.73	2981.4	224.78	976	224.87	99.39	224.07	53
	225.07	914	225.17	12.35	225.27	0	225.37	0	225.49	5001	225.54	13803	225.63	3025.2	225.76	976	225.82	99.39	225	53
	226.01	870	226.11	11.84	226.24	0	226.31	0	226.4	5009	226.51	13803	226.57	3000.8	226.67	976	226.77	99.39	225.92	53
	226.99	816	227.04	12.28	227.13	0	227.26	0	227.31	4997	227.4	13803	227.51	3015.4	227.6	976	227.7	99.39	226.87	53
	227.87	1095	227.98	11.8	228.05	0	228.15	0	228.26	5006	228.35	13803	228.44	3005.8	228.54	976	228.63	99.39	227.79	53
	228.81	1147	228.9	14.54	229.02	0	229.11	0	229.24	4962	229.28	13803	229.37	3025.2	229.44	976	229.54	99.39	228.76	53
	229.74	1128	229.8	11.48	229.89	0	230	0	230.07	5014	230.17	13803	230.26	2986.2	230.34	976	230.42	99.39	229.63	53
	230.63	796	230.7	12.11	230.8	0	230.89	0	231	5008	231.08	13803	231.19	3020.4	231.29	976	231.39	99.39	230.52	53
	231.56	887	231.65	12.01	231.77	0	231.84	0	231.93	5000	232.04	13803	232.13	3005.8	232.23	976	232.32	99.39	231.48	53
	232.52	839	232.62	11.66	232.71	0	232.81	0	232.9	5002	232.98	13494	233.06	3010.6	233.15	982	233.27	99.39	232.42	53
	233.43	747	233.54	12.25	233.63	0	233.73	0	233.81	5000	233.9	13494	234	3000.8	234.07	982	234.16	99.39	233.34	53
	234.37	821	234.45	12.05	234.54	0	234.64	49	234.71	4988	234.79	13647	234.88	2996	234.94	971	235.02	99.39	234.27	53
	235.19	1449	235.27	13.13	235.37	0	235.46	0	235.54	4996	235.63	13647	235.75	3000.8	235.81	971	235.9	99.39	235.11	53
	236.08	1583	236.18	11.89	236.28	0	236.37	0	236.45	5013	236.54	13647	236.63	2986.2	236.71	971	236.8	99.39	236.02	53
	237.01	1536	237.07	13.27	237.17	0	237.28	0	237.36	4992	237.45	13647	237.55	3005.8	237.62	971	237.75	99.39	236.9	53
	237.89	819	237.97	11.79	238.06	0	238.15	0	238.26	5012	238.35	13647	238.41	3015.4	238.53	971	238.62	99.39	237.81	53
	238.77	908	238.86	11.96	238.96	0	239.04	0	239.13	5009	239.23	13647	239.31	3025.2	239.4	971	239.53	99.39	238.71	53
	239.68	904	239.79	11.53	239.89	0	239.98	0	240.06	5009	240.15	13647	240.27	3005.8	240.34	971	240.43	99.39	239.59	53
	240.63	875	240.73	12.23	240.82	0	240.92	0	241.01	4995	241.11	13647	241.21	3020.4	241.27	971	241.34	99.39	240.54	53
	241.5	881	241.59	11.97	241.68	0	241.78	0	241.87	4999	241.95	13647	242.03	3000.8	242.12	971	242.21	99.39	241.42	53
	242.4	899	242.48	11.88	242.57	0	242.67	0	242.76	4995	242.85	13568	242.94	2991	243.02	978	243.12	99.39	242.31	53
	243.31	792	243.38	12.27	243.48	0	243.57	0	243.65	5001	243.77	13568	243.83	3025.2	243.91	978	244.03	99.39	243.21	53
and the 2nd + 3rd log
Monday	27	April	2026	21:11:39:62060-VCID:79BA3E80F82B3E5784-802C	VCDS Version: Release 26.3.0 (x64)	Data version: 20260320 DS375.1
		G004	F0	G215	F0	G216	F0	G338	F0	G339	F0	G342	F0	G343	F0	G347	F0	G455	F0	G456	F0	G457	F0	G462	F0
Marker	TIME	Loc. IDE00021	TIME	Loc. IDE03140	TIME	Loc. IDE03141	TIME	Loc. IDE03765-ENG188621	TIME	Loc. IDE03766-ENG188621	TIME	Loc. IDE03768	TIME	Loc. IDE03769	TIME	Loc. IDE04098	TIME	Loc. IDE05346	TIME	Loc. IDE05347	TIME	Loc. IDE05348	TIME	Loc. IDE05353
	STAMP	Engine speed	STAMP	NOx sensor 1: NOx concentration	STAMP	NOx sensor 2: NOx concentration	STAMP	NOx Sensor 1: Status-Bits 0-7	STAMP	NOx sensor 2: status-Bits 0-7	STAMP	NOx sensor 1: feed voltage	STAMP	NOx sensor 2: feed voltage	STAMP	NOX Sensor	STAMP	NOx Emission NOx-Sensor 2	STAMP	NOx Emission NOx Sensor	STAMP	NOx-Sensor 2: O2-Concentration	STAMP	Measured NOx conversion
		 /min		 ppm		 ppm		 		 		 mV		 mV		 		 ppm		 ppm
Monday	27	April	2026	21:31:53:62060-VCID:79BA3E80F82B3E5784-802C	VCDS Version: Release 26.3.0 (x64)	Data version: 20260320 DS375.1
		G004	F0	G123	F0	G319	F0	G402	F0	G403	F0	G404	F0	G407	F0	G408	F0	G409	F0	G416	F0	G457	F0	G523	F0
Marker	TIME	Loc. IDE00021	TIME	Loc. IDE00558	TIME	Loc. IDE03383	TIME	Loc. IDE04673	TIME	Loc. IDE04674	TIME	Loc. IDE04675	TIME	Loc. IDE04678-ENG188621	TIME	Loc. IDE04679-ENG188621	TIME	Loc. IDE04680	TIME	Loc. IDE04687	TIME	Loc. IDE05348	TIME	Loc. IDE07524-ENG127377
	STAMP	Engine speed	STAMP	Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor)	STAMP	Exhaust mass flow of EGR	STAMP	O2 sensor 1 bank 1: duty cycle O2 heater	STAMP	O2 sensor 1 bank 1: adjusted oxygen value	STAMP	O2 sensor 1 bank 1: air flow volume	STAMP	Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-Bits 0-7	STAMP	O2 sensor 1: bank 1: status O2 signal: validity-Bits 0-7	STAMP	Oxygen sensor 1 bank 1: voltage raw value O2 signal	STAMP	Mean temperature of SCR catalyst	STAMP	NOx-Sensor 2: O2-Concentration	STAMP	Reducing agent efficiency-diagnosis releases: short-trip status-Test_Program_SCR Chk Compu Valid UBYTE
		 /min		 		 kg/h		 %		 		 g		 		 		 mV		 °C
	0.47	778	0.54	0.141 Lambda / 0.650 V	0.62	15.8	0.7	45.75	0.77	0.00209	0.86	0	0.95	1	0.03	1	0.11	651	0.21	186	0.28	0.11655	0.37	0
	1.53	777	1.61	0.141 Lambda / 0.648 V	1.69	14.9	1.77	45.83	1.85	0.00209	1.94	0	2.02	1	1.05	1	1.14	647.6	1.27	185.9	1.36	0.11655	1.46	0
	2.53	776	2.61	0.140 Lambda / 0.647 V	2.69	15.3	2.77	45.88	2.84	0.00209	2.92	0	3	1	2.11	1	2.19	648.2	2.28	185.7	2.36	0.11655	2.46	0
	3.53	780	3.62	0.140 Lambda / 0.647 V	3.7	15.9	3.78	46.35	3.87	0.00209	3.94	0	4.02	1	3.09	1	3.17	647.4	3.26	185.6	3.35	0.11634	3.46	0
	4.51	780	4.6	0.141 Lambda / 0.651 V	4.68	15.3	4.76	45.19	4.85	0.00209	4.93	0	4.99	1	4.11	1	4.2	645.6	4.27	185.7	4.35	0.11634	4.44	0
	5.55	779	5.63	0.141 Lambda / 0.650 V	5.76	15.3	5.86	45.94	5.95	0.00209	6.05	0	6.14	1	5.08	1	5.18	651.8	5.28	185.6	5.38	0.11613	5.51	0
	6.76	779	6.85	0.140 Lambda / 0.646 V	6.94	15.8	7.02	46.81	7.1	0.00209	7.19	0	7.27	1	6.26	1	6.36	648.8	6.45	185.4	6.54	0.11592	6.65	0
	7.8	784	7.89	0.141 Lambda / 0.651 V	8.01	6	8.1	46.75	8.19	0.00209	8.27	0	8.35	1	7.35	1	7.44	654.6	7.53	185.5	7.63	0.11572	7.76	0
	8.89	1026	9.01	0.121 Lambda / 0.559 V	9.11	17.1	9.19	47.1	9.27	0.00209	9.36	0	9.44	1	8.43	1	8.53	463.6	8.63	184.7	8.75	0.11572	8.82	0
	9.99	1051	10.03	0.104 Lambda / 0.447 V	10.12	14	10.19	47.58	10.27	0.00209	10.35	0	10.44	1	9.52	1	9.6	408.8	9.71	184.4	9.78	0.10421	9.88	0
	10.99	1233	11.03	0.103 Lambda / 0.445 V	11.11	16.3	11.19	48.11	11.26	0.00209	11.34	0	11.42	1	10.52	1	10.61	490.4	10.7	184.3	10.78	0.09026	10.88	0
	11.95	1440	12.01	0.112 Lambda / 0.503 V	12.09	28.3	12.18	48.82	12.26	0.00209	12.33	0	12.41	1	11.5	1	11.59	468.4	11.67	184.2	11.77	0.08734	11.85	0
	12.92	1781	13	0.111 Lambda / 0.499 V	13.09	48	13.16	49.69	13.25	0.00209	13.34	0	13.41	1	12.5	1	12.58	547.2	12.68	184	12.76	0.08614	12.84	0
	13.91	1289	14	0.091 Lambda / 0.345 V	14.08	17.1	14.16	50.95	14.26	0.00209	14.35	0	14.44	1	13.5	1	13.59	774.6	13.67	184.3	13.75	0.09005	13.84	0
	15.01	1574	15.09	0.088 Lambda / 0.320 V	15.17	30.2	15.26	50.83	15.36	0.00209	15.45	0	15.54	1	14.52	1	14.61	331.2	14.72	183.7	14.81	0.07202	14.9	0
	16.13	1839	16.25	0.101 Lambda / 0.432 V	16.3	39.2	16.38	52.6	16.46	0.00209	16.55	0	16.63	1	15.63	1	15.71	323.8	15.81	184	15.9	0.06132	16.04	0
	17.14	1965	17.25	0.125 Lambda / 0.578 V	17.3	48.1	17.37	55.92	17.45	0.00209	17.53	0	17.61	1	16.72	1	16.8	559.8	16.89	184.4	17.01	0.07707	17.06	0
	18.09	1328	18.17	0.083 Lambda / 0.271 V	18.26	20.9	18.34	53.06	18.42	0.00209	18.51	0	18.59	1	17.69	1	17.76	548	17.85	183.7	17.94	0.09603	18.02	0
	19.09	1415	19.17	0.081 Lambda / 0.256 V	19.26	24.9	19.34	50.05	19.42	0.00209	19.51	0	19.59	1	18.67	1	18.76	229.4	18.85	183.6	18.93	0.06798	19.02	0
	20.12	1515	20.21	0.084 Lambda / 0.286 V	20.3	29.7	20.38	51.84	20.5	0.00209	20.55	0	20.63	1	19.67	1	19.76	288.2	19.86	183.4	19.95	0.05157	20.03	0
	21.14	1601	21.26	0.113 Lambda / 0.509 V	21.3	31.6	21.38	51.91	21.45	0.00209	21.53	0	21.61	1	20.71	1	20.8	333.4	20.89	183.4	21.01	0.05169	21.06	0
	22.15	1466	22.26	1.157 Lambda / 1.176 V	22.3	42.4	22.38	50.83	22.51	0.00209	22.55	0	22.62	1	21.69	1	21.78	939.6	21.87	183.3	21.97	0.07993	22.06	0
	23.12	1110	23.2	0.288 Lambda / 0.945 V	23.28	27.8	23.36	50.24	23.43	0.00209	23.51	0	23.59	1	22.7	1	22.78	1100.8	22.87	183.3	22.95	0.15101	23.05	0
	24.1	1075	24.18	0.072 Lambda / 0.144 V	24.26	0.5	24.34	47.79	24.42	0.00209	24.51	0	24.59	1	23.67	1	23.76	236.2	23.85	182.8	23.93	0.16662	24.02	0
	25.11	1104	25.19	0.077 Lambda / 0.205 V	25.27	2	25.34	51.02	25.43	0.00209	25.52	0	25.6	1	24.67	1	24.77	202.6	24.85	182.7	24.94	0.04759	25.03	0
	26.11	1122	26.19	0.078 Lambda / 0.214 V	26.28	3.7	26.36	52.31	26.44	0.00209	26.52	0	26.61	1	25.69	1	25.77	224.6	25.86	182.4	25.94	0.04203	26.03	0
	27.11	1132	27.19	0.079 Lambda / 0.223 V	27.27	5.8	27.34	50.73	27.42	0.00209	27.51	0	27.59	1	26.69	1	26.77	224.4	26.86	182.3	26.94	0.04203	27.03	0
	28.11	1134	28.19	0.076 Lambda / 0.195 V	28.26	5.7	28.35	51.07	28.42	0.00209	28.52	0	28.6	1	27.67	1	27.77	229.8	27.85	182.2	27.94	0.04203	28.03	0
	29.14	1136	29.27	0.080 Lambda / 0.236 V	29.32	8	29.41	51.07	29.51	0.00209	29.61	0	29.69	1	28.69	1	28.78	198.8	28.9	182	29.01	0.04147	29.07	0
	30.22	1307	30.3	0.087 Lambda / 0.310 V	30.39	19	30.51	50.36	30.55	0.00209	30.63	0	30.76	1	29.77	1	29.85	230	29.95	182	30.03	0.04074	30.12	0
	31.27	1549	31.34	0.101 Lambda / 0.432 V	31.42	26.7	31.51	52.08	31.59	0.00209	31.67	0	31.76	1	30.8	1	30.88	378.6	31.02	182.1	31.06	0.04993	31.15	0
	32.26	1496	32.34	0.127 Lambda / 0.590 V	32.42	25.6	32.51	52.84	32.59	0.00209	32.67	0	32.76	1	31.84	1	31.92	541.2	32.03	181.8	32.11	0.06997	32.19	0
	33.27	1438	33.34	0.110 Lambda / 0.492 V	33.42	27.1	33.51	49.95	33.59	0.00209	33.67	0	33.76	1	32.85	1	32.92	526.8	33.02	181.4	33.09	0.0932	33.18	0
	34.27	1368	34.34	0.121 Lambda / 0.558 V	34.42	25.1	34.52	50.24	34.59	0.00209	34.67	0	34.77	1	33.84	1	33.92	508.8	34.02	181.3	34.09	0.09278	34.18	0
	35.29	1330	35.36	0.129 Lambda / 0.599 V	35.44	24.7	35.52	49.62	35.59	0.00209	35.68	0	35.77	1	34.84	1	34.92	575.4	35.03	181.3	35.11	0.09088	35.2	0
	36.28	1222	36.37	0.651 Lambda / 1.115 V	36.45	30.9	36.52	47.89	36.61	0.00209	36.7	0	36.77	1	35.84	1	35.92	852.8	36.03	181	36.12	0.09669	36.2	0
	37.32	1071	37.41	1.999 Lambda / 1.213 V	37.52	23.7	37.6	47.61	37.67	0.00209	37.77	0	37.85	1	36.86	1	36.95	1198.8	37.04	181.2	37.14	0.12319	37.27	0
	38.37	847	38.44	0.253 Lambda / 0.904 V	38.52	20.1	38.6	47.39	38.67	0.00209	38.77	0	38.85	1	37.92	1	38.02	1200	38.12	181.4	38.2	0.1596	38.28	0
	39.36	905	39.45	0.176 Lambda / 0.762 V	39.53	21.3	39.61	45.79	39.69	0.00209	39.77	0	39.85	1	38.92	1	39.02	815.6	39.11	180.7	39.2	0.17306	39.28	0
	40.36	1421	40.44	0.071 Lambda / 0.127 V	40.51	1.3	40.6	48.93	40.67	0.00209	40.77	0	40.85	1	39.92	1	40.02	365.8	40.1	180.5	40.19	0.16221	40.28	0
	41.39	1695	41.51	0.078 Lambda / 0.215 V	41.56	39.9	41.62	52.89	41.7	0.00209	41.78	0	41.86	1	40.93	1	41.02	240.4	41.11	180.8	41.2	0.04167	41.29	0
	42.36	1705	42.44	0.127 Lambda / 0.587 V	42.51	27.9	42.59	56.96	42.67	0.00209	42.77	0	42.84	1	41.94	1	42.01	297.2	42.11	180.6	42.19	0.04244	42.28	0
	43.36	1714	43.44	0.126 Lambda / 0.581 V	43.52	34.5	43.6	52.03	43.67	0.00209	43.77	0	43.84	1	42.92	1	43.02	620.2	43.11	180.3	43.19	0.09164	43.29	0
	44.37	1741	44.45	0.144 Lambda / 0.662 V	44.51	44.2	44.59	49.08	44.68	0.00209	44.77	0	44.84	1	43.92	1	44.02	664.4	44.11	180	44.19	0.09994	44.29	0
	45.38	1148	45.46	0.109 Lambda / 0.487 V	45.53	12.3	45.62	50.73	45.7	0.00209	45.77	0	45.85	1	44.93	1	45.01	708.2	45.11	179.9	45.2	0.10976	45.29	0
	46.37	1214	46.45	0.098 Lambda / 0.405 V	46.52	13.9	46.6	49.55	46.68	0.00209	46.77	0	46.85	1	45.93	1	46.02	440.6	46.11	180	46.2	0.10547	46.28	0
	47.37	1299	47.45	0.085 Lambda / 0.295 V	47.52	15.4	47.61	50.18	47.7	0.00209	47.78	0	47.87	1	46.93	1	47.02	408.2	47.12	179.6	47.2	0.08403	47.28	0
	48.39	1403	48.51	0.081 Lambda / 0.254 V	48.54	21.1	48.62	49.68	48.71	0.00209	48.78	0	48.86	1	47.95	1	48.02	280.2	48.11	179.5	48.2	0.06803	48.29	0
	49.37	1547	49.44	0.075 Lambda / 0.175 V	49.52	12	49.6	48.78	49.68	0.00209	49.77	0	49.84	1	48.94	1	49.01	229.4	49.11	179.4	49.2	0.05351	49.28	0
	50.34	1790	50.42	0.073 Lambda / 0.155 V	50.51	23.5	50.6	57.54	50.67	0.00209	50.77	0	50.84	1	49.92	1	50.01	161	50.1	180.2	50.18	0.03478	50.27	0
	51.32	2099	51.41	0.078 Lambda / 0.221 V	51.51	42.6	51.59	63.22	51.68	0.00209	51.78	0	51.87	1	50.92	1	51.01	190.6	51.1	180.6	51.18	0.0323	51.25	0
	52.46	2496	52.54	0.082 Lambda / 0.260 V	52.64	48.3	52.77	67.76	52.83	0.00209	52.91	0	53.02	1	51.96	1	52.06	249	52.16	181.2	52.27	0.03671	52.37	0
	53.56	2128	53.65	0.116 Lambda / 0.529 V	53.77	2.5	53.85	67.61	53.95	0.00209	54.03	0	54.13	1	53.1	1	53.2	445	53.28	182.1	53.37	0.06449	53.47	0
	54.7	2192	54.79	0.080 Lambda / 0.245 V	54.87	56	54.95	63.7	55.03	0.00209	55.11	0	55.18	1	54.21	1	54.31	305.6	54.41	182.3	54.52	0.06542	54.61	0
	55.68	2365	55.76	0.081 Lambda / 0.248 V	55.84	73.7	55.92	65.94	56.01	0.00209	56.09	0	56.17	1	55.27	1	55.34	248.6	55.43	183	55.52	0.04842	55.6	0
	56.67	2479	56.76	0.101 Lambda / 0.430 V	56.84	70	56.92	64.82	57.01	0.00209	57.09	0	57.17	1	56.26	1	56.34	258.8	56.43	183.7	56.51	0.04741	56.6	0
	57.68	2070	57.76	0.091 Lambda / 0.352 V	57.84	0.5	57.92	59.9	58.01	0.00209	58.09	0	58.17	1	57.26	1	57.34	233.8	57.43	184	57.52	0.05345	57.6	0
	58.7	2171	58.77	0.096 Lambda / 0.388 V	58.84	0.6	58.93	67.33	59.02	0.00209	59.09	0	59.17	1	58.27	1	58.34	390.4	58.44	185.4	58.52	0.06126	58.6	0
	59.68	2266	59.77	0.101 Lambda / 0.431 V	59.86	0.6	59.94	66.28	60.02	0.00209	60.09	0	60.17	1	59.27	1	59.34	417.8	59.44	186.7	59.52	0.0655	59.6	0
	60.69	1985	60.77	0.104 Lambda / 0.450 V	60.84	-4.9	60.93	68.04	61.02	0.00209	61.12	0	61.18	1	60.27	1	60.34	435.4	60.43	188.3	60.51	0.06916	60.6	0
	61.7	2016	61.77	0.094 Lambda / 0.373 V	61.85	0.5	61.93	59.32	62.02	0.00209	62.1	0	62.18	1	61.27	1	61.35	273.6	61.44	189.5	61.52	0.05641	61.61	0
	62.7	2075	62.77	0.095 Lambda / 0.384 V	62.84	0.6	62.93	65.85	63.02	0.00209	63.1	0	63.18	1	62.26	1	62.35	381.2	62.44	191	62.52	0.06161	62.61	0
	63.7	2129	63.77	0.100 Lambda / 0.418 V	63.85	0.8	63.93	64.62	64.02	0.00209	64.1	0	64.18	1	63.27	1	63.35	400.2	63.44	192.5	63.52	0.06475	63.61	0
	64.7	2166	64.77	0.107 Lambda / 0.474 V	64.85	56	64.93	66.42	65.02	0.00209	65.11	0	65.2	1	64.27	1	64.35	482.8	64.44	194.4	64.52	0.06983	64.61	0
	65.71	2180	65.78	0.096 Lambda / 0.394 V	65.87	58.6	65.95	57.31	66.03	0.00209	66.12	0	66.18	1	65.28	1	65.37	357.6	65.46	195.1	65.53	0.07355	65.63	0
	66.7	2180	66.77	0.103 Lambda / 0.441 V	66.85	57.5	66.93	56.74	67.02	0.00209	67.1	0	67.18	1	66.26	1	66.34	436.4	66.43	195.5	66.52	0.07024	66.6	0
	67.69	2179	67.76	0.104 Lambda / 0.450 V	67.84	57	67.92	53.4	68	0.00209	68.08	0	68.16	1	67.27	1	67.34	433.6	67.43	196	67.52	0.07502	67.61	0
	68.69	2173	68.76	0.107 Lambda / 0.474 V	68.84	48.4	68.93	56.04	69.01	0.00209	69.09	0	69.17	1	68.27	1	68.34	467.2	68.44	196.5	68.52	0.07724	68.6	0
	69.71	2160	69.78	0.104 Lambda / 0.450 V	69.87	54.2	69.94	52.82	70.02	0.00209	70.09	0	70.17	1	69.26	1	69.35	477	69.43	196.9	69.52	0.08136	69.62	0
	70.67	2152	70.76	0.083 Lambda / 0.268 V	70.84	68.4	70.92	53.38	71.02	0.00209	71.09	0	71.17	1	70.25	1	70.33	305	70.41	197.2	70.52	0.07916	70.6	0
	71.69	2162	71.77	0.078 Lambda / 0.213 V	71.84	44.3	71.92	60.98	72.01	0.00209	72.09	0	72.18	1	71.27	1	71.34	246.6	71.43	198.3	71.52	0.04434	71.6	0
	72.7	2191	72.77	0.089 Lambda / 0.332 V	72.84	0.4	72.93	66.37	73.01	0.00209	73.09	0	73.18	1	72.26	1	72.34	249.8	72.43	200.1	72.51	0.04178	72.61	0
	73.69	2214	73.77	0.094 Lambda / 0.375 V	73.86	0.5	73.96	65.63	74.04	0.00209	74.13	0	74.27	1	73.27	1	73.35	334	73.44	202.8	73.51	0.05335	73.61	0
	74.81	2237	74.9	0.097 Lambda / 0.400 V	75.02	57.7	75.1	65.26	75.2	0.00209	75.29	0	75.38	1	74.32	1	74.41	395.6	74.53	205.7	74.62	0.06252	74.72	0
	75.9	2239	76.02	0.081 Lambda / 0.249 V	76.06	69.8	76.14	59.9	76.21	0.00209	76.29	0	76.37	1	75.52	1	75.56	289	75.65	207.8	75.77	0.06333	75.82	0
	76.87	2225	76.95	0.101 Lambda / 0.429 V	77.03	57.4	77.11	58.63	77.19	0.00209	77.28	0	77.35	1	76.45	1	76.53	442.2	76.61	209.1	76.68	0.05683	76.79	0
	77.86	2193	77.95	0.107 Lambda / 0.473 V	78.04	46.7	78.14	55.82	78.23	0.00209	78.32	0	78.41	1	77.42	1	77.53	429.6	77.61	209.8	77.68	0.07018	77.78	0
	78.97	2147	79.05	0.128 Lambda / 0.591 V	79.13	44.3	79.21	53.86	79.3	0.00209	79.38	0	79.47	1	78.53	1	78.58	503	78.67	210.2	78.79	0.07811	78.89	0
	80.05	2098	80.13	0.124 Lambda / 0.575 V	80.21	43	80.3	50.53	80.38	0.00209	80.46	0	80.55	1	79.55	1	79.63	577.8	79.73	210.2	79.83	0.09649	79.92	0
	81.08	2054	81.16	0.125 Lambda / 0.576 V	81.28	41.8	81.33	52.17	81.41	0.00209	81.53	0	81.58	1	80.63	1	80.72	583.2	80.81	210.9	80.9	0.09777	81.04	0
	82.13	2012	82.22	0.121 Lambda / 0.558 V	82.3	40.9	82.38	51.87	82.46	0.00209	82.55	0	82.63	1	81.66	1	81.78	556.8	81.84	211	81.93	0.09895	82.05	0
	83.14	1974	83.22	0.120 Lambda / 0.551 V	83.3	39.8	83.37	50.89	83.46	0.00209	83.55	0	83.62	1	82.71	1	82.78	547.2	82.87	211.5	82.95	0.09874	83.04	0
	84.12	1944	84.2	0.120 Lambda / 0.554 V	84.29	38.3	84.37	51.31	84.45	0.00209	84.53	0	84.61	1	83.7	1	83.78	559.8	83.86	212	83.93	0.09833	84.04	0
	85.12	1919	85.2	0.115 Lambda / 0.526 V	85.28	37	85.36	50	85.45	0.00209	85.53	0	85.61	1	84.69	1	84.78	544.8	84.87	212.1	84.95	0.09833	85.04	0
	86.12	1897	86.21	0.111 Lambda / 0.501 V	86.28	35.6	86.37	50.33	86.43	0.00209	86.53	0	86.62	1	85.68	1	85.78	505.2	85.86	213.1	85.93	0.09589	86.04	0
	87.14	1882	87.22	0.108 Lambda / 0.481 V	87.3	34.8	87.37	50.33	87.45	0.00209	87.53	0	87.61	1	86.7	1	86.78	480.4	86.88	213.8	86.96	0.0914	87.04	0
	88.13	1870	88.21	0.108 Lambda / 0.477 V	88.28	34.4	88.35	50.97	88.43	0.00209	88.53	0	88.62	1	87.69	1	87.78	473.8	87.87	214.4	87.96	0.08761	88.04	0
	89.13	1862	89.21	0.108 Lambda / 0.480 V	89.28	34.9	89.37	51.16	89.44	0.00209	89.53	0	89.62	1	88.69	1	88.78	477	88.89	215.2	88.97	0.08643	89.05	0
	90.13	1855	90.21	0.109 Lambda / 0.482 V	90.28	35.7	90.37	51.73	90.44	0.00209	90.53	0	90.62	1	89.69	1	89.78	475.4	89.88	215.9	89.96	0.08572	90.04	0
	91.13	1851	91.21	0.108 Lambda / 0.481 V	91.28	36	91.37	50.64	91.45	0.00209	91.53	0	91.62	1	90.69	1	90.78	477.2	90.88	216.9	90.96	0.0855	91.05	0
	92.13	1855	92.21	0.109 Lambda / 0.484 V	92.28	36.4	92.36	50.96	92.43	0.00209	92.53	0	92.61	1	91.7	1	91.78	483.8	91.88	217.7	91.96	0.0855	92.04	0
	93.13	1858	93.22	0.109 Lambda / 0.486 V	93.3	37.1	93.37	51.05	93.45	0.00209	93.55	0	93.62	1	92.69	1	92.78	491.2	92.86	218.4	92.93	0.0855	93.04	0
	94.12	1806	94.21	0.255 Lambda / 0.906 V	94.28	41.7	94.36	49.45	94.44	0.00209	94.53	0	94.62	1	93.7	1	93.78	489.2	93.87	219	93.95	0.0855	94.04	0
	95.12	1818	95.21	1.999 Lambda / 1.232 V	95.28	48.7	95.35	48.34	95.46	0.00209	95.55	0	95.62	1	94.68	1	94.78	1210.6	94.86	218.4	94.93	0.14642	95.05	0
	96.16	1792	96.24	1.999 Lambda / 1.242 V	96.31	0.5	96.39	49.12	96.46	0.00209	96.54	0	96.63	1	95.7	1	95.79	1246.6	95.9	220.4	95.99	0.18832	96.07	0
	97.18	1773	97.3	1.999 Lambda / 1.256 V	97.36	0.8	97.46	54.33	97.56	0.00209	97.65	0	97.72	1	96.71	1	96.79	1252.4	96.89	221.4	96.97	0.19597	97.07	0
	98.3	1756	98.32	1.999 Lambda / 1.250 V	98.41	1.2	98.49	55.16	98.56	0.00209	98.65	0	98.73	1	97.79	1	97.89	1258	97.98	222.5	98.07	0.19864	98.17	0
	99.23	1741	99.3	1.999 Lambda / 1.251 V	99.38	1.2	99.46	54.96	99.55	0.00209	99.63	0	99.71	1	98.8	1	98.88	1253	98.97	223.7	99.05	0.19989	99.14	0
	100.23	1730	100.31	1.999 Lambda / 1.257 V	100.4	1.3	100.48	55.09	100.54	0.00209	100.63	0	100.71	1	99.8	1	99.88	1253.2	99.97	224.6	100.05	0.20068	100.14	0
	101.23	1724	101.3	1.999 Lambda / 1.249 V	101.38	1.4	101.46	55.81	101.55	0.00209	101.63	0	101.71	1	100.8	1	100.88	1256.6	100.97	225.6	101.04	0.20113	101.14	0
	102.23	1719	102.3	1.999 Lambda / 1.251 V	102.39	1.3	102.48	56.28	102.57	0.00209	102.67	0	102.8	1	101.79	1	101.88	1250.4	101.97	226.4	102.05	0.20155	102.15	0
	103.3	1660	103.37	1.999 Lambda / 1.245 V	103.45	1.2	103.54	56	103.62	0.00209	103.7	0	103.79	1	102.83	1	102.92	1253.4	103.06	227.7	103.09	0.20196	103.18	0
	104.31	1881	104.4	1.999 Lambda / 1.264 V	104.48	2.6	104.55	56.42	104.62	0.00209	104.71	0	104.8	1	103.88	1	103.96	1259.2	104.06	228.2	104.15	0.20227	104.24	0
	105.31	1741	105.4	1.999 Lambda / 1.251 V	105.48	1.1	105.55	58.65	105.63	0.00209	105.7	0	105.8	1	104.89	1	104.98	1259.8	105.06	230.1	105.15	0.20276	105.24	0
	106.3	2045	106.39	1.999 Lambda / 1.269 V	106.48	2.1	106.55	58.55	106.64	0.00209	106.72	0	106.8	1	105.87	1	105.95	1264	106.05	230.8	106.12	0.20278	106.22	0
	107.31	1867	107.39	1.999 Lambda / 1.261 V	107.47	1.1	107.54	60.4	107.63	0.00209	107.71	0	107.79	1	106.87	1	106.96	1265.4	107.06	232.3	107.14	0.2032	107.23	0
	108.31	1837	108.39	1.999 Lambda / 1.261 V	108.47	1.4	108.55	56.9	108.62	0.00209	108.7	0	108.79	1	107.88	1	107.95	1248.6	108.06	232.6	108.14	0.2032	108.23	0
	109.29	2133	109.37	1.999 Lambda / 1.271 V	109.45	1.6	109.54	62.99	109.63	0.00209	109.7	0	109.79	1	108.87	1	108.95	1270.2	109.05	234.6	109.12	0.2034	109.21	0
	110.29	1862	110.38	1.999 Lambda / 1.258 V	110.46	1.2	110.53	61.11	110.62	0.00209	110.7	0	110.8	1	109.87	1	109.96	1265.4	110.06	235.6	110.14	0.20361	110.22	0
	111.3	1777	111.38	1.999 Lambda / 1.262 V	111.46	1.2	111.56	57.9	111.65	0.00209	111.74	0	111.81	1	110.88	1	110.95	1261.2	111.05	236.5	111.13	0.20361	111.22	0
	112.32	1809	112.4	0.158 Lambda / 0.711 V	112.49	49.6	112.56	55.5	112.66	0.00209	112.75	0	112.84	1	111.89	1	111.97	930.2	112.07	235.3	112.16	0.20188	112.25	0
	113.43	1388	113.55	0.086 Lambda / 0.303 V	113.6	14.4	113.68	55	113.76	0.00209	113.84	0	113.94	1	112.92	1	113.02	273.2	113.11	237.3	113.21	0.09835	113.34	0
	114.52	1464	114.61	0.075 Lambda / 0.177 V	114.69	14.5	114.81	52.28	114.85	0.00209	114.94	0	115.06	1	114.07	1	114.13	254	114.23	237.5	114.32	0.06188	114.43	0
	115.57	1590	115.67	0.077 Lambda / 0.209 V	115.75	18.4	115.83	58.07	115.91	0.00209	115.99	0	116.07	1	115.1	1	115.19	172.6	115.32	238.9	115.38	0.04227	115.48	0
	116.61	1729	116.7	0.089 Lambda / 0.333 V	116.81	0.8	116.86	61.57	116.94	0.00209	117.06	0	117.09	1	116.16	1	116.24	171.2	116.34	240.6	116.43	0.03689	116.57	0
	117.6	1884	117.67	0.093 Lambda / 0.369 V	117.75	28.8	117.82	67.48	117.9	0.00209	117.98	0	118.06	1	117.17	1	117.25	397.6	117.35	243.5	117.42	0.06105	117.51	0
	118.58	2036	118.67	0.081 Lambda / 0.256 V	118.76	53.7	118.83	65.12	118.91	0.00209	118.98	0	119.07	1	118.15	1	118.22	297.2	118.32	244.2	118.41	0.06051	118.5	0
	119.61	2184	119.7	0.081 Lambda / 0.250 V	119.81	77.5	119.85	65.09	119.94	0.00209	120.06	0	120.12	1	119.16	1	119.25	245.8	119.35	245.4	119.43	0.04884	119.52	0
	120.61	2317	120.7	0.081 Lambda / 0.247 V	120.81	81.3	120.86	64.04	120.94	0.00209	121.06	0	121.11	1	120.19	1	120.3	237	120.35	246.4	120.44	0.04646	120.57	0
	121.61	1931	121.7	0.101 Lambda / 0.431 V	121.8	29.1	121.84	63.16	121.92	0.00209	122	0	122.08	1	121.19	1	121.31	265.6	121.35	247.5	121.44	0.04575	121.57	0
	122.58	1952	122.66	0.084 Lambda / 0.281 V	122.73	56.5	122.81	60.64	122.9	0.00209	122.97	0	123.06	1	122.16	1	122.23	325.2	122.32	247.2	122.4	0.06463	122.5	0
	123.57	2021	123.65	0.082 Lambda / 0.259 V	123.74	62.6	123.81	58.9	123.89	0.00209	123.97	0	124.07	1	123.14	1	123.22	264.6	123.32	247.8	123.4	0.05325	123.49	0
	124.67	2087	124.74	0.085 Lambda / 0.290 V	124.82	71	124.9	59.29	124.98	0.00209	125.06	0	125.14	1	124.16	1	124.26	270.2	124.36	248.6	124.46	0.04989	124.58	0
	125.65	1816	125.73	0.098 Lambda / 0.405 V	125.82	26.7	125.92	58.51	126.01	0.00209	126.11	0	126.19	1	125.21	1	125.31	294	125.39	249.1	125.46	0.05055	125.57	0
	126.68	1806	126.74	0.086 Lambda / 0.304 V	126.82	39.3	126.91	55.94	126.98	0.00209	127.07	0	127.16	1	126.3	1	126.34	333.6	126.43	249	126.55	0.06763	126.6	0
	127.68	1840	127.81	0.083 Lambda / 0.268 V	127.9	48	127.98	54.48	128.07	0.00209	128.15	0	128.23	1	127.24	1	127.34	243	127.44	248.9	127.55	0.05598	127.61	0
	128.82	1869	128.88	0.094 Lambda / 0.374 V	128.95	43.8	129.06	58.66	129.14	0.00209	129.21	0	129.31	1	128.31	1	128.38	377	128.49	249.1	128.59	0.05395	128.69	0
	129.88	1878	129.96	0.120 Lambda / 0.552 V	130.08	32.3	130.16	53.62	130.24	0.00209	130.34	0	130.43	1	129.39	1	129.46	357.6	129.57	248.8	129.67	0.0619	129.78	0
	130.95	1880	131.06	0.109 Lambda / 0.486 V	131.11	37.7	131.19	50.91	131.31	0.00209	131.34	0	131.42	1	130.56	1	130.6	515.6	130.69	248.1	130.8	0.08868	130.86	0
	131.93	1879	132	0.113 Lambda / 0.510 V	132.08	38.3	132.16	49.89	132.23	0.00209	132.31	0	132.39	1	131.5	1	131.58	477.8	131.67	248.1	131.75	0.0887	131.84	0
	132.93	1879	133.01	0.114 Lambda / 0.518 V	133.08	37.4	133.17	50.85	133.25	0.00209	133.33	0	133.42	1	132.47	1	132.57	523.8	132.67	248.3	132.75	0.08817	132.84	0
	133.92	1843	134	1.688 Lambda / 1.201 V	134.08	47.2	134.16	48.58	134.24	0.00209	134.31	0	134.39	1	133.5	1	133.58	990.6	133.67	247.5	133.75	0.08951	133.84	0
	134.9	1809	134.98	1.999 Lambda / 1.236 V	135.06	19.2	135.14	47.44	135.22	0.00209	135.31	0	135.39	1	134.47	1	134.56	1231.6	134.65	247.5	134.73	0.17825	134.82	0
	135.9	1778	135.98	1.999 Lambda / 1.248 V	136.06	0.7	136.14	51.2	136.21	0.00209	136.31	0	136.39	1	135.47	1	135.56	1241.4	135.64	249	135.73	0.19434	135.82	0
	136.91	1747	136.98	1.999 Lambda / 1.248 V	137.06	1	137.15	55.12	137.22	0.00209	137.31	0	137.39	1	136.48	1	136.57	1252.4	136.66	248.9	136.73	0.19833	136.82	0
	137.9	1720	137.98	1.999 Lambda / 1.247 V	138.06	1.1	138.14	54.86	138.22	0.00209	138.31	0	138.39	1	137.47	1	137.56	1247	137.66	248.8	137.73	0.20029	137.82	0
	138.9	1691	138.98	1.999 Lambda / 1.254 V	139.06	1.2	139.14	54.65	139.21	0.00209	139.31	0	139.39	1	138.46	1	138.56	1255	138.65	248.8	138.73	0.20111	138.82	0
	139.9	1663	139.98	1.999 Lambda / 1.247 V	140.06	1.4	140.13	54.44	140.2	0.00209	140.31	0	140.4	1	139.47	1	139.56	1255.6	139.65	248.6	139.73	0.20171	139.83	0
	140.9	1631	140.98	1.999 Lambda / 1.243 V	141.06	1.4	141.14	54.91	141.22	0.00209	141.31	0	141.38	1	140.48	1	140.56	1246.2	140.64	248.7	140.71	0.20196	140.82	0
	141.94	1554	142.06	1.999 Lambda / 1.250 V	142.1	1.4	142.2	53.78	142.32	0.00209	142.41	0	142.49	1	141.49	1	141.57	1252.4	141.68	248.9	141.76	0.20237	141.86	0
	143.06	1437	143.11	1.999 Lambda / 1.239 V	143.21	1.3	143.32	54.06	143.41	0.00209	143.49	0	143.57	1	142.59	1	142.69	1241.2	142.81	248.5	142.84	0.20258	142.93	0
	144.11	1270	144.19	1.999 Lambda / 1.232 V	144.31	0.8	144.37	52.74	144.44	0.00209	144.56	0	144.59	1	143.67	1	143.76	1243.8	143.86	247.8	143.95	0.20258	144.07	0
	145.09	1232	145.17	1.999 Lambda / 1.237 V	145.25	16.3	145.33	51.1	145.41	0.00209	145.49	0	145.56	1	144.67	1	144.75	1234.2	144.85	247.3	144.92	0.20276	145.02	0
	146.08	1241	146.16	1.999 Lambda / 1.225 V	146.24	30.8	146.31	50.21	146.39	0.00209	146.47	0	146.56	1	145.64	1	145.72	1234.4	145.83	246.6	145.91	0.20278	145.99	0
	147.09	1310	147.15	1.999 Lambda / 1.230 V	147.23	35.4	147.31	48.51	147.39	0.00209	147.47	0	147.56	1	146.64	1	146.72	1217.4	146.82	246.1	146.9	0.20278	146.99	0
	148.06	1136	148.14	1.999 Lambda / 1.229 V	148.21	29.5	148.3	47.74	148.37	0.00209	148.45	0	148.56	1	147.64	1	147.72	1231.6	147.8	245.9	147.87	0.20278	147.96	0
	149.07	1399	149.15	1.999 Lambda / 1.233 V	149.23	40.1	149.31	46.78	149.39	0.00209	149.46	0	149.56	1	148.64	1	148.73	1234.4	148.82	245.2	148.9	0.20278	148.99	0
	150.07	1385	150.16	0.440 Lambda / 1.050 V	150.23	42.5	150.31	47.86	150.4	0.00209	150.46	0	150.57	1	149.64	1	149.71	1233.2	149.82	244.7	149.9	0.20299	149.99	0
	151.11	1427	151.19	0.156 Lambda / 0.704 V	151.3	38	151.35	48.32	151.44	0.00209	151.56	0	151.61	1	150.66	1	150.74	876.4	150.84	244.8	150.93	0.19785	151.07	0
	152.12	1525	152.19	0.118 Lambda / 0.539 V	152.31	38.3	152.35	49.09	152.45	0.00209	152.56	0	152.61	1	151.7	1	151.81	602.6	151.86	244.5	151.94	0.14948	152.06	0
	153.12	1633	153.21	0.109 Lambda / 0.482 V	153.32	43.3	153.41	49.97	153.5	0.00209	153.59	0	153.68	1	152.69	1	152.81	524.2	152.86	244	152.95	0.1121	153.07	0
	154.26	1762	154.36	0.099 Lambda / 0.416 V	154.44	47	154.56	51.25	154.6	0.00209	154.7	0	154.83	1	153.81	1	153.86	423.4	153.95	243.9	154.07	0.09347	154.17	0
	155.34	1882	155.43	0.117 Lambda / 0.534 V	155.56	48	155.6	52.67	155.7	0.00209	155.82	0	155.92	1	154.9	1	154.98	493.2	155.08	244.7	155.16	0.08073	155.26	0
	156.51	1429	156.58	0.088 Lambda / 0.323 V	156.66	29.2	156.74	51.56	156.83	0.00209	156.92	0	157	1	156.01	1	156.1	519.8	156.2	244	156.32	0.10945	156.42	0
	157.56	1526	157.61	0.086 Lambda / 0.306 V	157.7	33.8	157.81	50.09	157.86	0.00209	157.95	0	158.06	1	157.08	1	157.16	305	157.25	244.1	157.34	0.06883	157.45	0
	158.57	1616	158.66	0.101 Lambda / 0.431 V	158.74	34.3	158.82	51.02	158.91	0.00209	158.98	0	159.07	1	158.1	1	158.19	341.6	158.32	244.3	158.36	0.06128	158.45	0
	159.61	1679	159.7	0.146 Lambda / 0.669 V	159.81	33.5	159.85	52.42	159.95	0.00209	160.06	0	160.1	1	159.16	1	159.24	557.8	159.34	244	159.43	0.07597	159.57	0
	160.62	1302	160.72	1.644 Lambda / 1.200 V	160.82	37.5	160.91	47.8	160.99	0.00209	161.08	0	161.16	1	160.2	1	160.31	1119	160.36	244.3	160.45	0.1005	160.57	0
	161.68	1314	161.76	1.999 Lambda / 1.228 V	161.83	26.3	161.92	47.24	162.01	0.00209	162.08	6.1	162.16	1	161.24	1	161.33	1224	161.42	244.5	161.5	0.1673	161.59	0
	162.68	1300	162.76	1.999 Lambda / 1.247 V	162.83	0.4	162.92	47.44	163.01	0.00209	163.08	29	163.17	1	162.25	1	162.33	1242.8	162.43	243.2	162.51	0.19125	162.59	0
	163.68	1253	163.76	1.999 Lambda / 1.246 V	163.83	0.6	163.92	50.65	164.01	0.00209	164.08	51.2	164.17	1	163.25	1	163.33	1246	163.43	243.4	163.51	0.1975	163.6	0
	164.66	1309	164.74	1.999 Lambda / 1.242 V	164.81	16	164.9	50.57	164.97	0.00209	165.07	0	165.16	1	164.26	1	164.32	1243.8	164.41	243.5	164.49	0.19965	164.58	0
	165.71	1305	165.83	1.999 Lambda / 1.236 V	165.92	34	166.02	48.99	166.11	0.00209	166.2	1.8	166.33	1	165.25	1	165.33	1238.4	165.42	243	165.52	0.20072	165.62	0
	166.88	1497	166.97	1.999 Lambda / 1.252 V	167.08	0.8	167.17	47.98	167.25	0.00209	167.34	29.8	167.43	1	166.41	1	166.5	1244.2	166.59	242.6	166.69	0.2015	166.82	0
	168.02	1366	168.11	1.999 Lambda / 1.233 V	168.21	12.9	168.31	52.78	168.38	0.00209	168.46	0	168.56	1	167.52	1	167.61	1250.2	167.72	243.5	167.82	0.20216	167.93	0
	169.07	1389	169.16	0.121 Lambda / 0.556 V	169.24	24.9	169.31	50.74	169.39	0.00209	169.47	0	169.56	1	168.63	1	168.71	834.8	168.82	243	168.91	0.20045	169	0
	170.13	1500	170.22	0.111 Lambda / 0.497 V	170.34	29.2	170.44	51.25	170.53	0.00209	170.63	0	170.72	1	169.64	1	169.73	495.8	169.82	243.2	169.93	0.11448	170.03	0
	171.27	1594	171.35	0.117 Lambda / 0.534 V	171.45	35.6	171.52	50.47	171.6	0.00209	171.69	0	171.77	1	170.84	1	170.92	527.4	171.01	243	171.09	0.09665	171.2	0
	172.33	1622	172.38	0.166 Lambda / 0.735 V	172.48	41.2	172.59	49.87	172.69	0.00209	172.77	0	172.85	1	171.86	1	171.94	565.8	172.03	243	172.12	0.09605	172.2	0
	173.37	1264	173.44	1.453 Lambda / 1.192 V	173.52	35.3	173.6	48.98	173.67	0.00209	173.75	0	173.83	1	172.94	1	173.02	1111.4	173.11	243.3	173.19	0.11568	173.28	0
	174.34	1305	174.42	1.999 Lambda / 1.230 V	174.51	37.5	174.58	46.3	174.67	0.00209	174.75	0	174.84	1	173.91	1	173.99	1219.8	174.09	243.3	174.17	0.15801	174.26	0
	175.34	1202	175.43	1.999 Lambda / 1.231 V	175.51	32.1	175.58	47.92	175.66	0.00209	175.74	0	175.83	1	174.94	1	175.02	1230.4	175.1	243.1	175.17	0.18537	175.27	0
	176.34	1124	176.43	1.999 Lambda / 1.231 V	176.51	28.1	176.58	47.39	176.66	0.00209	176.75	0	176.84	1	175.91	1	175.99	1231	176.09	242.9	176.18	0.19247	176.27	0
	177.34	1040	177.43	1.999 Lambda / 1.230 V	177.5	23.5	177.59	46.45	177.67	0.00209	177.76	0	177.83	1	176.93	1	177.01	1231	177.09	242	177.18	0.19531	177.27	0
	178.34	965	178.43	1.999 Lambda / 1.230 V	178.51	21.1	178.59	47.12	178.68	0.00209	178.76	0	178.83	1	177.91	1	178	1230.6	178.1	241.4	178.18	0.19678	178.27	0
	179.36	1095	179.44	0.207 Lambda / 0.828 V	179.52	27.9	179.6	46.33	179.68	0.00209	179.76	0	179.84	1	178.92	1	179.01	1096.6	179.1	242.5	179.19	0.19802	179.29	0
	180.34	1456	180.43	0.106 Lambda / 0.465 V	180.51	25.7	180.57	46.29	180.66	0.00209	180.74	0	180.82	1	179.92	1	180.01	616.6	180.09	240.8	180.18	0.19422	180.26	0
	181.34	1627	181.43	0.124 Lambda / 0.573 V	181.5	39.4	181.59	49.25	181.69	0.00209	181.78	0	181.87	1	180.9	1	180.98	526	181.09	240.6	181.18	0.10512	181.26	0
	182.46	1794	182.58	0.120 Lambda / 0.551 V	182.64	49.3	182.74	49.92	182.84	0.00209	182.94	0	183.02	1	181.97	1	182.07	578	182.17	240.7	182.26	0.1021	182.36	0
	183.58	1707	183.64	0.209 Lambda / 0.832 V	183.73	23.5	183.83	49.61	183.91	0.00209	184	0	184.08	1	183.1	0	183.19	545.6	183.29	241.4	183.36	0.10079	183.45	0
	184.62	1276	184.72	0.191 Lambda / 0.795 V	184.84	30.9	184.93	49.92	185	0.00209	185.07	0	185.15	1	184.17	1	184.25	615	184.34	241.2	184.44	0.13151	184.53	0
	185.65	1232	185.74	0.242 Lambda / 0.888 V	185.83	34.1	185.91	46.49	185.99	0.00209	186.07	0	186.16	1	185.23	1	185.32	836.4	185.42	241.4	185.49	0.12255	185.58	0
	186.67	1184	186.76	1.837 Lambda / 1.205 V	186.84	30.4	186.91	47.58	186.99	0.00209	187.08	0	187.15	1	186.24	1	186.32	1159.4	186.41	241.2	186.48	0.1354	186.58	0
	187.65	1131	187.73	1.999 Lambda / 1.227 V	187.83	27.4	187.91	46.92	187.99	0.00209	188.08	0	188.17	1	187.23	1	187.33	1222.6	187.42	240.8	187.49	0.16676	187.58	0
	188.69	1072	188.78	1.999 Lambda / 1.229 V	188.86	25.5	188.95	46.89	189.02	0.00209	189.1	0	189.2	1	188.26	1	188.33	1228.4	188.43	241.5	188.51	0.18504	188.6	0
	189.71	1077	189.85	0.168 Lambda / 0.739 V	189.93	12.8	190.01	46.68	190.08	0.00209	190.17	0	190.26	1	189.27	1	189.36	1222.6	189.46	241	189.57	0.19135	189.63	0
	190.77	1104	190.85	0.126 Lambda / 0.584 V	190.93	24.9	191	47.08	191.08	0.00209	191.16	0	191.24	1	190.33	1	190.42	471.8	190.52	239.9	190.59	0.18237	190.69	0
	191.76	1026	191.84	1.077 Lambda / 1.171 V	191.91	22	191.99	47.59	192.07	0.00209	192.15	0	192.24	1	191.33	1	191.41	1077.8	191.5	240.2	191.57	0.11934	191.67	0
	192.76	871	192.84	0.393 Lambda / 1.026 V	192.91	20.2	192.99	46.82	193.08	0.00209	193.16	0	193.23	1	192.32	1	192.41	1214	192.5	240.1	192.59	0.13116	192.67	0
	193.76	885	193.84	0.274 Lambda / 0.930 V	193.93	19.3	194.01	46.2	194.08	0.00209	194.16	0	194.24	1	193.33	1	193.41	994.6	193.5	239.9	193.58	0.16244	193.67	0
	194.76	1071	194.84	0.154 Lambda / 0.697 V	194.93	18.1	195.01	45.71	195.09	0.00209	195.18	0	195.26	1	194.33	1	194.41	680.8	194.5	239	194.58	0.17037	194.68	0
	195.77	1249	195.84	0.099 Lambda / 0.412 V	195.92	14.6	196.01	46.31	196.09	0.00209	196.16	0	196.24	1	195.33	1	195.42	550.8	195.52	239	195.59	0.14747	195.69	0
	196.75	1412	196.83	0.111 Lambda / 0.497 V	196.91	27.9	196.99	49.61	197.08	0.00209	197.15	0	197.24	1	196.32	1	196.41	373	196.5	238.6	196.58	0.09133	196.68	0
	197.76	1442	197.83	0.162 Lambda / 0.722 V	197.91	39	197.99	49.57	198.08	0.00209	198.16	0	198.24	1	197.33	1	197.41	711	197.5	239	197.58	0.08134	197.67	0
	198.75	1355	198.84	0.238 Lambda / 0.882 V	198.91	40.3	198.99	47.7	199.08	0.00209	199.16	0	199.24	1	198.33	1	198.41	839.8	198.5	238.6	198.58	0.11561	198.68	0
	199.76	1098	199.83	1.358 Lambda / 1.188 V	199.91	26.4	199.99	47.79	200.08	0.00209	200.16	0	200.24	1	199.32	1	199.4	1116.8	199.48	238.3	199.58	0.13199	199.67	0
	200.78	990	200.87	0.175 Lambda / 0.759 V	200.95	24.2	201.08	46.97	201.11	0.00209	201.2	0	201.28	1	200.33	1	200.42	1072.8	200.52	238.7	200.59	0.15397	200.69	0
	201.83	922	201.91	0.231 Lambda / 0.872 V	201.98	22.5	202.07	46.29	202.15	0.00209	202.23	0	202.32	1	201.37	1	201.45	686.2	201.59	238.7	201.62	0.17281	201.72	0
	202.84	867	202.92	0.231 Lambda / 0.870 V	203	18.8	203.08	48.9	203.15	0.00209	203.24	0	203.32	1	202.41	1	202.49	915.4	202.59	238.2	202.68	0.15911	202.77	0
	203.84	887	203.93	0.183 Lambda / 0.777 V	204.01	19.9	204.08	45.48	204.15	0.00209	204.24	0	204.33	1	203.41	1	203.49	771.8	203.59	239.6	203.68	0.15112	203.77	0
	204.84	898	204.93	0.180 Lambda / 0.770 V	205.01	21.2	205.08	45.33	205.16	0.00209	205.24	0	205.33	1	204.41	1	204.49	774.2	204.59	238.1	204.68	0.15093	204.77	0
	205.83	851	205.91	0.158 Lambda / 0.711 V	205.98	18.7	206.06	46.42	206.15	0.00209	206.22	0	206.33	1	205.41	1	205.49	726.4	205.58	238	205.65	0.14766	205.75	0
	206.86	790	206.94	0.181 Lambda / 0.773 V	207.03	14.2	207.11	47.13	207.19	0.00209	207.28	0	207.36	1	206.42	1	206.5	713.8	206.59	237.5	206.68	0.14279	206.79	0
	207.87	913	207.95	0.100 Lambda / 0.420 V	208.07	9.6	208.12	45.88	208.2	0.00209	208.27	0	208.34	1	207.45	1	207.53	767.6	207.62	238	207.71	0.13663	207.83	0
	208.85	1180	208.93	0.129 Lambda / 0.597 V	209.01	26.4	209.08	45.63	209.15	0.00209	209.23	0	209.33	1	208.42	1	208.51	563.4	208.59	236.8	208.67	0.13304	208.77	0
	209.84	733	209.93	0.206 Lambda / 0.827 V	210.01	13.9	210.09	48.46	210.17	0.00209	210.27	0	210.35	1	209.41	1	209.49	864.8	209.59	236.6	209.67	0.10783	209.77	0
	210.86	793	210.95	0.167 Lambda / 0.738 V	211.04	16.8	211.11	46	211.2	0.00209	211.29	0	211.36	1	210.43	1	210.51	766	210.6	237.7	210.7	0.10814	210.78	0
	211.87	756	211.96	0.132 Lambda / 0.614 V	212.03	14.2	212.11	44.4	212.19	0.00209	212.27	0	212.35	1	211.45	1	211.52	681	211.62	236.6	211.7	0.12193	211.8	0
	212.85	796	212.93	0.150 Lambda / 0.685 V	213.01	17.2	213.1	45.32	213.2	0.00209	213.28	0	213.36	1	212.45	1	212.52	671.6	212.6	236.7	212.68	0.12565	212.77	0
	213.89	784	213.98	0.146 Lambda / 0.667 V	214.09	16.6	214.13	44.85	214.23	0.00209	214.34	0	214.38	1	213.45	1	213.55	694	213.65	236.1	213.73	0.12512	213.86	0
	214.87	798	214.96	0.150 Lambda / 0.686 V	215.03	16.9	215.11	44.33	215.2	0.00209	215.27	0	215.35	1	214.46	1	214.54	678.6	214.63	236.8	214.71	0.12296	214.79	0
	215.87	806	215.96	0.183 Lambda / 0.778 V	216.03	16.8	216.12	44.07	216.2	0.00209	216.28	0	216.37	1	215.45	1	215.54	740.6	215.62	235.8	215.71	0.12234	215.8	0
	216.86	796	216.95	0.192 Lambda / 0.798 V	217.03	17.7	217.11	45.98	217.2	0.00209	217.27	0	217.35	1	216.45	1	216.52	791.2	216.61	236.2	216.7	0.12193	216.79	0
	217.86	800	217.93	0.192 Lambda / 0.797 V	218.03	17.6	218.12	44.8	218.21	0.00209	218.34	0	218.39	1	217.44	1	217.52	784.2	217.61	236.3	217.69	0.12238	217.78	0
	218.96	783	219.09	0.199 Lambda / 0.813 V	219.13	18	219.22	43.85	219.34	0.00209	219.37	0	219.46	1	218.49	1	218.6	810	218.7	235.4	218.79	0.12685	218.87	0
From what I could understand - the tank was reporting as full of adblue, temperature ok, pump working etc. But one of the NOX sensors was not reporting anything.
I guess the next step is checking the corresponding fuse, and then the nox sensor plug for voltage/good earth.
Yours has the early NOX cat which is prone to blockage from a dribbling reductant injector and this is detected by NOX sensor 2 as in the fault code stored.
  • Informative
rayhoop
C?ID=288499
This sounds annoyingly expensive to resolve properly... :(
