- Apr 17, 2015
- 121
- 37
- Vestal NY
- hexa193-00c6a4-0b4731-a38ba6-eajahh-5a19
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
Wednesday,24,February,2016,09:17:12:18225
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWUK73C28E084248 Mileage: 121700km-75620miles
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A18070160
Shop #: WSC 05314 000 00000
VCID: 306FE808A36462BECE-8064
005641 - Crash Shut-Down Activated
P1609 - 001 -
Fault Status: 01100001
Load: 0.0 %
Temperature: 14.0°C
Temperature: 17.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.684 V
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776128335
Coding: 0000345
Shop #: WSC 05311 000 00000
VCID: 1F4D1BB4CEFAEDC667-804A
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6ED3367079D0344E9C-803A
01297 - Sensor for Vent Temperature; Footwell (G192)
007 - Short to Ground
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000007572423
Coding: 10840F0340041A00470000000F000000000859435C000100000000000000
Shop #: WSC 05124 000 00000
VCID: 71E92D0C68EE2BB681-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 280807 003 0205
Coding: 00046997
Shop #: WSC 05124
Fault Status: 00101010
Reset counter: 43
Mileage: 120705 km
Date: 2016.01.03
Time: 14:24:00
Voltage: 11.80 V
Reset counter: 43
Mileage: 119887 km
Date: 2015.12.12
Time: 10:32:00
Voltage: 14.15 V
Reset counter: 43
Mileage: 120668 km
Date: 2015.12.31
Time: 15:30:00
Voltage: 14.10 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 17 AIRBAG VW8R 032 2522
Revision: 13032000 Serial number: 003B2PJ829RK
Coding: 0012599
VCID: 3169ED0CA86E6BB6C1-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003P4TX
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME17705E65Gÿ†63
Subsystem 5 - Serial number: 05E65Gÿ†6342MSME177120774ÿ†63
Subsystem 6 - Serial number: 120774ÿ†6351HTS6L4IK0MH6Vÿ†63
Subsystem 7 - Serial number: K0MH6Vÿ†6361HTS61CGOC9075ÿ†63
Subsystem 8 - Serial number: OC9075ÿ†63727TS61CG89M56 ÿ†63
Subsystem 9 - Serial number: 89M56 ÿ†63827TS61CGGMPQ6+ÿ
Subsystem 10 - Serial number: GMPQ6+ÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507BK
Coding: 0000013
VCID: 3561D91C5C0647969D-8060
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 FX HW: 3C0 920 971 FX
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 08158 444 53279
VCID: 000F78C85344323E7E-8054
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P079190164
Coding: F9807F070012021002
VCID: 23451744E292C92643-8076
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TRRMC06
VCID: 6DD1317C74D6CF56A5-8038
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 08158 444 11104
VCID: 73E5270412F219A673-8026
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000091178915
Coding: 0001205
VCID: 3B75CF247A2291E66B-806E
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A0F0E085C00
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000007378914
Coding: 0001204
VCID: 3C77CC387F2C96DE62-8068
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000174778
Coding: 0000057
VCID: 2959056C80BE137609-807C
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 014 0019
Revision: 00014000 Serial number: VWZ4Z7G6288401
Coding: 0040402
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1118
Revision: 12006001 Serial number: 00000002365121
Coding: 0001168
VCID: 3E73C630693084CE4C-806A
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1118
Revision: 12006001 Serial number: 00000002375493
Coding: 0001168
VCID: 3F8DBB346E3A8DC647-806A
End-------------------------(Elapsed Time: 01:52)--------------------------
