just picked up from the auction
stevenpierce83
Vestal NY
hexa193-00c6a4-0b4731-a38ba6-eajahh-5a19
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
Wednesday,24,February,2016,09:17:12:18225
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWUK73C28E084248   Mileage: 121700km-75620miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWZCZ000000000
   Coding: 0404010A18070160
   Shop #: WSC 05314 000 00000
   VCID: 306FE808A36462BECE-8064
005641 - Crash Shut-Down Activated
               P1609 - 001 -
                    Fault Status: 01100001
                    Temperature: 14.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.684 V
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000776128335
   Coding: 0000345
   Shop #: WSC 05311 000 00000
   VCID: 1F4D1BB4CEFAEDC667-804A
   Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6ED3367079D0344E9C-803A
01297 - Sensor for Vent Temperature; Footwell (G192)
            007 - Short to Ground
   Revision: 00H54000    Serial number: 01000007572423
   Coding: 10840F0340041A00470000000F000000000859435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 71E92D0C68EE2BB681-8024
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 280807 003  0205
   Coding: 00046997
   Shop #: WSC 05124
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00101010
                    Reset counter: 43
                    Mileage: 120705 km
                    Date: 2016.01.03
                    Time: 14:24:00
                    Voltage: 11.80 V
                    Reset counter: 43
                    Mileage: 119887 km
                    Date: 2015.12.12
                    Time: 10:32:00
                    Voltage: 14.15 V
                    Reset counter: 43
                    Mileage: 120668 km
                    Date: 2015.12.31
                    Time: 15:30:00
                    Voltage: 14.10 V
   Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Component: 17 AIRBAG VW8R  032 2522
   Revision: 13032000    Serial number: 003B2PJ829RK
   Coding: 0012599
   VCID: 3169ED0CA86E6BB6C1-8064
   Subsystem 1 - Part No: 3C0 959 339 B
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 0000000003P4TX
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME17705E65Gÿ†63
   Subsystem 5 - Serial number: 05E65Gÿ†6342MSME177120774ÿ†63
   Subsystem 6 - Serial number: 120774ÿ†6351HTS6L4IK0MH6Vÿ†63
   Subsystem 7 - Serial number: K0MH6Vÿ†6361HTS61CGOC9075ÿ†63
   Subsystem 8 - Serial number: OC9075ÿ†63727TS61CG89M56 ÿ†63
   Subsystem 9 - Serial number: 89M56 ÿ†63827TS61CGGMPQ6+ÿ
   Subsystem 10 - Serial number: GMPQ6+ÿ
   Part No SW: 3C0 953 549 L    HW: 3C0 953 549 L
   Component: Lenksäulenmodul 006 0010
   Revision: 00006000    Serial number: 3C5953507BK
   Coding: 0000013
   VCID: 3561D91C5C0647969D-8060
   Part No SW: 3C0 920 971 FX    HW: 3C0 920 971 FX
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 08158 444 53279
   VCID: 000F78C85344323E7E-8054
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P079190164
   Coding: F9807F070012021002
   VCID: 23451744E292C92643-8076
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1166279TRRMC06
   VCID: 6DD1317C74D6CF56A5-8038
   Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
   Component:    IMMO         051 0383
   Revision: 00051000    Serial number: VWZCZ000000000
   Shop #: WSC 08158 444 11104
   VCID: 73E5270412F219A673-8026
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000091178915
   Coding: 0001205
   VCID: 3B75CF247A2291E66B-806E
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.134 H08 1901
   Shop #: WSC 02069 000 90108
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 RDK 051 0221
   Coding: 13910F8001862E521004141FF08A0F0E085C00
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000007378914
   Coding: 0001204
   VCID: 3C77CC387F2C96DE62-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000174778
   Coding: 0000057
   VCID: 2959056C80BE137609-807C
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
   Component: Radio DE2       014 0019
   Revision: 00014000    Serial number: VWZ4Z7G6288401
   Coding: 0040402
   Component: J388   TUER-SG HL   1118
   Revision: 12006001    Serial number: 00000002365121
   Coding: 0001168
   VCID: 3E73C630693084CE4C-806A
   Coding: 0100101
   Component: J389   TUER-SG HR   1118
   Revision: 12006001    Serial number: 00000002375493
   Coding: 0001168
   VCID: 3F8DBB346E3A8DC647-806A
End-------------------------(Elapsed Time: 01:52)--------------------------
headlights work and ive never seen that code for crash hmmmmmm
stevenpierce83
Vestal NY
just did lol
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It just means that at some point in the past, the ECU insta-stopped the engine in response to an airbag deployment. It's one of several actions the car takes upon airbag deployment, like turning on dome lights and unlocking doors. This particular code shouldn't have any permanent effect, and should be clearable.
Jason
