- Apr 8, 2026
- 3
- 1
- Birmingham, UK
- C?ID=644228
Have an A4 2014 1.8CJEB Manual, which I picked up ~9 months back. Came with no air con and had rough idling but still a good price.
Had it scanned back then and sorted the idle issue with the camshaft adjustment magnet.
Now sorted myself out with VCDS as its make sence in the long run, so forgive me if I have missed something obvious.
Not sure if they used VCDS or another tool but it logged this:
VAG03220: Climatronic Refrigerant shut off valve open circuit/Short to ground static
I have since scanned and have the following:
15455 - Thermostat for Transmission
P19A0 00 [00101111] - Short to Plus
03220 - Stop Valve for Coolant for Climatronic (N422)
009 - Open or Short to Ground
0457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
0256 - A/C Pressure/Temperature Sensor (G395)
looking in to (03220) I see the code linked to Coolant Blocking / Solenoid Valve 4H0121671B/D faulting and leaking coolant in to the wiring that by the gear box on the left side/UK passenger side.
I have checked and I have the updated 4H0121671D part and the plug and connector look dry and clean.
I have seen (15455) also related to the same part.
Now I have found two of the valve’s, one by the gear box and one in the plenum chamber. Is there a way to identify which valve is ID’ed as N422 or are they both called that?
Can the part fail without leaking coolant past the connector and still cause the same issue?
Is there anything else I should try and test
hassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
VIN: WAUZZZ8K8EA105469 Mileage: 159500km-99108miles
5F-Information Electr. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CJEB) Labels:. 06L-906-264-CJE.clb
Part No SW: 8K0 906 264 A HW: 8K0 906 264
Component: 1.8l R4 TFSI H09 0004
Revision: --H09--- CVN: 3315C716
Coding: 12190032242501022000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM18TFS0218K0906264A 001004
ROD: EV_ECM18TFS0218K0906264A.rod
VCID: 2F3CF003B79DAAE2271-807A
VINID: 9D196AAAA21B21544100510624074C771D
Fault Frequency: 199
Mileage: 155380 km
Date: 2025.09.13
Time: 17:04:54
Engine speed: 1259.75 /min
Normed load value: 17.3 %
Coolant temperature: 12 °C
Intake air temperature: 13 °C
Voltage terminal 30: 11.347 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 1 s
MAP_MES_SAE: 56 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.041 V
FAC_TPS_1_SAE: 16.796875 %
FUP_H_SAE: 6350.0 kPa
15074 - Cylinder Disabling
P130A 00 [01100000] - -
15077 - Idle Control System RPM
P0507 00 [01100000] - Higher than Expected.
15131 - Cylinder 3
P0303 00 [01100000] - Misfire Detected
14916 - Catalyst System; Bank 1
P0420 00 [01100000] - Efficiency Below Threshold
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CL HW: 8K0 907 379 CL
Component: ESP8 front H09 0020
Coding: 03154401
Shop #: WSC 06335 000 00000
VCID: 055072AB4521C0B2BDD-8050
01486 - System Function Test Activated
Reset counter: 15
Mileage: 159502 km
Date: 2026.04.04
Time: 16:23:39
Hex Value: 0x0000
Hex Value: 0x0702
Hex Value: 0x0014
Hex Value: 0x318E
Hex Value: 0x0000
Fault Status: 01101101
Reset counter: 15
Mileage: 159502 km
Date: 2026.04.04
Time: 16:53:34
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0015
Hex Value: 0x028E
Hex Value: 0x0000
Part No SW: 8K0 907 064 JG HW: 8K0 907 064 JG
Component: BCM2 2.0 H14 0650
Coding: 03B24040000000000000
VCID: 7EA21D4720F7936AFC7-802A
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0814000008769006
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0213000398228004
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 T HW: 8K2 820 043 T
Revision: D1000000 Serial number: 01240120140528
Coding: 642402C000
VCID: 3A2AD1577C5F7F4A80F-806E
Fault Status: 01101001
Reset counter: 181
Mileage: 154550 km
Date: 2025.08.18
Time: 11:28:04
Reset counter: 194
Mileage: 158623 km
Date: 2026.02.01
Time: 16:53:05
Fault Status: 01101000
Reset counter: 194
Mileage: 158623 km
Date: 2026.02.01
Time: 16:53:05
Temperature: 10.0°C
Part No SW: 8K0 907 063 DD HW: 8K0 907 063 DD
Component: BCM1 1.0 H16 0103
Revision: 04016001 Serial number: 00000052770901
Coding: 290000308034A7C00081000300001F1F001D060827080201000008004000020000000024000000
VCID: 74B63F6F1EBBC93A9A3-8020
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150114 H06 0080
Serial number: SWF14010155265
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 22147993
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000001001140897
Serial number: 5EC88A07000000000001
Fault Frequency: 18
Reset counter: 203
Mileage: 158683 km
Date: 2026.02.08
Time: 12:54:43
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H47 0610
Serial number: 003KFDB3T109 Dataset Number: 8K0909602Q 0001
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 61983 001 1048576
VCID: 48CEBB9F32331DDA06B-801C
Serial number: 6334MSME410B292CE
Serial number: 6344MSME4C3D467D-
Serial number: 6352QSME7C3B2146N
Serial number: 6362QSME583C2758S
Serial number: 63732SME273C245C3
Serial number: 63832SME203C0A48$
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NAK0004O
Coding: 000017
VCID: 48CEBB9F32B31DDA06B-801C
Part No SW: 8K0 920 983 E HW: 8K0 920 983 E
Component: KOMBIINSTR. H35 0564
Revision: 00100000 Serial number: ZA970881F
Coding: 33A4100002012600010000
VCID: 372CC8634F4D62227F1-8062
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y1411302ED
Coding: 80CF07FF00
VCID: 4ACA81972CBFEFCA10F-801E
Serial number: 7304372103
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 14016002181011200181
Fault Frequency: 51
Reset counter: 15
Mileage: 158303 km
Date: 2026.01.02
Time: 15:23:05
Bin. Bits: 10000
Voltage: 12.00 V
Count: 10
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0510
Revision: Serial number: 0000086971925
Coding: 011002204001410001
VCID: 50FE93FFCAE3D51A5EB-8004
Part No SW: 8K0 909 144 G HW: 8K0 909 144 B
Component: RCEPS H40 0508
Revision: 00001000 Serial number: 0007190740 Dataset Number: 8K0909852J 0024
Coding: 100000000001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008015
ROD: EV_RCEPSAU48X_008.rod
VCID: 3530C26B55C190326DD-8060
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [00001000] - -
[Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit]
Reset counter: 32
Mileage: 159230 km
Date: 2026.03.18
Time: 20:40:02
2048.00 /min
Revision: 00002001 Serial number: 0324345672
Coding: 013B0622A0B930408330023680000047
02615 - Fuel Tank Cap; Lock
Fault Frequency: 13
Reset counter: 234
Mileage: 156493 km
Date: 2025.10.26
Time: 13:33:03
02616 - Fuel Tank Cap; Unlock
Reset counter: 231
Mileage: 156563 km
Date: 2025.10.27
Time: 18:05:49
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0510
Revision: Serial number: 0000132681848
Shop #: WSC 06325 000 00000
VCID: 4FFC9083D7DDCAE2471-801A
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 20000000385110
ROD: EV_ParkiBrake_AU48.rod
VCID: 3928CE5B79D97452895-806C
Address 56: Radio
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000094756202
Coding: 010002204001210001
VCID: 46D2B5A738A70BAAF47-8012
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8K9 827 851 C HW: 8K9 827 851 C
Component: J605 Master H53 0330
Revision: -------- Serial number: 8K9827851C
VCID: 3E22DD476077536ABC7-806A
Subsystem 1 - Part No SW: 8K9 827 852 C HW: 8K9 827 852 C
Component: J756 Slave H53 0330
Serial number: 8K9827852C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000087755689
End----(Elapsed Time: 01:32, VBatt start/end: 11.3V/11.3V. VIgn 11.3V)-----
------------------------------15 Faults Found------------------------------
