Databus fault error message received
vagcars69
C?ID=413796
2017 Octavia, a traction/parking/front assist warning message would appear randomly when driving. Customer already had an airbag module replaced as someone said its creating fault but after that fault still appears:
Thursday,09,April,2026,11:26:23:45700
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
VIN: TMBKJ7NE4J0012fiveEightNiner   License Plate: octavia
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 20 42 44 4B 52 5F D6 D7
VIN: TMBKJ7NE4J0012fiveEightniner   Mileage: 176896km-109918miles
Address 01: Engine (J623-CRMB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 BN    HW: 04L 907 309 R
   Component: R4 2.0l TDI   X23 7759
   Revision: B5X23---    CVN: FD1DD350
   Coding: 01190012032501090000
   Shop #: WSC 26813 005 104857
   ASAM Dataset: EV_ECM20TDI01104L906026BN 004006
   ROD: EV_ECM20TDI01104L906026BN_004_SK37.rod
   VCID: 77ABEF9D4F466CF2FE9-8022
   VINID: 91D49B68779511A000042148248218D913
8 Faults Found:
17158 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
                    Engine speed: 0.00 /min
                    Coolant temperature: 20 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 12.020 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [00100110] - -
          [Diagnostic interface for data busRead out DTC]
                    Date: 2026.04.08
                    Time: 14:51:38
                    Limitation: torque: 1000.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Accelerator pedal travel: raw value: 0.00 %
                    Engine torque: -500.0 Nm
                    Generator: load signal: 0.02 %
4976 - Glow Plug Control Module (J179)
          P0684 00 [00100111] - Implausible Signal
                    Mileage: 176896 km
                    Date: 2026.04.09
                    Time: 11:15:57
                    Engine speed: 954.00 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 12 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.260 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 146
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Pre-glow time: 2500 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 1
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Outside temperature sensor 1: B1: raw value: 12.0 °C
4988 - Glow Plug Cylinder 1
          P066A 00 [00100111] - Short to Ground
                    Mileage: 176896 km
                    Date: 2026.04.09
                    Time: 11:19:56
                    Pre-glow time: 800 ms
4989 - Glow Plug Cylinder 2
          P066C 00 [00100111] - Short to Ground
                    Mileage: 176896 km
                    Date: 2026.04.09
                    Time: 11:18:52
4990 - Glow Plug Cylinder 3
          P066E 00 [00100111] - Short to Ground
                    Mileage: 176896 km
                    Date: 2026.04.09
                    Time: 11:19:28
4991 - Glow Plug Cylinder 4
          P067A 00 [00100111] - Short to Ground
                    Mileage: 176896 km
                    Date: 2026.04.09
                    Time: 11:18:52
4997 - Glow Plug Control Module
          P064C 00 [00100111] - -
                    Mileage: 176896 km
                    Date: 2026.04.09
                    Time: 11:22:20
                    Intake air temperature: 15 °C
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AM    HW: 5Q0 614 517 AB
   Component: ESC           H25 0312
   Revision: 00000000    Serial number: 60367000001516
   Coding: 25078A912421096E407C060840CC24A451249002600224723063F070C002430000000012121212B8586C384E4484EE
   Shop #: WSC 26813 005 1048576
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 7CA1F0B176604FAA93B-8028
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 49
                    Mileage: 176896 km
8252 - Databus
          U1121 00 [10001000] - Missing Message
          [FCAN: Motor_11 message is not received]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 49
                    Mileage: 176896 km
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Reset counter: 49
                    Mileage: 176896 km
   Part No SW: 5E0 907 044 AJ    HW: 5E0 907 044 AJ
   Revision: 00001K00
   Coding: 0211010400211001100500080010100A
   Shop #: WSC 73430 031 00063
   VCID: 6D87CDF53D1AD622145-8038
   Air quality sensor:
   Part No SW: 5Q0 937 086 BG    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: 865829011700HY Dataset Number: V03935270GG 0001
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017_SK37.rod
   VCID: 005984411A882B4ACF3-8054
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 151217  051 0915
   Serial number: 887253F0401535100480
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S4Y17M02D08H08M15S54
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY163482QC0
   Serial number: 00000000000037406869
   Humidity sensor: interior:
528405 - Databus
          [Airbag_01 Datenbus fehlende Botschaft]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 14.7 V
                    Outside temperature: 23.5 °C
   Part No SW: 5QA 919 283 A    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0038
   Serial number: 000308419617025 Dataset Number: V03935251FZ 0001
   Coding: 0601050001
   ASAM Dataset: EV_EPHVA14AU3700000 009029
   ROD: EV_EPHVA14AU3700000_009_SK37.rod
   VCID: 48C95C617238D30A473-801C
13637426 - Databus
                    Reset counter: 49
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
   Dataset Number: V03935254LY 0001
   Coding: 2D00600141FFC728949C810500400F00000000000000000000
   VCID: 3C2130B136E08FAAD3B-8068
8 Faults Found:
2109 - Databus
          [FAULT_AWV_CONSISTENCY_FAIL]
                    Reset counter: 9
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 14.5 V
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 49
                    Voltage terminal 15: 14.3 V
                    Longitudinal_acceleration_vehicle_reference: -0.13 m/s²
1110 - Databus
          [FAULT_TIMEOUT_ESP_02]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
                    Voltage terminal 15: 14.2 V
                    Velocity_vehicle_reference: 0.03 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.04 m/s²
1058 - Databus
          [FAULT_TIMEOUT_ESP_05]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
1089 - Databus
          [FAULT_TIMEOUT_ESP_10]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
1092 - Databus
          [FAULT_TIMEOUT_ESP_21]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
1076 - Databus
          [FAULT_TIMEOUT_GRA_ACC_01]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
                    Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
1031 - Databus
          [FAULT_TIMEOUT_LWI_01]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
                    Voltage terminal 15: 14.1 V
                    Longitudinal_acceleration_vehicle_reference: -0.05 m/s²
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003R6P4UP1C4 Dataset Number: V03935257SD 0001
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X_SK37.rod
   VCID: 074B9F5D3FA61C728E9-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 001 801 17
   Serial number: 357000000002C668512E
   Subsystem 2 - Part No SW: -----------    HW: 454 001 801 17
   Serial number: 3580000000030BC8512F
   Subsystem 3 - Part No SW: -----------    HW: 454 801 801 17
   Serial number: 351002ADB2E0C000000U
   Subsystem 4 - Part No SW: -----------    HW: 454 801 701 17
   Serial number: 35200560ED20E000000L
   Subsystem 5 - Part No SW: -----------    HW: 454 800 301 17
   Serial number: 355003BAE7E0E0000000
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 09021704220468
   Coding: 1400
   VCID: 7EA5FAB9607C5DBABDF-802A
   Part No SW: 5E0 920 951 D    HW: 5E0 920 951 D
   Component: KOMBI         302 8311
   Coding: 27A40A002980A60001886B011001000000000000
   VCID: 2809FCE1D278330AA73-807C
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 49
                    Mileage: 176896 km
                    Date: 2026.04.08
                    Time: 14:51:38
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005909325 Dataset Number: V03935243KR 0001
   Coding: 030100045F087300EB00024A080F00010001050000000000000000000000
   Shop #: WSC 13370 007 1048576
   GVL: 01563C0000000100400C80000000480000000000000200000000000000000000
   ROD: EV_GatewNF_SK37.rod
   VCID: 2F3B17FDF7966432669-807A
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000C0053270117
   Serial number: 75410803001701284507
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 G    HW: 3G0 857 511 G
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404010700000100000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 2C0100F1C6801F2A43B-8078
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Component: TSG FS        010 0032
   Serial number: 0000238159893  Dataset Number: V03935252QV 0001
   Coding: 00110020D001040000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 47CB5F5D7F26DC724E9-8012
   Serial number: 00000000000013148988
   Coding: 1D0200
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: V03935242GR 0001
   Coding: 8107
   Shop #: WSC 73430 790 00000
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75555452ACE62BC5-8010
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 02021710520742 Dataset Number: V03935256SC 0001
   Coding: 000000070100046600003D01010000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_001_VW37.rod
   VCID: 72BDDE89242409DAC97-8026
   Component: TSG BFS       010 0032
   Serial number: 0000240411700  Dataset Number: V03935252QY 0001
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 46D55259782CC57AB5F-8012
   Serial number: 00000000000013122099
   Coding: 050200
   Part No SW: 5Q0 035 874 B    HW: 5Q0 035 874 B
   Component: MU-S-ND-ER    H30 0361
   Serial number: SKZAZ2T5052089 Dataset Number: V03935256PC 0001
   Coding: 03731201FF00000051111201008800002F0300C601200100CE
   ROD: EV_MUStd4CTSAT_SK37.rod
   VCID: 33331B8D1BBE40D2021-8066
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H35 8074
   Serial number: SKZ6ZDT0341366
   Subsystem 2 - Part No SW: 5L0 051 236 T    HW: -----------
   Component: ECE1 2017/18  --- 0820
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   Part No SW: 7P5 941 591 AJ    HW: 7P5 941 591 A
   Component: LED1R         H07 0011
   Dataset Number: V03935316MT 0001
   VCID: 045188510E90376AEBB-8050
End----(Elapsed Time: 01:48, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------25 Faults Found------------------------------
Quite a mess of errors on the powertrain bus there, but nothing strikes me as an obvious source.
vagcars69
C?ID=413796
Exactly. When cleared only glow plugs would remain and then at random all would appear. I'm guessing one of the modules would interrupt can com and throw a chain of errors, but which module?
Spacewalker
Poland
C?ID=159607
I will say like that :
ABS show error because ECU errors , then ACC show merror
then PDC show error because of that
when look closer- seems like ECU could be "defective"
glow Plug modules is not "open circuit" it show "short to ground" so if all wires are ok and glow plug, perhaps module itself is defective , or ecu can not control it in proper way
start from glow plug module , wires , glow plug first
vagcars69
C?ID=413796
Glow plug module is not on can network so I doubt it will be causing the issues.
From what I gathered owner already tried to disconnect radar but same effect. He also tried run on a different engine ecu with same effect.
So if its not airbag module, engine ecu or the radar... would that be abs module? Any way to pinpoint it?
