- Apr 6, 2026
- 17
- 2
- Evergreen, CO, USA
- C?ID=598853
Correct. Nice Camaro, took my driver's test in a red '73.So you swapped a used E87 and you still did not have high blower speed?
Your reading is wrong ! That thinking is the REAL reason behind you being unable to solve a very simple Fan Blower fault !!So after doing some reading, it actually is a resistor.
So clearly there is a signal coming from the green/black wire from the ACCH that varies the continuity between the brown ground wire (chassis) and the brown/red wire that goes to the blower motor.
Since the resistor is not in series on high speed that kinda eliminates the E87 as the problemSo you swapped a used E87 and you still did not have high blower speed?
Couldn't the used replacement be bad? Not have ground where it should.Since the resistor is not in series on high speed that kinda eliminates the E87 as the problem
IF it's just a resistor then that just incrementally steps in series with the motor to produce lower speeds, no ground needed.Couldn't the used replacement be bad? Not have ground where it should.
Are we looking at the same WD posted in #11 which I believe Op confirmed that is what Op has. So it has a constant 12v+ to motor with car on except when 75 /X turns it off.IF it's just a resistor then that just incrementally steps in series with the motor to produce lower speeds, no ground needed.
OK, I assumed the motor was grounded and the resistor in the 12V side.Are we looking at the same WD posted in #11 which I believe Op confirmed that is what Op has. So it has a constant 12v+ to motor with car on except when 75 /X turns it off.
You had me questioning if I was reading that WD correctly or was not seeing something I should have.OK, I assumed the motor was grounded and the resistor in the 12V side.
With motor speed set to max resistor pack is bypassed completely from what I remember. straight 12v to motor.
Yes, that's correctSo you swapped a used E87 and you still did not have high blower speed?
Yes you stated alreadyYes, that's correct
75x is live without engine running (verified) so that must mean T50 is not active. What is T50? Do you mean the ECM?Op confirms that the wiring Diagram in Post #11 is correct for his car.
In that case this is Auto Climate and does Not have a resistor pack to control blower motor speed.
It has a PWM Controller. It has 75x Live - Live when Ignition on and With Engine Running - Dead Whilst T50 is active. It is Negative side Switched / modulated. Simple Childs Play !
No - I meant exactly what I wrote !!75x is live without engine running (verified) so that must mean T50 is not active. What is T50? Do you mean the ECM?
Assuming would then be like not insisting on an Autoscan for each post ?? Just assume hey ?IF it's just a resistor then that just incrementally steps in series with the motor to produce lower speeds, no ground needed.
Assuming would then be like not insisting on an Autoscan for each post ?? Just assume hey ?OK, I assumed the motor was grounded and the resistor in the 12V side.
