- Apr 6, 2026
- 17
- 2
- Evergreen, CO, USA
- C?ID=598853
2002 Audi TT Quattro 225 manual 55k miles like new, car is garaged. HVAC Blower motor not working on any setting. It stopped working, then I removed motor and checked with 12V (battery direct) and motor works, reassembled under dash, and it worked for a few minutes. Then quit again. Fan speed display shows high, but then bars drop down, and cycle repeats. I can hear noises like attempts are being made to open flaps (?) under dash. Pulled motor and it ran fine on batery 12V. Checked ground with test light directly on battery and ground is fine. Checked motor continuity while slowly turning manually and no breaks. Removed battery and replaced connectors at the ground terminal under the battery after finding some very minor green corrosion between connectors and wire. Replaced resister (new). Swapped out HVAC controller with used (ebay), motor and display behaves the same. Checked voltage going to motor and it is only receiving 2.5 - 3V no matter what the speed setting. Removed the entire lower dash and center stack to inspect harness. Found one tiny mouse poop, but no evidence of chewed harness that I can see. Maybe dead mouse is blocking the operation of the flapper doors inside the HVAC port? I'll try to find using a camera probe. Edit: removed center console (between seats) and found more evidence of mouse infestation: chewed insulation piles, bits of corn chewed up, and pee stains. No chewed harness evidence. Connectors all looked clean. Will pull up the wire harness diagram next to trace circuit.
Here are the codes:
Thank you all for your assistance,
Jeff Jones
Evergreen, Colorado
Here are the codes:
Monday,06,April,2026,14:15:50:25529
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.5
Dealer/Shop Name: Jeff K Jones
Chassis Type: 8N - Audi TT (1999 > 2007)
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AMU.lbl
Part No: 8N0 906 018 AN
Component: 1.8L R4/5VT G 0004
Coding: 06710
Shop #: WSC 01236
VCID: 7DA021D804E75572A45-5160
TRUWT28N721023906 AUZ5Z0B1156014
16795 - Secondary Air Injection System
P0411 - 35-10 - Incorrect Flow Detected - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-10 - System too Lean - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17069 - ECM Power Relay Control Circuit
P0685 - 35-10 - Open Circuit - Intermittent
18058 - Powertrain Data Bus
P1650 - 35-00 - Missing Message from Instrument Cluster
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-A.lbl
Part No: 8N0 907 379 H
Component: ESP ALLRAD MK60 0101
Coding: 0022544
Shop #: WSC 01236 785 00200
VCID: 41D89D283D9FF19280D-5160
00813 - Sensor 2 for Brake Pressure (G214)
00493 - ESP-Sensor Unit (G419)
014 - Defective
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 01236
VCID: 280E208CBBE520DAA73-258E
00600 - Potentiometer On Positioning Motor for Temperature Flap (G92)
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
01582 - Signal for Coolant Temperature
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 A
Component: Airbag Front+Seite 5000
Coding: 01103
Shop #: WSC 01236
VCID: 3E22E6D449618E6AFDF-5156
10 Faults Found:
00-10 - - - Intermittent
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
VCID: 201E38ACD3D5D89AEF3-4B1E
Address 35: Centr. Locks Labels:. 8Nx-962-267.clb
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D06
Coding: 15976
Shop #: WSC 09480
VCID: 3FDC9BD04E6B8762F69-4F30
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 37: Navigation Labels: 4B0-919-887-BNS4.lbl
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0007
VCID: 3530F9F87C574D322C5-4B02
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177 A
Component: Innenraumueberw. D09
Coding: 00001
VCID: 3D20E1D844679572E45-5176
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: 659069B88C77FDB25C5-51FA
End----------(Elapsed Time: 02:41, VBatt start/end: 12.1V/12.1V)-----------
------------------------------24 Faults Found------------------------------
Jeff Jones
Evergreen, Colorado
I ordered a variable DC power supply, will get here Thursday.
