2005 Phaeton Leveling system
VWPCB
Long Island, USA
C?ID=446914
Vehicle: 2005 Volkswagen Phaeton 2005 (NAR)
VIN: WVWAF03D058004821
Concern:
Front ride height is below spec.
  • Measured: 389 mm (center of wheel → fender lip)
  • Spec: 417 mm (NAR)
System used to raise/lowers normally (until I started working with it), but baseline height is too low at the front.
Work performed:
Attempted level control calibration per Ross-Tech procedure:
https://www.ross-tech.com/vag-com/cars/levelcontrol.html
Issue during adaptation:
  • Enter security access successfully
  • Start adaptation (Channel 01 – Front Left; Channel 02 - front Right)
  • After saving second value → controller requests security access again
  • Adaptation session resets → unable to complete all four corners
Result: stuck in loop, cannot complete calibration.
Additional faults:
Intermittent ABS / ESP warning lights (come and go).
Unsure if related.
Attached:
  • Full Auto-Scan
  • Controller channel map (Level Control module)
Questions:
  1. Is repeated security access request normal behavior on this module, or indicative of a fault?
  2. Are there known conditions that interrupt adaptation (e.g., ABS faults, implausible level sensor values)?
  3. Is there a required timing/order to save all 4 values before session timeout?
  4. Could front level sensor or stored values being out of range cause adaptation to abort?
Any guidance appreciated.
Monday,06,April,2026,15:47:50:45330
VCDS Version: 25.3.1.2 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
VIN: WVWAF03D058004821   License Plate:
Mileage: 238860km-148420mi   Repair Order:
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
          34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWAF03D058004821   Mileage: 238860km-148420miles
Address 01: Engine        Labels: 4D0-907-560-BGH.lbl
   Part No SW: 4D0 907 560 DD    HW:
   Component: 4.2L V8/5V      G   0030
   Revision: 00000000    Serial number: VWZ3Z0E5311988
   Coding: 0007873
   Shop #: WSC 01065 000 00000
   VCID: 6B83CEC5AF9EE1724AB-5160
   VINID: 9E69D15800D400520000420204B5A99409
18057 - Powertrain Data Bus
            P1649 - 008 - Missing Message from ABS Controller - Intermittent
Readiness: 0010 1101
   Part No SW: 09L 927 760 G    HW: GS1 904 1
   Component: AG6 09L 4,2L V8     1905
   Coding: 0001102
   VCID: 3B233E859F7EB1F29AB-5160
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Status: 00110000
                    Reset counter: 38
                    Mileage: 238867 km
                    RPM: 704 /min
                    RPM: 704 /min
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 91.0 C
                    T.B. Angle: 0.0
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008376
   VCID: 6B83CEC5AF9EE1724AB-51CE
   Part No SW: 3D0 909 135 P    HW: 5WK 470 25
   Component:    Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0E5311988
   Coding: 0006376
   VCID: 323D13A1483470BA49D-5160
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 C
   Component: Sitzmemory D1 BF    1705
   Coding: 0000003
   VCID: 36352FB1A45C6C9A655-5160
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3D0 035 008 Q
   Component:    ZAB COCKPIT      0223
   Coding: 0000000
   VCID: 2809F1C97EE80A6AE79-5160
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 H
   Component: Climatronic D1      2021
   Coding: 0000002
   Shop #: WSC 26386 002 1048576
   VCID: 2313E6E507CEE932B2B-5160
00713 - Centre Left Vent Positioning Motor (V110)
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000002
   VCID: 2F3B1AD55B065D52263-5160
   Part No: 3D0 909 601 H
   Component: 03 Airbag 8.4E++H01 0554
   Revision: BB38727     Serial number: 0000675>
   Coding: 0012339
   Subsystem 1 - Part No: 3D0 959 339
   Component: BF-Gewichtsens. 006 0005
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 D
   Component: Lenks ulenmodul     3401
   Coding: 0000032
   VCID: 2E0507D15C0C545A2D5-5160
Address 17: Instruments        Labels: 3D0-920-INS-V1.lbl
   Part No: 3D0 920 981 Q
   Component: KOMBIINSTRUMENT RB8 0517
   Coding: 0007221
   VCID: 353728BDB95A67826CF-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D9A986B802AA7F9-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000001
   VCID: 6695BFF1B47CDC1A155-5184
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0007722
   VCID: 270BF2F573F60512EE3-5160
01437 - Control Position not Learned
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 B
   Component: Sitzmemory D1 F     1505
   Coding: 0000004
   VCID: 2D0700DD510A2F4214F-5160
Address 37: Navigation        Labels: 3D0-919-887.lbl
   Part No: 3D0 919 887 F
   Component:    NAVIGATION       0168
   Coding: 0400000
   VCID: 372B22B5A35695927E3-5160
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 C
   Component: Dachmodul           0708
   Coding: 0000047
   Shop #: WSC 05072 444 53225
00206 - Control Circuit for Interior Mirror Motor
00220 - Connection to Sunroof
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000001
   VCID: 678BB2F5B376C5122E3-5160
Address 46: Central Conv.        Labels: 3D0-959-933.clb
   Part No: 3D0 959 933 F
   Component: 29 HSG              0101
   Coding: 0000040
   VCID: 333316A5B72E79B242B-4B00
   Subsystem 1 - Part No: 3D1 959 701 F
   Component: Tuersteuergeraet FS 5616
   Subsystem 2 - Part No: 3D1 959 702 F
   Component: Tuersteuergeraet BF 5616
   Subsystem 3 - Part No: 3D0 959 703 F
   Component: Tuersteuergeraet HL 5616
   Subsystem 4 - Part No: 3D0 959 704 F
   Component: Tuersteuergeraet HR 5616
   Subsystem 5 - Part No: 3D0 909 610 C
   Component: 3L HDSG             2330
   Subsystem 6 - Part No: 7L0 907 719
01816 - Exterior Door Handle Switch in Drivers Door (F272)
   Part No: 3D0 035 466 A
   Component: 12K-AUDIOVERST      0118
   VCID: 2019E9E916D8F22AAF9-5160
Address 65: Tire Pressure        Labels: 3D0-907-273-V2.clb
   Part No: 3D0 907 273 G
   Component: Reifendruckueberw.  0026
   Coding: 0210204
   Shop #: WSC 08261 444 84834
   VCID: 2A0D0BC160E4387AF1D-5160
00003 - Control Module
            014 - Defective - MIL ON
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
            004 - No Signal/Communication - Intermittent - MIL ON
02757 - Learning Tire Pressures
            000 - - - MIL ON
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
   Part No: 3D1 955 119 A
   Component: Front Wiper         2005
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 2411E5F902C0EE0ACB1-5160
Address 75: Telematics        Labels: 3D0-035-617.lbl
   Part No SW: 3D0 035 617 A    HW: 3D0 035 617 A
   Component: Telematik NAR1      0106
   Coding: 0061860
   VCID: 1E65D7112CACC4DA9D5-5160
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 C
   Component: 03 Einparkhilfe     0807
Address 77: Telephone        Labels: None
   Part No: 3D0 035 729
   Component: Telefon             0118
   VCID: 619FACED5D52BB22E07-5160
End----(Elapsed Time: 07:20, VBatt start/end: 13.6V/13.3V. VIgn 0.0V)------
------------------------------18 Faults Found------------------------------
SW:3D0-614-517-AK   HW: ---  ABS Brakes
;Component:ESP 5.7 allrad  H33 0047, Coding:0008376
;Monday,06,April,2026,15:51:23:45330
;VCDS Version: Release 25.3.1 (x64)  Data version: 20250604 DS365.0
;VCID: 6B83CEC5AF9EE1724AB-51CE
1,0,Current Wheel Speed,
1,1,Speed Sensor,Front Left (G47),Range: 0.0...255.0 km/h (1.0 km/h while Standing)
;1.0 km/h,Speed,
1,2,Speed Sensor,Front Right (G45),Range: 0.0...255.0 km/h (1.0 km/h while Standing)
;1.0 km/h,Speed,
1,3,Speed Sensor,Rear Left (G46),Range: 0.0...255.0 km/h (1.0 km/h while Standing)
;1.0 km/h,Speed,
1,4,Speed Sensor,Rear Right (G44),Range: 0.0...255.0 km/h (1.0 km/h while Standing)
;1.0 km/h,Speed,
2,0,Switches && Buttons,
2,1,Brake Test Switch,(F47),Range: 0/operated
;0.0,(no units),
2,2,Brake Light Switch,(F),Range: 0/operated
;0.0,(no units),
2,3,Parking Brake,Switch (F9),Range: 0/operated
;0.0,(no units),
2,4,ASR/ESP Button,(E256),Range0/operated
;0.0,(no units),
3,0,Engine Data,
3,1,Engine Speed,,
;704 /min,RPM,
3,2,Engine Torque,,
;70.8 Nm,Torque,
3,3,Engine Torque,(loss),
;70.8 Nm,Torque,
3,4,Throttle Valve Angle,,
;0.0 %,Duty Cycle,
4,0,,
4,1,Standing Time,,
;02:23,Clock,
4,2,EDL-T Flag,,Range: ON/OFF
Specification: OFF
;OFF, ,
4,3,,,
;N/A,,
4,4,,,
;N/A,,
5,0,,
5,1,Steering Angle,Sensor (G85),Display Range: -720.0...+720.0
Tolerance (when straight):  5.0
;-7.5 ,Steering Angle,
5,2,Rotation Rate,,Display Range: -69.0...+69.0  /s
;-0.27 /s,Turn Rate,
5,3,Brake Pressure,,Display Range: -41.0...+292.0 bar
40.0 bar = Short to Ground
290.0 bar = Short to Plus
;-0.65 bar,Pressure,
5,4,Transverse,Acceleration,Display Range: -25.0...+25.0 m/s
;0.96 m/s*2,Lateral Accel.,
6,0,,
6,1,Supply Voltage,(Terminal 30),Specification: 9.8...17.4 V
;13.49 V,Voltage,
6,2,Valve Relay,(J106),Display Range: ON = OK / OFF = not OK
;ON, ,
6,3,Return Flow Pump,(V39),Display Range: ON/OFF
;OFF, ,
6,4,Work Shop Code,,
;01065,Work Shop Code,
7,0,Installation Position,
7,1,Speed Sensor,Front Left (G47),Range: invalid/OK/not OK
;Invalid, ,
7,2,Speed Sensor,Front Right (G45),Range: invalid/OK/not OK
;Invalid, ,
7,3,Speed Sensor,Rear Left (G46),Range: invalid/OK/not OK
;Invalid, ,
7,4,Speed Sensor,Rear Right (G44),Range: invalid/OK/not OK
;Invalid, ,
8,0,Direction of Rotation,
8,1,Speed Sensor,Front Left (G47),Range: invalid/forward/reverse (invalid when not moving)
;Invalid, ,
8,2,Speed Sensor,Front Right (G45),Range: invalid/forward/reverse (invalid when not moving)
;Invalid, ,
8,3,Speed Sensor,Rear Left (G46),Range: invalid/forward/reverse (invalid when not moving)
;Invalid, ,
8,4,Speed Sensor,Rear Right (G44),Range: invalid/forward/reverse (invalid when not moving)
;Invalid, ,
9,0,,
9,1,Brake Test Switch,(F47),'Activated' shows when brake pedal is pressed
;0.0,(no units),
9,2,Brake Light Switch,(F),'Activated' shows when brake pedal is pressed
;0.0,(no units),
9,3,Brake Pressure,,Display Range: -41.0...+292.0 bar
9,4,,,
;N/A,,
80,0,Advanced Control Module Identification I,
80,1,,,
;BPA-000 13.12.04 00000000 0139 0286,,
125,0,CAN-Databus Communication (Powertrain),
125,1,Steering Angle,Sensor (G85),Specification: Steer. ang. 1
Display Range: Steer. ang. 0/Steer. ang. 1
;Steer. ang. 1, ,
125,2,Transmission,,Display Range: Transm. 1/Transm. 0
;Engine 1, ,
125,3,Engine,,Specification: Engine 1
Range: Engine 0/Engine 1
;Transm. 1, ,
125,4,Instrument Cluster,(J285),Specification: Instruments 1
Range: Instruments 0/Instruments 1
;Instruments 1, ,
Ziddywerks
Northern NJ USA
C?ID=208579
Can we please code wrap logs. Also can we also used the search function to cut down on redundancy threads hat have been answered time and time again.
Procedure is the same for a8, phaeton, bentley cgt and many others.
Note the following procedure is for a Bentley.
Protocol: KWP2000
Part No: 3W0 907 553
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
Shop #: WSC 00083
[Security Access - 16]
Enter 31564
[Do It!]
Coding
The suspension controller is controller 34. The normal coding for this controller in Europe is 0015500, and the normal coding for this controller in North America is 0017700. Each increment of one digit in the location where the 5’s and 7’s are is equal to a 5 mm increase in body ride height above the axles. If you change the coding of the suspension controller from xxx77xx to xxx55xx (the x representing digits you don’t pay attention to, and should not change), then you will eliminate the 10 mm upward adjustment.
So, using your diagnostic scan tool, change the coding of the controller, save your work, and close the controller. Now, because you have changed the coding, you must re-adapt the controller – otherwise, you will see a message in the Y24 display (the screen between the speedometer and the tachometer) telling you that you have suspension problems. In fact, this message will appear immediately as soon as you change the coding – don’t worry about it, it will go away once you have completed the adaptation.
Change the coding from xxx77xx to xxx55xx – no security code is needed or wanted for this step.
Don’t forget to save the work after you do this.
Adaptation
Put the car on a level surface. Make sure that the tire pressures are correctly set on all 4 tires. Get whatever you need out of the car, because you cannot open any doors or lids during the adaptation process (if you do open a door or lid, it aborts the adaptation). Roll the driver window down all the way. Plug the cable from the diagnostic scan tool into the OBD (on board diagnostic) connector, which is just inboard of the parking brake foot pedal. Run the cable out the open driver door window, and plug it into your diagnostic scan tool (now you know why it helps to have a bar stool to put the scan tool on).
Start the engine, and leave the car idling, in Park. Get out, and close all the doors.
Open the suspension controller (address 34), and enter the security code that is needed to give you access to the adaptation section of the controller. The security code is 31564 – this is the same for a Touareg or a Phaeton. Be aware that once you have entered the security code, you have initiated the adaptation procedure. You then have to fully complete the adaptation cycle – if you back out before the end (channel 5), your car will display a fault message, and the suspension system will be in ‘limp home’ mode.
Enter the Security Code
Once you have entered the security code, go to adaptation, and select channel 1. The Bentley will then move up and down a little bit, and eventually, ask you to enter a measurement. Measure the exact distance between the axle centerline and the bottom edge of the front left fender, and enter that value. Repeat this process for adaptation channels 2, 3, and 4, which correspond to the front right, rear left, and rear right wheels.
Go to channel 1, wait for the car to move up and down, then enter the observed measurement
Normally you have to wait about 1 minute until the car stops moving up and down, rarely longer than 2 minutes.
When the word WAIT disappears, and ENTER appears, enter your measurement.
VCDS software will occasionally 'hang' on adaptation channel 1. If the word 'wait' has not been replaced with 'enter' after 5 minutes, just dismiss the yellow guidance balloon (click on the X in the corner of the balloon), then enter your measurement, and click test, then click save.
How to make your measurements
Keep the ruler level, use a credit card to line up with the center of the axle. It helps to mark the desired measurements (401 mm and 407 mm) on the ruler with a felt pen.
Once you have entered the measurements for all 4 wheels in channels 1 to 4, you then have to go to channel 5, and enter a one (1) to save your work. Entering the 1 tells the controller that you want it to write the values to memory. If you don’t do this, you won’t successfully complete the adaptation.
After you have entered and saved the 1 to channel five, close the controller. Then get in the car, back it up about 15 feet, then drive it forward about 15 feet, so you are back in the original position again. Leave the engine running, and without hooking up the scan tool, take the 4 measurements again. You should find that the measurements are within 5 mm of the nominal distances – that is to say, 401 front and 407 rear if you have coded the controller with 5’s, and 411 front and 417 rear if you have coded the controller with 7’s.
If the measurements are outside of that range, or, if they are inside of that range but you want to make them more accurate, repeat the adaptation process again, starting with the entry of the security code. It’s not uncommon to need to complete two adaptation cycles to get things perfect. Once you are within 2 mm of nominal, stop, because that is about as close as you can reasonably expect to get.
Experience has taught us that it is kind of pointless to try to go through more than 3 adaptation cycles in one day. If you don’t get the results you want after 3 cycles, put the car in the garage and try again the next day.
Background Information
You can increase the Bentley ride height up to 20 mm above the nominal European settings – for example, if you had to drive the Dempster highway to the Arctic ocean, this might be worth considering, you would enter 9’s as coding values – but it seems that you cannot code the controller with a number that is lower than 5. You can try, but the controller won’t accept it. My guess is that you need to have a different security code (that we don’t know about) to enter values lower than the European norm.
Some people have managed to get the car to sit quite low on the axles by ‘fibbing’ to the controller during the adaptation process. In other words, they take the measurement, and if the measurement is, for example, 401 mm, they enter 406 mm. This tells the car that it is 5 mm higher than it thinks it is, and the car responds by sitting 5 mm lower when the adaptation cycle is finished. Personally, I don’t think this is a good idea. If you lower the car the ‘proper’ way – by coding – then do a truthful adaptation, the car knows exactly where it is at all times, so far as limits of suspension travel are concerned. If you fib to the car when you do the adaptation, then it will think it still has (for example) 30 mm of downward or upward shock absorber travel before it hits the physical limit of travel, when in actual fact it has only 25mm of downward travel, and 35 mm of upward travel. This will result in less than optimum suspension performance at all times.
VWPCB
Long Island, USA
C?ID=446914
I’m still having the same issue. I’m able to enter the value for Channel 2 (front left), run the test, and save the change.
But when I move to Channel 3 (front right), I get locked out with a “Security Access Denied” message and can’t change any fields.
What am I doing wrong? I’m following the procedure step by step.
Also, is anyone in the area able to help with this?
@Ziddywerks, I saw that you’re in northern New Jersey. I’m on Long Island, and the car is drivable. Would you be able to help, or do you know someone in my area who could?
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
It's just too low for those values to be considered valid, so that's why you can't go further. Then it won't raise on its own because control positions aren't learned, so that's where you're stuck. Question is, why is it too low? What work have you been doing on the car?
Do these steps in exactly this order:
1. Take a NEW (not old/saved) controller channel map of 34-Level Control, exactly as the car stands before you start. The one you already shared was for 03-ABS.
2. Open a session to 34-Level Control.
3. Security access, code 31564.
4. Security access, code 08367. Yes, you need to do both, in the same session, in that order.
5. Go into Basic Settings, from the drop-down pick Front Axle - Filling (not venting/bleeding)
6. Press the ON button.
You'll hear the compressor run, and the front of the car should start lifting immediately. After a certain pressure is reached, it will turn itself off and display Done. Assuming it lifted itself to a more reasonable height, you can then retry the calibration procedure. If it seems to run for more than 30-40 seconds without perceptibly lifting, I would hit the OFF button, and start looking for your very large air leak.
If you run into trouble, take a second controller channel map of 34-Level Control and share BOTH the before AND after maps here. That will help us understand the state of your system, help us spot whether it's a leak or a problem with a height sensor, etc.
Vdub
C?ID=57533
if the car is too low, you have to type in a number LOWER than you measured, only then it will raise the car. so if you measure 389, enter 370 for example.. it is possible that you cannot enter to low numbers, but you can try to do it a few times if you cannot input lower numbers than 380 or so
