- Jun 26, 2014
- 1,173
- 1,812
- Newcastle, England
- C?ID=24330
For one day only, whilst my car was in service, I had a play with an e-tron. The service guy said people are quite polar about them ('marmite' - you either love them or you hate them) but something like this would probably suit my daily commute. Also, being a hybrid, is much better than the Nissan Leaf as there are no worries about running out of charge.
It would be rude to have it all day without grabbing an Auto-Scan:
Tuesday,23,February,2016,16:32:31:26758
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ8V4GA0***** License Plate: NA65***
Mileage: 6052km-3760mi Repair Order: e-tron
Chassis Type: 8V (5QE)
Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75
8C C6
VIN: WAUZZZ8V4GA0***** Mileage: 6052km-3760miles
Address 01: Engine (J623-CUKB) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 023 AF HW: 04E 907 309 F
Component: R4 1.4l TFSI H21 1725
Revision: X3H21---
Coding: 021D0012632401083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM14TFS01104E906023AF 005005
ROD: EV_ECM14TFS01104E906023AF.rod
VCID: 64CDD7B86F33391EFA-8030
5604 - Park/Neutral Switch Input Circuit
P0850 00 [032] - Open or Short to Plus
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0DD 300 045 L HW: 0DD 927 770 B
Component: GSG DQ400E H31 1110
Revision: 00031033 Serial number: TFK01504290287
Shop #: WSC 00099 780 00200
ROD: EV_TCMDQ400021.rod
VCID: 30656BE86B4BD5BECE-8064
17 Faults Found:
32317 - Unknown Error Code
U04B5 00 [002] - -
10893 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [002] - -
60354 - ROD - Unknown Error Code
- 00 [002]
60355 - ROD - Unknown Error Code
- 00 [002]
60356 - ROD - Unknown Error Code
- 00 [002]
60357 - ROD - Unknown Error Code
- 00 [002]
60358 - ROD - Unknown Error Code
- 00 [002]
60359 - ROD - Unknown Error Code
- 00 [002]
60360 - ROD - Unknown Error Code
- 00 [002]
60361 - ROD - Unknown Error Code
- 00 [002]
60362 - ROD - Unknown Error Code
- 00 [002]
60363 - ROD - Unknown Error Code
- 00 [002]
60364 - ROD - Unknown Error Code
- 00 [002]
60365 - ROD - Unknown Error Code
- 00 [002]
60366 - ROD - Unknown Error Code
- 00 [002]
60367 - ROD - Unknown Error Code
- 00 [002]
60369 - ROD - Unknown Error Code
- 00 [002]
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AK HW: 5Q0 907 379 H
Component: ESC H31 0809
Revision: 00000000 Serial number: 61805000001946
Coding: 12F180A23823326E017C060241C32948011C4C80608294F402A100788608
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_AU37.rod
VCID: 050BEA3C8449A0164D-8050
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0373591152
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7149C0BD371FEE70-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 F HW: 8V0 820 043 F
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 00000000684704
Coding: 0310001000000000000000000000100001000000
ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
ROD: EV_AirCondiFrontRDWAU37X.rod
VCID: 356B5AFC9429F0969D-8060
Subsystem 1 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: LM151993003807000181
Subsystem 3 - Part No SW: 12E 820 803 E HW: 12E 820 803 E
Component: J842 eKK H02 0005
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AQ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061519600494
Coding: 07151C42C25106FD038C5004B31407A80800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 0717E034BE45B2063F-8052
Slave 1:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150701 042 0580
Serial number: 150704185228
Coding: 0A47F7
Slave 2:
Component: G397_RLFS H06 0002
Serial number: 24078775
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 04 05 2015 00001346
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY151672XRZ
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000063127378
Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000FKK9S00000
Coding: 901E00
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39231519400576
Coding: 0000040011
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3C7D4FD8B70321DE62-8068
Part No SW: 5Q0 959 655 S HW: 5Q0 959 655 S
Component: AirbagVW20 010 0870
Serial number: 003MFR011R6G
Coding: 98CCC0000C2000009C5400CA00C800000065
VCID: 50A50B680B8BB5BEAE-8004
Subsystem 1 - Part No SW: ----------- HW: 480 001 207 15
Serial number: 35700000000568C4F41R
Subsystem 2 - Part No SW: ----------- HW: 480 001 207 15
Serial number: 35800000000969C4F41X
Subsystem 3 - Part No SW: ----------- HW: 480 401 407 15
Serial number: 3510002BD1C52F439268
Subsystem 4 - Part No SW: ----------- HW: 480 401 407 15
Serial number: 3520002A91B7E8F1F3AU
Subsystem 5 - Part No SW: ----------- HW: 480 402 306 15
Serial number: 3550002BD1C52F344324
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 402 906 15
Component: PedP_Sensor_D 001 6149
Serial number: 2280002BD1B65D534044
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 402 906 15
Component: PedP_Sensor_P 001 6149
Serial number: 2290002B31B65D548297
Subsystem 8 - Part No SW: ----------- HW: 480 002 805 15
Serial number: I0M00000000AC8016494
Subsystem 9 - Part No SW: ----------- HW: 480 002 805 15
Serial number: I0N0000000078901649%
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 FB HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 15071504220491
Coding: A418
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 7F0778D4E695FAC607-802A
Part No SW: 8V0 920 972 E HW: 8V0 920 972 E
Component: KOMBI H03 6421
Coding: 27240C182B8026000103E8101200000000000000
VCID: 40853B28DBEB453E3E-8014
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
Fault Frequency: 14
Mileage: 43 km
Date: 2015.11.04
Time: 07:53:56
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5QE 907 530 D HW: 5QE 907 530 A
Component: GW MQB EV 312 3225
Revision: -------- Serial number: 27061510804213
Coding: 0201001726F200005B001208580000000001010100010000000000000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti.rod
VCID: 47972034FEC57206FF-8012
Subsystem 1 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 06 07 2015 E0024140
Subsystem 2 - Part No SW: 5QE 915 181 HW: 5QE 915 181
Component: J367-BDMHella H04 8050
Serial number: 1713827103
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5QE 909 059 D HW: 5QE 909 059 B
Component: EBKV H14 0182
Serial number: 085430010238
Coding: 03720100331902030002050500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
ROD: EV_BrakeBoostBoschMQBOMG_AU37.rod
VCID: 4FA7081416B5AA46B7-801A
Subsystem 2 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861070715001814
239616 - Implausible Data Received from Engine Control Module
U0401 00 [032] - -
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000174836008
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346D67F89F53E99EAA-8060
Component: TSG FS 020 0041
Serial number: 280615BFR15176
Coding: 001C9E204001040000001002
Shop #: WSC 06385 790 00021
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 438F3424CAFD5E2623-8016
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: C102
ROD: EV_SteerAssisMQB.rod
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 D HW: 5G0 907 080 D
Component: VW370P3815010 H06 4492
Revision: 00H06000
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM09550115G0907080D 001018
ROD: EV_DMCM09550115G0907080D.rod
VCID: 28558388539B9D7E16-807C
Component: TSG BFS 020 0041
Serial number: 020715BG11620A
Coding: 001C96204001040000001002
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42813120D5E7572E28-8016
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 011E00002B230200
VCID: 3F8738D4A6153AC647-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7050
Coding: E00100
Part No SW: 8V0 035 036 E HW: 8V0 035 036 B
Component: MU-H-LND-EU H45 0397
Serial number: A300G0F7551897
Coding: 01739301FF00000021111101000A02102F00010701000100DE
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 Q HW: -----------
Component: ECE 2015/2016 --- 0122
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY203P4V
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000015051500020054
Door Electronics Rear Left:
Component: Gracenote --- 1010
Address 75: Telematics (J949) Labels: None
Part No SW: 5QE 035 284 A HW: 5QE 035 284 A
Component: OCULowMQBEU 008 0561
Coding: 017393011080BA0100F800000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5Q0 915 182 C HW: 5Q0 915 182 C
Component: BECM H05 0652
Serial number: T4030045
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006036
ROD: EV_BECM06020115C6915182_AU37.rod
VCID: 336F64E49A5DEEA6B3-8066
Subsystem 2 - Part No SW: 5Q0 915 250 D HW: 5Q0 915 250 D
Component: BJB H27 0240
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0472
Serial number: V013C1550730200
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0472
Serial number: V013C1550730190
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0472
Serial number: V013C1550730189
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0472
Serial number: V013C1550531081
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0472
Serial number: V013C1550730336
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0472
Serial number: V013C1550730334
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0472
Serial number: V013C1550730340
Subsystem 10 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0472
Serial number: V013C1550730335
Address C6: Batt. Chrg. (J1050) Labels: None
Part No SW: 5QE 915 682 AA HW: 5QE 915 682 AA
Component: OBC KOSTAL H61 3017
Revision: -------- Serial number: 0107150FP00148
Coding: 115068203000
ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
ROD: EV_OBCSinglPhaseKLOVW3709_AU37.rod
VCID: 0C1DDF18A723D15E12-8058
End-------------------------(Elapsed Time: 05:08)--------------------------
