Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: Release 26.9.0(x64) Data version: 20260828 DS378.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,30,September,2026,18:37:02:38382
VIN: WAU7FLFF8F1085342 License Plate: CTT7087
Mileage: 128108km-79602mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 26 3C 42 44 52 55 5F 6C
VIN: WAU7FLFF8F1085342 Mileage: 128108km-79602miles
26-Auto Roof -- Status: Malfunction 0010
-------------------------------------------------------------------------------VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13--- CVN: AA4FCDAE
Coding: 0A1D00324426000F2000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C06E765D682698A6B8-8078
VINID: 9D194759C5962160402050C408F83FC6E3
17178 - Databus
U1123 00 [00101111] - Received Error Message
Mileage: 128089 km
Date: 2025.10.31
Time: 05:15:00
Engine speed: 862.75 /min
Normed load value: 23.1 %
Vehicle speed: 1 km/h
Coolant temperature: 57 °C
Intake air temperature: 11 °C
Voltage terminal 30: 14.316 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system malfunction: No
21417 - Internal Control Module Error
P2610 00 [01100000] - Engine Shut-down TimerVCDS
Self-Diagnosis Log
Page 3
Part No SW: 0D9 300 012 K HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4515
Revision: 05853104 Serial number: TFK01411041733 CVN: 0000E245
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1E623DAD903E8B1AF5C-804A
Self-Diagnosis Log
Page 4
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 63164000002716
Coding: 11FF6A9234280A71017A030481C52988562C5080C08194B4024100588208
VCID: 48CEBBF5623AA5AA6F0-801C
0294 - Steering angle sensor
B1168 16 [00001000] - Voltage Too Low
Reset counter: 173
Mileage: 128089 km
Date: 2025.10.31
Time: 05:15:00
0297 - Steering angle sensor
B1168 16 [10001001] - Voltage Too Low
Reset counter: 135
Mileage: 128089 km
Date: 2025.10.31
Time: 05:16:18
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 201
Mileage: 111314 km
Date: 2024.03.30
Time: 16:05:52
16412 - Display for Tire Pressure Monitoring
C1146 02 [10001001] - Signal Failure
Reset counter: 135VCDS
Self-Diagnosis Log
Page 5
Date: 2025.10.31
Time: 05:21:15
16413 - Display for Tire Pressure Monitoring
Reset counter: 135
Mileage: 128089 km
Date: 2025.10.31
Time: 05:21:15
Self-Diagnosis Log
Page 6
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000487946
Coding: 05000004010000000000000000001400
VCID: 3334FC190BBC36722A2-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 20280A57000000000001
328964 - Motor for Front Air Distribution Flap
B1091 71 [00001000] - Actuator Stuck
Fault Frequency: 16
Reset counter: 165
Mileage: 121026 km
Date: 2025.05.17
Time: 17:11:48
Voltage terminal 30: 12.2 V
Inside temperature: 24.8 °C
Outside temperature: 13.5 °C
Front air distribution flap: actual value: 0
Front air distribution flap: actual value: 100.0 %
Air distribution door front - Specified value: 92
329987 - Motor for Defroster Flap
B1090 13 [00001000] - Open Circuit
Fault Frequency: 18
Reset counter: 169
Mileage: 111134 km
Date: 2024.03.29
Time: 09:47:47
Voltage terminal 30: 14.4 V
Inside temperature: 30.2 °C
Outside temperature: 9 °C
Defrost door - Specified value: 52
Defroster flap: actual value: 100.0 %
Defroster flap: actual value: 930VCDS
Self-Diagnosis Log
Page 7
329988 - Motor for Defroster Flap
B1090 71 [00001001] - Actuator Stuck
Fault Frequency: 81
Reset counter: 135
Mileage: 110894 km
Date: 2024.03.15
Time: 10:28:30
Inside temperature: 23.0 °C
Outside temperature: 11 °C
Self-Diagnosis Log
Page 8
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0137
Serial number: 01011430600058 Dataset Number: 8V7909514D 0032
Coding: 04041A46C04122F541604004511007000100000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 79A80E3169500C22A0E-802C
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 141102 042 0585
Serial number: 141112095339
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23415040
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AD HW: 8V0 941 531 AD
Serial number: 10 09 2014 00000852
Serial number: 00000000000060821457
B1263 01 [00001001] - Electrical Failure
Fault Frequency: 60
Reset counter: 95
Mileage: 110895 km
Date: 2024.03.16
Time: 08:00:16
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operatedVCDS
Self-Diagnosis Log
Page 9
Low beams: Not operated
Voltage: 12.8 V
Outside temperature: 12.0 °C
545300 - Databus
[Gateway_78 Datenbus empfangener Fehlerwert EPS_Lastinfo]
Reset counter: 135
Mileage: 128089 km
Date: 2025.10.31
Time: 05:11:22
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: Not operated
last_wakeup: gültiges Funktelegramm
Voltage: 14.2 V
Outside temperature: 5.0 °C
Self-Diagnosis Log
Page 10
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39331431400179 Dataset Number: 8V7909526C 0010
Coding: 0030150011
ROD: EV_EPHVA18AU3700000_002_AU37.rod
VCID: 42DAA9DD44068FFAB14-8016
13637426 - Databus
Reset counter: 135
Mileage: 128089 km
Date: 2025.10.31
Time: 05:15:00
Self-Diagnosis Log
Page 11
Part No SW: 5Q0 959 655 AC HW: 5Q0 959 655 AC
Component: AirbagVW20 009 0825
Serial number: 003MNR002R2K Dataset Number: 8V7909602B 0008
Coding: 9DC0F0C00000A0005000001AC24800000065
VCID: 015866D1018054E2E8E-8054
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34178313B07111440499
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34178314B07111470685
Coding: 333135
Subsystem 3 - Part No SW: 5C6 959 339 C HW: 5C6 959 339 C
Component: BF-Gewichtss. H10 0047
Serial number: 6940000Y140001922U0G
Coding: 303435
Subsystem 4 - Part No SW: ----------- HW: 480 000 711 14
Serial number: 3570000000045501B110
Subsystem 5 - Part No SW: ----------- HW: 480 000 711 14
Serial number: 3580000000076501B115
Subsystem 6 - Part No SW: ----------- HW: 480 012 909 14
Component: SideSensor_Dr 004 0108
Serial number: 351001A01DB0E1732E33
Subsystem 7 - Part No SW: ----------- HW: 480 400 910 14
Serial number: 3550002A718166A360A/
Coding: 2D2D2DVCDS
Self-Diagnosis Log
Page 12
Subsystem 8 - Part No SW: ----------- HW: 480 400 910 14
Component: FrontSensor_P 001 6149
Serial number: 3560002A718166A2316Y
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 135
Mileage: 128089 km
Date: 2025.10.31
Time: 05:15:00
Part No SW: 8V0 953 521 CB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 10111408491621
Coding: A018
ROD: EV_SMLSKLOMQB_017_VW37.rod
VCID: 7CA617256662390ABB8-8028
Part No SW: 8V0 920 971 D HW: 8V0 920 971 D
Component: KOMBI H02 4291
Coding: 0BF410092B88D7050200E8001800000000000000
VCID: 3E22DD2D30FEEB1AD5C-806A
Self-Diagnosis Log
Page 13
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 01111410803240 Dataset Number: 8V7909515D 0024
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
GVL: 01D43C0000200000404C10000002C80000000000000000000000000000000000
ROD: EV_GatewConti_011_VW37.rod
VCID: 72BA391D34267F7AE14-8026
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 08 11 2014 E0026355
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00006.10.14 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
VCID: 46D2B5CD682EB3DA9DC-8012
16671 - Pump for Haldex Clutch
C1112 04 [00001000] - Internal System Fault
[Pump Motor - mechanisch defekt (mechanisch festgefahren)]
Fault Frequency: 141
Reset counter: 175
Mileage: 110894 km
Date: 2024.03.15
Time: 10:32:25
Self-Diagnosis Log
Page 14
Address 26: Auto Roof (J256) Labels: 8V7-959-255.clb
Part No SW: 8V7 959 255 HW: 8V7 959 255
Component: VSG-AU375 H03 0030
Coding: C00000
ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
ROD: EV_ElectRoofContrMAQAU37X.rod
VCID: 084E7BF522BA65AAAF0-805C
0021 - Databus
[Motor_14 - No Signal]
Reset counter: 154
Mileage: 122782 km
Date: 2025.09.27
Time: 11:53:52
Self-Diagnosis Log
Page 15
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0350643041 Dataset Number: 8V7909535B 0009
Coding: 030211
ROD: EV_LaneChangAssis_AU37.rod
VCID: 382ECB3512DAD52A1F0-806C
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0349346283
Coding: 030211
733696 - Control Module 2 for Lane-Change Assist
C1115 F5 [00001000] - Limited Visibility
Reset counter: 149
Mileage: 123598 km
Date: 2025.10.10
Time: 13:37:41
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 28101406070164 Dataset Number: 8V7909872F 0022
Coding: 00104F724008048000000402
Subsystem 1 - Part No SW: 5Q0 959 812 C HW: 5Q0 959 812 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 002 0005
Serial number: 00000000000003515646
Coding: 110000
Self-Diagnosis Log
Page 16
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Dataset Number: 8V7909852F 0012
Coding: 0102
VCID: 43D4ACD95B1C86F2BA2-8016
4867 - Internal Fault
B200F F0 [00001000] - -
[Fehler im Abschaltpfadtest 1st current check (PWM: 65/35/50)]
Motor status: 00
System status: Reset
Supply voltage: 12.25 V
Temperature: 13.0 °C
KFC: 13
KFA: 00 03
Freeze frame conditions: 71
nApplI_RotorSpeedFilt_xds16: 1 /min
mApplI_LimitedMotorTorque_xds16: 0.000 Nm
icuCurrentPhase_U_IRQ_xds16: 5.50 A
icuCurrentPhase_W_IRQ_xds16: 0.38 A
mApplI_TorsionBarTorque_xds16: 0.00 Nm
wrsCurrRotorPosIRQ_xdu16: 179.2 °
229504 - Internal Control Module Memory Check Sum Error
B2000 00 [10011001] - -
[Steuergerät defekt - Interne Störung]
MIL ON - Confirmed - Not Tested Since Memory Clear
Motor status: 00
KFC: 13
KFA: 00 03VCDS
Self-Diagnosis Log
Page 17
16130 - Steering Angle Sensor
B1168 F2 [00001001] - Not Initialized
Reset counter: 0
Motor status: 00
Supply voltage: 11.50 V
Temperature: 12.0 °C
KFC: 3F
KFA: 00 02
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 11.63 V
uAdSensI_SwitchedKl30_xdu16: 11.62 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 01111401100675 Dataset Number: 8V7909873F 0022
Coding: 001047724008048000000402
VCID: 41D8A6D1410094E2A8E-8014
Subsystem 1 - Part No SW: 5Q0 959 811 C HW: 5Q0 959 811 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 002 0005
Serial number: 00000000000004219303
Coding: 090000
Self-Diagnosis Log
Page 18
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: -------------- Dataset Number: 8V7909865D 0017
Coding: 012A000101000000
ROD: EV_HeadlRegulVWLWRMQB_VW37.rod
VCID: 75B0020145486842C46-8020
Self-Diagnosis Log
Page 19
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 047 G HW: 8V0 035 047 B
Component: MU-H-NS-US H43 0394
Serial number: A052K0EB003124 Dataset Number: 8V7909545E 0017
Coding: 01730502FF08000021220001041A00002F000105010001047E
Shop #: WSC 10869 003 1048576
ROD: EV_MUHig6C3HBAS_VW48.rod
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Multimedia display unit 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY202470
Subsystem 3 - Part No SW: 8V0 919 614 K HW: 8V0 919 614 K
Component: ControlUnit_H H81 0816
Serial number: C1000025081400010264
Compact disc data bank:
Component: Gracenote --- 3006
Reset counter: 133
Mileage: 110894 km
Date: 2024.03.15
Time: 10:29:36
Satellite radio tuner status-Audio Signal: Available
Satellite radio tuner status-Reception quality: optimum_signal
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
0522 - Front Left Bass SpeakerVCDS
Self-Diagnosis Log
Page 20
[Tieftonlautsprecher Kanal 3: Unterbrechung]
Reset counter: 135
Mileage: 110894 km
Date: 2024.03.15
Time: 10:29:41
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Dataset Number: 8V7909460A 0007
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 303EF315FAAA0D6A570-8064
9529428 - Steering angle sensor
B1168 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 135
Mileage: 128108 km
Date: 2026.07.18
Time: 22:04:50
Initialization
End----(Elapsed Time: 01:32, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
------------------------------23 Faults Found------------------------------
