Missing label files VW CADDY 2016
LN-TAL
Norway
C?ID=13729
There is some missing files on the 2016 caddy.
Saturday,20,February,2016,14:00:09:62006
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WV1ZZZ2KZGXxxxxxx License Plate:
Chassis Type: 2K (7N0)
Scan: 01 02 03 08 09 13 15 16 17 18 19 22 25 42 44 46 52 5F 61 69
Address 01: Engine (J623-DFSB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 016 BS HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1798
Revision: 8AH20---
Coding: 011D001A047615090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016BS 001004
ROD: N/A
VCID: 7BFF58CDF21756E62B-802E
No ASAM data for: "EV_ECM20TDI01104L906016BS" (VN35)
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 016 J HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4902
Revision: 06253104 Serial number: 00001512010215
Shop #: WSC 35110 377 08192
VCID: 1B3F784DDA57F6E68B-804E
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H05 0132
Revision: 00000000 Serial number: 43305000000341
Coding: 1079809BB36AA48508770177CD8525A378F750
ROD: EV_Brake1ESCCONTIVN75XGP2.rod
VCID: 4085EF21DB71F53E3E-8014
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 1K8 907 426 AE HW: 1K8 907 426 AE
Component: AC Manuell H20 0808
Revision: 00001002
Coding: 0010004003
ROD: EV_ACManueBHBVW36X_SE36.rod
VCID: 76E949F9C9350B8E54-8022
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0183
Revision: BD122001
Coding: 611A0A3A8025086D088800809000096C03850008424DAD20E48487000041
VCID: 73EF70EDD2471EA673-8026
Subsystem 1 - Part No: 2K1 955 119 D
Component: Wischer 01121 26 0512
Coding: 009795
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 7N0 907 572 A HW: 7N0 907 572
Component: ACC Bosch PQx H03 0111
Serial number: 10011677110172
Coding: 00001800FE0339
ASAM Dataset: EV_ACCBEGVW361 001004
ROD: EV_ACCBEGVW361_SE36.rod
VCID: 346DB3F19FC9599EAA-8060
1130 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
Fault Priority: 9
Reset counter: 43
Mileage: 158 km
Date: 2000.14.24
Time: 16:23:05
1132 - Sensor for Automatic Distance Control
Fault Priority: 9
Reset counter: 43
Mileage: 118 km
Date: 2000.14.24
Time: 13:53:20
1131 - Sensor for Automatic Distance Control
Fault Priority: 9
Reset counter: 43
Mileage: 158 km
Date: 2000.14.24
Time: 16:23:05
1542 - Sensor for Automatic Distance Control
Reset counter: 43
Mileage: 118 km
Date: 2000.14.24
Time: 13:53:35
1545 - Sensor for Automatic Distance Control
Reset counter: 43
Mileage: 118 km
Date: 2000.14.24
Time: 13:53:35
Address 15: Airbags (J234) Labels: None
Part No SW: 2K5 959 655 HW: 2K5 959 655
Component: VW10Airbag017 008 0016
Revision: -------- Serial number: 003QV001AV2I
Coding: 000000000000000000000000000000003137
ROD: EV_AirbaVW10BPAVN750_SE12.rod
VCID: 79F342C5F82B64F639-802C
Serial number: 3497ARB400O55585BBS5
Serial number: 3507ARB40553NM3QH212
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 FG HW: 5K0 953 569 BC
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20151215301840
Coding: 1882C60008
ROD: EV_SMLSNGVOLWSR8C.rod
Subsystem 1 - Part No SW: 2K0 959 442 A HW: 2K0 959 442 A
Serial number: 3421502272500268BC1B
Coding: 2C0000
Address 17: Instruments (J285) Labels: None
Part No SW: 2K5 920 876 A HW: 2K5 920 876 A
Component: KOMBI H04 1009
Coding: 180A001100
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
VCID: 336FB0ED9AC75EA6B3-8066
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 E
Component: Standheizer 044 4941
Revision: 00044000 Serial number: 09028239000000
Coding: 0031032
Shop #: WSC 35110 377 00177
VCID: 377784FD46BFB2868F-8062
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 041215F1002489
Coding: 357420
VCID: 72E175E9AD5D17AE78-8026
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00020.11.15
Coding: 0501
ROD: EV_AllWheelContrHA1VW37X_VN35.rod
VCID: 52A1D569051D77AE98-8006
Component: IMMO H04 1009
VCID: 6AD16D898D8DDF6EC0-803E
Address 42: Door Elect, Driver Labels: None
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2143
Coding: 0132144
VCID: 71E37AE5685B2CB681-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 397382C570ABA4F679-806C
Address 52: Door Elect, Pass. Labels: None
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0132144
Shop #: WSC 35110 377 00149
VCID: 72E175E96D5D17AE78-8026
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 C HW: 1K8 035 150 C
Component: MU-E-D-ER 857 6499
Serial number: 04121500010192
Coding: 063307002800000041111101008000001F0000940000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_SE25.rod
VCID: 254B5EB5241330162D-8070
1564 - Microphone 1
B129B 13 [008] - Open Circuit
Reset counter: 47
Mileage: 386 km
Date: 2000.14.31
Time: 09:15:44
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1663
Coding: 330F1873
VCID: 71E37AE5A85B2CB681-8024
Subsystem 1 - Part No SW: 1K0 915 181 K HW: 1K0 915 181 K
Component: J367-BDM H07 0223
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000389561677
Coding: 010D000103000000
VCID: 3261B5E96DDD57AEB8-8066
End-------------------------(Elapsed Time: 02:49)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Would you mind emailing that scan to us (Support@Ross-Tech.com) and include the full VIN? Appreciated.
