Hello all, having an issue with my front radar on a 2018 GTI. after driving for a few miles, the front sensor error will appear on the cluster saying "no view". If I turn it off then back on it will go away and then repeat after driving. In the time when it's working, it'll show the 2 cars with the exclamation mark when I'm driving close to someone. Horizontal misalignment is -0.157, fast algorithm is -0.385 and vertical deadjustment is 1.354. I've taken off the badge, cleaned the sensor and front and back of the badge. Any help would be appreciated
Monday,30,March,2026,16:55:57:14918
VCDS Version: 25.3.0.4 (x64) HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: 3VW547AU8JM292268 License Plate: GTI
Mileage: 103948km-64590mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 16 17 19 29 2B 32 39 3C 42 44 4B 52 5F
75 A9 D6 D7
VIN: 3VW547AU8JM292268 Mileage: 103948km-64590miles
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: E527EE9C
Coding: 091900122424002F1000
Shop #: WSC 00066 790 00235
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 37205882EFCE20D27ED-8062
VINID: 0E69C510746521A74224208620BA48E174
Readiness: 0000 1100
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 CP HW: 5Q0 614 517 AB
Component: ESC H25 0323
Revision: 00000000 Serial number: 61158000001399
Coding: 01FA6BA15429096E4079020660CB6880D62A90024006163610435051C089430B00000012121212B835351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
ROD: EV_Brake1UDSContiMK100ESP_037.rod
VCID: 0154F65AF18AAE62809-8054
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0474201041 Dataset Number: V03935252QE 0001
Coding: 032C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3C2A47AED6E8038A93F-8068
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 G HW: 5GM 907 426 G
Component: AC Manuell H03 2001
Revision: 00001K05
Coding: 00020004200110000000000000000006
ROD: EV_ACManueBHBVW37X_004_VW37.rod
VCID: 4CCA176E8648B30A23F-8018
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C8641107180140 Dataset Number: V03935274HK 0001
Shop #: WSC 00066 790 00145
ROD: EV_BCMBOSCH_018.rod
VCID: 0B48D472C3C6F432EA5-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 180418 043 0551
Serial number: 97022066180427012646
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S7Y18M06D08H23M21S23
Coding: 00A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 5GD 959 591 A HW: 5GD 959 591 A
Component: J245 PS60.006 H07 0170
Serial number: 03691601961211170300
Coding: 181803
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Dataset Number: V03935266FC 0205
Coding: 2D00008101FFC728949C810500401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E2E4DA6C0F4119ABDB-806A
1538 - Sensor for Automatic Distance Control
C110B F0 [00001001] - Limited Visibility
[FAULT_SENSOR_BLIND]
Reset counter: 87
Mileage: 103944 km
Date: 2026.03.30
Time: 16:49:30
Control Module temperature: 38 °C
Voltage terminal 15: 13.9 V
Velocity_vehicle_reference: 30.55 m/s
Longitudinal_acceleration_vehicle_reference: -0.42 m/s²
1542 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_BLIND]
Reset counter: 87
Mileage: 103944 km
Date: 2026.03.30
Time: 16:49:30
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR098U1K Dataset Number: V03935251DQ 0001
VCID: 47C028429F2E50520ED-8012
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000009IM7DT
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 002 406 18
Serial number: 3570000000050C442032
Subsystem 3 - Part No SW: ----------- HW: 480 002 306 18
Serial number: 35800000000A51594F2O
Subsystem 4 - Part No SW: ----------- HW: 480 401 105 18
Serial number: 3510001A329D6792E65A
Subsystem 5 - Part No SW: ----------- HW: 480 401 105 18
Serial number: 3520001AD29B7D6685BQ
Subsystem 6 - Part No SW: ----------- HW: 480 402 905 18
Component: FrontSensor_D 004 6149
Serial number: 3550001102AE89C5F217
Subsystem 7 - Part No SW: ----------- HW: 480 402 905 18
Component: FrontSensor_P 004 6149
Serial number: 3560001102AE89C65376
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 10051804401633
Coding: 0400
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 0740E842DFAE9052CED-8052
Part No SW: 5G1 920 856 C HW: 5G1 920 856 C
Component: KOMBI 342 0310
Coding: 0BAD0912A988CF0502886B095000000080000000
VCID: 2E0E7DE61094E11A2DB-807A
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 07071800841425 Dataset Number: V03935272LR 0001
Coding: 0101000830085900FB00002B080F00000001070000000000000000000000
Shop #: WSC 00066 790 00011
GVL: 01523C5000000600404C80008000480000000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 38225BBEE2D02FAA777-806C
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29180000991700078191
Coding: 30FFFF
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000150560004
Coding: 5500000000000000
VCID: 343A6F8EFEB8CBCA5BF-8060
Address 32: Differential Locks (J492) Labels:| 0CQ-907-554-V2.clb
Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
Component: Quersperre H52 8043
Serial number: HA1-00028.02.18 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 52F60916646CE5FA693-8006
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0480361067 Dataset Number: V03935270GQ 0001
Coding: 01011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D2C4AAACDF20A82A41-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0481171791
Coding: 010111
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038819101481 Dataset Number: V03935265HB 0001
Coding: 003E13200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000551916
Coding: 011000
Part No SW: 5QN 909 144 A HW: 5QN 909 144 A
Component: EPS_MQB_ZFLS 507 5081
Dataset Number: V03935281SJ 0001
Coding: 810A0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50F2031E6A6097EA5F7-8004
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 11071800841130 Dataset Number: V03935262LQ 0001
Coding: 000000050100210A01110F00030000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_001_VW37.rod
VCID: 72B6A996C42C85FA893-8026
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038819400406 Dataset Number: V03935265HC 0001
VCID: 46DE25469824495AF5B-8012
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000482248
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 722 0867
Serial number: Dataset Number: V03935281LR 0001
Coding: 02731000FF00000051220001001808009F0503D40120050002
ROD: EV_MUStd4CDELP_VW37.rod
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 252 8130
Serial number: VWZ6ZMV1755195
Reset counter: 86
Mileage: 103931 km
Date: 2026.03.30
Time: 15:16:00
Voltage terminal 30: 14.1 V
SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 113 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
ROD: EV_OCULowMQB_VW37.rod
VCID: 43D83C52AB167C72D25-8016
Part No SW: 5G0 907 159 G HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 180426201051
VCID: 3236699604ACC5FA493-8066
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 39245EBAD9DA36A2889-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:45, VBatt start/end: 13.9V/13.8V)-----------
------------------------------3 Faults Found-------------------------------
