Missing ROD and ASAM dataset update failing
   #41
Yep, I haven't done a mobile scan for a while as my wireless LAN doesn't stretch to the car, and I can't get VCDS Cloud to work reliably over 4G tethering in the UK, everything seems to time out and lose connection.
That shouldn't matter. Just put the interface in Access Point mode.
andyvee
Rossendale, Lancashire, UK
C?ID=159389
[COLOR=#000000]VCDS Mobile 0.4309.0.4[/COLOR]
VIN: TMBKJ9NE0F0104172
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6D
	 A5
Address 01: Engine  (CKFC2 J623)	Labels: None
	Part No SW: 04L 906 021 DT	HW: 04L 907 309 D
	Component: R4 2,0L EDC   H22 7545
	Revision: 83H22---
	Coding: 111D0032046501091000
	Shop #: WSC 73430 031 00000
	ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
	ROD: EV_ECM20TDI01104L906021DT_SK37.rod
	VCID: 7AB761EB603BD16227C740ABE0-802F
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0D-02.lbl
	Part No SW: 0D9 300 041 P	HW: 02E 927 770 AQ
	Component: DQ250-6F MQB  H53 4507
	Revision: 03253104
	ROD: EV_TCMDQ250021_AU37.rod
	VCID: 250D6297B9058E9A3A759BAF31-8070
Address 03: ABS Brakes  (J104)	Labels: None
	Part No SW: 5Q0 907 379 M	HW: 5Q0 907 379 H
	Component: ESC           H31 0571
	Revision: 00000000
	Coding: 1C078A91242009700078060741C5243851249000608224F2F661F072C009
	Shop #: WSC 73430 031 00063
	ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
	VCID: 46CFC51B6443658213BF045B44-8013
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 5Q0 959 435 A	HW: 5Q0 959 435
	Revision: 00021000
	Coding: 030C0C
	Shop #: WSC 73430 790 00000
	ROD: EV_KessyHellaMQBAB_AU37.rod
	VCID: 3A37A1EB20BB1162674780AB20-806F
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5E0 907 044 N	HW: 5E0 907 044 N
	Component: Climatronic   H03 0907
	Revision: 00001K06
	Coding: 02110104000100011005000100101000
	ASAM Dataset: EV_ACClimaBHBVW37X 003017
	ROD: EV_ACClimaBHBVW37X_SK37.rod
	VCID: 302383C3F6C7DB32D9E31253A6-8065
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: None
	Part No SW: 5Q0 937 086 AA	HW: 5Q0 937 086 AA
	Component: BCM PQ37BOSCH 028 0106
	Revision: --------
	Coding: 0F511B76424722FB0FA44086B11C17280800000000000000000000000000
	Shop #: WSC 73430 790 12345
	ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
	ROD: EV_BCMBOSCH_AU37.rod
	VCID: 79B57EE7653DDA7A2EBD37BFFD-802C
	Subsystem 1 - 	Part No SW: 5E2-955-119	Labels: 5Qx-955-119-V1.clb
	Component: Mý
	Subsystem 2 -
	Subsystem 3 -
	Subsystem 4 -
	Subsystem 5 - 	Component: ™
	Subsystem 6 - 	Component: ™
	Subsystem 7 -
Address 10: Park/Steer Assist  (J791)	Labels: 5Q0-919-298.clb
	Part No SW: 5Q0 919 298 F	HW: 5Q0 919 298
	Component: PARKHILFE PLA H12 0047
	Revision: --------
	Coding: 0131161051
	Shop #: WSC 73430 790 00063
	ASAM Dataset: EV_EPHVA2CAU3700000 003019
	ROD: EV_EPHVA2CAU3700000_SK37.rod
	VCID: 42C7D90B486B59A23F97D80B88-8017
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 D	HW: 5Q0 907 572 D
	Coding: 00081600FE0739
	ROD: N/A
	VCID: 3833BBE31EB7037291336AB30E-806D
	No ASAM data for: "EV_ACCMRRBoschVW372"
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 3Q0 959 655 AA	HW: 3Q0 959 655 AA
	Component: Airbag VW20   012 0200
	Revision: --------
	Coding: 98FCC000000000005C5400CC008800000065
	ROD: EV_AirbaVW20TS6VW48X_SK37.rod
	VCID: 7DBD6AF77115E65A02E563CF89-8028
	Subsystem 1 - 	Part No SW: 5G0-980-945-B
	Component: 315
	Subsystem 2 - 	Component: 315
	Subsystem 3 - 	Component: ---
	Subsystem 4 - 	Component: ---
	Subsystem 5 - 	Component: ---
	Subsystem 6 - 	Component: ---
Address 16: Steering wheel  (J527)	Labels: 5Q-16.lbl
	Part No SW: 5Q0 953 507 EJ	HW: 5Q0 953 549 C
	Revision: --------
	Coding: 6C10
	ROD: EV_SMLSKLOMQB_SK37.rod
	VCID: 8247990B88EB19A2FF17980B48-80D7
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5E0 920 911	HW: 5E0 920 911
	Component: KOMBI         304 4270
	Coding: 27A50A186D90A60001887A031000000000000000
	Shop #: WSC 00123 123 12345
	VCID: E083B38366A7ABB289C3A293B6-80B5
Address 19: CAN Gateway  (J533)	Labels: 5Q0-907-530-V1.clb
	Part No SW: 5Q0 907 530 T	HW: 5Q0 907 530 F
	Component: GW MQB High   128 1188
	Revision: --------
	Coding: 030100340F087300EF00025E1C0F00010001050000000000000000000000
	ASAM Dataset: EV_GatewLear 011016
	ROD: EV_GatewLear.rod
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 2B: Steer. Col. Lock  (J764)	Labels: 5Q0-905-861.clb
	Part No SW: 5Q0 905 861 A	HW: 5Q0 905 861 A
	Revision: 00000000
	Coding: 5D00000000000000
	ROD: EV_ELVMarquMQB_AU37.rod
	VCID: 342B8FD302DFE712BD0B3E6372-8061
Address 36: Seat Mem. Drvr  (J810)	Labels: None
	Part No SW: 5Q0 959 760 A	HW: 5Q0 959 760 A
	Component: Sitzmemory    H06 0009
	Coding: 001400000000010001A081808080000000008181000000D4
	ASAM Dataset: EV_SeatMemorDriveSide 001015
	ROD: EV_SeatMemorDriveSide_SK37.rod
	VCID: 3B39A4EF2F81286A7C518DD7D7-806E
Address 42: Door Elect, Driver  (J386)	Labels: None
	Part No SW: 5Q4 959 593 B	HW: 5Q4 959 593 B
	Component: TSG FS        009 0014
	Coding: 001D0820DE01048000001100
	ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
	VCID: 44CBDF13527F57920DABEE23A2-8011
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 5Q0 909 144 P	HW: 5Q0 909 144 P
	Component: EPS_MQB_ZFLS  122 1043
	Coding: 9302
	ROD: EV_SteerAssisMQB.rod
	VCID: 41C5D6074D6D42BA268DCF1F85-8014
Address 52: Door Elect, Pass.  (J387)	Labels: None
	Part No SW: 5Q4 959 592 B	HW: 5Q4 959 592 B
	Component: TSG BFS       009 0014
	Coding: 001D0020DE01048000001100
	ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
	VCID: 43C9DC0F577150AA34A1E537BF-8016
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Part No SW: 7P6 907 357 D	HW: 7P6 907 357 A
	Revision: --------
	Coding: 03CE02003F010000
	ROD: EV_HeadlRegulVWAFS_SE26.rod
	VCID: 40C3D30346674BB22983C21396-8015
	Subsystem 1 - 	Part No SW: 1T0-941-329-B	Labels: 3D0-941-329.clb
	Component: >
Address 5F: Information Electr.  (J794)	Labels: None
	Part No SW: 5E0 035 020 C	HW: 5E0 035 020 C
	Component: MU-H-ND-EU    H43 0390
	Coding: 03730201000000001111120200A800002F0003F601000100F6
	Shop #: WSC 47024 001 104857
	ASAM Dataset: EV_MUHig6C3HBAS 001041
	ROD: EV_MUHig6C3HBAS_SK37.rod
	VCID: 1771585F73692C0AB8E90107FB-8042
	Subsystem 1 - 	Part No SW: 5E0-919-606
	Component: ABT_High
	Subsystem 2 -
0006 - Antenna Amplifier 2 for Radio
	B126E 13 [008] - Open Circuit
		Fault Status: 00000000
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 66289 km
0008 - Connection between Antenna Amp 2 for Radio and Antenna
	B1273 13 [008] - Open Circuit
		Fault Priority: 8
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 197361 km
0013 - Antenna Amplifier 1 for Digital Radio
	B1270 13 [008] - Open Circuit
		Fault Priority: 13
		Fault Frequency: 8
		Reset Counter: 1
		Mileage: 66289 km
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 5E0 959 107 A	HW: 5E0 959 107
	Component: HDSG-Modul    H01 0746
	Revision: 42001001
	Coding: 1233074002
	ASAM Dataset: EV_HDSGSk462 301136
	ROD: EV_HDSGSk462_SK37.rod
	VCID: 2A1791ABD01BA1E217A7D0EBF0-807F
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 5Q0-980-653.clb
	Part No SW: 5Q0 980 653 F	HW: 5Q0 980 653
	Component: MQB_MFK       H06 0052
	Coding: 0100010001030303000400000100010100
	ROD: EV_MFKBoschAU370_AU37.rod
 [COLOR=#000000]No fault codes found.[/COLOR]
Any idea why it fails to retrieve data on the majority of sub-modules as well?
D-Dub
C?ID=272151
still having rod re-downloading problems with CB V0.4313
updated to ds 10000042 successfully with 16.3 updater app
still (re) downloading same rod files over and over again.
tried with both app updater and hexnet web
Piranha
Malta
C?ID=90948
HI,
Still having the same issue with the 1.6l TDI ASAm Data.
VCDS keeps trying to download data for the engine ecu each time and it never works.
To make this worse, issue is on my own car. :(
Autoscan:
VCDS-Mobile
Auto-Scan
Finished
VIN: 12345678901234567
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 55 56 5F
Address 01: Engine  (CAYC6 J623)	Labels: 03L-906-023-CAY.clb
	Part No SW: 03L 906 023 KQ	HW: 03L 906 023 KP
	Component: 1,6L R4 CR td H63 8530
	Revision: --H63---
	Coding: 00114036032501080000
	Shop #: WSC 00046 790 00000
	ASAM Dataset: EV_ECM16TDI02103L906023KQ 003009
	ROD: N/A
	VCID: 7F4190FF7A47F47640F979E7AF-802A
	No ASAM data for: "EV_ECM16TDI02103L906023KQ"
Address 03: ABS Brakes  (J104)	Labels: 6R0-907-37x-ESP82.clb
	Part No SW: 6R0 907 379 BB	HW: 6R0 907 379 AH
	Component: ESP8.2i front H07 0001
	Revision: --------
	Coding: 330448E9436D00B2CC2C12E8C2D200920F00
	Shop #: WSC 00046 123 12345
	VCID: 7F4190FF7A47E87640F979E7AF-802A
Address 08: Auto HVAC	Labels: None
	Part No SW: 8X0 820 045 A	HW: 8X0820045A
	Component: J255 Klima Manuell   0140
	Revision: 0000707S	Serial Number: 03030004579074
	Shop #: WSC 00046 000 00000
	VCID: 342B8FD303817F2EED0B3E637E-8061
00898 - Control Circuit A/C compressor
		Fault Status: 00100111
		Reset Counter: 30
Address 09: Cent. Elect.  (J519)	Labels: 8X0-907-063.clb
	Part No SW: 8X0 907 063 D	HW: 8X0 907 063 D
	Component: BCM PQ35  M   108 0621
	Revision: 00108 AC
	Coding: 06000AB8E003F100A00041E021008948537E000A31EFD522E40887870045
	VCID: 3D3DAAF730CB3E661265A3CFC5-8068
	Subsystem 1 - 	Part No SW: 8K0-955-559	Labels: 8K-09-01.lbl
	Component: RLS          H04 0003
	Coding: 02562D
	Subsystem 2 - 	Part No SW: 8X0-951-177
	Component: DWA-Sensor H0H01 0020
	Subsystem 3 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
00332 - Control Circuit for Tank Flap
		Fault Status: 01100111
		Fault Frequency: 13
		Reset Counter: 250
		Mileage: 55915 km
		Date: 2016.04.11
		Time: 10:20:37
		: Term 15 Off
		Voltage: 12.25 V
		: OFF
		: ON
		: Term 50 Off
		: OFF
		: OFF
Address 10: Park/Steer Assist  (J446)	Labels: 8X0-919-475.clb
	Part No SW: 8X0 919 475 R	HW: 4H0 919 475 C
	Component: PARKHILFE 8K  H07 0050
	Revision: 11001001
	Coding: 040001
	ASAM Dataset: EV_EPHVA18AU21X0000 002005
	ROD: EV_EPHVA18AU21X0000.rod
	VCID: 55ED1257A8BBDE263A55ABEF8D-8000
Address 15: Airbags  (J234)	Labels: 8X0-959-655.clb
	Part No SW: 8X0 959 655 A	HW: 8X0 959 655 A
	Component: Airbag10.41   H04 0008
	Revision: --------
	Coding: 30314539303330303034554A305238583053
	ASAM Dataset: EV_Airba1041BPAAU210 001015
	ROD: EV_Airba1041BPAAU210.rod
	VCID: 48D3CB236F0973CEB1D31A7372-801D
	Subsystem 1 - 	Serial Number: 3554VRB404R0FAME6OTQ
	Subsystem 2 - 	Serial Number: 3575HRB40650HM78D0RC
	Subsystem 3 - 	Serial Number: 3585HRB40650HM78714S
Address 16: Steering wheel  (J527)	Labels: 8X-16.lbl
	Part No SW: 8X0 953 501 D	HW: 5K0 953 569 H
	Revision: FF010016
	Coding: 1184204000
	VCID: 3B39A4EF2EDF28562C518DD7DB-806E
Address 17: Instruments  (J285)	Labels: 8X0-920-xxx-17.clb
	Part No SW: 8X0 920 980 A	HW: 8X0 920 980 A
	Component: KOMBI         H07 0124
	Coding: 11DE00
	Shop #: WSC 00046 790 12345
	ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04086
	VCID: 3D3DAAF730CB26661265A3CFC5-8068
Address 19: CAN Gateway  (J533)	Labels: 8X0-907-468.clb
	Part No SW: 8X0 907 468 A	HW: 8X0 907 468 A
	Component: GAT 4CAN 1L M H04 0083
	Revision: 1C060023
	Coding: FBCF005A000100010153
	VCID: 43C9DC0F562F489664A1E537B3-8016
	Subsystem 1 - 	Part No SW: 8K0-915-181-H
	Component: J367-BDM     H07 0171
	Subsystem 2 - 	Part No SW: 8K0-959-663-B
	Component: J532_DCDCStabH05 0006
Address 25: Immobilizer  (J334)	Labels: 5K0-920-xxx-25.clb
	Component: IMMO          H07 0124
	Coding: 000002
	ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04008
	ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver  (J386)	Labels: 8X0-959-793.clb
	Part No SW: 8X0 959 793 D	HW: 8X0 959 793 D
	Component: TSG FA        H09 0409
	Revision: --------
	Coding: 011E02200101120102
	VCID: 4EDFFD3B8D6DB5FEFB0F5CBB20-801B
Address 44: Steering Assist	Labels: 6Q0-423-156.lbl
	Part No SW: 6R0 423 156 B
	Coding: 11221
	VCID: 2F2180BFEAA748F690D90927BF-807A
Address 46: Failed to respond
Address 47: Sound System  (J525)	Labels: None
	Part No SW: 8X0 035 223 C	HW: 8X0 035 223 B
	Component: BOSE G3 A1Q3  H04 0130
	Revision: CK004200
	VCID: 322789CBF995F11EFFF7284B54-8067
03389 - Data Set Implausible
		Reset Counter: 250
Address 52: Door Elect, Pass.  (J387)	Labels: 8X0-959-792.clb
	Part No SW: 8X0 959 792 D	HW: 8X0 959 792 D
	Component: TSG BF        H09 0409
	Revision: --------
	Coding: 011E02200D01120102
	VCID: 4DDDFA37806B8EE68205538F35-8018
Address 55: Xenon Range  (J431)	Labels: 8X0-907-357.clb
	Part No SW: 8X0 907 357	HW: 8X0 907 357
	Component: ****LWR12**** H02 0040
	Coding: 1131941010002601
	ROD: EV_HeadlRegulBasic.rod
	VCID: FF4110FFFA477476C0F9F9E72F-80AA
Address 56: Radio  (R)	Labels: None
	Part No SW: 4G0 035 053 G	HW: 4G0 035 053
	Component: Radio U Basic H52 0121
	Revision: AB001007
	Coding: 010005010000000002
	VCID: 2207798BA975619E0F57788B64-8077
	Part No SW: 8X0 035 666 G	HW: 8X0 035 666
	Component: H-BN-EU       H51 0636
	Revision: --------
	Coding: 0C0101020008C0E90100033600000001E40000000000000000
	VCID: 41C5D6074C335A86768DCF1F89-8014
	Subsystem 1 - 	Part No SW: 8R0-060-884-N
	Component: EUR 2011     1205
	Subsystem 2 - 	Part No SW: 8X0-919-604
	Component: DU6 High     H42 0084
	Subsystem 3 - 	Part No SW: 8R0-060-961-A
	Component: CD-Database  2712
		Reset Counter: 250
		Mileage: 57005 km
		Date: 2016.05.04
		Time: 11:17:34
		Bin. Bits: 00000010 00000000
		Bin. Bits: 00000000 00000000
End-------------------------(Elapsed Time: 02:52)--------------------------
Please run updates again. A big batch was just pushed, and we THINK we have this fixed.
