Re-calibrating airbag sensors
NitrousOxide
Jamaica
C?ID=269481
Greetings,
I'm trying to clear a few errors on my airbag. The previous owner had a minor fender-bender (and as such replaced the front fender and a headlight). The airbags themselves were not deployed. Now that I bought the car, I want to at least reduce the number of airbag error messages to something the actual components that need to be repaired or replaced.
This is the error message that I get when I try to enter the access code for the airbag module (even after recycling the ignition and taking the car for a test drive for a few minutes). :
I want to re-calibrate (or zero) the seatbelt tension system (as well as seat occupancy), but I just want to verify that attempting to do so will NOT trigger the deployment of the airbags if I do not fix the other reported error messages first. Having the airbags accidentally deploy right now would be a real inconvenience.
My autoscan (with the numerous error messages) can be found below.
Sunday,21,February,2016,16:35:08:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ1KZ8W111078   License Plate: 3395 GY
Mileage: 146210km-90850mi   Repair Order:
                Address 01: Engine       Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1K0 907 115 R    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0020
           Software Coding: 040300101C070060
            Work Shop Code: WSC 80182 411 444102
                      VCID: 354FD8585CDD5E969D-8060
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
Readiness: 0110 0101
                Address 15: Airbags       Labels: 1K0-909-605.lbl
Control Module Part Number: 1K0 909 605 T    HW: 1K0 909 605 T
  Component and/or Version: 3A AIRBAG VW8   020 2300
           Software Coding: 0013121
            Work Shop Code: WSC 01269 785 00200
                      VCID: 3D5FC07864ED86D655-8068
7 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
            007 - Short to Ground - Intermittent - MIL ON
                Address 15: Airbags
           Software Coding:
            Work Shop Code:
                      VCID: 558F78D8AC9D7E967D-8000
Advanced Identification
     Serial number: 0038PD1FKU0T
     Identification: SME-RBG
     Revision: 05020000
     Date: 05.09.07
     Test stand number: 000D
     Manufacturer number: 0340
     Serial number: 6332MSME2C406B29H
     Serial number: 6342MSME2C42223ED
     Serial number: 6352QSME3D213635D
     Serial number: 6362QSME3C0B0C41L
Misc.
VCDS Info:
       Labels: 1K0-909-605.LBL
Address 19:1K0 907 530 L recoded (Installation List) from ED811F060002020001 to ED811F070002020001
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZ8W111078   Mileage: 146210km-90850miles
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Shop #: WSC 80182 411 444102
                    Mileage: 146101 km
                    Time: 20:10:32
                    RPM: 758 /min
                    Load: 25.9 %
                    Temperature: 93.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
                    Mileage: 146101 km
                    Time: 20:10:42
                    RPM: 750 /min
                    Load: 23.5 %
                    Temperature: 93.0°C
                    Temperature: 65.0°C
                    Voltage: 13.716 V
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 04808020    Serial number: 00000907050136
   Shop #: WSC 09537 809 89632
   VCID: 1C192DFCDF37EFDE82-8048
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 00000 785 00200
   VCID: 73CB2640122900A673-8026
7 Faults Found:
01487 - System Function Test
            000 -  -  - Intermittent
01486 - System Function Test Activated
            000 -  -
            013 - Check DTC Memory
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79D7146830457AF639-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 01000007456322
   Coding: E70C8E2F00041500471400041400000000097F075C100100000000000000
   Shop #: WSC 11111 111 45725
   VCID: 71C72C48683532B681-8024
   Component: Wischer 300807 021  0501
   Coding: 00038805
   Shop #: WSC 11111
   Component: RLS     130907 046  0204
   Coding: 00208933
   Shop #: WSC 11111
02498 - Left Low Beam Reflector Motor (V294)
                    Fault Status: 01111100
                    Reset counter: 248
                    Mileage: 146104 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.60 V
02499 - Right Low Beam Reflector Motor (V295)
                    Reset counter: 248
                    Mileage: 146104 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.60 V
                    Reset counter: 248
                    Mileage: 146101 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.25 V
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012102
   VCID: 01277C885895223671-8054
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0004103
   Shop #: WSC 12345 111 45725
   Revision:   H07 01    Serial number: 040907F1000254
   Coding: ED811F060002020001
   Shop #: WSC 12345 785 00200
   VCID: 3041E94CA3BF7BBECE-8064
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000564
   VCID: 3851D16C4BCFA3FE86-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   VCID: 2F43EA30BE816446D7-807A
01312 - Powertrain Data Bus
                    Fault Status: 00101110
                    Reset counter: 33
                    Mileage: 146211 km
                    Time: 20:59:37
                    Voltage: 13.50 V
                        DU
                    Temperature: 60.0°C
                    RPM: 1498 /min
                    Speed: 2.0 km/h
                    Speed: 2.0 km/h
                    Count: 3
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 238
                    Mileage: 146101 km
                    Time: 20:10:39
                    Battery Volts: 13.9 V
                        DU
                    Temperature: 56.0°C
                    Count: 5
                    Steering Angle: -0.70°
                    Count: 1
                        SteerAng Init
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 9890020851030C7F42CC8F0F70085A2690BC00
   VCID: 032B76804289302663-8056
                    Reset counter: 238
                    Mileage: 146101 km
                    Time: 20:10:39
00950 - Central Locking Motor - tailgate (V53); UNLOCK
                    Fault Status: 01100111
                    Reset counter: 239
                    Mileage: 146114 km
                    Time: 18:00:03
   Coding: 0000564
   VCID: 3957D46870C5BAF679-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74C9255C1727079E6A-8020
01533 - Terminal 56 (High Beams)
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       018 0035
   Revision: 00018000    Serial number: VWZ5Z7G2174742
   Coding: 0040400
   VCID: 2A75FB248563016E00-807E
End-------------------------(Elapsed Time: 01:03)--------------------------
Address 01: Engine
   Protocol: CAN
   Part No: 1K0 907 115 R
   Shop #: WSC 80182
   Protocol: CAN
   Part No: 02E 300 044 J
   Shop #: WSC 09537
   Protocol: CAN
   Part No: 1K0 907 379 AC
   Coding: 0004738
   Protocol: CAN
   Part No: 1K0 907 044 BS
   Protocol: CAN
   Part No: 3C0 937 049 AJ
   Shop #: WSC 11111
Address 15: Airbags
   Protocol: CAN
   Part No: 1K0 909 605 T
   Coding: 0013121
   Shop #: WSC 01269
   Protocol: CAN
   Part No: 1K0 953 549 AQ
   Coding: 0012102
   Protocol: CAN
   Part No: 1K6 920 974
   Coding: 0004103
   Shop #: WSC 12345
   Protocol: CAN
   Part No: 1K0 907 530 L
   Coding: ED811F070002020001
   Shop #: WSC 12345
   Protocol: CAN
   Protocol: CAN
   Part No: 1K0 959 701 M
   Coding: 0000564
   Protocol: CAN
   Protocol: CAN
   Part No: 1K0 959 433 BT
   Shop #: WSC 11111
Address 4F: Centr. Electr. II
   Protocol: CAN
   Part No: 1K0 907 532
   Coding: 00000000
   Shop #: WSC 12345
   Protocol: CAN
   Part No: 1K0 959 702 M
   Coding: 0000564
   Protocol: CAN
   Coding: 0000003
Address 56: Radio
   Protocol: CAN
   Part No: 1K0 035 180 M
   Coding: 0040400
Gateway Installation List:  1K0 907 530 L
65-Tire Pressure -- Status: Cannot be reached 1100
Address 4F:1K0 907 532  recoded (Long Coding) from 00000000 to 01000000  (12345/785/00200)
Someone should correct me if I'm wrong, but I don't think there's anything that can be calibrated with the tensioners. I don't see any issue with the passenger occupancy detection in your scan. If restraints didn't deploy, based on the scan above, it looks to me like perhaps there's something unplugged. Have inspected the connections?
NitrousOxide
Jamaica
C?ID=269481
Uwe;51904[COLOR=#333333 said:
I don't think there's anything that can be calibrated with the tensioners[/COLOR]
I figured since the message showed that the "upper limit exceeded", I figured that I simply calibrate it to zero. My seatbelts do not fully retract back into the B-pillar by themselves (due to normal usage over time), hence I thought that was one of the error messages. I wanted to get the number of SRS messages error messages down so that I can find the root cause of the issue. I have looked at the connections under each of the front seats, so I can vouch for those. I don't know if it is safe to remove the internal covering of the B-pillar to look at those connections without triggering the deployment of the airbag (when I switch on the ignition).
Gone But Not Forgotten
If the car has been in a collision then chances are the seat belt igniters have expired.......however, if you have a short to ground ........it should be verified using the WD and "isolating" for safety......... all the bags or pyrotechnic devices.......... before measuring for resistance.
NitrousOxide
Jamaica
C?ID=269481
I didn't know that these items have expiration. I'll take the time over the weekend to look at ALL the wiring, since I too have the concerns about shorting to ground.
I wished that there were actual measuring blocks for this.
raf0468
C?ID=120244
you have faults on the following equipment..
passenger seat belt
driver seat belt
passenger airbag
driver airbag
airbag cut off switch..
generally when you see all these faults in the airbag system, the car has been involved in a crash,
the belt tensioners , driver and passenger airbag, have been deployed..after replacement vcds clears them..
you say the airbags didn't deploy but something has gone on with the passenger and driver airbags.(replaced?) it would be a coincident both record faults,
the reason i say this is that the airbag cut off switch in an accident has no function or protection its sole purpose is up to the owner whether he wants it on or off, that being unplugged raises questions as to why it was unplugged..
lastly if all equipment is installed correctly and the faults do not clear it means new airbag module..
hope that helps..
NitrousOxide
Jamaica
C?ID=269481
The dashbord is perfectly intact where the passenger airbag is (like it came from the factory), so I can vouch for the passenger one on the dashboard.
The steering wheel looks about 90% OK (due to a slight discoloration from sunlight and normal wear).
The sections that cover the B-pillar seem to be sagging a bit (common VW issue with these models).
The airbag cutoff switch is in the ON position, so I'll have to check that circuit over the weekend.
Is the airbag module just a single unit, or one unit per airbag?
raf0468
C?ID=120244
its a single control unit for all the triggers and sensors..
normally found beneath the gear stick area or at the back of the center console in foot wells depending on model of car.
NitrousOxide
Jamaica
C?ID=269481
You may have solved my issue. The previous owner did indeed run a pair of RCA cables under the carpet in that area to the back of the head unit to feed some aftermarket amplifiers. In my hasty process of trying to revert the audio to the stock setup, I yanked on the RCA cable in that area before giving up and scheduling a day where I can remove the head unit the proper way to disconnect the cables. I also realized that he must have wired the switch for the amplifier to an existing harness in the glovebox area. I'll check it out over the weekend and disconnect it to verify that it really isn't in any way affecting the SRS.
Jef
HQ
For the airbag system, an item that has "Upper Limit Exceeded", that can be interpreted as "open circuit". A cut wire for example, or as noted here, more likely deployed seat belts.
In many cases, if you have a pyrotechnic unplugged, you will get a "Lower Limit Exceeded" because there is a metal clip that shorts the wires together when you unplug most pyrotechnic items. This is done for safety reasons, with the wires shorted together when unplugged, you can't get a static charge on one wire, and have it discharge to the other when you plug a pyrotechnic back up.
To that end, go into the Airbag module, MVB group 001.3 and 001.4 for live data on the front seat belts. Does the value change between Too Low and Too High as you plug and unplug the belts? If so, you need belts.
NitrousOxide
Jamaica
C?ID=269481
Thanks. I'll test the MVB for the belts when I get home.
I've learnt quite a bit from that last post
