I used the Control Module Finder feature to discover the Central Electrics 2 module at address 4F. It never shows up during an AutoScan, nor can I select it by going to the list of installed control modules. I can only access it by going to address"4F". The module itself has the coding set to all zeros as though it isn't even used (although I highly doubt that the manufacturer would ship the car like this with no real retrofitting options). This one doesn't have a label file associated with it either. Looking at other sources online, I see where there is the option for comfort features for a sliding-roof (this was already off at the time of the initial scan). Coincidentally, my sunroof does this weird thing where it opens randomly whether or not the car is already locked and the keys are out of the ignition. They sunroof doesn't actually close properly either in that it closes in the "tilt" position, so I have to use the manual close option (by pressing the forward-most part of the button to slide it shut). I just wanted to know if enabling this option in the module at address 4F would address these concerns (of it simply opening at random for no good reason). I disabled the automatic headlight and rain-sensor hoping that it would have resolved the issue, but it didn't.
As it relates to the real question that I want to ask though: Why can't I see this module under the list of regular modules even after the Control Module Finder has identified the presence of the module?
Address 4F: Centr. Electr. II
Protocol: CAN
Part No: 1K0 907 532
Component: J533 Gateway H07 0052
Coding: 00000000
Shop #: WSC 12345
Protocol: CAN
Coding: 00000000
Shop #: WSC 12345
Sunday,21,February,2016,16:35:08:39976
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZ1KZ8W111078 License Plate: 3395 GY
Mileage: 146210km-90850mi Repair Order:
Address 01: Engine Labels: 06F-907-115-AXX.clb
Control Module Part Number: 1K0 907 115 R HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 040300101C070060
Work Shop Code: WSC 80182 411 444102
VCID: 354FD8585CDD5E969D-8060
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Readiness: 0110 0101
Control Module Part Number: 1K0 909 605 T HW: 1K0 909 605 T
Component and/or Version: 3A AIRBAG VW8 020 2300
Software Coding: 0013121
Work Shop Code: WSC 01269 785 00200
VCID: 3D5FC07864ED86D655-8068
7 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
007 - Short to Ground - Intermittent - MIL ON
Address 15: Airbags
Software Coding:
Work Shop Code:
VCID: 558F78D8AC9D7E967D-8000
Advanced Identification
Serial number: 0038PD1FKU0T
Identification: SME-RBG
Revision: 05020000
Date: 05.09.07
Test stand number: 000D
Manufacturer number: 0340
Serial number: 6332MSME2C406B29H
Serial number: 6342MSME2C42223ED
Serial number: 6352QSME3D213635D
Serial number: 6362QSME3C0B0C41L
Misc.
VCDS Info:
Labels: 1K0-909-605.LBL
Address 19:1K0 907 530 L recoded (Installation List) from ED811F060002020001 to ED811F070002020001
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZ8W111078 Mileage: 146210km-90850miles
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G83NA8OV
Shop #: WSC 80182 411 444102
Mileage: 146101 km
Time: 20:10:32
RPM: 758 /min
Load: 25.9 %
Temperature: 93.0°C
Temperature: 66.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
Mileage: 146101 km
Time: 20:10:42
RPM: 750 /min
Load: 23.5 %
Temperature: 93.0°C
Temperature: 65.0°C
Voltage: 13.716 V
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 044 J HW: 02E 927 770 AD
Component: GSG DSG 082 1407
Revision: 04808020 Serial number: 00000907050136
Shop #: WSC 09537 809 89632
VCID: 1C192DFCDF37EFDE82-8048
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 00000 785 00200
VCID: 73CB2640122900A673-8026
7 Faults Found:
01487 - System Function Test
01486 - System Function Test Activated
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 79D7146830457AF639-802C
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007456322
Coding: E70C8E2F00041500471400041400000000097F075C100100000000000000
Shop #: WSC 11111 111 45725
VCID: 71C72C48683532B681-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 300807 021 0501
Coding: 00038805
Shop #: WSC 11111
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 130907 046 0204
Coding: 00208933
Shop #: WSC 11111
02498 - Left Low Beam Reflector Motor (V294)
Fault Status: 01111100
Reset counter: 248
Mileage: 146104 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.60 V
02499 - Right Low Beam Reflector Motor (V295)
Reset counter: 248
Mileage: 146104 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.60 V
Reset counter: 248
Mileage: 146101 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.25 V
Component: 3A AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1FKU0T
Coding: 0013121
Shop #: WSC 01269 785 00200
Subsystem 1 - Serial number: 6332MSME2C406B29H
Subsystem 2 - Serial number: 6342MSME2C42223ED
Subsystem 3 - Serial number: 6352QSME3D213635D
Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012102
VCID: 01277C885895223671-8054
Component: E0221 002 0010
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
Part No SW: 1K6 920 974 HW: 1K6 920 974
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G83NA8OV
Coding: 0004103
Shop #: WSC 12345 111 45725
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Revision: H07 01 Serial number: 040907F1000254
Coding: ED811F060002020001
Shop #: WSC 12345 785 00200
VCID: 3041E94CA3BF7BBECE-8064
Component: IMMO VDD 1216
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120B
Coding: 0000564
VCID: 3851D16C4BCFA3FE86-806C
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H15000
VCID: 2F43EA30BE816446D7-807A
01312 - Powertrain Data Bus
Fault Status: 00101110
Reset counter: 33
Mileage: 146211 km
Time: 20:59:37
Voltage: 13.50 V
DU
Temperature: 60.0°C
RPM: 1498 /min
Speed: 2.0 km/h
Speed: 2.0 km/h
Count: 3
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 238
Mileage: 146101 km
Time: 20:10:39
Battery Volts: 13.9 V
DU
Temperature: 56.0°C
Count: 5
Steering Angle: -0.70°
Count: 1
SteerAng Init
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 9890020851030C7F42CC8F0F70085A2690BC00
VCID: 032B76804289302663-8056
Subsystem 1 - Component: Sounder No Answer
Reset counter: 238
Mileage: 146101 km
Time: 20:10:39
00950 - Central Locking Motor - tailgate (V53); UNLOCK
Fault Status: 01100111
Reset counter: 239
Mileage: 146114 km
Time: 18:00:03
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 3957D46870C5BAF679-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C9255C1727079E6A-8020
01533 - Terminal 56 (High Beams)
Part No SW: 1K0 035 180 M HW: 1K0 035 180 M
Component: Radio PM6 018 0035
Revision: 00018000 Serial number: VWZ5Z7G2174742
Coding: 0040400
VCID: 2A75FB248563016E00-807E
End-------------------------(Elapsed Time: 01:03)--------------------------
Address 01: Engine
Protocol: CAN
Part No: 1K0 907 115 R
Shop #: WSC 80182
Protocol: CAN
Part No: 02E 300 044 J
Shop #: WSC 09537
Protocol: CAN
Part No: 1K0 907 379 AC
Coding: 0004738
Protocol: CAN
Part No: 1K0 907 044 BS
Protocol: CAN
Part No: 3C0 937 049 AJ
Shop #: WSC 11111
Address 15: Airbags
Protocol: CAN
Part No: 1K0 909 605 T
Coding: 0013121
Shop #: WSC 01269
Protocol: CAN
Part No: 1K0 953 549 AQ
Coding: 0012102
Protocol: CAN
Part No: 1K6 920 974
Coding: 0004103
Shop #: WSC 12345
Protocol: CAN
Part No: 1K0 907 530 L
Coding: ED811F070002020001
Shop #: WSC 12345
Protocol: CAN
Protocol: CAN
Part No: 1K0 959 701 M
Coding: 0000564
Protocol: CAN
Protocol: CAN
Part No: 1K0 959 433 BT
Shop #: WSC 11111
Protocol: CAN
Coding: 00000000
Shop #: WSC 12345
Protocol: CAN
Part No: 1K0 959 702 M
Coding: 0000564
Protocol: CAN
Coding: 0000003
Address 56: Radio
Protocol: CAN
Part No: 1K0 035 180 M
Coding: 0040400
Gateway Installation List: 1K0 907 530 L
65-Tire Pressure -- Status: Cannot be reached 1100
Address 4F:1K0 907 532 recoded (Long Coding) from 00000000 to 01000000 (12345/785/00200)
