No power to the instrument cluster or Can Bus
WadeMcKissick
New Wilmington, PA, USA
C?ID=530882
I have a 2011 Tiguan 2.0 4 Motion, 60000 miles. Suddenly the instrument cluster doesn't turn on when i open the door. I had to power the Can Bus, fuse SC14, externally in order to pull the codes. here are the results on the scan:
Monday,23,March,2026,13:18:30:58083
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
          4F 52 53 55 56 62 65 69 6C 72 77
VIN: WVGBV7AX5BW002093
04-Steering Angle -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Cannot be reached 1100
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 029 R    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 01 1521
   Revision: P3H07---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 30616 002 1048576
   VCID: 46D55A4FE4A9C30AF47-8012
   VINID: 9E65D29874681529C00020090C0397CD0A
               U0155 - 000 -
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 15.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.684 V
   Part No SW: 09G 927 750 LQ    HW: 09G 927 750 LQ
   Component: AQ 250 6F           1771
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 01324 020 00200
   VCID: 0B43AB7BBF4B7E62EB9-805E
                    Reset counter: 201
                    Date: 2063.14.31
                    Time: 13:48:51
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 R    HW: 5N0 614 109 R
   Component: J104    C4 450 V44B 0006
   Revision: --H28---    Serial number: 00000004065516
   Coding: 0002336
   VCID: 3A2D3EBFA051B7EA80F-806E
                    Reset counter: 75
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 172
                    Hex Value: 0x0000
                    Reset counter: 75
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 235
                    Hex Value: 0x0000
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0802
   Revision: 00085000    Serial number: 0146219223 Dataset Number: 5K0116v____ 5N0B
   Coding: 030C0C
   ASAM Dataset: EV_KESSY_PQ35GP A01018
   ROD: EV_KESSY_PQ35GP_VW32.rod
   VCID: 3333139B8BBB46A2439-8066
   Part No SW: 5K0 907 044 EG    HW: 5K0 907 044 EG
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000001002
   VCID: 74B1D087CE35019A9A3-8020
   Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
   Component: BCM PQ35 H+   111 0148
   Revision: BL111001
   Coding: 6D580A1B88232EC480880085B4000D0440555186576D8DF05C800000A040
   VCID: 43D3435BDB9BF622D39-8016
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 200411 03  32  0010
   Coding: 009795
   Component: RLS 030511 05  54  0403
   Coding: 03304D
                    Fault Status: 00101001
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.60 V
01259 - Fuel Pump Relay (J17)
                    Fault Status: 01101001
                    Reset counter: 100
                    Mileage: 93377 km
                    Date: 2063.14.31
                    Time: 00:00:06
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.60 V
                    Fault Status: 00101011
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.65 V
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 22014000    Serial number: 003GJP6NQDGI
   Coding: 0012340
   VCID: 4ACD6E7FF0B1276A10F-801E
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000003JCR
   Subsystem 3 - Serial number: 0022.03.110000300000650016ÿ†63
   Subsystem 4 - Serial number: 650016ÿ†6332MTS609441041 ÿ†63
   Subsystem 5 - Serial number: 41041 ÿ†6342MTS663301081 ÿ†63
   Subsystem 6 - Serial number: 01081 ÿ†6351HTS67UHBS9KJ ÿ†63
   Subsystem 7 - Serial number: BS9KJ ÿ†6361HTS69L2CS9KJ ÿ†63
   Subsystem 8 - Serial number: CS9KJ ÿ†63727TS6S3SCQ9KJ ÿ†63
   Subsystem 9 - Serial number: CQ9KJ ÿ†63827TS6E6JEP9KR ÿ
   Subsystem 10 - Serial number: EP9KR ÿ
                    Reset counter: 75
   Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
   Revision: FF010040    Serial number: 20110502101788
   Coding: 110A140000
   VCID: 75B7ED83C54F1892ADD-8020
   Component: E221__MFL-TAS  H07 0013
   Coding: 820000
Address 17: Instruments
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 030511F1000330
   Coding: 356002
   VCID: 313F1993712774B2315-8064
                    Reset counter: 75
                    Fault Frequency: 240
                    Reset counter: 75
                    Reset counter: 75
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   VCID: 4CC16867FAC5395A223-8018
                    Reset counter: 138
                    Time Indication: 1
                    Veh. life cycle counter: 0
                    Reset counter: 138
                    Time Indication: 1
Address 25: Immobilizer
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000097251003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: 2E0502EF60996B4A2C7-807A
Address 2E: Media Player 3
   Part No SW: 5N0 959 760 B    HW: 5N0 959 760 B
   Component: MEM-FS        H04 0033
   Revision: AA000000    Serial number: 00001002381241
   Coding: 20581B00000000000011
   VCID: 392F21B3A957BCF2895-806C
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684 C
   Component: RNS-MID       H10 1040
   Revision: AB001001    Serial number: VWZ6Z7L8051032
   Coding: 040500000100008600
   VCID: 2313E3DB3BDBD622B39-8076
                    Reset counter: 75
                    Mileage: 95896 km
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 0802
   Revision: 1AH03831    Serial number: 00111030478001
   Coding: 0000258
   VCID: 3B233BBBAF6B8EE29B9-806E
                    Fault Status: 11100100
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.80 V
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.80 V
                    Reset counter: 75
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
00576 - Terminal 15
                    Fault Status: 01101000
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.90 V
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218109122470 Dataset Number: 1K8050v____ 5N04
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 678BB7CB8FE3FA022F1-8032
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FBBDFEBA7932242671-803A
01512 - Control Module for Sliding Roof
                    Reset counter: 195
                    Mileage: 95900 km
                    Date: 2063.14.31
                    Time: 08:33:08
02907 - Control Module for Roof Shade (J394)
                    Fault Status: 01100101
                    Reset counter: 195
                    Mileage: 95900 km
                    Date: 2063.14.31
                    Time: 08:33:05
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range        Labels: 5M0-907-357-V2.clb
   Coding: 1356998
   VCID: 343110878235419A5A3-8060
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000020
                    Reset counter: 75
                    Voltage: 11.50 V
                        ABS 1
                    Reset counter: 75
                    Voltage: 11.50 V
                        ABS 1
                    Reset counter: 75
                    Mileage: 95896 km
Address 62: Door, Rear Left
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
02214 - Tire Pressure Warning
                    Mileage: 100425 km
                    Date: 2063.14.31
                    Time: 16:07:17
                    Text: 3455814674
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -2.8°C
                    Text: 00
                    Speed: 15.0 km/h
02904 - Hard Warning 3
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Mileage: 100425 km
                    Date: 2063.14.31
                    Time: 16:10:09
                    Text: 3455814650
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -2.0°C
                    Text: 00
                    Speed: 18.0 km/h
02801 - Hard Warning
                    Mileage: 100425 km
                    Date: 2063.14.31
                    Time: 11:53:27
                    Text: 3455814667
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -8.8°C
                    Text: 80
   Revision: 3A001001    Serial number: 00000146594325
   Coding: 420D000100000000
   VCID: 30391C977A2D7DBA3EB-8064
                    Reset counter: 75
00576 - Terminal 15
                    Reset counter: 75
Address 6C: Back-up Cam.
Address 72: Door, Rear Right
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661263348 Dataset Number: 5K0035730E  0001
   Coding: 0A11040000010100
   Shop #: WSC 05072 444 84364
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BF7CB4F633A02EF1-8072
End----(Elapsed Time: 01:52, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
------------------------------29 Faults Found------------------------------
any advise is greatly appreciated
Wade
Ziddywerks
Northern NJ USA
C?ID=208579
Yeah not dealing with that post a proper log and code wrap.
WadeMcKissick
C?ID=530882
here's a better version of the auto scan
               U0155 - 000 -
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 15.0°C
                    Temperature: 17.0°C
                    Voltage: 11.684 V
   Coding: 0000840
                    Reset counter: 201
                    Date: 2063.14.31
                    Time: 13:48:51
   Coding: 0002336
                    Reset counter: 75
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 172
                    Hex Value: 0x0000
                    Reset counter: 75
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 235
                    Hex Value: 0x0000
   Coding: 030C0C
   Revision: 00003001
   Coding: 0000001002
   Revision: BL111001
   Coding: 009795
   Coding: 03304D
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.60 V
                    Reset counter: 100
                    Mileage: 93377 km
                    Date: 2063.14.31
                    Time: 00:00:06
                        Term 15 Off
                    Voltage: 12.05 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.60 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.65 V
   Coding: 0012340
                    Reset counter: 75
   Coding: 110A140000
   Coding: 820000
   Coding: 356002
                    Reset counter: 75
                    Reset counter: 75
                    Reset counter: 75
   Coding: 0000005
                    Reset counter: 138
                    Time Indication: 1
                    Reset counter: 138
                    Time Indication: 1
                    Reset counter: 75
                    Mileage: 95896 km
   Coding: 0000258
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.80 V
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.80 V
                    Reset counter: 75
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
00576 - Terminal 15
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.90 V
   Coding: 050B0500
                    Reset counter: 195
                    Mileage: 95900 km
                    Date: 2063.14.31
                    Time: 08:33:08
                    Reset counter: 195
                    Mileage: 95900 km
                    Date: 2063.14.31
                    Time: 08:33:05
   Coding: 1356998
   Coding: 00000020
   Coding: 00000020
                    Reset counter: 75
                    Voltage: 11.50 V
                        ABS 1
                    Reset counter: 75
                    Voltage: 11.50 V
                        ABS 1
                    Reset counter: 75
                    Mileage: 95896 km
   Coding: 018705
                    Mileage: 100425 km
                    Date: 2063.14.31
                    Time: 16:07:17
                    Text: 3455814674
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -2.8°C
                    Text: 00
                    Speed: 15.0 km/h
                    Mileage: 100425 km
                    Date: 2063.14.31
                    Time: 16:10:09
                    Text: 3455814650
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -2.0°C
                    Text: 00
                    Speed: 18.0 km/h
                    Mileage: 100425 km
                    Date: 2063.14.31
                    Time: 11:53:27
                    Text: 3455814667
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -8.8°C
                    Text: 80
                    Reset counter: 75
00576 - Terminal 15
                    Reset counter: 75
   ROD: UHVNA.rod
Ziddywerks
Northern NJ USA
C?ID=208579
Ok it looks like cluster isn't talking but now the question becomes is this a cluster issue or is this a failing gateway issue. I would try a gateway as it probably cheaper.
I'm kind wondering what's going on in the BCM.
Spacewalker
Poland
C?ID=159607
take out cluster and us 3 wires on the bench (12V power supply) to see if wake up
WadeMcKissick
C?ID=530882
So, Here is the latest. The cluster is dead. I got one off of Ebay that works. The original BCM seems to be ok. Now, i need to link the replacement Instrument cluster to the BCM and get the correct VIN and Mileage into the Instrument Cluster. The keys will Lock, Unlock the doors but the Cluster displays the message "Immobilizer Active". I've copied the current scan in the post. Any advice is greatly appreciated.
Wade
Monday,20,April,2026,10:44:22:58083
VIN: WVGBV7AX5BW002093   Mileage: 318390km-197838miles
25-Immobilizer -- Status: Malfunction 1010
36-Seat Mem. Drvr -- Status: Sporadic communication error 1000
53-Parking Brake -- Status: Malfunction 1010
               U0155 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 15.0°C
                    Temperature: 17.0°C
                    Voltage: 11.684 V
               U1017 - 000 -
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:44:04
                    Temperature: 17.0°C
                    Temperature: 19.0°C
                    Voltage: 11.557 V
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:44:08
                    Temperature: 18.0°C
                    Temperature: 19.0°C
                    Voltage: 11.557 V
049682 - Steering Column Control Module
               U0212 - 000 - No Communications - Intermittent
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:00:37
                    Temperature: 17.0°C
                    Temperature: 19.0°C
                    Voltage: 11.303 V
   Coding: 0000840
                    Reset counter: 177
                    Date: 2020.09.10.
                    Time: 13:48:51
   Coding: 0010000
7 Faults Found:
                    Fault Frequency: 13
                    Speed: 252.0 km/h
                    Hex Value: 0x0000
                    Voltage: 0.00 V
                    Bin. Bits: 00000000
                    Count: 170
                    Hex Value: 0x0000
02779 - Databus for Electric Parking Brake
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:20:04
                    Hex Value: 0x0000
                    Voltage: 11.25 V
                    Bin. Bits: 00000001
                    Count: 203
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:20:04
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:20:04
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:20:04
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:20:04
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:20:04
   Coding: 030C0C
65826 - No Basic Setting
          B2010 00 [00001001] - -
   Revision: 00003001
   Coding: 0000001002
   Revision: BL111001
   Coding: 009795
   Coding: 03304D
11 Faults Found:
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.85 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.80 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.80 V
                    Reset counter: 100
                    Mileage: 93377 km
                    Date: 2020.09.10.
                    Time: 00:00:06
                        Term 15 Off
                    Voltage: 12.05 V
01516 - Terminal 30; Left
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.80 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.80 V
01800 - Light Switch (E1)
                    Reset counter: 75
                        Term 15 Off
                    Voltage: 11.85 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.80 V
02391 - Terminal 30 Reference
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.80 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.90 V
                    Reset counter: 115
                        Term 15 Off
                    Voltage: 11.90 V
   Coding: 0012340
                    Reset counter: 115
   Coding: 110A140000
   Coding: 820000
   Part No SW: 5N0 920 972 B    HW: 5N0 920 972 B
   Component: KOMBI         H03 0406
   Coding: 210F00
   VCID: 323D169F74A14FAA48F-8066
12658688 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Steuergerät für elektrische Parkbremse: keine Kommunikation]
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2026.04.20.
                    Time: 01:15:43
   Coding: 356002
                    Reset counter: 75
                    Reset counter: 115
                    Fault Status: 00110100
                    Reset counter: 115
01335 - Drivers Seat/Mirror Position Control Module (J543)
                    Reset counter: 115
                    Reset counter: 115
                    Mileage: 318393 km
                    Date: 2020.09.10.
                    Time: 00:20:05
   Coding: 0000005
                    Reset counter: 138
                    Time Indication: 1
                    Reset counter: 10
                    Time Indication: 1
   Component: IMMO          H03 0406
   VCID: 6A8DCEFF9CF1C76A30F-803E
9456128 - Engine Control Module (ECM) not Authorized
          B104A 00 [00001001] - -
9456433 - Key
          B104B 31 [00001001] - No Signal
                    Reset counter: 75
                    Mileage: 318393 km
                    Date: 2026.04.20.
                    Time: 01:09:59
                    Reset counter: 75
                    Mileage: 95896 km
   Coding: 0000258
                    Reset counter: 115
                    (no units): 4.0
                    Voltage: 11.80 V
                    Fault Frequency: 11
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.80 V
                    Reset counter: 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
                    (no units): 115
00576 - Terminal 15
                    Fault Frequency: 11
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.90 V
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 75
                    (no units): 4.0
                    Voltage: 11.90 V
   Coding: 050B0500
                    Reset counter: 195
                    Mileage: 95900 km
                    Date: 2020.09.10.
                    Time: 08:33:08
                    Reset counter: 195
                    Mileage: 95900 km
                    Date: 2020.09.10.
                    Time: 08:33:05
   Coding: 1356998
   Coding: 00000020
   Coding: 00000020
                    Reset counter: 75
                    Voltage: 11.50 V
                        ABS 1
                    Reset counter: 115
                    Voltage: 11.50 V
                        ABS 1
                    Reset counter: 75
                    Mileage: 95896 km
   Coding: 018705
                    Mileage: 100425 km
                    Date: 2020.09.10.
                    Time: 16:07:17
                    Text: 3455814674
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -2.8°C
                    Text: 00
                    Speed: 15.0 km/h
                    Mileage: 100425 km
                    Date: 2020.09.10.
                    Time: 16:10:09
                    Text: 3455814650
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -2.0°C
                    Text: 00
                    Speed: 18.0 km/h
                    Mileage: 100425 km
                    Date: 2020.09.10.
                    Time: 11:53:27
                    Text: 3455814667
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: -8.8°C
                    Text: 80
                    Reset counter: 115
00576 - Terminal 15
                    Reset counter: 75
   ROD: UHVNA.rod
End----(Elapsed Time: 02:00, VBatt start/end: 11.9V/11.8V. VIgn 11.3V)-----
------------------------------51 Faults Found------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
I can assist in programming cluster to vehicle. It's a service I do provide. However for mileage I would need to physically have the cluster here on the bench.
Ziddywerks
Northern NJ USA
C?ID=208579
Does the cluster part number match what came out of the vehicle?
