Widows 10 and HEX NET Config
Gizmo
S.E.Kent UK
C?ID=49193
My netbook is dying fast and due to ongoing VCDS-Mobile issues I have bought a cheap Windows 10 tablet purely to run VCDS on.
However despite using the links on the HEX-NET downloads page to install Java (Version 8 Update 73) and then the HEX-NET Config (both V2.007 and I also tried the older V1.963)
When I try to open HEX-NETConfig I get the following error:
According to the Java site, Java has installed correctly??
I have tried downloading with Internet Explorer and Firefox with the same results (I deleted Java and HEX-NETConfig fully between trying with each browser)
Has anyone else had issues with Windows 10? (I am usually a Mac user)
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Nope, but I manually installed both the 64 and 32 bit java versions
Edit - after checking I only installed the 64 bit version :)
It's not clear to me.. Have you got this sorted?
Gizmo
S.E.Kent UK
C?ID=49193
No, everything I tried came back with the same error above so thought I would ask if there was a known conflict with Windows 10.
Santos
Have you tried running it via command prompt?
Access your command prompt (search CMD)
enter the following
Java -jar C:\Users\Martin\Downloads\HexNetConfigV2.007.jar
Gizmo
S.E.Kent UK
C?ID=49193
No I hadn’t, but that has worked thanks :thumbs:
