How to activate rain closing on a Octavia 3
Wiking
Denmark
C?ID=266811
Hi all
Tried to activate rain closing on a Skoda Octavia 3 today, but with no success.
In the module 09 - slave 2 RLFS there are no help to see what the coding actually does (no long coding help) and in the 09 I cant´t find the rain closing function.
I have done it with a Golf 6 and Octavia 2.
Has anybody tried this with succes. ?
Styreenhed 09: Centralelektrik (J519) Forklaringsfil: NEZ\5Q0-937-08X-HV1.clb
Styreenhedsnr: SW: 5Q0 937 086 Q HW: 5Q0 937 086 Q
Komponent : BCM PQ37BOSCH 026 0095
Revision: -------- Serienummer: 86580801140503
Kodning : 0C021B46424722FB47E04000000C07080000000000000000000000000000
Forhandler : WSC 45652 000 1048576
ASAM datasæt: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_AU37.rod
VCID: 489F3D95F353137EF8-801C
Slave 2:
Undersystem 2 - Styreenhedsnr: SW: 5Q0 955 547 HW: 5Q0 955 547
Komponent : RLFS 024 0042
Serienummer: Y14M01D11H04M04S29S9
Kodning : 02805D
pronet
Romania
C?ID=157414
elect STG 09 (vehicle power)
STG Access Permission -> Function 16
Access code 31347
STG adjustment -> function 10
(14) Zugriffskontrolle 2-Regenschliessen auswählen
Value: adjust value to Permanent
(26) Zugriffskontrolle 2-Menuesteuerung Regenschliessen auswählen
Value:adjust value to Active/Aktif
Select STG 09 (vehicle power)
STG Long Coding -> Function 07
Subsystem: Rain / Light Sensor (RLS)
Byte 0
Bit 1-Bit 2 DeActivate - enable
andyvee
Rossendale, Lancashire, UK
C?ID=159389
It depends which RLFS or RLHS you have - follow the link in my signature for full details
Wiking
Denmark
C?ID=266811
You are right. The channel on this one is slightly higher. I had done as you are writing and now also tried to deactivate and activate the comfort closing of the windows. But I must be missing something because it will not close "in rain". Great site you have there by the way.
Wiking: Hi. I've been to andyvee's site more than a few times and you are correct, it's a very well useful resource for MQB platform vehicles. Unfortunately though, this particular tweak has been problematic for many folk for some unknown reason (I understand that it's much easier to implement with VCP). So I suspect that you are not "missing something" at all - you are just a member of the growing throng of those that just can't make this tweak work! Little solace I know, but as the saying goes "that's just the way the pickle-squirts"!
PS: I've written-up a similar process to that on andyvee's site, but the in-car procedure is a little different. Will likely make no difference to the outcome, but you could give my process a try - as a last resort. See HERE (there are also some suggestions from forum colleagues at the bottom of my post)
Finally and coincidentally, I've recently been discussing this tweak with a colleague from Germany (who, not surprisingly speaks the same language as written on many of the adaptation channels). His advice is that in Germany, some folk have been able to get this tweak to work by not setting Byte 0, Bit 1 in the RLS/RLHS/RLFS - again, low probability fix, but it might be worth a try
Wiking
Denmark
C?ID=266811
I will try your way as well. Regarding the last part. Byte 0 bit 0 and 1 in module 9 is if the car is left or right side driven. If RLFS sensor is mounted is in byte 6.
Or do you mean in the sub menu for the RLFS.
Thanks for the feedback.
Don Regarding the last part. Byte 0 bit 0 and 1 in module 9 is if the car is left or right side driven. If RLFS sensor is mounted is in byte 6.
Wiking: Sorry I wasn't clear enough in my explanation, I meant the RLS/RLHS/RLFS as a slave module to the BCM (see pic below). As I say these suggestions are "long-shots", so expectations low !!
NEtech
Denmark
C?ID=56995
That was also (how I read it, but not easy to see) what "pronet" wrote:
For 5Q0 955 547
Byte 0 Bit 1 - Disable
Byte 0 Bit 2 - Enable
For 5Q0 955 547
NEtech: arrhhh......now I read it correctly - Didn't interpret Pronet's instructions correctly when I 1st read it. So perhaps there is merit in my German colleague's advice - this is getting interesting!
Try 068885 as the coding for the RLFS.
Andy: Interesting Byte 1- 2 value. Is hex6885 another coding for the Octavia using the 5Q0 937 086 module? Here's what the 5Q0 937 547 says
Wiking
Denmark
C?ID=266811
Hi all
It is strange because I have no long code explanation. Just from bit 0 to 7. And no coding is accepted
Wiking
Denmark
C?ID=266811
Andy
I have entered your code and guess what
I IS WORKING.
Thanks a lot to all
Wiking
Denmark
C?ID=266811
Don: Your explanation was clear enough. I was just not reading it right.
Can anyone tell me why there are no long code explanation to this car. Seems that the rest of you have a more normal long code.
NEtech
Denmark
C?ID=56995
It will be there for next update, 15.17.4, next week.
Send me an complete Autoscan. In this forum, it should be an Autoscan made with English VCDS.
Wiking
Denmark
C?ID=266811
Would like to send a autoscan but my version is in Danish. Is there a way to make the autoscan in English anyway ?
martijn v o
C?ID=138199
Wednesday,08,July,2015,20:11:06:38406
VCDS Version: 15.6.1.0 (x64)
Data version: 20150612
VIN: TMBJG9NE7F0093066   License Plate: SKODAMARTIJN
Mileage: 8056km-5005mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F 6D A5
VIN: TMBJG9NE7F0093066   Mileage: 8056km-5005miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 8138
   Revision: 84H22---
   Coding: 01250032032401091000
   Shop #: WSC 73430 031 00138
   ASAM Dataset: EV_ECM16TDI01104L906021N 002013
   ROD: EV_ECM16TDI01104L906021N_SK37.rod
   VCID: 306514426BB555BF49-8064
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 300 047 R    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serial number: CU501409176090
   ROD: EV_TCMDQ200021_SK25.rod
   VCID: 4A9166AAED290F6F67-801E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 62514000001089
   Coding: 1C0762911429096F0077060641C9243846289000608224F00041F072C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
   VCID: 448D4892CF0DD91F9D-8010
   Revision: 00021000    Serial number: 0347150194
   Coding: 030C0C
   Shop #: WSC 73430 790 00138
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A71366ABDC99FEFF7-806E
   Part No SW: 5E0 907 044 N    HW: 5E0 907 044 N
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 02010104000100011005004100101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86582709140821
   Coding: 0C511B66424722FB4FE44004001C17280800000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
   VCID: 79F3E966F84F54F7BE-802C
   Slave 1:
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119
   Component: WWS371 140831  041 0570
   Serial number:         140916055616
   Coding: 065DDD
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y14M09D19H09M53S24
   Coding: 00885D
   Subsystem 3 - Part No SW: 5E9 959 591     HW: 7P0 959 591 B
   Component: J245 PS24.011  H01 0008
   Serial number:     WOO3215251-
   Coding: 991900
   Subsystem 4 - Part No SW: 5E9 959 591 A    HW: 7P0 959 591 C
   Component: J394 PS24.011  H01 0008
   Serial number:     WOO3188597F
   Coding: 991900
549652 - Databus
10762 - Bulb for Right Tail Light
          B12BF 15 [008] - Open or Short to Plus
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39411424200535
   Coding: 0031161051
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_SK37.rod
   VCID: 42814E8AD519D72FAF-8016
   Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003NYPJTMVCQ
   Coding: 98FCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 7DFBFD76EC6768D792-8028
   Seat belt tensioner; left:
   Serial number: 34169593B01101470011
   Coding: 333135
   Seat belt tensioner; right:
   Serial number: 34169592B29091440191
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 000 709 14
   Serial number: 3576U00000079669F01I
   Subsystem 4 - Part No SW: -----------    HW: 454 000 709 14
   Serial number: 3586U00000035548E016
   Subsystem 5 - Part No SW: -----------    HW: 454 801 409 14
   Serial number: 3516R87B384040000001
   Subsystem 6 - Part No SW: -----------    HW: 454 801 409 14
   Serial number: 3526R4A3B8B040000008
   Subsystem 7 - Part No SW: -----------    HW: 454 802 708 14
   Serial number: 3556VBC809604000000E
   Part No SW: 5Q0 953 507 EE    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02091404401368
   Coding: 1410
   ROD: EV_SMLSKLOMQB_SK37.rod
   Part No SW: 5E0 920 751     HW: 5E0 920 751
   Component: KOMBI         304 4270
   Coding: 07A50A186994000801087A021000000000000000
   VCID: 62C1AE0A75D9B72F8F-8036
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002486773
   Coding: 030100040F087300EF00024E1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear.rod
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000B1019020914
   Serial number: 5727124403
   Revision: 00000000    Serial number: 14000256917001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 346D18529FAD699F2D-8060
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000119482723
   Coding: 00150920D000048000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000003879547
   Coding: 010200
65639 - Motor for Window Regulator
          B1487 29 [008] - Signal Implausible
                    Mileage: 6084 km
                    Date: 2015.04.23
                    Time: 17:37:07
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 9302
   ROD: EV_SteerAssisMQB.rod
   VCID: 41834186D01FCC37B6-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000119738270
   Coding: 00150120DC00048000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 438F4B8ECA03DE27A4-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000003863022
   Coding: 190200
   Coding: 03CA02003F010000
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 40854482DB15C53FB9-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5E0 035 020 C    HW: 5E0 035 020 C
   Component: MU-H-ND-EU    H43 0370
   Serial number: A313I0EB011048
   Coding: 03730201000000001111120200A000002F0000F401000100F6
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_SK37.rod
   VCID: 1737CFDEEE1BA28728-8042
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H60 0030
   Serial number: SKZ8Z9PT6005B2
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 800 ME    HW: -----------
   Component: ECE 2015/2016  --- 0123
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 5E0 959 107 A    HW: 5E0 959 107
   Component: HDSG-Modul    H01 0746
   Revision: 42001001    Serial number: 252400845
   Coding: 1233074002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 2A51062A4D692F6F87-807E
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000225268
   Coding: 0101010001030303000400000000000100
   ROD: EV_MFKBoschAU370_AU37.rod
   VCID: 3B7F336EB2F3A6E7EC-806E
End-------------------------(Elapsed Time: 04:36)--------------------------
Wiking
Denmark
C?ID=266811
I can see my version is 15.7.3
So maybe the best thing to do is downloading the latest version in english directly from Ross-Tech
Wiking
Denmark
C?ID=266811
Sorry. Wrong thread
You can always install and use the English version in parallel with whatever translated version you might have.
Wiking
Denmark
C?ID=266811
I have posted an Auto-Scan in the reference scan section.
And with the latest VCDS 15.7.4 I also have a full working long coding help. :thumbs:
