battery reguator
adzzz999
Australia
C?ID=264917
hi I have a problem fault with the battery regulator I have installed a new cangateway and I'm not sure if I have the battery regulator settings right I have in long coder set it to all other engines the car is 2005 gti here is the print out of the s can
VCDS Version: Release 15.7.3 Running on Windows 10 x64
Data version: 20151216
Sunday,21,February,2016,12:52:31:65451
Gateway Installation List:  7N0 907 530 AR
Sunday,21,February,2016,12:54:11:65451
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WVWZZZ1KZ6U009412   Mileage: 172380km-107111miles
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2427964
   Coding: 0403000318070160
   Shop #: WSC 00046 412 00000
   VCID: 63EB54B6A2AA13260C-8036
Readiness: 0110 0101
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0004738
   VCID: 40A1BB3A137C683E31-8014
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   VCID: 67F340A656927F06D0-8032
            000 -  -
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000002115976
   Coding: E50D8F270004180000140000140000000019000F5C
   Shop #: WSC 00046 412 12345
   VCID: 2B7BFC968AFA9B66F4-807E
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00049109
   Shop #: WSC 00046
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00207646
   Shop #: WSC 00046
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 36 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0K7V1B
   Coding: 0013110
   VCID: 3753D0E646B22F8680-8062
   Subsystem 1 - Serial number: 6332MSME0A787938N
   Subsystem 2 - Serial number: 6342MSME0B267825D
   Subsystem 3 - Serial number: 6351HSME080C17656
   Subsystem 4 - Serial number: 6361HSME075B604DE
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0002022
   VCID: 77D310E60632EF8640-8022
   Component: E0221           007 0050
   Part No: 1K6 920 862
   Coding: 0003707
   Shop #: WSC 30067 959 86331
   VCID: 6DFF328E746E5556AA-8038
   Coding: 0003707
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 1206201500F127
   Coding: 350003
   VCID: 00217B3A93FCA83E71-8054
   Component: IMMO            VDD 1212
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2370
   Coding: 0000692
   VCID: 364DDDE241B8D68E9B-8062
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 334BE4F652CAC3A6BC-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 19C802487F2D840548DFC69010CC
   VCID: 79D716DE3026F9F636-802C
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1K0 951 177 A
   Component: Innenraumueberw.005 0202
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000034596
   VCID: 69F7469E40864976C6-803C
   Part No: 1K0 959 702 K
   Coding: 0000692
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3K3023035
   Coding: 0100040004
   VCID: 62E551B27DB01A2E07-8036
00468 - CD-ROM Drive (R92)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 85
                    Mileage: 172381 km
                    Time: 12:44:18
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2429
   Coding: 0000144
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 3449E7EA57C4C49EA5-8060
End-------------------------(Elapsed Time: 01:09)--------------------------
Welder75
Canada
C?ID=261654
Are you sure the car has a battery regulator? if you code the can gateway to think the car has one it will show as a malfunction because it can't communicate with it because its not there. address 61 doesn't show on the autoscan, but shows as a available address on the list at top of scan. Confirm your have a Battery reg. if not, code gateway as per.
here is a snip from another Chassis Type: 1K (7N0)
it has the same gateway coding as yours and the battery regulator shows on the autoscan !
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 270511F1000856
Coding: 350003
VCID: 3778B7EA86EB658680-8062
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 030B185A
VCID: 71EC49F2A80FFBB68E-8024
Component: J367-BDM H07 0180
Coding: 350003
Coding: 030B185A
I'm pretty confident a 2006 GTI didn't have a battery regulator stock, but car you cited does, and it's part of the Gateway itself. Notice the same HW number..
I do not know whether it's feasible to get it working in a gateway retrofit.
Welder75
Canada
C?ID=261654
that's what i was getting at,,, but getting him to do a little bit of digging. Several vw's use that same Can Gateway that have a battery reg. so its preset in the gateway.
ADZZZ999 you can view battery voltage from several MB. find easy in 01 , if its good voltage, you can just ignore the 61-Battery Regul. -- Status: Malfunction 0010. or http://www.ross-tech.com/vcds/tour/installation-list.html delete it from the gateway install list. But it maybe programmed into the software...so don't sweat it to much.
