Good morning,
I want to reset all adaptation values on my DQ381 transmission after replacing the pressure sensors (IDE00498 Reset all adaptation values). However, I keep getting the error: "Request aut of Range" or "Service Not Supported in Active Session".
I'm using the original Ross-Tech dongle and the latest VCDS version.
Basic settings work without any problems.
Everything worked fine for about four weeks after the sensor replacement, but now I'm constantly getting P176E/F error codes.
Does anyone have any ideas?
Wednesday,18,March,2026,22:31:32:53615
VCDS Version: 25.3.3.0 (x64) HEX-V2 CB: 0.4671.5
Data version: 20260227 DS365.0
VIN: VSSZZZ5FZKR006182 License Plate:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 42 44 47 4B 52 5F 69 A5
D6 D7
VIN: VSSZZZ5FZKR006182 Mileage: 113215km-70348miles
Address 01: Engine (J623-DKZA) Labels:. 06K-907-309-V2.clb
Part No SW: 8V0 907 115 E HW: 06K 907 309 B
Component: R4 2.0l TFSI H60 0002
Revision: O1H60000 CVN: 1BA3D963
Coding: 032540122434010B24000000000000000000000000000000
Shop #: WSC 00049 770 00177
ASAM Dataset: EV_ECM20TFS0118V0907115E 001004
ROD: EV_ECM20TFS0118V0907115E_AU37.rod
VCID: 3A29E22FCCD28F2A80F-806E
VINID: 9A38EAAAA156A9B880006048083F1EB08F
Readiness: 1010 0001
Part No SW: 0GC 300 043 A HW: 0GC 927 711 H
Component: GSG DQ381 H06 2304
Revision: 00H06V08 CVN: 0D15E96C
Shop #: WSC 54321 321 54321
ROD: EV_TCMDQ381061.rod
VCID: 25132153556C10D2DDD-8070
No subsystems:
Part No SW: 5Q0 614 517 DG HW: 5Q0 614 517 AG
Component: ESC H62 0654
Revision: 00000000 Serial number: 61958000000114
Coding: 19EE6A92342021728778060860C52898562C84E160061475304250F4C223430B00000012121212B835351919323200
Shop #: WSC 00049 770 00251
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 79AB3D2389544432C95-802C
Part No SW: 5F0 907 044 AL HW: 5F0 907 044 AL
Component: Climatronic H05 1801
Revision: 00001K09
Coding: 02000004200114011105000000101020
VCID: 70BD0007DA2E057A7EB-8024
Air quality sensor:
Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
Component: BCM MQBAB H H38 0273
Serial number: 00001823002710 Dataset Number: V03935283TE 0002
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7DA329339D7C7812E5D-8028
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 180706 041 0574
Serial number: 180726193059
Coding: 0BC5FD
Serial number: 21753531X81A955555A0
Coding: 00005D
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018220 Dataset Number: V03935268GT 0002
Coding: 0471151111
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CC5B4F79646019A223-8018
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 5Q0 907 572 J
Dataset Number: V03935269FJ 0001
Coding: 350000C959FFC428949C814500300400000000000000000000
VCID: 44D59CD7BE16C9DAEA3-8010
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 11061841351059 Dataset Number: V03935286WC 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 382DF827F2DE9D3A76B-806C
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0712
Revision: -------- Serial number: 003W4PGZ1JAG Dataset Number: V03935263XZ 0001
Coding: 98CCC000000000005C0000CC000800000065
VCID: 055341D3F5AC30D2BDD-8050
Subsystem 1 - Part No SW: ----------- HW: 454 001 607 18
Serial number: 357000000009EC9DA03%
Subsystem 2 - Part No SW: ----------- HW: 454 001 807 18
Serial number: 3580000000099668113G
Subsystem 3 - Part No SW: ----------- HW: 454 802 007 18
Serial number: 3510071E261150000003
Subsystem 4 - Part No SW: ----------- HW: 454 802 007 18
Serial number: 35200882A7215000000A
Subsystem 5 - Part No SW: ----------- HW: 454 800 907 18
Serial number: 355002A4374150000006
Part No SW: 5Q0 953 507 GT HW: 5Q0 953 549 E
Revision: -------- Serial number: 19071804401221
Coding: 2C10
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 0E417EFFA0DA738A0C7-805A
Part No SW: 5F0 920 790 A HW: 5F0 920 790 A
Component: KOMBI 609 1693
Coding: 04A451087B840008018862031001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 270F2B5B2F6002C2EF1-8072
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 439 4344
Revision: -------- Serial number: 0008348231 Dataset Number: V03935283 0001
Coding: 030100F42F085900EB0002489C0F00010001070000000000000000000000
GVL: 01563C0000000000C08C80000080CC0000000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3D23E933DDFCB812A5D-8068
Generator:
Subsystem 2 - Part No SW: 5F0 959 537 D HW: 5F0 959 537 D
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1275300718
Coding: 012000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 7588600000180719183B
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 0000340796565 Dataset Number: V03935276VH 0001
Coding: 00140320DC00020000001000
VCID: 4FFFA3FB67503A82471-801A
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000022986470
Coding: 310000
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Dataset Number: V03935275DB 0002
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B27E72BC3E8B6229B9-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5F0 035 456 HW: 5F0 035 456
Component: KonzernAmp12K H03 2109
Revision: -------- Serial number: A1126A00038137 Dataset Number: V03935257ZG 0008
Coding: 0403000000A8FA88000000000000
ASAM Dataset: EV_AMPCAN12C3PASE 001003
ROD: EV_AMPCAN12C3PASE_SE37.rod
VCID: 62997A4F04C2A7EAF8F-8036
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0342
Serial number: 13081811600263 Dataset Number: V03935270EA 0003
Coding: 000000070900094A07000940000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002004
ROD: EV_MultiModulContiVW48X_002_VW48.rod
VCID: 3533F113E5CC60526DD-8060
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 0000341443681 Dataset Number: V03935276VJ 0001
Coding: 00140120DE00020000001000
VCID: 4EC1BEFF605A338A4C7-801A
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000023005987
Coding: 290000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5F0 035 877 HW: 5F0 035 877
Component: MU-S-ND-ER H50 0512
Serial number: SEZAZ2U0771461 Dataset Number: V03935282SK 0001
Coding: 04738201000000001111010300880A232F0101F4012004008E
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_MUStd4CTSAT 001001
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 698B6D63F9F4F4B2395-803C
Subsystem 1 - Part No SW: 5F0 919 606 HW: 5F0 919 606
Component: ABTm-2_8-CR H41 1042
Serial number: SEZ8Z9V6C04QMH
Subsystem 2 - Part No SW: 6P0 919 866 AF HW: -----------
Component: ECE1 2018/19 --- 1030
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0486389986 Dataset Number: V03935222LJ 0001
Coding: 0101000202000000
VCID: 40DD90C7AA0ED5FACEB-8014
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 19061841K10184 Dataset Number: V03935273GQ 0001
Coding: 0303070300000400002213458150A90094000E200020
ROD: EV_MFKBoschMQBB_001_SE37.rod
VCID: 084D48E7C2BE2DBAC6B-805C
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 7EA12E3F907A630AFC7-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
End----------(Elapsed Time: 01:38, VBatt start/end: 13.0V/13.0V)-----------
---------------------------No fault code found.----------------------------
