Audi Q5 tailgate electric lift lifts too low
bonzaii
Poland
C?ID=641924
Hello
I am having issues with my trunk's / boot's tailgate (depending on which side of the pond you’re messaging from).
I’ve had electric opening motors fall out (bracket snapped). I have since replaced the bracket, but in the process of doing so, I had to unplug and remove motors, which I later put back in. Putting them in position was quite a challenge and I am not sure if I’ve put them back in their original position (rotation). I am mentioning this as it might be related to the fact now my boot only opens to neck height (and when you’re 1.7m / 5ft7 it's not very high at all)
I’ve tried adapting the range both manually (using the button method) as well as via VCDS. I’ve adapted module 6D-Trunk Elect. channel 01 from 345 to 400 (which is max) and after an hour it has reset itself back to 345.
Just to be clear, at 345 it opens to my waist height, at 400 it opens to my neck height.
The button method doesn't allow setting it any higher (even if I push it all the way to the top and then do the buttons)
I’ve checked DTCs and I am reading that whilst boot is closed, it’s reading current position at 55%. When I push it (gently) to the position I really want it to open to, it’s reading 125%, when set to 400 it goes to 115.5%.
Another thing I am noticing and not sure if this is something to look into is End position Actual/last both show 0% ? I’ve opened and closed the boot a few times during diagnostic.
Below are plain logs and auto-scan at the end of my post.
I’ve been doing some reading and it lead me to think I need to re-adapt motors for them to know their range of operation?
Do you fine folk know where do I go from there? Any help will be greatly appreciated.
Here are readings from 6D-Trunk Elect. module (when boot is closed):
09:34:26 Group 004: Motor Status
OFF  Motor 1 Status
0.0 %  Motor 1
OFF  Motor 2 Status
0.0 %  Motor 2
09:34:26 Group 005: Clutch Status
Hold  Clutch Status 1
Hold  Clutch Status 2
09:34:26 Group 006: Tailgate Position
55.5 %  Current Position
115.5 %  Selectable Opening stop
09:36:05 Group 007: Tailgate
100.0 %  End position Learned (Open)
0.0 %  End position Actual/Last (Open)
2.5 %  End position Learned(Closed)
0.0 %  End position Actual/Last(Closed)
09:36:05 Group 008
25  Count
0  Count
0.0  Counter/timer Anti-play Protection
30142  Counter/timer Actuation Counter
09:36:05 Group 012
Closed  Status Lock
Closed  Status Closing aid
Retracted  Status Closing aid
Here's auto-scan:
Sunday,15,March,2026,09:40:33:31649
VCDS Version: 26.2.0.1 (x64)  HEX-V2 CB: 0.4701.5
Data version: 20251222 DS375.0
[www.Ross-Tech.com](http://www.ross-tech.com/)
VIN: WAUZZZ8R2DA041344   License Plate:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 20 36 42 44 46 52 53 56 5F 62
69 6D 72
VIN: WAUZZZ8R2DA041344   Mileage: 265770km-165141miles
## 01-Engine -- Status: Malfunction 0010
Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
Part No SW: 8K5 997 401     HW: 4G0 907 401
Component: 3.0TDI EDC17  H40 0006
Revision: 53H40---    CVN: 8ED68DA2
Coding: 2A254012053603020000
Shop #: WSC 02809 006 1048576
ASAM Dataset: EV_ECM30TDI0118K5997401 001006
ROD: EV_ECM30TDI0118K5997401.rod
VCID: 76B205AF984087AAE1E-8022
VINID: 9D196AAAA2220944401010C410EAA95538
7140 - Function Restriction due to Faults in Other Modules
U1113 00 [00100000] - -
5585 - Particulate Filter (Bank 1)
P242F 00 [00101111] - Restricted/Clogged
Mileage: 261076 km
Date: 2026.01.23
Time: 13:36:13
                Engine speed: 1284.50 /min
                Normed load value: 27.1 %
                Vehicle speed: 27 km/h
                Coolant temperature: 29 °C
                Intake air temperature: 2 °C
                Voltage terminal 30: 13.860 V
                Crankshaft speed (RPM): 1284.5 /min
                Vehicle speed: 27.47 km/h
                Exhaust gas jet volume in particle filter: 146.5 m³/h
                Particul.filter diff.pressure: 15 hPa
                Particle filter: oil ash volume: 0.39 l
                Exh t Adap T Oxi Cat Ds: 72.4 °C
                P Flt Ld fac Ash Cor: 0.6400
14583 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 00 [00101111] - Electrical Fault
Mileage: 256667 km
Date: 2025.09.27
Time: 10:40:06
                Engine speed: 1014.50 /min
                Normed load value: 97.3 %
                Coolant temperature: 9 °C
                Intake air temperature: 11 °C
                Voltage terminal 30: 11.100 V
                Glow-control unit: activation voltage: 11100 mV
                Glow_period_control_unit_ground_offset_voltage: 0 mV
                Glow-control unit: calculated glow voltage: 6075 mV
                Glow_period_control_unit_energy_integrator_calculated_value: 239.2 V²s
                Glow cycles upon reaching temperature threshold-Bits 0-7: 33
                Glow cycles upon reaching temperature threshold-Bits 0-7: 98
                Glow status-Bits 0-7: 0
                Co EOM st Op Mode Short-Bits 0-7: 0
14588 - Cylinder 6 Glow Plug Circuit (Q15)
P0676 00 [00101111] - Electrical Fault
Mileage: 254797 km
Date: 2025.07.23
Time: 10:35:07
                Engine speed: 988.50 /min
                Normed load value: 36.5 %
                Coolant temperature: 20 °C
                Intake air temperature: 20 °C
                Voltage terminal 30: 11.320 V
                Glow-control unit: activation voltage: 11380 mV
                Glow_period_control_unit_ground_offset_voltage: 2680 mV
                Glow_period_control_unit_energy_integrator_calculated_value: 215.5 V²s
                Glow cycles upon reaching temperature threshold-Bits 0-7: 23
Part No SW: 8R2 927 156 T    HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H02 0001
Revision: --H02---    CVN: 00007C48
Shop #: WSC 13944 004 1048576
ASAM Dataset: EV_TCMDL501021 001026
ROD: EV_TCMDL501021.rod
VCID: 4EC28D4F40509F6A09E-801A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 P    HW: 8R0 907 379 P
Component: ESP8 quattro  H09 0080
Coding: 229D4C
Shop #: WSC 06335 000 00000
VCID: 4DC08A434DD6A472704-8018
Part No SW: 8K0 907 064 GH    HW: 8K0 907 064 FH
Component: BCM2 2.0      H11 0621
Coding: 05A54040000000000000
VCID: 7CA61787A6ECDDFA97A-8028
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
Revision: C1000000    Serial number: 01151120121088
Coding: 3621028000
VCID: 3928CE93E95E28D2CCC-806C
Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
Revision: 08016001    Serial number: 00000512653301
Coding: 260000108174AFC00081400300001D0D0F1C670826090201000008004401030100000024000000
Shop #: WSC 06335 123 12345
VCID: 78AE0B9792D4F1DAF32-802C
Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
Component: WWS416 121105  H11 0050
Serial number: 90243014121026021445
Coding: 01DD13
Serial number: 20740528
Coding: 02005C
Component: E1 - LDS  H03 0031
Serial number: 00000000000211120545
Serial number: 06184856000000000001
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
Serial number: 003JPD9271YR   Dataset Number: 8R0909602E  0010
Coding: 30463431313030303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48CEBB57A234415A432-801C
Serial number: 6334MSME7521563BD
Serial number: 6344MSME75210622%
Serial number: 6352QSME04253A7EM
Serial number: 6362QSME512234443
Serial number: 63732SME0D262D664
Serial number: 63832SME4924057C0
Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
Revision: --------    Serial number: 90372LK7000LX
Coding: 000017
VCID: 43D4AC7B9B926202960-8016
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 P    HW: 8R0 920 930 P
Component: KOMBIINSTR.   H35 0556
Revision: 00000000    Serial number: UWI40FGCD
Coding: 13A6220003010008000000
VCID: 41D8A673818E701284C-8014
Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0055
Revision: 1Z100027    Serial number: 2741Z12A190335
Coding: 80CF07FF00
VCID: 4CC68747B6CCAD7A67A-8018
Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
Component: J367-BDM  H07 0141
Serial number: 00000000003790483199
Serial number: 12317000795011200181
Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
Component: FLA           H04 0012
Revision: AA001002
Coding: 02012064747464545425363E00
Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
Component: MEM-FS        H07 0076
Revision: AA000000    Serial number: 00000043509298
Coding: 01581B00000000000000
VCID: 42DAA97F84886B0A9D6-8016
Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
Component: TSG FA        H02 0506
Revision:             Serial number: 0000044310369
Coding: 011D12205E00440004
Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
Component: RCEPS         H37 0507
Revision: 00001000    Serial number: 0031014293 Dataset Number: 8R0909852H  0021
Coding: 100000000001
Shop #: WSC 06334 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B24D49BE3E21AC2DE0-806E
Revision: 00002001    Serial number: 0186786524
Coding: 01000E2020B93081852005328004000F
Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
Component: TSG BF        H02 0506
Revision:             Serial number: 0000044012897
Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
Component: EPB-4         H01 0003
Revision: --------    Serial number: 20000000175489
ROD: EV_ParkiBrake_AU48.rod
VCID: 382ECB97D2D431DA332-806C
Part No SW: 4G1 035 053 G    HW: 4G1 035 053
Component: Radio U Basic H41 0121
Revision: AB001007    Serial number: 227K%0C7661165
Coding: 010003020100000001
VCID: 23140CFB7BD24202F60-8076
Part No SW: 8R1 035 666 B    HW: 8R1 035 666 C
Component: H-BN-EU       H45 0639
Revision: --------    Serial number: 205K20C7557267
Coding: 160100060005A1ED4180AB5E00000403E40000020000000000
VCID: 372CC8ABDF4A3EA23A8-8062
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013  1505
Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
Component: DU7 High  H41 0104
Serial number: A130K.0C2584177
Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
Serial number: 00000001329406
Component: CD-Database  4949
02244 - Button in Control Head is Stuck
Reset counter: 70
Mileage: 265775 km
Date: 2026.03.14
Time: 11:12:18
                Voltage: 11.50 V
                Hex Value: 0x0001
                    not available
Component: TSG HL        H01 0506
Revision:             Serial number: 0000044506002
Coding: 010C12204000240004
VCID: 46D2B56FA8A0572AB1E-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
Revision: 1G001001    Serial number: 00000185507591
Coding: 0109080000000000
Shop #: WSC 25397 000 00000
VCID: 3530C2A3C546CCB2284-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
Component: J605  Master  H52 0330
Revision: --------    Serial number: 8R0827851B
VCID: 3B24D49BE3621AC2DE0-806E
Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
Component: J756  Slave  H52 0330
Serial number: 8R0827852B
Component: TSG HR        H01 0506
Revision:             Serial number: 0000044506066
End----------(Elapsed Time: 01:44, VBatt start/end: 14.6V/14.7V)-----------
------------------------------5 Faults Found-------------------------------
I have had this when one motor has failed and the other can't quite do it. Yours has the old units 8R0 827 851 and 2 B but you can't directly fit the revised D suffix units
bonzaii
Poland
C?ID=641924
When I had them out they both were turning when button was actuated, but that's as far as I was able to test. When I fitted them back in, they both looked like they're "pulling their weight", just not quite to the point I wanted. In a separate thread on this forum someone mentioned the struts might've given up and motors aren't able to lift it all the way on their own, perhaps it's something I should try replacing first as I imagine these are going to be fair cheaper and far less complicated than replacing the motors? It's 2012 after all so it's fair game if they haven't been replaced.
Also the only error I had on them was the connection issue from when I disconnected them - it hasn't returned since I cleared it.
bonzaii
Poland
C?ID=641924
So today I replaced struts. Old ones were indeed tired. After fitting, I pushed the tailgate to highest point, pushed and held close button until lights flash, and it made no difference. Looking at VCDS it set it to 301 so I, again, reset it to 400. It seems to reset itself back to 345 after locking and unlocking doors from keyfob.
I've been reading and from what I understand, there is a position sensor in the opening button assembly and that can sometimes cause issues. If that's true, is there any way I can read data from that sensor to see what it sees?
I had this with a 2018 A4 and I could not find a way with VCDS, I had to use ODIS. There probably is a way, it was just that I was pushed for time.
Ziddywerks
Northern NJ USA
C?ID=208579
I would recommend doing it through basic settings then selecting Set tail gate opening height . Write it in and see if it sticks.
