No Crank/no start after battery reconnection.
wildgoose
Australia
C?ID=400597
Monday,16,March,2026,14:56:40:57406
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: WAUZZZF23LN015414   License Plate:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 09 13 15 16 17 19 22 36 3C 42 44 46 47 52 5F 69 6D
          74 75 80 81 82 A5 BB BC CA CF D6 D7 DB DC DE
VIN: WAUZZZF23LN015414   Mileage: 48159km-29924miles
46-Central Conv. -- Status: Cannot be reached 0100
74-Chassis Control -- Status: Malfunction 0010
80-Batt. reg. aux. accum. -- Status: OK 0000
81-Gear Shift -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-----)       Labels: Redir Fail!
   Part No SW: 4K0 906 259 D    HW: 06L 907 425 C
   Component: R4 2.0l TFSI  H15 0005
   Revision: --H15---    CVN: 44546E13
   Coding: 0A6500122376050B34282000000400000000000000000000
   Shop #: WSC 12592 004 104857
   ASAM Dataset: EV_ECM20TFS0204K0906259D 001006
   ROD: EV_ECM20TFS0204K0906259D.rod
   VCID: 323D1C1494A1627A48F-8066
   VINID: 9D196AAAA5820DC78004510110C79A5C21
20276 - Ignition Switch; ON Position
          P2532 00 [00100111] - Short to Plus
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 19  C
                    Intake air temperature: 24  C
                    Voltage terminal 30: 11.933 V
                    FAC_TPS_1_SAE: 17.578125 %
                    FUP_H_SAE: 940.0 kPa
                    MAP_MES_SAE: 98 kPa
                    Engine: operating status: ES
                    TAA: 21.500  C
                    T_AST_SAE: 0 s
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
19862 - Body Control Module (Central Electric 2)
          U0141 00 [10100111] - No Communications
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:06
                    Voltage terminal 30: 11.953 V
                    LF_MVB_PDU_INTC_DIAG_15: 32512
                    LF_MVB_PDU_INTC_DIAG_16: 0
                    LF_MVB_PDU_INTC_DIAG_17: 33040
                    LF_MVB_PDU_INTC_DIAG_18: 0
                    LF_MVB_PDU_INTC_DIAG_19: 639
                    LF_MVB_PDU_INTC_DIAG_20: 2227
                    LF_MVB_BUS_INTC_DIAG: 256
23039 - Implausible Data Received from ABS Control Module
          U0415 00 [00100111] - -
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:05
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_2: 49152
                    LF_MVB_PDU_INTC_DIAG_3: 1571
                    LF_MVB_PDU_INTC_DIAG_4: 0
                    LF_MVB_PDU_INTC_DIAG_5: 0
                    LF_MVB_PDU_INTC_DIAG_6: 61472
26388 - Lane change assistant control module
          U1045 00 [00100111] - No communication
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:06
                    LF_MVB_PDU_INTC_DIAG_8: 20480
                    LF_MVB_PDU_INTC_DIAG_9: 898
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_13: 12288
Readiness: 1110 0001
   Part No SW: 4K0 927 153 F    HW: 0HK 927 156 B
   Component: 0CJ 20TFSIRdW H01 0004
   Revision: --H01---    Serial number: 0000002713 CVN: 306CDAF200000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 3039161C9AAD506A3EB-8064
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190177000627
21026 - Body Control Module (Central Electric 2)
          U0141 00 [00100111] - No Communications
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:05
                    Engine speed: 0 /min
                    Driving position: P
                    ATF temperature: 20  C
                    Voltage terminal 30: 11.9 V
                    Engine torque: -28 Nm
                    selected gear: 1
                    Ctrl. mod.: operating condition: regular operation
                    Auxiliary pump for transmission: requesting function: Check accum. pressure
                    Auxiliary hydraulic pump for transmission oil: current: 1 A
                    Oil pressure reservoir: pressure: 0.0 bar
                    Pressure of clutch 1: actual value: 0.0 bar
                    Pressure of clutch 2: actual value: 0.0 bar
                    Clutch status: Neutral
                    Occurrence_counter_over_length_of_life: 14
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4N0 907 379 AL    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0856
   Dataset Number: 4K0909504AC 0001 CVN: 6C92D866
   Coding: 18AA41972CA30B9B11A24C922881D2E2F5B9C9188234D08832144B47AF9D93
   Shop #: WSC 12592 004 1048576
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 025D8CD4648112FA98F-8056
7 Faults Found:
0077 - Databus
          U1121 00 [00101111] - Missing Message
          [ComScl:_PDU_KAS_01_-_Timeout_error]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    79 00 03 00 C2 03 00 50 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
475904 - Databus
          [ComScl:_PDU_Licht_hinten_01-_Timeout_error]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
277248 - Databus
          U1121 00 [10101111] - Missing Message
          [ComScl:_Signal_Group_SG_Klemmen_Status_01-_Timeout_error]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
451328 - Databus
          [ComScl:_Signal_Group_SG_RCTA_01_-_Timeout_error]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
494080 - Comfort Control Module
          C1254 F0 [00101111] - Brake Light Signal Implausible
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
15728897 - Control Module Improper Shut Down
          U3001 00 [00100111] - -
          [Multiple_power_cycles_has_happened_without_proper_postrun]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:17:04
                    77 00 03 00 C2 03 00 50 00 00
12665088 - Body Control Module (Central Electric 2)
          [During_variant_check_no_Vin_was_received_in_time]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:17:03
                    77 00 00 00 C2 03 00 50 00 00
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 FE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0690
   Dataset Number: 4K0909514E  0032
   Coding: 07000743C13900DD070457881FFF8C68130B33110406009701010A00193316810A450A024010000000000303004109080802000044010100000000000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 76B5E00438493E5AA47-8022
   Subsystem 1 - Part No SW: 4K2 955 119     HW: 4K2 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001904030404686
   Coding: 7DC727
   Serial number: 23371851X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K2 941 501     HW: 4K2 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 16S10.07.1900300286
   Serial number: GX1CE122051924210558
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AH    HW: 4K0 947 135 AH
   Component: Dachmodul  H42 0415
   Serial number: B01283270
   Coding: 0D0104
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA138277000070397017
   Coding: 0A0700
65828 - Databus
          [Comfort system central control module: no signal/communication]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:59:42
                    average_Voltage_terminals: 12.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 21.50  C
                    interior_temperature: 23.00  C
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 15 via CAN: OFF
66707 - Control Module for Driver Assist Systems
          U12B9 00 [00001001] - No Communication
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:59:45
   Part No SW: 4K0 907 561 G    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Dataset Number: 4K0909863N  0003
   Coding: 5265E7D458082C00000060E00000003E4A1246484401009E01
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
11 Faults Found:
2174 - Databus
          [FAULT_BRAKINGLIGHT_IMPLAUSIBLE]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
                    Control Module temperature: 35  C
                    Voltage terminal 15: 12.0 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s
                    Adaptive distance regulation: status: ACC_irreversible error
                    Steering_angle-Data: -4.900
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: OFF
                    Misalignment angle: horiz: -0.122
                    Misalignment angle: horiz: fast algorithm: -0.265
                    Congestion pilot: status: OFF
                    Outside temperature: 21.50  C
                    Sensor blindness: radar: no blindness detected
1229 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FAULT_CODING_AAG]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2337 - Databus
          [FAULT_CORNERRADAR_FL_DATA_TRANSFER]
                    Fault Frequency: 229
                    Reset counter: 115
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:09
2338 - Databus
          U1122 00 [00001000] - Implausible Message
          [FAULT_CORNERRADAR_FR_DATA_TRANSFER]
                    Reset counter: 115
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:09
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2115 - Databus
          [FAULT_HMS_FAILURESTATE]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
0800 - Databus
          [FAULT_SWA_RELEVANT_ERROR]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2370 - Databus
          [FAULT_TIMEOUT_KLEMMEN_STATUS_01]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
1224 - Databus
          [FAULT_TIMEOUT_LICHT_HINTEN_01]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
1135 - Databus
          [FAULT_TIMEOUT_SWA_HEADER]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
Address 15: Airbags (J234)       Labels:| 80A-959-655-V1.clb
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H19 2720
   Serial number: 003YZM06RXYM Dataset Number: 4K0909602AF 0001
   Coding: AAFCF0C00CC000009854003FF08D41AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 4ACD64F41C310ABA10F-801E
   Left seat belt tensioner:
   Serial number: 00AI2019189118800000
   Coding: 04F001
   Right seat belt tensioner:
   Serial number: 00AI2019184100900000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 002 108 19
   Serial number: 35700000000BC5151F3P
   Subsystem 4 - Part No SW: -----------    HW: 480 002 407 19
   Serial number: 35800000000A884C0E3W
   Subsystem 5 - Part No SW: -----------    HW: 480 031 908 19
   Serial number: 351001C24B9E4A70DCAW
   Subsystem 6 - Part No SW: -----------    HW: 480 031 908 19
   Serial number: 352001C2452392E0BDBD
   Subsystem 7 - Part No SW: -----------    HW: 480 032 607 19
   Serial number: 355001C244DE4CC09E4W
   Subsystem 8 - Part No SW: -----------    HW: 480 032 607 19
   Serial number: 356001C244DE04B0CC8P
   Subsystem 9 - Part No SW: -----------    HW: 480 031 707 19
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C2461088A0DD52
   Subsystem 10 - Part No SW: -----------    HW: 480 001 207 19
   Serial number: I0M00000000491205DB%
   Subsystem 11 - Part No SW: -----------    HW: 480 001 207 19
   Serial number: I0N000000005D1205DB5
          B13BC F2 [10001001] - No function
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:41
1054208 - Databus
          [NWD: 0x3C0 Klemmen_Status_01 Timeout]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:42
   Part No SW: 4N0 907 129 AF    HW: 4N0 907 129 AF
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 75B7E708254F3542ADD-8020
   Part No SW: 4K0 920 790 B    HW: 4K0 920 790 B
   Component: FBenRDWACC--- H12 0208
   Dataset Number: 4K0909525E  0029
   Coding: A58520C2FC88000801A3E1609080280008002200
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 2C01026CB685348A023-8078
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 4K0 907 468 L    HW: 4K0 907 468 C
   Component: Gateway       H06 0262
   Serial number: 1YF03068838901 Dataset Number: 4K0909515E  0036
   Coding: 020100050020864029870000005B0132DCB8004710000000097D078E10000000
   GVL: F1D13C080800000080DC88008000C800110C0060004000000000000000000100
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 3D273F285DFFAD02A5D-8068
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 741863130019071902F7
0513 - Terminal 15
          U1405 00 [00001001] - Implausible signal
          [HW_Clamp_15_Implausible]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:25
                    Terminal 15 status-Terminal 15 power supply: 11.70 V
                    Terminal 15 status-Terminal 15 status measured: OFF
                    Terminal 15 status-Terminal 15 resulting: OFF
                    Terminal 15 status-Terminal 15 via CAN: OFF
                    Terminal 15 status-Terminal 15 via comparator: On
65793 - Comfort System Databus (VAG Wingle-Wire Mode) (SAE L Shorted H)
          U0018 00 [00001001] - -
          [CAN_Comfort_Single_Wire_Error]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:16
                    Voltage_Comfort_CAN-Voltage_CAN_High: 0.18 V
                    Voltage_Comfort_CAN-Voltage_CAN_Low: 0.00 V
131591 - Control Module 2 for Lane Change Assist
          U13C2 00 [00001001] - No Communication on 2nd Bus
          [Timeout_Node_0x07_DiagAdress_CF_MRR_HL]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:18
131592 - Control Module for Lane Change Assist
          U13C1 00 [00001001] - No Communication on 2nd Bus
          [Timeout_Node_0x08_DiagAdress_3C_MRR_HR]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:18
131723 - Body Control Module (Central Electric 2)
          U0141 00 [00001001] - No Communications
          [Timeout_Node_0x8B_DiagAdress_46_BCM2]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:18
262669 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [BAP_Timeout_DoorLocking]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:16
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 4K0 927 755 A    HW: 0CJ 927 749 A
   Component: C8_DL3_N_SD1  H01 0007
   Serial number: 19144B1592
   Coding: 110C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 333319106BBB6B72439-8066
29727 - Implausible Data Received from ABS Control Module
          [Invalid Data Received FromAnti-Lock Brake System Control Module]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Battery voltage: 12.121 V
                    Engine current: 0.0000 A
                    Internal system status: 00
                    Actuator angle: actual value: 0.359375
                    Processor load: 73 %
                    Stack store: 00 00 00
                    Operating time: 10 min
                    Ambient temperature: 21.5  C
                    End stage temperature: 24  C
                    HW KL15 Debounce Time: 30 ms
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    System condition: 00 00
                    XCP-DAQ OdtEntryCount: 0
                    UDS Session: Extended Diagnostic Session
                    Standard Seed and Key unlocked: 0
                    Advanced Seed and Key unlocked: 0
                    XCP Calibration activated: 0
                    XCP Measurement active: 0
                    DEV_X_06 enabled: 0
                    Reserved: FF FF FF FF FF FF
                    Unlearning counter according OBD-OBD unlearning counter: 40
                    Solenoid Current-SolenoidCurrent: 0.0000 A
                    Sensor Speed: 0 /min
                    NM-State: NM_STATE_NORMAL_OPERATION
                    Wakeup-Reason-Wakeup Reason: FLEXRAY_UP
                    Reset reason-ResetReason: FF 00 00 00
                    DTC Subcode (FR_ESP_21_SIGNAL_ERROR)-DTC SubCode: Signal not valid
29736 - Implausible Data Received from ABS Control Module
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
                    DTC Subcode (FR_ESP_08_SIGNAL_ERROR)-DTC SubCode: Signal not valid
30032 - Terminal 15
          U1405 00 [00100111] - Implausible signal
          [Terminal 15Implausible signal]
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
32070 - Implausible Data Received from ABS Control Module
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
                    DTC Subcode (FR_ESP_22_SIGNAL_ERROR)-DTC SubCode: Signal not valid
33190 - Body Control Module (Central Electric 2)
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
                    Timeout PDU ID (FR_BCM2_TIMEOUT)-Timeout PDU ID: PDU_VIN_01
   Serial number: 00000383381105 Dataset Number: 4K8909856C  0016
   Coding: 00781A400000B4010003010101010000000000000000000000000000004000
   VCID: 79AFEB3809575122C95-802C
458764 - Databus
          U1121 00 [00101001] - Missing Message
          [Kessy_11_missing_message]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:22
458767 - Databus
          [Klemmen_Status_01_missing_message]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:18
458818 - Databus
          [ZV_02_missing_message]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:19
459027 - Databus
          [Kessy_12_missing_message]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:19
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Dataset Number: 4K8909535D  0023
   Coding: 4FDC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 3B23313043EBA3329B9-806E
2232325 - Databus
          [databus message missing - BCM - Klemmen_Status_01]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:35
                    Control Module temperature: 53  C
                    Voltage terminal 30: 12.00 V
                    Vehicle speed: Malfunction
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: Measuring value not available
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS002 0189
   Serial number: YE007SEV02559 Dataset Number: 4K8909872B  0034
   Coding: 001DDB0052010480A001B030
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 40D946DC2A0DC0EACEB-8014
Address 44: Steering Assist (J500)       Labels:* 4N0-909-144-V1.clb
   Dataset Number: 4K0909852K  0002
   Coding: B4002101010000
   ROD: EV_EPSVWBSAU426_010.rod
3155969 - Databus
          [COMI_TIMEOUT_KLEMMENSTATUS]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:05
                    FreezeFrame_mw_120C_Timeout-Engine speed: 0.00 /min
                    FreezeFrame_mw_120C_Timeout-System status: 0
                    FreezeFrame_mw_120C_Timeout-Terminal 30 power supply: 12.15 V
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
                    FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
                    FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
                    FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: OFF
                    FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: -4.79
                    FreezeFrame_mw_120C_Timeout-ARA_signal_red_cyclic: 00
                    FreezeFrame_mw_120C_Timeout-PLA_signal_red_cyclic: 00
                    FreezeFrame_mw_120C_Timeout-SCU state: System OK
                    FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
Address 46: Central Conv.
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D021BX0 Dataset Number: 4K0909510A  0009
   Coding: 0185010000AAAA2FAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411EA4CDE55FCCACA3-8070
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS002 0189
   Serial number: YE007SFC10675 Dataset Number: 4K8909873B  0034
   Coding: 001DDB005E010480A001B030
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 3FDB452057F3BF12B71-806A
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 066 D    HW: 4K0 035 066 A
   Component: MU-H-LN-ER    054 2711
   Dataset Number: 4K0909545F  0038
   Coding: 0185010800000000C1511102C00800302F0001E603F00804CE
   VCID: 270BFD40AF6317D2EF1-8072
   Subsystem 1 - Part No: V03 959 808 AR
   Component: MIB2P_RW_Q223  0673
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4K1 919 605 H    HW: 4K1 919 605 F
   Component: DU AU58x Top  H71 0171
   Serial number: BHB00130071903200068
   Compact disc data bank:
   Component: Gracenote2  4012
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000072745055
   Multimedia display unit 5:
   Subsystem 5 - Part No SW: 4K4 919 603 H    HW: 4K4 919 603 F
   Component: DU AU58x Bot  H71 0171
   Serial number: BHB00124071903130727
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900428274008
6705 - Databus
          [Terminal_status: no communication]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:03:44
                    Voltage terminal 30: 12.0 V
                    Network diagnosis-Status: Enabled
6714 - Databus
          [VIN: no communication]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:03:44
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0563524818
   Coding: 0300000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3537270865CF75426DD-8060
340484 - Databus
          [Central module comfort system - no signal/communication]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:12
   Part No SW: 8W5 959 107 D    HW: 8W5 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8791-2 Dataset Number: 4K0909541D  0013
   Coding: 0730
   VCID: 47CB5DC00F23F7D20F1-8012
0100 - Data Set Implausible
          B2012 00 [00001001] - -
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:27
0055 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:27
Address 74: Chassis Control (J775)       Labels:* 4N0-907-777.clb
   Part No SW: 4K0 907 777 CB    HW: 4K0 907 777 D
   Component: Fahrwerk-SG   H52 2135
   Serial number: 1107190548  Dataset Number: 4K0909576M  0009
   Coding: 105D58385842
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
13 Faults Found:
3407876 - Databus
          [Internal_communication_error_ESP_Systemstatus]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 84
4456458 - Implausible Data Received from ABS Control Module
          U0415 00 [00001001] - -
          [Function_restriction_due_to_communication_interruption_EspOverSteer]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 130
4456531 - Implausible Data Received from ABS Control Module
          [Function_restriction_due_to_communication_interruption_EspUnderSteer]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 138
6553615 - Implausible Data Received from ABS Control Module
          [Function_restriction_due_to_communication_interruption_trqBrkWFL_In]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 235
6553616 - Implausible Data Received from ABS Control Module
          [Function_restriction_due_to_communication_interruption_trqBrkWFR_In]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 236
6553617 - Implausible Data Received from ABS Control Module
          [Function_restriction_due_to_communication_interruption_trqBrkWRL_In]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 237
6553618 - Implausible Data Received from ABS Control Module
          [Function_restriction_due_to_communication_interruption_trqBrkWRR_In]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 238
327793 - Control Module Incorrectly Coded
          [Incorrectly_coded_mounting_coding_trailer]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 564
262158 - Databus
          U1121 00 [10001001] - Missing Message
          [Timeout_Error_Klemmen_Status_01]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 599
262173 - Databus
          [Timeout_Error_ZV_02]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 612
262207 - Databus
          [Timeout_Error_Kessy_11]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 644
262210 - Databus
          [Timeout_Error_Personalisierung_01]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 656
196611 - Quantity of Fuel Added to Tank
          C123D 29 [00001001] - Signal Implausible
          [Function limitation through implausible Signal KBI_Inhalt_Tank]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 839
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4M1 035 283 B    HW: 4M1 035 283 B
   Component: ConBox        H09 0232
   Serial number: 005CCA18F110709 Dataset Number: 4K0909612D  0016
   Coding: 01C020FF4040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 290FFB78B97721A2F95-807C
197128 - Databus
          [Clamp_State_Timeout]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:09
197142 - Databus
          [VIN_timeout]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:09
197143 - Databus
          [ZV_Timeout]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:09
1114627 - Antenna 2 for Emergency Call and Communications Module
          B18BE 13 [00001001] - Open Circuit
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:12
                    Voltage terminal 30: 12.20 V
                    Mobile communications antenna 2 for emergency call module and communications unit-Connection to antenna: Open circuit
                    Mobile communications antenna 2 for emergency call module and communications unit-Reception level antenna: -113.00 %
                    Mobile communications antenna 2 for emergency call module and communications unit-Voltage: 1300 mV
Address 80: Batt. reg. aux. accum. (A1)       Labels: 8W0-915-101.clb
   Part No SW: 4K0 915 101     HW: 4K0 915 101
   Component: MQ-BMS        H20 0127
   Serial number: 19000058906001
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 6099A65C8ACDA0EAEEB-8034
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4K2 713 041 H    HW: 4K2 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 19.192 40071
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
9014 - Databus
          [MESSAGE_KLEMMEN_01_TIMEOUT]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:25
                    Selec. range display: spec. val.-Text: P
                    Selector lever position-Text: Basic setting X
                    Inside temperature: 23.50  C
                    System run time-Hours: 0 H
                    System run time-Minutes: 14 min
                    System run time-Seconds: 24 s
Address 82: Head Up Display (J898)       Labels:| 4Nx-919-617-V1.clb
   Part No SW: 4K2 919 617 B    HW: 4K2 919 617 B
   Component: HeadupDisplay H05 4910
   Coding: 4600E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 34311A0C6EB56C4A5A3-8060
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AM    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0293
   Dataset Number: 4K0909466N  0048
   Coding: 03C182000000000000FBD60000F0460C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980800000000000000078D00080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 0A4DA4F45CB14ABAD0F-805E
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS004 0189
   Serial number: YE007SGB08423 Dataset Number: 4K8909897B  0035
   Coding: 000DD90000010480A000B020
   VCID: 42DD4CD42401D2FAD8F-8016
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS004 0189
   Serial number: YE007SGB00714 Dataset Number: 4K8909896B  0035
   Dataset Number: 4K0909469G  0017
   Coding: 768040058101
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Dataset Number: 4K8909468D  0023
   Coding: 4FDC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
2232325 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:06:05
                    Control Module temperature: 52  C
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   Dataset Number: 4K0909471K  0019
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BDDC145421227A88F-8026
   Dynamic left front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 035     HW: 4K0 941 035
   Component: M134DynTurnFL  003 0004
   Serial number: 02051900026533001011
   Dataset Number: 4K0909472K  0019
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
   Dynamic right front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 036     HW: 4K0 941 036
   Component: M135DynTurnFR  003 0004
   Serial number: 13031900024116001011
Address DB: Frt Corner Rdar 1 (J1089)       Labels:| 4N0-907-669.clb
   Part No SW: 4N0 907 669 H    HW: 4N0 907 669 A
   Component: MRR_VR H16 MRR_VR H16 02670267
   Dataset Number: 4K8909482C  0020
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: N/A
Address DC: Frt Corner Rdar 2 (J1088)       Labels:| 4N0-907-669.clb
   Component: MRR_VL H16 0267
   Dataset Number: 4K8909483C  0021
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400000
   VCID: 2019E65CCA4DE0EAAEB-8074-R
End----------(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.1V)-----------
------------------------------68 Faults Found------------------------------
wildgoose
Australia
C?ID=400597
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:06
                    MAP_MES_SAE: 98 kPa
                    TAA: 21.500  C
                    T_AST_SAE: 0 s
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:06
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:05
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:06
   MTF pump:
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:05
                    Driving position: P
                    selected gear: 1
7 Faults Found:
0077 - Databus
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
475904 - Databus
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
277248 - Databus
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
451328 - Databus
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:17:04
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:17:03
   Coding: 7DC727
   Coding: 02006E
   Coding: 210000
   Coding: 0D0104
   Coding: 0A0700
65828 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:59:42
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 00:59:45
11 Faults Found:
2174 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
          [FAULT_CODING_AAG]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2337 - Databus
                    Reset counter: 115
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:09
2338 - Databus
                    Reset counter: 115
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:09
2101 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2115 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
0800 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2370 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
1224 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
1135 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
2068 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:07
   Coding: 04F001
   Coding: 04F001
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:41
1054208 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:00:42
0513 - Terminal 15
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:25
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:16
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:18
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:18
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:18
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:16
   Coding: 110C0000
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
30032 - Terminal 15
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:01:52
                    Combined KL15: 1
                    HW KL15 Filtered: 1
                    HW KL15 Raw: 1
                    SW KL15: 0
                    SW KL15 Timeout: 1
                    DEV_X_06 enabled: 0
458764 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:22
458767 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:18
458818 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:19
459027 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:19
   Coding: 4FDC00
2232325 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:02:35
3155969 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:07:05
   Volume Control 1:
   Media socket:
6705 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:03:44
6714 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:03:44
340484 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:12
   Coding: 0730
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:27
0055 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:27
13 Faults Found:
3407876 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 84
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 130
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 138
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 235
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 236
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 237
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:41
                    Internal DTC: 238
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 564
262158 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 599
262173 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 612
262207 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 644
262210 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 656
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:04:42
                    Internal DTC: 839
197128 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:09
197142 - Databus
          [VIN_timeout]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:09
197143 - Databus
          [ZV_Timeout]
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:09
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:12
9014 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:05:25
   Coding: 4600E0
   Coding: 4FDC00
2232325 - Databus
                    Reset counter: 75
                    Mileage: 48159 km
                    Date: 2026.03.14
                    Time: 01:06:05
   Coding: 001000
   ROD: N/A
   Coding: 001000
   Coding: 400000
I've posted this twice - sorry, it's a new laptop
Sounds like there's a lot more to this story.......
