Monday,16,March,2026,14:56:40:57406
VCDS Version: 25.3.3.0 (x64) HEX-V2 CB: 0.4671.4
Data version: 20260227 DS365.0
VIN: WAUZZZF23LN015414 License Plate:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 09 13 15 16 17 19 22 36 3C 42 44 46 47 52 5F 69 6D
74 75 80 81 82 A5 BB BC CA CF D6 D7 DB DC DE
VIN: WAUZZZF23LN015414 Mileage: 48159km-29924miles
46-Central Conv. -- Status: Cannot be reached 0100
74-Chassis Control -- Status: Malfunction 0010
80-Batt. reg. aux. accum. -- Status: OK 0000
81-Gear Shift -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-----) Labels: Redir Fail!
Part No SW: 4K0 906 259 D HW: 06L 907 425 C
Component: R4 2.0l TFSI H15 0005
Revision: --H15--- CVN: 44546E13
Coding: 0A6500122376050B34282000000400000000000000000000
Shop #: WSC 12592 004 104857
ASAM Dataset: EV_ECM20TFS0204K0906259D 001006
ROD: EV_ECM20TFS0204K0906259D.rod
VCID: 323D1C1494A1627A48F-8066
VINID: 9D196AAAA5820DC78004510110C79A5C21
20276 - Ignition Switch; ON Position
P2532 00 [00100111] - Short to Plus
Mileage: 48159 km
Date: 2026.03.14
Time: 01:07:06
Engine speed: 0.00 /min
Coolant temperature: 19 C
Intake air temperature: 24 C
Voltage terminal 30: 11.933 V
FAC_TPS_1_SAE: 17.578125 %
FUP_H_SAE: 940.0 kPa
MAP_MES_SAE: 98 kPa
Engine: operating status: ES
TAA: 21.500 C
T_AST_SAE: 0 s
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
19862 - Body Control Module (Central Electric 2)
U0141 00 [10100111] - No Communications
Mileage: 48159 km
Date: 2026.03.14
Time: 01:07:06
Voltage terminal 30: 11.953 V
LF_MVB_PDU_INTC_DIAG_15: 32512
LF_MVB_PDU_INTC_DIAG_16: 0
LF_MVB_PDU_INTC_DIAG_17: 33040
LF_MVB_PDU_INTC_DIAG_18: 0
LF_MVB_PDU_INTC_DIAG_19: 639
LF_MVB_PDU_INTC_DIAG_20: 2227
LF_MVB_BUS_INTC_DIAG: 256
23039 - Implausible Data Received from ABS Control Module
U0415 00 [00100111] - -
Mileage: 48159 km
Date: 2026.03.14
Time: 01:07:05
LF_MVB_PDU_INTC_DIAG_1: 0
LF_MVB_PDU_INTC_DIAG_2: 49152
LF_MVB_PDU_INTC_DIAG_3: 1571
LF_MVB_PDU_INTC_DIAG_4: 0
LF_MVB_PDU_INTC_DIAG_5: 0
LF_MVB_PDU_INTC_DIAG_6: 61472
26388 - Lane change assistant control module
U1045 00 [00100111] - No communication
Mileage: 48159 km
Date: 2026.03.14
Time: 01:07:06
LF_MVB_PDU_INTC_DIAG_8: 20480
LF_MVB_PDU_INTC_DIAG_9: 898
LF_MVB_PDU_INTC_DIAG_10: 0
LF_MVB_PDU_INTC_DIAG_11: 0
LF_MVB_PDU_INTC_DIAG_13: 12288
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 153 F HW: 0HK 927 156 B
Component: 0CJ 20TFSIRdW H01 0004
Revision: --H01--- Serial number: 0000002713 CVN: 306CDAF200000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 3039161C9AAD506A3EB-8064
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190177000627
21026 - Body Control Module (Central Electric 2)
U0141 00 [00100111] - No Communications
Mileage: 48159 km
Date: 2026.03.14
Time: 01:07:05
Engine speed: 0 /min
Driving position: P
ATF temperature: 20 C
Voltage terminal 30: 11.9 V
Engine torque: -28 Nm
selected gear: 1
Ctrl. mod.: operating condition: regular operation
Auxiliary pump for transmission: requesting function: Check accum. pressure
Auxiliary hydraulic pump for transmission oil: current: 1 A
Oil pressure reservoir: pressure: 0.0 bar
Pressure of clutch 1: actual value: 0.0 bar
Pressure of clutch 2: actual value: 0.0 bar
Clutch status: Neutral
Occurrence_counter_over_length_of_life: 14
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4N0 907 379 AL HW: 4N0 907 379 P
Component: ESP9 Premium H06 0856
Dataset Number: 4K0909504AC 0001 CVN: 6C92D866
Coding: 18AA41972CA30B9B11A24C922881D2E2F5B9C9188234D08832144B47AF9D93
Shop #: WSC 12592 004 1048576
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 025D8CD4648112FA98F-8056
7 Faults Found:
0077 - Databus
U1121 00 [00101111] - Missing Message
[ComScl:_PDU_KAS_01_-_Timeout_error]
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
79 00 03 00 C2 03 00 50 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
475904 - Databus
[ComScl:_PDU_Licht_hinten_01-_Timeout_error]
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
277248 - Databus
U1121 00 [10101111] - Missing Message
[ComScl:_Signal_Group_SG_Klemmen_Status_01-_Timeout_error]
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
451328 - Databus
[ComScl:_Signal_Group_SG_RCTA_01_-_Timeout_error]
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
494080 - Comfort Control Module
C1254 F0 [00101111] - Brake Light Signal Implausible
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
15728897 - Control Module Improper Shut Down
U3001 00 [00100111] - -
[Multiple_power_cycles_has_happened_without_proper_postrun]
Mileage: 48159 km
Date: 2026.03.14
Time: 00:17:04
77 00 03 00 C2 03 00 50 00 00
12665088 - Body Control Module (Central Electric 2)
[During_variant_check_no_Vin_was_received_in_time]
Mileage: 48159 km
Date: 2026.03.14
Time: 00:17:03
77 00 00 00 C2 03 00 50 00 00
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 FE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0690
Dataset Number: 4K0909514E 0032
Coding: 07000743C13900DD070457881FFF8C68130B33110406009701010A00193316810A450A024010000000000303004109080802000044010100000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016.rod
VCID: 76B5E00438493E5AA47-8022
Subsystem 1 - Part No SW: 4K2 955 119 HW: 4K2 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001904030404686
Coding: 7DC727
Serial number: 23371851X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K2 941 501 HW: 4K2 941 501
Component: E1 - LTM H05 0053
Serial number: 16S10.07.1900300286
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE122051924210558
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AH HW: 4K0 947 135 AH
Component: Dachmodul H42 0415
Serial number: B01283270
Coding: 0D0104
Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA138277000070397017
Coding: 0A0700
65828 - Databus
[Comfort system central control module: no signal/communication]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 00:59:42
average_Voltage_terminals: 12.00 V
Outside air temperature sensor-Outside air temperature on CAN: 21.50 C
interior_temperature: 23.00 C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 15 via CAN: OFF
66707 - Control Module for Driver Assist Systems
U12B9 00 [00001001] - No Communication
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 00:59:45
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4K0 907 561 G HW: 4K0 907 561
Component: LRR4R H04 0332
Dataset Number: 4K0909863N 0003
Coding: 5265E7D458082C00000060E00000003E4A1246484401009E01
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_VW53.rod
11 Faults Found:
2174 - Databus
[FAULT_BRAKINGLIGHT_IMPLAUSIBLE]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
Control Module temperature: 35 C
Voltage terminal 15: 12.0 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s
Adaptive distance regulation: status: ACC_irreversible error
Steering_angle-Data: -4.900
Yaw_rate-Data: 0.000 rad/s
adjustment_calculation: OFF
Misalignment angle: horiz: -0.122
Misalignment angle: horiz: fast algorithm: -0.265
Congestion pilot: status: OFF
Outside temperature: 21.50 C
Sensor blindness: radar: no blindness detected
1229 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[FAULT_CODING_AAG]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
2337 - Databus
[FAULT_CORNERRADAR_FL_DATA_TRANSFER]
Fault Frequency: 229
Reset counter: 115
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:09
2338 - Databus
U1122 00 [00001000] - Implausible Message
[FAULT_CORNERRADAR_FR_DATA_TRANSFER]
Reset counter: 115
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:09
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
2115 - Databus
[FAULT_HMS_FAILURESTATE]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
0800 - Databus
[FAULT_SWA_RELEVANT_ERROR]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
2370 - Databus
[FAULT_TIMEOUT_KLEMMEN_STATUS_01]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
1224 - Databus
[FAULT_TIMEOUT_LICHT_HINTEN_01]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
1135 - Databus
[FAULT_TIMEOUT_SWA_HEADER]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:07
Address 15: Airbags (J234) Labels:| 80A-959-655-V1.clb
Part No SW: 4N0 959 655 Q HW: 4N0 959 655 Q
Component: AirbagVW31 H19 2720
Serial number: 003YZM06RXYM Dataset Number: 4K0909602AF 0001
Coding: AAFCF0C00CC000009854003FF08D41AC00C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 4ACD64F41C310ABA10F-801E
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2019189118800000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2019184100900000
Coding: 04F001
Subsystem 3 - Part No SW: ----------- HW: 480 002 108 19
Serial number: 35700000000BC5151F3P
Subsystem 4 - Part No SW: ----------- HW: 480 002 407 19
Serial number: 35800000000A884C0E3W
Subsystem 5 - Part No SW: ----------- HW: 480 031 908 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C24B9E4A70DCAW
Subsystem 6 - Part No SW: ----------- HW: 480 031 908 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C2452392E0BDBD
Subsystem 7 - Part No SW: ----------- HW: 480 032 607 19
Component: FrontSensor_D 002 0149
Serial number: 355001C244DE4CC09E4W
Subsystem 8 - Part No SW: ----------- HW: 480 032 607 19
Component: FrontSensor_P 002 0149
Serial number: 356001C244DE04B0CC8P
Subsystem 9 - Part No SW: ----------- HW: 480 031 707 19
Component: PedP_Sensor_C 002 0149
Serial number: 230001C2461088A0DD52
Subsystem 10 - Part No SW: ----------- HW: 480 001 207 19
Serial number: I0M00000000491205DB%
Subsystem 11 - Part No SW: ----------- HW: 480 001 207 19
Serial number: I0N000000005D1205DB5
B13BC F2 [10001001] - No function
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:41
1054208 - Databus
[NWD: 0x3C0 Klemmen_Status_01 Timeout]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:00:42
Part No SW: 4N0 907 129 AF HW: 4N0 907 129 AF
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 75B7E708254F3542ADD-8020
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 790 B HW: 4K0 920 790 B
Component: FBenRDWACC--- H12 0208
Dataset Number: 4K0909525E 0029
Coding: A58520C2FC88000801A3E1609080280008002200
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2C01026CB685348A023-8078
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 4K0 907 468 L HW: 4K0 907 468 C
Component: Gateway H06 0262
Serial number: 1YF03068838901 Dataset Number: 4K0909515E 0036
Coding: 020100050020864029870000005B0132DCB8004710000000097D078E10000000
GVL: F1D13C080800000080DC88008000C800110C0060004000000000000000000100
ASAM Dataset: EV_Gatew31xAU65x 003190
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 3D273F285DFFAD02A5D-8068
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 741863130019071902F7
0513 - Terminal 15
U1405 00 [00001001] - Implausible signal
[HW_Clamp_15_Implausible]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:25
Terminal 15 status-Terminal 15 power supply: 11.70 V
Terminal 15 status-Terminal 15 status measured: OFF
Terminal 15 status-Terminal 15 resulting: OFF
Terminal 15 status-Terminal 15 via CAN: OFF
Terminal 15 status-Terminal 15 via comparator: On
65793 - Comfort System Databus (VAG Wingle-Wire Mode) (SAE L Shorted H)
U0018 00 [00001001] - -
[CAN_Comfort_Single_Wire_Error]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:16
Voltage_Comfort_CAN-Voltage_CAN_High: 0.18 V
Voltage_Comfort_CAN-Voltage_CAN_Low: 0.00 V
131591 - Control Module 2 for Lane Change Assist
U13C2 00 [00001001] - No Communication on 2nd Bus
[Timeout_Node_0x07_DiagAdress_CF_MRR_HL]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:18
131592 - Control Module for Lane Change Assist
U13C1 00 [00001001] - No Communication on 2nd Bus
[Timeout_Node_0x08_DiagAdress_3C_MRR_HR]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:18
131723 - Body Control Module (Central Electric 2)
U0141 00 [00001001] - No Communications
[Timeout_Node_0x8B_DiagAdress_46_BCM2]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:18
262669 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[BAP_Timeout_DoorLocking]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:16
Address 22: AWD (J492) Labels:| 0CJ-927-749.clb
Part No SW: 4K0 927 755 A HW: 0CJ 927 749 A
Component: C8_DL3_N_SD1 H01 0007
Serial number: 19144B1592
Coding: 110C0000
ASAM Dataset: EV_AWDCQUOD31 001052
ROD: EV_AWDCQUOD31.rod
VCID: 333319106BBB6B72439-8066
29727 - Implausible Data Received from ABS Control Module
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
Battery voltage: 12.121 V
Engine current: 0.0000 A
Internal system status: 00
Actuator angle: actual value: 0.359375
Processor load: 73 %
Stack store: 00 00 00
Operating time: 10 min
Ambient temperature: 21.5 C
End stage temperature: 24 C
HW KL15 Debounce Time: 30 ms
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 0
SW KL15 Timeout: 1
System condition: 00 00
XCP-DAQ OdtEntryCount: 0
UDS Session: Extended Diagnostic Session
Standard Seed and Key unlocked: 0
Advanced Seed and Key unlocked: 0
XCP Calibration activated: 0
XCP Measurement active: 0
DEV_X_06 enabled: 0
Reserved: FF FF FF FF FF FF
Unlearning counter according OBD-OBD unlearning counter: 40
Solenoid Current-SolenoidCurrent: 0.0000 A
Sensor Speed: 0 /min
NM-State: NM_STATE_NORMAL_OPERATION
Wakeup-Reason-Wakeup Reason: FLEXRAY_UP
Reset reason-ResetReason: FF 00 00 00
DTC Subcode (FR_ESP_21_SIGNAL_ERROR)-DTC SubCode: Signal not valid
29736 - Implausible Data Received from ABS Control Module
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 0
SW KL15 Timeout: 1
DEV_X_06 enabled: 0
DTC Subcode (FR_ESP_08_SIGNAL_ERROR)-DTC SubCode: Signal not valid
30032 - Terminal 15
U1405 00 [00100111] - Implausible signal
[Terminal 15Implausible signal]
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 0
SW KL15 Timeout: 1
DEV_X_06 enabled: 0
32070 - Implausible Data Received from ABS Control Module
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 0
SW KL15 Timeout: 1
DEV_X_06 enabled: 0
DTC Subcode (FR_ESP_22_SIGNAL_ERROR)-DTC SubCode: Signal not valid
33190 - Body Control Module (Central Electric 2)
Mileage: 48159 km
Date: 2026.03.14
Time: 01:01:52
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 0
SW KL15 Timeout: 1
DEV_X_06 enabled: 0
Timeout PDU ID (FR_BCM2_TIMEOUT)-Timeout PDU ID: PDU_VIN_01
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000383381105 Dataset Number: 4K8909856C 0016
Coding: 00781A400000B4010003010101010000000000000000000000000000004000
VCID: 79AFEB3809575122C95-802C
458764 - Databus
U1121 00 [00101001] - Missing Message
[Kessy_11_missing_message]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:02:22
458767 - Databus
[Klemmen_Status_01_missing_message]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:02:18
458818 - Databus
[ZV_02_missing_message]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:02:19
459027 - Databus
[Kessy_12_missing_message]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:02:19
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 H HW: 4N0 907 566 A
Component: MRR_HR H16 0267
Dataset Number: 4K8909535D 0023
Coding: 4FDC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_AU58.rod
VCID: 3B23313043EBA3329B9-806E
2232325 - Databus
[databus message missing - BCM - Klemmen_Status_01]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:02:35
Control Module temperature: 53 C
Voltage terminal 30: 12.00 V
Vehicle speed: Malfunction
Terminal 15 status: Measuring value not available
Voltage terminal 15: Measuring value not available
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: TSG FS002 0189
Serial number: YE007SEV02559 Dataset Number: 4K8909872B 0034
Coding: 001DDB0052010480A001B030
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 40D946DC2A0DC0EACEB-8014
Address 44: Steering Assist (J500) Labels:* 4N0-909-144-V1.clb
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Dataset Number: 4K0909852K 0002
Coding: B4002101010000
ROD: EV_EPSVWBSAU426_010.rod
3155969 - Databus
[COMI_TIMEOUT_KLEMMENSTATUS]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:07:05
FreezeFrame_mw_120C_Timeout-Engine speed: 0.00 /min
FreezeFrame_mw_120C_Timeout-System status: 0
FreezeFrame_mw_120C_Timeout-Terminal 30 power supply: 12.15 V
FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: OFF
FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: -4.79
FreezeFrame_mw_120C_Timeout-ARA_signal_red_cyclic: 00
FreezeFrame_mw_120C_Timeout-PLA_signal_red_cyclic: 00
FreezeFrame_mw_120C_Timeout-SCU state: System OK
FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
Address 46: Central Conv.
Part No SW: 4N0 035 223 C HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0170
Revision: 00000001 Serial number: AUZ8ZAK7D021BX0 Dataset Number: 4K0909510A 0009
Coding: 0185010000AAAA2FAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
ROD: EV_AMPMst16C1Gen2pALPI.rod
VCID: 2411EA4CDE55FCCACA3-8070
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: TSG BFS002 0189
Serial number: YE007SFC10675 Dataset Number: 4K8909873B 0034
Coding: 001DDB005E010480A001B030
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 3FDB452057F3BF12B71-806A
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 066 D HW: 4K0 035 066 A
Component: MU-H-LN-ER 054 2711
Dataset Number: 4K0909545F 0038
Coding: 0185010800000000C1511102C00800302F0001E603F00804CE
VCID: 270BFD40AF6317D2EF1-8072
Subsystem 1 - Part No: V03 959 808 AR
Component: MIB2P_RW_Q223 0673
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4K1 919 605 H HW: 4K1 919 605 F
Component: DU AU58x Top H71 0171
Serial number: BHB00130071903200068
Compact disc data bank:
Component: Gracenote2 4012
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004419000072745055
Multimedia display unit 5:
Subsystem 5 - Part No SW: 4K4 919 603 H HW: 4K4 919 603 F
Component: DU AU58x Bot H71 0171
Serial number: BHB00124071903130727
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051900428274008
6705 - Databus
[Terminal_status: no communication]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:03:44
Voltage terminal 30: 12.0 V
Network diagnosis-Status: Enabled
6714 - Databus
[VIN: no communication]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:03:44
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0563524818
Coding: 0300000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 3537270865CF75426DD-8060
340484 - Databus
[Central module comfort system - no signal/communication]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:12
Part No SW: 8W5 959 107 D HW: 8W5 959 107
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C744-8791-2 Dataset Number: 4K0909541D 0013
Coding: 0730
VCID: 47CB5DC00F23F7D20F1-8012
0100 - Data Set Implausible
B2012 00 [00001001] - -
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:27
0055 - Databus
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:27
Address 74: Chassis Control (J775) Labels:* 4N0-907-777.clb
Part No SW: 4K0 907 777 CB HW: 4K0 907 777 D
Component: Fahrwerk-SG H52 2135
Serial number: 1107190548 Dataset Number: 4K0909576M 0009
Coding: 105D58385842
ASAM Dataset: EV_ChassContrContiAU651 002016
ROD: EV_ChassContrContiAU651_002.rod
13 Faults Found:
3407876 - Databus
[Internal_communication_error_ESP_Systemstatus]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:41
Internal DTC: 84
4456458 - Implausible Data Received from ABS Control Module
U0415 00 [00001001] - -
[Function_restriction_due_to_communication_interruption_EspOverSteer]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:41
Internal DTC: 130
4456531 - Implausible Data Received from ABS Control Module
[Function_restriction_due_to_communication_interruption_EspUnderSteer]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:41
Internal DTC: 138
6553615 - Implausible Data Received from ABS Control Module
[Function_restriction_due_to_communication_interruption_trqBrkWFL_In]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:41
Internal DTC: 235
6553616 - Implausible Data Received from ABS Control Module
[Function_restriction_due_to_communication_interruption_trqBrkWFR_In]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:41
Internal DTC: 236
6553617 - Implausible Data Received from ABS Control Module
[Function_restriction_due_to_communication_interruption_trqBrkWRL_In]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:41
Internal DTC: 237
6553618 - Implausible Data Received from ABS Control Module
[Function_restriction_due_to_communication_interruption_trqBrkWRR_In]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:41
Internal DTC: 238
327793 - Control Module Incorrectly Coded
[Incorrectly_coded_mounting_coding_trailer]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:42
Internal DTC: 564
262158 - Databus
U1121 00 [10001001] - Missing Message
[Timeout_Error_Klemmen_Status_01]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:42
Internal DTC: 599
262173 - Databus
[Timeout_Error_ZV_02]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:42
Internal DTC: 612
262207 - Databus
[Timeout_Error_Kessy_11]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:42
Internal DTC: 644
262210 - Databus
[Timeout_Error_Personalisierung_01]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:42
Internal DTC: 656
196611 - Quantity of Fuel Added to Tank
C123D 29 [00001001] - Signal Implausible
[Function limitation through implausible Signal KBI_Inhalt_Tank]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:04:42
Internal DTC: 839
Address 75: Telematics (J949) Labels:* Redir Fail!
Part No SW: 4M1 035 283 B HW: 4M1 035 283 B
Component: ConBox H09 0232
Serial number: 005CCA18F110709 Dataset Number: 4K0909612D 0016
Coding: 01C020FF4040800000
ROD: EV_ConBoxAU651_002.rod
VCID: 290FFB78B97721A2F95-807C
197128 - Databus
[Clamp_State_Timeout]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:05:09
197142 - Databus
[VIN_timeout]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:05:09
197143 - Databus
[ZV_Timeout]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:05:09
1114627 - Antenna 2 for Emergency Call and Communications Module
B18BE 13 [00001001] - Open Circuit
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:05:12
Voltage terminal 30: 12.20 V
Mobile communications antenna 2 for emergency call module and communications unit-Connection to antenna: Open circuit
Mobile communications antenna 2 for emergency call module and communications unit-Reception level antenna: -113.00 %
Mobile communications antenna 2 for emergency call module and communications unit-Voltage: 1300 mV
Address 80: Batt. reg. aux. accum. (A1) Labels: 8W0-915-101.clb
Part No SW: 4K0 915 101 HW: 4K0 915 101
Component: MQ-BMS H20 0127
Serial number: 19000058906001
ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
VCID: 6099A65C8ACDA0EAEEB-8034
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K2 713 041 H HW: 4K2 713 041 H
Component: GSM-LL H14 0051
Serial number: 19.192 40071
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
9014 - Databus
[MESSAGE_KLEMMEN_01_TIMEOUT]
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:05:25
Selec. range display: spec. val.-Text: P
Selector lever position-Text: Basic setting X
Inside temperature: 23.50 C
System run time-Hours: 0 H
System run time-Minutes: 14 min
System run time-Seconds: 24 s
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 4K2 919 617 B HW: 4K2 919 617 B
Component: HeadupDisplay H05 4910
Coding: 4600E0
ASAM Dataset: EV_HeadUpDisplAU65X 001011
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 34311A0C6EB56C4A5A3-8060
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AM HW: 4N0 907 107 H
Component: zFAS Var C H09 0293
Dataset Number: 4K0909466N 0048
Coding: 03C182000000000000FBD60000F0460C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980800000000000000078D00080009000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 0A4DA4F45CB14ABAD0F-805E
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: TSG HFS004 0189
Serial number: YE007SGB08423 Dataset Number: 4K8909897B 0035
Coding: 000DD90000010480A000B020
VCID: 42DD4CD42401D2FAD8F-8016
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS004 0189
Serial number: YE007SGB00714 Dataset Number: 4K8909896B 0035
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: 4K0909469G 0017
Coding: 768040058101
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H16 0267
Dataset Number: 4K8909468D 0023
Coding: 4FDC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_AU58.rod
2232325 - Databus
Reset counter: 75
Mileage: 48159 km
Date: 2026.03.14
Time: 01:06:05
Control Module temperature: 52 C
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0031
Dataset Number: 4K0909471K 0019
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72BDDC145421227A88F-8026
Dynamic left front turn signal:
Subsystem 1 - Part No SW: 4K0 941 035 HW: 4K0 941 035
Component: M134DynTurnFL 003 0004
Serial number: 02051900026533001011
Dataset Number: 4K0909472K 0019
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Dynamic right front turn signal:
Subsystem 1 - Part No SW: 4K0 941 036 HW: 4K0 941 036
Component: M135DynTurnFR 003 0004
Serial number: 13031900024116001011
Address DB: Frt Corner Rdar 1 (J1089) Labels:| 4N0-907-669.clb
Part No SW: 4N0 907 669 H HW: 4N0 907 669 A
Component: MRR_VR H16 MRR_VR H16 02670267
Dataset Number: 4K8909482C 0020
Coding: 001000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: N/A
Address DC: Frt Corner Rdar 2 (J1088) Labels:| 4N0-907-669.clb
Component: MRR_VL H16 0267
Dataset Number: 4K8909483C 0021
Coding: 001000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4K0 035 502 B HW: 4K0 035 502 B
Component: WLC Front H14 0061
Coding: 400000
VCID: 2019E65CCA4DE0EAAEB-8074-R
End----------(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.1V)-----------
------------------------------68 Faults Found------------------------------
