Procedure for calibrating level sensors on a Bentley Continental GT 2007
Dexter001
C?ID=604514
Hi, I have fault code 01780 - sensor for vehicle levelling
003 - Mechanical failure intermittent
I had the offside front level sensor replaced by a mechanic on my Bentley Continental GT 2007 RHD and the fault came up on driving back from the workshop.
The level seems very high on that front corner, where it wasn’t before the replacement sadly.
I understand this could be due to incorrect fitting, bent rod on the sensor or a faulty new sensor.
How can I use VCDS to check each of the four level sensors for both initial height setting and their output when manually raising or lowering each corner of the car?
Any advice appreciated, thank you
Please post an Auto-Scan so we can see what kind of car you have, and how it is equipped & configured.
Dexter001
C?ID=604514
Here is a VCDS Scan where the level control is intermittently faulty - But, the levels are totally incorrect where they are all over 400 mm and the right front is over 405 mm instead of the 395 mm norm sadly.
Saturday,14,March,2026,12:55:59:56366
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20260227 DS365.0
VIN: SCBCE63W17C042948   License Plate: F16 BLY
Mileage: 87650km-54463mi   Repair Order:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBCE63W17C042948   Mileage: 87650km-54463miles
Address 01: Engine        Labels: 07C-906-018-BWR1.clb
   Part No SW: 07C 906 018 DD    HW: 07C 906 018 EC
   Component: BY-6.0L-TT      G  ª9409
   Revision: --H01---    Serial number: VWZ3Z0F3517212
   Coding: 0001175
   Shop #: WSC 09550 758 180955
   VCID: 6A8A1D8370622BBA30F-5160
   VINID: 8D34935460E70474C0102244208075FE7E
008583 - Bank 1; System too Lean at Idle
               P2187 - 001 -
                    Fault Status: 01100001
                    Mileage: 87645 km
                    RPM: 614 /min
                    Load: 18.8 %
                    Temperature: 80.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.716 V
Address 02: Auto Trans        Labels: 09E-927-156.clb
   Part No SW: 09E 927 760 AA    HW: GS1 911 4
   Component: AG6 09E 6.0L W12TT  2811
   Revision: 00000001    Serial number:        0091185
   Coding: 0000111
   Shop #: WSC 00083 000 00000
   VCID: 6FBC0C974B80CE92671-5160
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.clb
   Part No: 3W0 614 517 F
   Component: ESP 5.7 4WD     H01 0047
   Coding: 0007878
   Shop #: WSC 62741 000 00000
   VCID: 382EF7CB7E4E492A76B-5160
   Part No SW: 3D0 909 137 D    HW: 5WK 485 08
   Component: 40 Kessy            6840
   Revision: 68406418    Serial number: VWZ3Z0F3517212
   Coding: 0422125
   Shop #: WSC 00083 001 00001
   VCID: 280E278BAEEED9AAE6B-5160
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
00190 - Driver's Door Handle Touch Sensor (G415)
            007 - Short to Ground
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000001
   Shop #: WSC 00143 106 186473
   VCID: 47CC843703B036D20F1-5160
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 J
   Component:    ZAB COCKPIT      2089
   Coding: 0400325
   VCID: 3334C0E76728AA72439-5160
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 F
   Component: Climatronic BY614   2014
   Coding: 0000111
   VCID: 3436C3FB6226AD4A5A3-5160
00716 - Air recirculation Flap Positioning Motor (V113)
            014 - Defective
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000107
   VCID: 2F3CCC978B008E92271-5160
Address 11: Engine II        Labels: 07C-906-018-BWR2.clb
   Coding: 0001175
   Shop #: WSC 00000 000 08192
Address 15: Airbags        Labels: None
   Part No SW: 3W8 909 601     HW: 3W8 909 601
   Component: 15 Airbag 9.41  H13 0040
   Revision: 91H13004    Serial number: 0039L0003G09
   Coding: 0012597
   VCID: 7BA428C70FF8A232DB9-5160
   Subsystem 1 - Serial number: 63328RB4017106182
   Subsystem 2 - Serial number: 63428RB401787E93S
   Subsystem 3 - Serial number: 63528RB4017A2958M
   Subsystem 4 - Serial number: 63628RB401787E38T
   Subsystem 5 - Serial number: 63700RB4        I
   Subsystem 6 - Serial number: 63800RB4        J
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 D
   Coding: 0000012
   Shop #: WSC 62741 004 1048576
   VCID: 2E02D1938C0A879A2C7-5160
Address 17: Instruments        Labels: 3Wx-920-xxx-17.clb
   Part No: 3W8 920 840
   Component: KOMBIINSTRUMENT RB8 0610
   Coding: 0021403
   VCID: 79A832CF05C49022C95-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70BE0FEB56BED16A7EB-5160
Address 34: Level Control        Labels: 3Wx-907-553-34.clb
   Part No: 3W0 907 553 B
   Component: LUFTFDR.-CDC- 3C3V0 7205
   Coding: 0005561
   VCID: 3928F2CF45445022895-5160
01583 - Leak in System Detected
01780 - Sensor for Vehicle Leveling
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000001
   VCID: 3FDC9CD75B607E12B71-5160
01174 - Driver Seat Height Adjustment Motor (V138)
01903 - Seat Tilt Adjustment Motor (V231)
Address 37: Navigation        Labels: None
   Part No: 3W0 919 887 D
   Component:    NAVIGATION       2085
   Coding: 0400000
   VCID: 48CE870B0EAE39AA06B-5160
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 E
   Component: Dachmodul           0707
   Coding: 0002461
Address 46: Central Conv.        Labels: 3D0-959-933.clb
   Part No: 3D0 959 933 H
   Component: 0T HSG              0200
   Coding: 0000034
   Shop #: WSC 04950 001 00001
   VCID: 3530FEFF695CB4426DD-4B14
   Subsystem 1 - Part No: 3W8 959 701 C
   Component: Tuersteuergeraet FS 1002
   Subsystem 2 - Part No: 3W8 959 702 C
   Component: Tuersteuergeraet BF 1002
   Subsystem 3 - Part No: 3W8 959 703 B
   Component: Tuersteuergeraet HL 0401
   Subsystem 4 - Part No: 3W8 959 704 B
   Component: Tuersteuergeraet HR 0401
00485 - Drivers Outside Door Handle Central Locking Button (E369)
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
   Part No: 3W8 035 456
   Component: 12K-AUDIOVERST      3000
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 D    HW: 3W0 907 801 D
   Component: EPB  BC6HX24    HC6 X240
   Coding: 0022413
   VCID: 372CF4F7735046527F1-5160
Address 54: Rear Spoiler        Labels: 1C0-959-733.clb
   Part No: 1C0 959 733 H
   Component: Heckspoiler         0002
   VCID: 303ECFEB933E916A3EB-5204
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 E
   Component: Wische&
   Shop #: WSC 00000 725 65552
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
   VCID: 241633BBD2C63DCACA3-5160
Address 75: Telematics        Labels: None
   Part No: 3W0 907 722 E
   Component:       TRACKER VTTS  0043
   VCID: 3A2AEDC340425B3A80F-508A
Address 76: Park Assist        Labels: 3W0-919-283-V1.clb
   Part No: 3W0 919 283 A
   Component: 02 Einparkhilfe     0303
   VCID: 3B24E8C74F7862329B9-5160
Address 77: Telephone        Labels: None
   Part No SW: 3W0 035 385 R    HW: 3W0 035 385 R
   Component: rSAP ECU            0054
   Coding: 0000272
   VCID: 44D6933B32861DCAEA3-5160
End----(Elapsed Time: 07:31, VBatt start/end: 12.3V/12.4V. VIgn 0.0V)------
------------------------------12 Faults Found------------------------------
Saturday,14,March,2026,13:35:16:56366
Mileage: 54467   Repair Order:
                Address 34: Level Control  (3W0 907 553 B)
13:34:41 Group 004: Deviation from Nominal Vehicle Height
  8.0 mm  Left Front Height Deviation
  -8.0 mm  Right Front Height Deviation
  -4.0 mm  Left Rear Height Deviation
  6.0 mm  Right Rear Height Deviation
13:34:41 Group 005: Absolute Vehicle Height
  130.0  Left Front (G78) Absolute Height
  121.0  Right Front (G289) Absolute Height
  109.0  Left Rear (G76) Absolute Height
  116.0  Right Rear (G77) Absolute Height
13:34:41 Group 003: General
  14.32 bar  Reservoir/Tank Pressure (G291)
  Not Oper.  Damper Control Button
  Not Oper.  Level Control Button (E388)
  Relay OFF  Compressor Relay (J403) Status
Dexter001
C?ID=604514
Hi, Can someone please point me to the procedure for calibrating the level sensors on a Bentley Continental GT 2007?
I found a link on here to the procedure a couple of days ago, but now cannot find it again sadly.
Thank you in advance for any help with this.
Ziddywerks
Northern NJ USA
C?ID=208579
Protocol: KWP2000
Component: LUFTFDR.-CDC- 3C1V0 7014
Coding: 0015500
Shop #: WSC 00083
[Security Access - 16]
Enter 31564
[Do It!]
Coding
The suspension controller is controller 34. The normal coding for this controller in Europe is 0015500, and the normal coding for this controller in North America is 0017700. Each increment of one digit in the location where the 5’s and 7’s are is equal to a 5 mm increase in body ride height above the axles. If you change the coding of the suspension controller from xxx77xx to xxx55xx (the x representing digits you don’t pay attention to, and should not change), then you will eliminate the 10 mm upward adjustment.
So, using your diagnostic scan tool, change the coding of the controller, save your work, and close the controller. Now, because you have changed the coding, you must re-adapt the controller – otherwise, you will see a message in the Y24 display (the screen between the speedometer and the tachometer) telling you that you have suspension problems. In fact, this message will appear immediately as soon as you change the coding – don’t worry about it, it will go away once you have completed the adaptation.
Change the coding from xxx77xx to xxx55xx – no security code is needed or wanted for this step.
Don’t forget to save the work after you do this.
Adaptation
Put the car on a level surface. Make sure that the tire pressures are correctly set on all 4 tires. Get whatever you need out of the car, because you cannot open any doors or lids during the adaptation process (if you do open a door or lid, it aborts the adaptation). Roll the driver window down all the way. Plug the cable from the diagnostic scan tool into the OBD (on board diagnostic) connector, which is just inboard of the parking brake foot pedal. Run the cable out the open driver door window, and plug it into your diagnostic scan tool (now you know why it helps to have a bar stool to put the scan tool on).
Start the engine, and leave the car idling, in Park. Get out, and close all the doors.
Open the suspension controller (address 34), and enter the security code that is needed to give you access to the adaptation section of the controller. The security code is 31564 – this is the same for a Touareg or a Phaeton. Be aware that once you have entered the security code, you have initiated the adaptation procedure. You then have to fully complete the adaptation cycle – if you back out before the end (channel 5), your car will display a fault message, and the suspension system will be in ‘limp home’ mode.
Enter the Security Code
Once you have entered the security code, go to adaptation, and select channel 1. The Bentley will then move up and down a little bit, and eventually, ask you to enter a measurement. Measure the exact distance between the axle centerline and the bottom edge of the front left fender, and enter that value. Repeat this process for adaptation channels 2, 3, and 4, which correspond to the front right, rear left, and rear right wheels.
Go to channel 1, wait for the car to move up and down, then enter the observed measurement
Normally you have to wait about 1 minute until the car stops moving up and down, rarely longer than 2 minutes.
When the word WAIT disappears, and ENTER appears, enter your measurement.
VCDS software will occasionally 'hang' on adaptation channel 1. If the word 'wait' has not been replaced with 'enter' after 5 minutes, just dismiss the yellow guidance balloon (click on the X in the corner of the balloon), then enter your measurement, and click test, then click save.
How to make your measurements
Keep the ruler level, use a credit card to line up with the center of the axle. It helps to mark the desired measurements (401 mm and 407 mm) on the ruler with a felt pen.
Once you have entered the measurements for all 4 wheels in channels 1 to 4, you then have to go to channel 5, and enter a one (1) to save your work. Entering the 1 tells the controller that you want it to write the values to memory. If you don’t do this, you won’t successfully complete the adaptation.
After you have entered and saved the 1 to channel five, close the controller. Then get in the car, back it up about 15 feet, then drive it forward about 15 feet, so you are back in the original position again. Leave the engine running, and without hooking up the scan tool, take the 4 measurements again. You should find that the measurements are within 5 mm of the nominal distances – that is to say, 401 front and 407 rear if you have coded the controller with 5’s, and 411 front and 417 rear if you have coded the controller with 7’s.
If the measurements are outside of that range, or, if they are inside of that range but you want to make them more accurate, repeat the adaptation process again, starting with the entry of the security code. It’s not uncommon to need to complete two adaptation cycles to get things perfect. Once you are within 2 mm of nominal, stop, because that is about as close as you can reasonably expect to get.
Experience has taught us that it is kind of pointless to try to go through more than 3 adaptation cycles in one day. If you don’t get the results you want after 3 cycles, put the car in the garage and try again the next day.
Background Information
You can increase the Bentley ride height up to 20 mm above the nominal European settings – for example, if you had to drive the Dempster highway to the Arctic ocean, this might be worth considering, you would enter 9’s as coding values – but it seems that you cannot code the controller with a number that is lower than 5. You can try, but the controller won’t accept it. My guess is that you need to have a different security code (that we don’t know about) to enter values lower than the European norm.
Some people have managed to get the car to sit quite low on the axles by ‘fibbing’ to the controller during the adaptation process. In other words, they take the measurement, and if the measurement is, for example, 401 mm, they enter 406 mm. This tells the car that it is 5 mm higher than it thinks it is, and the car responds by sitting 5 mm lower when the adaptation cycle is finished. Personally, I don’t think this is a good idea. If you lower the car the ‘proper’ way – by coding – then do a truthful adaptation, the car knows exactly where it is at all times, so far as limits of suspension travel are concerned. If you fib to the car when you do the adaptation, then it will think it still has (for example) 30 mm of downward or upward shock absorber travel before it hits the physical limit of travel, when in actual fact it has only 25mm of downward travel, and 35 mm of upward travel. This will result in less than optimum suspension performance at all times.
